Influxdb ne peux plus rdémarrer
c’est nouveau, Influxdb ne redémarre plus, tout d’abord j’avais un message qui doit se retrouver dans la log, maintenant il boucle sur arret et redamarrage etc…
que me conseillez vous ?
les dernières modifs consistaient à définir des compteurs de service avec 4 niveaux à chaque sensor, d, h, m, y et il y avait 4 sensors…
Serais ce ça le souci ?
[20:23:34] INFO: Starting the InfluxDB...
[20:23:40] INFO: InfluxDB stopped, restarting...
[20:23:41] INFO: Starting the InfluxDB...
[20:23:47] INFO: InfluxDB stopped, restarting...
[20:23:48] INFO: Starting the InfluxDB...
[20:23:55] INFO: InfluxDB stopped, restarting...
[20:23:56] INFO: Starting the InfluxDB...
ts=2024-12-09T20:23:57.915+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:24:03] INFO: InfluxDB stopped, restarting...
[20:24:04] INFO: Starting the InfluxDB...
[20:24:10] INFO: InfluxDB stopped, restarting...
[20:24:11] INFO: Starting the InfluxDB...
[20:24:18] INFO: InfluxDB stopped, restarting...
[20:24:19] INFO: Starting the InfluxDB...
[20:24:26] INFO: InfluxDB stopped, restarting...
[20:24:27] INFO: Starting the InfluxDB...
ts=2024-12-09T20:24:33.090+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:24:34] INFO: InfluxDB stopped, restarting...
[20:24:35] INFO: Starting the InfluxDB...
[20:24:41] INFO: InfluxDB stopped, restarting...
[20:24:42] INFO: Starting the InfluxDB...
[20:24:49] INFO: InfluxDB stopped, restarting...
[20:24:50] INFO: Starting the InfluxDB...
[20:24:57] INFO: InfluxDB stopped, restarting...
[20:24:58] INFO: Starting the InfluxDB...
[20:25:05] INFO: InfluxDB stopped, restarting...
[20:25:06] INFO: Starting the InfluxDB...
[20:25:12] INFO: InfluxDB stopped, restarting...
[20:25:13] INFO: Starting the InfluxDB...
ts=2024-12-09T20:25:16.051+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:25:20] INFO: InfluxDB stopped, restarting...
[20:25:21] INFO: Starting the InfluxDB...
[20:25:27] INFO: InfluxDB stopped, restarting...
[20:25:28] INFO: Starting the InfluxDB...
[20:25:36] INFO: InfluxDB stopped, restarting...
[20:25:37] INFO: Starting the InfluxDB...
[20:25:43] INFO: InfluxDB stopped, restarting...
[20:25:45] INFO: Starting the InfluxDB...
[20:25:51] INFO: InfluxDB stopped, restarting...
[20:25:52] INFO: Starting the InfluxDB...
[20:26:00] INFO: InfluxDB stopped, restarting...
[20:26:01] INFO: Starting the InfluxDB...
[20:26:08] INFO: InfluxDB stopped, restarting...
[20:26:09] INFO: Starting the InfluxDB...
[20:26:16] INFO: InfluxDB stopped, restarting...
[20:26:17] INFO: Starting the InfluxDB...
[20:26:23] INFO: InfluxDB stopped, restarting...
[20:26:24] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:30.570+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:30.577+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:30.990+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:31.594+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:32.346+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:32] INFO: InfluxDB stopped, restarting...
[20:26:33] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:34.311+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:37.255+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:40] INFO: InfluxDB stopped, restarting...
[20:26:41] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:42.886+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:46.495+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:48] INFO: InfluxDB stopped, restarting...
[20:26:49] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:52.982+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:55] INFO: InfluxDB stopped, restarting...
[20:26:56] INFO: Starting the InfluxDB...
[20:27:03] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:27:04.463+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:27:04] INFO: Starting the InfluxDB...
[20:27:11] INFO: InfluxDB stopped, restarting...
[20:27:12] INFO: Starting the InfluxDB...
ts=2024-12-09T20:27:14.447+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:27:19] INFO: InfluxDB stopped, restarting...
[20:27:20] INFO: Starting the InfluxDB...
[20:27:26] INFO: InfluxDB stopped, restarting...
[20:27:27] INFO: Starting the InfluxDB...
[20:27:33] INFO: InfluxDB stopped, restarting...
