HA me propose bien des maj depuis un moment mais impossible de passer au dela de la 17.3. Cela s'installer, ca redemarre mais toujours en 17.3
J'ai essaye toutes les MAJ propsés depuis un moment mais aucune ne passe.
Aucun autre probleme consté a part cela.
Je tourne sur une VM sur un synology.
| version |
core-2026.8.1 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| container_arch |
amd64 |
| user |
root |
| virtualenv |
false |
| python_version |
3.14.6 |
| os_name |
Linux |
| os_version |
6.12.85-haos |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| logged_in |
true |
| subscription_expiration |
1 janvier 2018 à 01:00 |
| relayer_connected |
false |
| relayer_region |
null |
| remote_enabled |
false |
| remote_connected |
false |
| remote_server |
null |
| alexa_enabled |
true |
| google_enabled |
true |
| cloud_ice_servers_enabled |
true |
| certificate_status |
null |
| instance_id |
e684cab97e9144e6be3bbc60a30a8860 |
| iot_state |
disconnected |
| iot_tries |
0 |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
HACS
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
| HACS Data |
ok |
5000 |
| Installed Version |
2.0.5 |
| Stage |
running |
| Available Repositories |
3996 |
| Downloaded Repositories |
30 |
| host_os |
Home Assistant OS 17.3 |
| update_channel |
stable |
| supervisor_version |
supervisor-2026.07.5 |
| agent_version |
1.8.1 |
| docker_version |
29.3.1 |
| disk_total |
125.3 GB |
| disk_used |
62.7 GB |
| nameservers |
192.168.10.1 |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
kvm |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Terminal & SSH (10.3.0), Mosquitto broker (7.1.0), Silicon Labs Flasher (0.5.0), Zigbee2MQTT (2.13.0-1), Spotify Connect (0.18.0), Node-RED (22.0.1), Studio Code Server (6.0.1), File editor (6.1.0), Matter Server (9.1.1), openWakeWord (2.1.1), SomfyProtect2MQTT (2026.8.3), OpenThread Border Router (3.1.0), eWeLink Smart Home (1.2.1), Home Assistant MCP Server (8.1.1), uni-meter (1.5.0), AstraMeter (2.2.4) |
| dashboards |
18 |
| resources |
14 |
| views |
32 |
| mode |
storage |
Network Configuration
| adapters |
lo (disabled), enp0s3 (enabled, default, auto), docker0 (disabled), hassio (disabled), vethc4fb9db (disabled), vethfaddeef (disabled), veth7c9ab71 (disabled), vethe1e69c1 (disabled), veth9b4b3c9 (disabled), veth7018420 (disabled), veth1bbe443 (disabled), vethf99a92b (disabled), veth63ce67e (disabled), wpan0 (disabled) |
| ipv4_addresses |
lo (127.0.0.1/8), enp0s3 (192.168.10.200/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vethc4fb9db (), vethfaddeef (), veth7c9ab71 (), vethe1e69c1 (), veth9b4b3c9 (), veth7018420 (), veth1bbe443 (), vethf99a92b (), veth63ce67e (), wpan0 () |
| ipv6_addresses |
lo (::1/128), enp0s3 (fdac:104e:ef15:cf53:29b8:5b78:f14b:bf09/64, fe80::72a7:4bca:d9ec:91a3/64), docker0 (fe80::5ceb:e2ff:fec4:7cd6/64), hassio (fd0c:ac1e:2100::1/48, fe80::cc25:f7ff:fed6:3752/64), vethc4fb9db (fe80::a096:43ff:fe79:3210/64), vethfaddeef (fe80::a469:acff:fe31:dd50/64), veth7c9ab71 (fe80::2496:efff:fe81:4a0a/64), vethe1e69c1 (fe80::3c3b:eeff:febf:4d3/64), veth9b4b3c9 (fe80::c0a3:62ff:fe7b:717e/64), veth7018420 (fe80::4cd8:e3ff:fe38:790f/64), veth1bbe443 (fe80::5868:c6ff:fe66:83c0/64), vethf99a92b (fe80::3411:7dff:fe54:d636/64), veth63ce67e (fe80::f842:f0ff:fe33:2608/64), wpan0 (fd2a:281:7ac:a05a:0:ff:fe00:fc11/64, fdcd:bcc4:d17a:1:de8c:2aec:e08c:e243/64, fd2a:281:7ac:a05a:0:ff:fe00:fc38/64, fd2a:281:7ac:a05a:0:ff:fe00:fc10/64, fd2a:281:7ac:a05a:0:ff:fe00:fc00/64, fd2a:281:7ac:a05a:0:ff:fe00:9c00/64, fd2a:281:7ac:a05a:51a1:aa9a:ae36:76b3/64, fe80::9453:bc74:a2be:1b31/64) |
| announce_addresses |
192.168.10.200, fdac:104e:ef15:cf53:29b8:5b78:f14b:bf09, fe80::72a7:4bca:d9ec:91a3 |
| oldest_recorder_run |
16 juillet 2026 à 21:48 |
| current_recorder_run |
9 août 2026 à 18:56 |
| estimated_db_size |
4571.57 MiB |
| database_engine |
sqlite |
| database_version |
3.53.2 |
Tu as sans doute un message d'erreur dans les logs
Et peut être même bien une base un peu trop grosse
Et je ne sais pas quel Syno et avec combien de RAM, mais 65 Gb de disque occupé (même sur 128 au total) c'est énorme.
Je tournais avec 30 Gb sur 40, avec plein de trucs lancés.
C'est un xpenology basé sur un i5 avec 16 go de ram.
Ah, je ne pourrais pas t'aider, car je ne connais pas du tout xpe.
En fait ca se comporte exactement comme un syno. aucune difference la dessus.
