Impossible de faire la MAJ 2025.8
je cherche depuis bientôt un moi pourquoi la MAJ ne passe pas, je crois comprendre que c’est un prb de compilation mais je ne suis pas assez bon pour trouver …
si quelqu’un a une solution je suis preneur
INFO ESPHome 2025.8.2
INFO Reading configuration /config/esphome/esp32-celier.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing esp32-celier (board: lolin_s2_mini; framework: arduino; platform: https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip)
INFO Package configuration completed successfully
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
  • framework-arduinoespressif32 @ 3.2.1
  • framework-arduinoespressif32-libs @ 5.4.0+sha.858a988d6e
  • tool-esptoolpy @ 5.0.2
  • tool-mklittlefs @ 3.2.0
  • toolchain-xtensa-esp-elf @ 14.2.0+20241119
    Dependency Graph
    |-- Networking @ 3.2.1
    |-- AsyncTCP @ 3.4.5
    |-- WiFi @ 3.2.1
    |-- FS @ 3.2.1
    |-- Update @ 3.2.1
    |-- ESPAsyncWebServer @ 3.7.10
    |-- ESP32 Async UDP @ 3.2.1
    |-- DNSServer @ 3.2.1
    |-- ESPmDNS @ 3.2.1
    |-- noise-c @ 0.1.10
    Compiling .pioenvs/esp32-celier/lib4c5/Network/NetworkClient.cpp.o
    Compiling .pioenvs/esp32-celier/lib4c5/Network/NetworkEvents.cpp.o
    In file included from /data/cache/platformio/packages/framework-arduinoespressif32/libraries/Network/src/NetworkClient.cpp:20:
    /data/cache/platformio/packages/framework-arduinoespressif32/libraries/Network/src/NetworkClient.h:22:10: fatal error: Arduino.h: No such file or directory
  • Looking for Arduino.h dependency? Check our library registry!
  • CLI > platformio lib search « header:Arduino.h »
  • Web > PlatformIO Registry
22 | #include « Arduino.h »
compilation terminated.
In file included from /data/cache/platformio/packages/framework-arduinoespressif32/libraries/Network/src/NetworkEvents.cpp:6:
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/Network/src/NetworkEvents.h:8:10: fatal error: sdkconfig.h: No such file or directory
  • Looking for sdkconfig.h dependency? Check our library registry!
  • CLI > platformio lib search « header:sdkconfig.h »
8 | #include "sdkconfig.h"
*** [.pioenvs/esp32-celier/lib4c5/Network/NetworkClient.cpp.o] Error 1
*** [.pioenvs/esp32-celier/lib4c5/Network/NetworkEvents.cpp.o] Error 1
========================== [FAILED] Took 1.01 seconds ==========================
merci d’avance Serge
Il faudrait le yaml de base déjà pour essayer si c’est propre à ton installation, ou si c’est ton fichier / les fonctions qu’il appelent qui pose problème.
esphome:
friendly_name: ESP32-CELIER
platformio_options:
board_build.extra_flags:
  - "-DARDUINO_USB_CDC_ON_BOOT=1"
esp32:
framework:
type: arduino
# Enable logging
logger:
uart:
tx_pin: 18
rx_pin: 33
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
  • uart_id: uart_2
text_sensor:
#- platform: ld2410
#version:
  #name: "firmware version" #Test si ça fonctionne
binary_sensor:
  • platform: ld2410
    has_target: #Présence
    has_moving_target: #Cible mobile
    has_still_target: #Cible immobile
  • platform: ld2410
    light: #intensité lumineuse
    moving_distance: #distance cible en mouvement
    still_distance: #distance cible immobile
    moving_energy: #quantité de mouvement
    still_energy: #quantité d’immobilité ??
    detection_distance: #distance de détection
#sensor:
  • platform: dht
    pin:
    number: GPIO01
    model: DHT22
    temperature:
    name: « Température Célier »
    filters:
    - offset: -1.0
    humidity:
    name: « Humidité Celier »
    filters:
    - offset: 9.0
    accuracy_decimals: 1
    update_interval: 120s
number:
  • platform: ld2410
    timeout: #Temps pour passer le binary sensor Présence à faux
    light_threshold: #Seuil de lumière
    name: light threshold
    max_move_distance_gate: #Distance de détection du mouvemenet 2-8
    name: max move distance gate
    max_still_distance_gate: #Distance de détection d’immobilité 2-8
    name: max still distance gate
button:
  • platform: ld2410
    restart:
    name: « restart »
switch:
  • platform: ld2410
    engineering_mode:
    name: « engineering mode »
# Enable Home Assistant API
api:
encryption:
key: "87uPEYeCwHPGkrNzfGv2fe2ybgL93W4MzbtQenv11lQ="
ota:
  • platform: esphome
    password: « c7d27bbfa68c447555b6c558b54ca3e3 »
wifi:
networks:
- ssid: !secret wifi_ssid_01
  password: !secret wifi_password_01
- ssid: !secret wifi_ssid_02
  password: !secret wifi_password_02
- ssid: !secret wifi_ssid_03
  password: !secret wifi_password_03
- ssid: !secret wifi_ssid_04
  password: !secret wifi_password_04
- ssid: !secret wifi_ssid_05
  password: !secret wifi_password_05
- ssid: !secret wifi_ssid_06
  password: !secret wifi_password_06
ap:
ssid: "Esp32-Celier"
password: "xxxxxxxx"
captive_portal:
Bonsoir,
Sur plusieurs ESP32 j’ai du passer récemment de
type: arduino
À
type: esp-idf
à tester.
Bob
Bonsoir,
Merci beaucoup Bob c’est ça
c’est le mieux.P areil, j’ai passé les quelques esp que j’avais sur arduino en esp-idf :wink:
Après la question, c’est pourquoi mettre à jour ses modules s’ils fonctionnent ?
Je ne met a jours mes ESP que si j’ai besoin de modifier leurs fonctions ou s’ils ne fonctionnement pas correctement.
Mettre a jour un module qui fonctionne parfaitement, c’est un peu chercher les ennuis.
Même si l’esp fonctionne bien, il y a des fix et optimisation. Ça vaut toujours le coup de mettre à jour sans y apporter une modification.
Je ne suis pas d’accord.
Si ça fonctionne déjà parfaitement, ces “fix et optimisations” ne t’apporteront rien. Et au contraire, ça risque d’apporter de nouveaux bugs sur des parties qui n’en avaient pas avant. Et on se retrouve entrainée dans la spirale des mises à jour / correction de bugs / introduction de nouveaux bugs… jusqu’à arriver, avec un peu de chance, a une version où tout fonctionne de nouveau satisfaisante, et en ayant perdu au passage beaucoup de temps.
Sur un truc qui fonctionne déjà bien, le rapport gain / temps passé n’est pas intéressant.
Mon expérience de la vie me fait dire “Plus tu touches, moins ça marche”
Donc quand la sécurité informatique n’est pas en jeux (et dans le cas d’un device ESPHome sur un réseau local c’est le cas..), ma politique c’est de ne mettre à jour que si ça apporte quelque chose, sinon je laisse ça tranquille.
Je met ESPHome à jour (et encore, pas toutes les installations en même temps, celle de HA en premier, les autres j’attends d’en avoir besoin) et quand je créer un nouveau périphérique je le fais avec la dernière version. Mais les modules déjà en place, sauf réel besoin de modification, j’y touche pas !
Après chacun fait ce qu’il veut chez lui bien entendu.