[20:27:35] INFO: Starting the InfluxDB...
[20:27:41] INFO: InfluxDB stopped, restarting...
[20:27:42] INFO: Starting the InfluxDB...
[20:27:49] INFO: InfluxDB stopped, restarting...
[20:27:50] INFO: Starting the InfluxDB...
ts=2024-12-09T20:27:50.418+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:27:57] INFO: InfluxDB stopped, restarting...
[20:27:58] INFO: Starting the InfluxDB...
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46846" url=/
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46846" response_time=6.981771ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46860" url=/index.c708214f.css
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46866" url=/index.4493d50d.js
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46866" response_time=12.342904ms status=200
[20:28:05] INFO: InfluxDB stopped, restarting...
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46860" response_time=51.062062ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46874" url=/worker.f6754a45.js
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46874" response_time=1.285679ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46884" response_time=1.714678ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46896" response_time="554.03µs" status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46898" response_time=1.547412ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Failed to retrieve database version" error="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused" url="http://localhost:8086"
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46900" response_time=2.591739ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46906" response_time="884.029µs" status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46908" url=/icomoon.779fca40.woff2
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46908" response_time=1.183094ms status=200
time="2024-12-09T20:28:05+01:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:46916" response_time="485.997µs" status=400
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46932" url=/laser-spinner.c83a0b4c.png
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46932" response_time=3.098727ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46934" response_time="455.926µs" status=200
time="2024-12-09T20:28:05+01:00" level=error msg="Error message Post \"http://localhost:8086/query?db=&epoch=ms&q=SELECT+count%28%22value%22%29+AS+%22count_value%22+FROM+%22chronograf%22.%22autogen%22.%22alerts%22+WHERE+time+%3E+now%28%29+-+30d+AND+time+%3C+now%28%29+GROUP+BY+time%281d%29+FILL%28null%29&rp=\": dial tcp [::1]:8086: connect: connection refused" component=server http_status =400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:46948" response_time="556.21µs" status=400
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46950" url=/Roboto-Regular.b5b51c7e.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46958" url=/Roboto-Bold.daa8e441.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46964" url=/Roboto-Black.dbac53af.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46964" response_time=24.032248ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46974" url=/Roboto-Medium.9eff68ae.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46958" response_time=57.079108ms status=200
time="2024-12-09T20:28:05+01:00" level=error msg="Error message Post \"http://localhost:8086/query?db=chronograf&epoch=ms&q=SELECT+host%2C+value%2C+level%2C+alertName+FROM+alerts+WHERE+time+%3E%3D+%272024-11-09T20%3A28%3A05%2B01%3A00%27+AND+time+%3C%3D+%272024-12-09T20%3A28%3A05%2B01%3A00%27+ORDER+BY+time+desc+LIMIT+30&rp=\": dial tcp [::1]:8086: connect: connection refused" component=server http_status =400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:46980" response_time=25.100219ms status=400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46974" response_time=25.197352ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46950" response_time=59.488723ms status=200
[20:28:06] INFO: Starting the InfluxDB...
[20:28:13] INFO: InfluxDB stopped, restarting...
[20:28:14] INFO: Starting the InfluxDB...
time="2024-12-09T20:28:15+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:37484" response_time=1.894173ms status=200
[20:28:21] INFO: InfluxDB stopped, restarting...
[20:28:22] INFO: Starting the InfluxDB...
time="2024-12-09T20:28:23+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:37512" response_time=2.729987ms status=200
time="2024-12-09T20:28:23+01:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2024-12-09T20:28:23+01:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:37500" response_time=6.220237ms status=400
time="2024-12-09T20:28:23+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:37528" response_time=25.035654ms status=200
time="2024-12-09T20:28:23+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:37542" response_time=1.364787ms status=204
time="2024-12-09T20:28:25+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52330" response_time="40.373µs" status=200
[20:28:28] INFO: InfluxDB stopped, restarting...
