Home assistant Appdaemon / RasPi4 & I2C
Pouvez-vous m’aider : Je cherche à faire causer HA sur raspi 4 avec quelques composants i2c.
J’ai utilisé HAssOS i2c config.
J’ai bien les i2c-0, i2c-1, i2c-10 et i2c-22 in /dev.
Donc normalement OK pour cette étape.
Etape suivante : je crée un script AppDaemon pour ouvrir SMBus.
Sans oublier l’ajout du package dans la config AppDaemon :
system_packages:
  - py3-smbus
python_packages: []
init_commands: []
log_level: info
Voici le script simpliste :
import appdaemon.plugins.hass.hassapi as hass
import smbus
class I2CDEV:
    def __init__(self, i2c_bus=1, addr=0x40):
        self.bus = smbus.SMBus(i2c_bus);
        self.addr = addr
    def read(self,address):
        data = self.bus.read_i2c_block_data(self.addr, address, 2)
        return ((data[0] * 256 ) + data[1])
class i2cTest(hass.Hass):
    def initialize(self):
        self.i2cDev = I2CDEV(i2c_bus=1,addr=0x43)
        self.adapi = self.get_ad_api()
        self.adapi.run_in(self.lireMesure, 20)
    def lireMesure(self, kwargs):
        config = self.i2cDev.read(0)
        self.log("config:  0x{:02x}".format(config))
Et voici le résultat :
2024-03-20 14:48:09.903133 WARNING i2cTest: ------------------------------------------------------------
2024-03-20 14:48:09.903587 WARNING i2cTest: Unexpected error running initialize() for i2cTest
2024-03-20 14:48:09.903963 WARNING i2cTest: ------------------------------------------------------------
2024-03-20 14:48:09.908173 WARNING i2cTest: Traceback (most recent call last):
  File "/usr/lib/python3.11/site-packages/appdaemon/app_management.py", line 162, in initialize_app
    await utils.run_in_executor(self, init)
  File "/usr/lib/python3.11/site-packages/appdaemon/utils.py", line 304, in run_in_executor
    response = future.result()
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/config/apps/i2cTest.py", line 17, in initialize
  File "/config/apps/i2cTest.py", line 6, in __init__
PermissionError: [Errno 1] Operation not permitted
2024-03-20 14:48:09.908631 WARNING i2cTest: ------------------------------------------------------------
Pourquoi PermissionError ???
Manquerait-il un user dans un group ?
Par ailleurs j’ai fait l’essai d’un addon sur le même principe et cet addon fonctionne :
I2C test starting...
Create INA219 instance ...
 ... created
config:  0xeef
Donc ce n’est pas un problème SMBus mais d’autorisation d’accès de SMBus dans AppDaemon.
Pouvez-vous m’aider ?
   .YO.
version core-2024.3.1
python_version 3.12.2
os_version 6.1.73-haos-raspi
Installed Version 1.34.0
Available Repositories 1475
Downloaded Repositories 4
host_os Home Assistant OS 12.1
supervisor_version supervisor-2024.03.0
agent_version 1.6.0
docker_version 24.0.7
disk_total 28.5 GB
disk_used 5.8 GB
board rpi4-64
installed_addons Advanced SSH & Web Terminal (17.2.0), File editor (5.8.0), Samba share (12.3.1), Mosquitto broker (6.4.0), Zigbee2MQTT (1.36.0-1), AppDaemon (0.16.4), Samba Backup (5.2.0), I2C Test (1.0.7)
dashboards 2
resources 0
views 4
oldest_recorder_run 10 mars 2024 à 03:28
current_recorder_run 19 mars 2024 à 19:11
estimated_db_size 290.20 MiB
database_version 3.44.2
Regarde ça
A mon avis appdaemon ne fonctionne pas en mode privilège … donc pas d’accès au bus
Oui sans en connaitre la raison, j’en étais à la même conclusion.
Et je me suis donc dirigé vers un add-on plutot qu’un appdaemon.
Par contre smbus2 n’étant pas disponible dans les paquets Alpine, je me suis rabattu sur py3-smbus.
Et 2nd point : dès que je veux faire une boucle pour lire les capteurs de manière périodique, l’addon ne semble plus fonctionner. Ou alors en tous cas, il ne sort plus aucun log.
Aurais-tu une idée ?
     .YO.
Je me réponds à moi-même.
L’addon fonctionne bien. Les logs arrivent beaucoup plus lentement dans le journal…
Je continue donc avec l’addon.
Merci Pulpy-Luke
