J’ai installé mqtt et de ce côté là tout fonctionne parfaitement.
Par contre j’ai installé zigbee2mqtt et après installation il ne veut pas se lancer, j’ai toujours ce message:
Je possède une clé : SONOFF ZigBee 3.0 USB
configuration zigbee2mqtt:
et le log du journal:
[20:32:06] INFO: Preparing to start…
[20:32:09] INFO: Socat not enabled
[20:32:16] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2023-12-13 20:32:37: Logging to console and directory: ‹ /config/zigbee2mqtt/log/2023-12-13.20-32-37 › filename: log.txt
Zigbee2MQTT:info 2023-12-13 20:32:38: Starting Zigbee2MQTT version 1.34.0 (commit #unknown)
Zigbee2MQTT:info 2023-12-13 20:32:38: Starting zigbee-herdsman (0.25.0)
Error: Reset error: Error: {« sequence »:-1} after 10000ms
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
Merci de votre aide.
[center]## System Information
version
core-2023.12.1
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.11.6
os_name
Linux
os_version
6.1.58-haos-raspi
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
5000
Installed Version
1.33.0
Stage
running
Available Repositories
1356
Downloaded Repositories
8
HACS Data
ok
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 11.2
update_channel
stable
supervisor_version
supervisor-2023.11.6
agent_version
1.6.0
docker_version
24.0.7
disk_total
28.5 GB
disk_used
5.3 GB
healthy
true
supported
true
board
rpi3-64
supervisor_api
ok
version_api
ok
installed_addons
Terminal & SSH (9.8.1), Studio Code Server (5.14.2), Duck DNS (1.15.0), Linky (1.2.0), Samba share (12.2.0), File editor (5.7.0), Mosquitto broker (6.4.0), Zigbee2MQTT (1.34.0-1)
Bonsoir,
Merci pour cette réponse rapide:
Pour le complément d’information de la clé:
DEVLINKS: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_24ac71e54e45ed11868cc58f0a86e0b4-if00-port0
/dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0-port0
DEVNAME: /dev/ttyUSB0
DEVPATH: >-
/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/ttyUSB0/tty/ttyUSB0
Je ne m’attendrais pas à voir ça dans le message d’erreur. c’est d’ailleurs a cause de ça que j’avais posé la question sur le type de clé La config est bien enregistrée ?
Désolé je ne peux pas dire plus j’ai exactement la même clé que toi mais Zigbee2MQTT n’est pas installé en module complémentaire donc je n’ai pas le journal sur cette forme…
Il est sur une autre machine tout seul dans une position plus centrale de la maison.
Je sais que certains ont eu un souci de fichier de configuration qui ne prend pas correctement en compte les changements après la première config.
Est-ce possible de regarder avec file editor dans /config/zigbee2mqtt/ ce qu’il y a comme fichiers yaml?
Il devrait y avoir un configuration.yaml pour voir s’il n’y a pas la ligne avec ezsp qui traine dedans?
Bonsoir,
Est-ce vraiment indispensable de créer un user/pwd pour zigbee2mqtt ?
J’ai fait une installation sans, et pour le moment je ne vois pas ce qui pourrait poser problème.
PS : j’ai fait l’installation en mode Add-On de HAOS.
En revanche, si c’est mieux en termes de sécurité, je veux bien savoir comment ajouter ceci à une installation déjà existante
Merci d’avance
Il y a les 2 écoles, oui c’est mieux en terme de sécurité (donc école 1, oui fait le) mais qui ça intéresse ton mqtt en local ? (donc école 2, pas utile)
Mon avis perso, ajoute ça après si tu en vois le besoin, fait déjà fonctionner sans t’éparpiller.
Edit, arf lol, pas la même personne. Donc si tu en sens le besoin, oui.
J’ai regardé dans la configuration.yaml, il y avait bien la ligne avec ezsp, j’ai effacé cette ligne et redémarrer mais toujours rien.
Demain je vais désinstaller, flasher la clé et refaire une nouvelle installation.
Je vous tiendrai informé.
Désinstallation complète.
Et suppression des fichiers s’il en reste avant de réinstaller.
Flasher c’est comme tu veux, je ne l’ai jamais fait et jamais eu de soucis particuliers.
Après 10 jours de recherches install, désinstall…
j’ai installé home assistant sous proxmox sur un mini pc dans une vm de façon à pouvoir migrer facilement si le coeur m’en dit.
Donc dans la config de la vm il faut attibuer à la VM le port usb où est installée la clé. Vérifier dans paramètres, système, matériel le port de la clé.
2/ installer mosquito et le démarrer sans rien configurer.
3/ installer zigbee2mqtt, le démarrer sans rien configurer.
4/ aller dans le répertoire config/zigbee2mqtt ouvrir configuration.yaml , copier ce qui se rapporte au server:mosquitto-core:8183 ou noter.
5/retourner dans paramètres/modules/zigbee2mosquitoo/configuration coller dans server mosquitto-core…
on enregistre la config
6 on retourne dans paramètres/system/matériel pour copier le port de la clé.
7 comme 5/
on colle le port dans port, et en dessous on précise adapter:le type de codage de votre clé.
on démarre le module… et enfin ça fonctionne.
le point important c’est de démarrer mosquitto sans configurer et idem pour zigbee2mosquitto. et de récuper le paramétrage dans le fichier /config/zigbee2mosquitoo ensuite.
en cas de plantage désinstaller et EFFACER le répertoire zigbee2mosquitto. j’utilise( visual studio)