[20:28:29] INFO: Starting the InfluxDB...
ts=2024-12-09T20:28:30.155+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
time="2024-12-09T20:28:31+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52350" response_time=6.483171ms status=200
time="2024-12-09T20:28:31+01:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2024-12-09T20:28:31+01:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:52346" response_time=6.975259ms status=400
time="2024-12-09T20:28:31+01:00" level=error msg="Error message Post \"http://localhost:8086/query?db=chronograf&epoch=ms&q=SELECT+host%2C+value%2C+level%2C+alertName+FROM+alerts+WHERE+time+%3E%3D+%272024-12-08T20%3A28%3A31%2B01%3A00%27+AND+time+%3C%3D+%272024-12-09T20%3A28%3A31%2B01%3A00%27+ORDER+BY+time+desc+&rp=\": dial tcp [::1]:8086: connect: connection refused" component=server http_status =400
time="2024-12-09T20:28:31+01:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:52362" response_time=3.162623ms status=400
time="2024-12-09T20:28:35+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:41752" response_time="346.19µs" status=200
[20:28:36] INFO: InfluxDB stopped, restarting...
[20:28:38] INFO: Starting the InfluxDB...
[20:28:44] INFO: InfluxDB stopped, restarting...
[20:28:45] INFO: Starting the InfluxDB...
[20:28:51] INFO: InfluxDB stopped, restarting...
[20:28:52] INFO: Chronograf stopped, restarting...
[20:28:52] INFO: NGINX stopped, restarting...
s6-svwait: fatal: timed out
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
[20:28:55] INFO: Kapacitor stopped, restarting...
s6-rc: info: service base-addon-banner: starting
 Add-on: InfluxDB
 Scalable datastore for metrics, events, and real-time analytics
 Add-on version: 5.0.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 14.0  (amd64 / qemux86-64)
 Home Assistant Core: 2024.12.1
 Home Assistant Supervisor: 2024.11.4
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
[20:29:00] INFO: Configuring timezone (Europe/Paris)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
cont-init: info: running /etc/cont-init.d/create-users.sh
cont-init: info: /etc/cont-init.d/create-users.sh exited 0
cont-init: info: running /etc/cont-init.d/influxdb.sh
cont-init: info: /etc/cont-init.d/influxdb.sh exited 0
cont-init: info: running /etc/cont-init.d/kapacitor.sh
cont-init: info: /etc/cont-init.d/kapacitor.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun chronograf (no readiness notification)
services-up: info: copying legacy longrun influxdb (no readiness notification)
services-up: info: copying legacy longrun kapacitor (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[20:29:00] INFO: Kapacitor is waiting until InfluxDB is available...
[20:29:00] INFO: Chronograf is waiting until InfluxDB is available...
[20:29:00] INFO: Starting the InfluxDB...
[20:29:08] INFO: InfluxDB stopped, restarting...
[20:29:09] INFO: Starting the InfluxDB...
[20:29:16] INFO: InfluxDB stopped, restarting...
[20:29:17] INFO: Starting the InfluxDB...
[20:29:24] INFO: InfluxDB stopped, restarting...
[20:29:25] INFO: Starting the InfluxDB...
[20:29:32] INFO: InfluxDB stopped, restarting...
[20:29:33] INFO: Starting the InfluxDB...
[20:29:40] INFO: InfluxDB stopped, restarting...
[20:29:41] INFO: Starting the InfluxDB...
[20:29:50] INFO: InfluxDB stopped, restarting...
[20:29:51] INFO: Starting the InfluxDB...
[20:29:58] INFO: InfluxDB stopped, restarting...
[20:29:59] INFO: Starting the InfluxDB...
[20:30:06] INFO: InfluxDB stopped, restarting...
[20:30:07] INFO: Starting the InfluxDB...
[20:30:14] INFO: InfluxDB stopped, restarting...
[20:30:15] INFO: Starting the InfluxDB...
dois je restaurer la base seule ?
les capteurs étant déclarés dans la config ils devraient se recréer ?
ou dois je tout restaurer et refaire la création de ces capteurs ?
Bon, ben, pas de suggestions… Je vais donc restaurer
restauration influxdb faite, ça semble tenir… à suivre…
et ça recommence !
j’ai vraiment besoin de conseils car je ne comprends pas ce qu’il se passe, influxdb n’arrivait plus à redémarrer, je l’ai restauré hier soir, ça a remarché jusqu’à aujourd’hui 13h puis ça recommence.
Depuis hier le changement majeur est l’ajout de compteurs de service public, j’en ai encore ajouté 2 ce matin pendant que ça fonctionnait bien.
si besoin de plus d’infos je peux fournir évidemment.
déjà la log de influxdb ici
[19:20:14] INFO: InfluxDB stopped, restarting...
[19:20:15] INFO: Starting the InfluxDB...
[19:20:21] INFO: InfluxDB stopped, restarting...
[19:20:22] INFO: Starting the InfluxDB...
[19:20:29] INFO: InfluxDB stopped, restarting...
[19:20:30] INFO: Starting the InfluxDB...
[19:20:37] INFO: InfluxDB stopped, restarting...
[19:20:38] INFO: Starting the InfluxDB...
[19:20:44] INFO: InfluxDB stopped, restarting...
[19:20:45] INFO: Starting the InfluxDB...
[19:20:52] INFO: InfluxDB stopped, restarting...
[19:20:53] INFO: Starting the InfluxDB...
ts=2024-12-09T19:20:53.880+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:21:00] INFO: InfluxDB stopped, restarting...
[19:21:01] INFO: Starting the InfluxDB...
[19:21:07] INFO: InfluxDB stopped, restarting...
[19:21:08] INFO: Starting the InfluxDB...
[19:21:14] INFO: InfluxDB stopped, restarting...
[19:21:15] INFO: Starting the InfluxDB...
[19:21:22] INFO: InfluxDB stopped, restarting...
[19:21:23] INFO: Starting the InfluxDB...
[19:21:29] INFO: InfluxDB stopped, restarting...
[19:21:30] INFO: Starting the InfluxDB...
[19:21:37] INFO: InfluxDB stopped, restarting...
[19:21:38] INFO: Starting the InfluxDB...
[19:21:45] INFO: InfluxDB stopped, restarting...
[19:21:46] INFO: Starting the InfluxDB...
[19:21:52] INFO: InfluxDB stopped, restarting...
[19:21:53] INFO: Starting the InfluxDB...
ts=2024-12-09T19:21:58.906+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:22:00] INFO: InfluxDB stopped, restarting...
[19:22:01] INFO: Starting the InfluxDB...
[19:22:08] INFO: InfluxDB stopped, restarting...
[19:22:09] INFO: Starting the InfluxDB...
[19:22:15] INFO: InfluxDB stopped, restarting...
[19:22:16] INFO: Starting the InfluxDB...
[19:22:24] INFO: InfluxDB stopped, restarting...
[19:22:25] INFO: Starting the InfluxDB...
[19:22:32] INFO: InfluxDB stopped, restarting...
[19:22:33] INFO: Starting the InfluxDB...
[19:22:40] INFO: InfluxDB stopped, restarting...
[19:22:41] INFO: Starting the InfluxDB...
ts=2024-12-09T19:22:43.444+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:22:48] INFO: InfluxDB stopped, restarting...
[19:22:49] INFO: Starting the InfluxDB...
[19:22:56] INFO: InfluxDB stopped, restarting...
[19:22:57] INFO: Starting the InfluxDB...
[19:23:04] INFO: InfluxDB stopped, restarting...
[19:23:05] INFO: Starting the InfluxDB...
[19:23:12] INFO: InfluxDB stopped, restarting...
[19:23:13] INFO: Starting the InfluxDB...
[19:23:21] INFO: InfluxDB stopped, restarting...
[19:23:22] INFO: Starting the InfluxDB...
[19:23:29] INFO: InfluxDB stopped, restarting...
[19:23:30] INFO: Starting the InfluxDB...
ts=2024-12-09T19:23:35.002+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:23:37] INFO: InfluxDB stopped, restarting...
[19:23:38] INFO: Starting the InfluxDB...
[19:23:45] INFO: InfluxDB stopped, restarting...
[19:23:46] INFO: Starting the InfluxDB...
[19:23:53] INFO: InfluxDB stopped, restarting...
[19:23:54] INFO: Starting the InfluxDB...
[19:24:02] INFO: InfluxDB stopped, restarting...
[19:24:03] INFO: Starting the InfluxDB...
[19:24:10] INFO: InfluxDB stopped, restarting...
[19:24:11] INFO: Starting the InfluxDB...
ts=2024-12-09T19:24:11.331+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:24:11.334+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:24:12.028+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:24:12.883+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:24:14.479+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:24:15.507+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:24:17.088+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:24:20.229+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:24:32] INFO: InfluxDB stopped, restarting...
[19:24:33] INFO: Starting the InfluxDB...
[19:24:40] INFO: InfluxDB stopped, restarting...
[19:24:41] INFO: Starting the InfluxDB...
[19:24:51] INFO: InfluxDB stopped, restarting...
[19:24:52] INFO: Starting the InfluxDB...
[19:25:00] INFO: InfluxDB stopped, restarting...
[19:25:01] INFO: Starting the InfluxDB...
ts=2024-12-09T19:25:02.135+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:25:02.641+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:25:03.552+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:25:04.343+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:25:05.994+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:25:09.366+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:25:09] INFO: InfluxDB stopped, restarting...
[19:25:10] INFO: Starting the InfluxDB...
ts=2024-12-09T19:25:14.783+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:25:18] INFO: InfluxDB stopped, restarting...
[19:25:19] INFO: Starting the InfluxDB...
ts=2024-12-09T19:25:20.744+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:25:26] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:25:27.157+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:25:27] INFO: Starting the InfluxDB...
[19:25:34] INFO: InfluxDB stopped, restarting...
[19:25:35] INFO: Starting the InfluxDB...
ts=2024-12-09T19:25:39.750+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:25:43] INFO: InfluxDB stopped, restarting...
[19:25:45] INFO: Starting the InfluxDB...
[19:25:51] INFO: InfluxDB stopped, restarting...
[19:25:52] INFO: Starting the InfluxDB...
ts=2024-12-09T19:25:53.500+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:25:59] INFO: InfluxDB stopped, restarting...
[19:26:00] INFO: Starting the InfluxDB...
[19:26:07] INFO: InfluxDB stopped, restarting...
[19:26:08] INFO: Starting the InfluxDB...
ts=2024-12-09T19:26:08.600+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:26:15] INFO: InfluxDB stopped, restarting...
[19:26:16] INFO: Starting the InfluxDB...
[19:26:22] INFO: InfluxDB stopped, restarting...
[19:26:23] INFO: Starting the InfluxDB...
[19:26:32] INFO: InfluxDB stopped, restarting...
[19:26:33] INFO: Starting the InfluxDB...
ts=2024-12-09T19:26:35.880+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:26:40] INFO: InfluxDB stopped, restarting...
[19:26:42] INFO: Starting the InfluxDB...
[19:26:48] INFO: InfluxDB stopped, restarting...
[19:26:49] INFO: Starting the InfluxDB...
[19:26:56] INFO: InfluxDB stopped, restarting...
[19:26:57] INFO: Starting the InfluxDB...
[19:27:04] INFO: InfluxDB stopped, restarting...
[19:27:05] INFO: Starting the InfluxDB...
[19:27:13] INFO: InfluxDB stopped, restarting...
[19:27:14] INFO: Starting the InfluxDB...
[19:27:21] INFO: InfluxDB stopped, restarting...
[19:27:23] INFO: Starting the InfluxDB...
[19:27:29] INFO: InfluxDB stopped, restarting...
[19:27:30] INFO: Starting the InfluxDB...
[19:27:39] INFO: InfluxDB stopped, restarting...
[19:27:41] INFO: Starting the InfluxDB...
[19:27:47] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:27:47.642+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:27:48] INFO: Starting the InfluxDB...
[19:27:55] INFO: InfluxDB stopped, restarting...
[19:27:56] INFO: Starting the InfluxDB...
[19:28:02] INFO: InfluxDB stopped, restarting...
[19:28:04] INFO: Starting the InfluxDB...
[19:28:14] INFO: InfluxDB stopped, restarting...
[19:28:15] INFO: Starting the InfluxDB...
[19:28:22] INFO: InfluxDB stopped, restarting...
[19:28:23] INFO: Starting the InfluxDB...
[19:28:30] INFO: InfluxDB stopped, restarting...
[19:28:31] INFO: Starting the InfluxDB...
[19:28:37] INFO: InfluxDB stopped, restarting...
[19:28:38] INFO: Starting the InfluxDB...
[19:28:46] INFO: InfluxDB stopped, restarting...
[19:28:47] INFO: Starting the InfluxDB...
ts=2024-12-09T19:28:50.365+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:28:54] INFO: InfluxDB stopped, restarting...
[19:28:55] INFO: Starting the InfluxDB...
[19:29:02] INFO: InfluxDB stopped, restarting...
[19:29:03] INFO: Starting the InfluxDB...
[19:29:11] INFO: InfluxDB stopped, restarting...
[19:29:12] INFO: Starting the InfluxDB...
[19:29:19] INFO: InfluxDB stopped, restarting...
[19:29:20] INFO: Starting the InfluxDB...
ts=2024-12-09T19:29:21.181+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:29:30] INFO: InfluxDB stopped, restarting...
[19:29:31] INFO: Starting the InfluxDB...
[19:29:37] INFO: InfluxDB stopped, restarting...
[19:29:38] INFO: Starting the InfluxDB...
[19:29:45] INFO: InfluxDB stopped, restarting...
[19:29:46] INFO: Starting the InfluxDB...
[19:29:53] INFO: InfluxDB stopped, restarting...
[19:29:54] INFO: Starting the InfluxDB...
[19:30:01] INFO: InfluxDB stopped, restarting...
[19:30:02] INFO: Starting the InfluxDB...
[19:30:09] INFO: InfluxDB stopped, restarting...
[19:30:10] INFO: Starting the InfluxDB...
[19:30:16] INFO: InfluxDB stopped, restarting...
[19:30:17] INFO: Starting the InfluxDB...
ts=2024-12-09T19:30:22.920+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:30:22.929+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:30:23.305+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:30:23.706+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:30:24] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:30:25.110+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:30:25] INFO: Starting the InfluxDB...
ts=2024-12-09T19:30:27.293+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:30:30.997+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:30:32] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:30:33.298+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:30:33] INFO: Starting the InfluxDB...
ts=2024-12-09T19:30:38.926+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:30:41] INFO: InfluxDB stopped, restarting...
[19:30:42] INFO: Starting the InfluxDB...
ts=2024-12-09T19:30:48.823+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:30:49] INFO: InfluxDB stopped, restarting...
[19:30:50] INFO: Starting the InfluxDB...
[19:30:56] INFO: InfluxDB stopped, restarting...
[19:30:57] INFO: Starting the InfluxDB...
ts=2024-12-09T19:30:58.069+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:31:04] INFO: InfluxDB stopped, restarting...
[19:31:05] INFO: Starting the InfluxDB...
[19:31:11] INFO: InfluxDB stopped, restarting...
[19:31:12] INFO: Starting the InfluxDB...
[19:31:19] INFO: InfluxDB stopped, restarting...
[19:31:20] INFO: Starting the InfluxDB...
ts=2024-12-09T19:31:24.531+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:31:27] INFO: InfluxDB stopped, restarting...
[19:31:28] INFO: Starting the InfluxDB...
[19:31:34] INFO: InfluxDB stopped, restarting...
[19:31:35] INFO: Starting the InfluxDB...
[19:31:42] INFO: InfluxDB stopped, restarting...
[19:31:43] INFO: Starting the InfluxDB...
[19:31:50] INFO: InfluxDB stopped, restarting...
[19:31:51] INFO: Starting the InfluxDB...
[19:32:00] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:32:01.487+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:32:01] INFO: Starting the InfluxDB...
[19:32:08] INFO: InfluxDB stopped, restarting...
[19:32:09] INFO: Starting the InfluxDB...
[19:32:15] INFO: InfluxDB stopped, restarting...
[19:32:16] INFO: Starting the InfluxDB...
[19:32:23] INFO: InfluxDB stopped, restarting...
[19:32:24] INFO: Starting the InfluxDB...
[19:32:31] INFO: InfluxDB stopped, restarting...
[19:32:32] INFO: Starting the InfluxDB...
[19:32:39] INFO: InfluxDB stopped, restarting...
[19:32:40] INFO: Starting the InfluxDB...
[19:32:46] INFO: InfluxDB stopped, restarting...
[19:32:48] INFO: Starting the InfluxDB...
[19:32:54] INFO: InfluxDB stopped, restarting...
[19:32:55] INFO: Starting the InfluxDB...
ts=2024-12-09T19:32:56.985+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:33:02] INFO: InfluxDB stopped, restarting...
[19:33:03] INFO: Starting the InfluxDB...
[19:33:10] INFO: InfluxDB stopped, restarting...
[19:33:11] INFO: Starting the InfluxDB...
[19:33:18] INFO: InfluxDB stopped, restarting...
[19:33:19] INFO: Starting the InfluxDB...
[19:33:25] INFO: InfluxDB stopped, restarting...
[19:33:27] INFO: Starting the InfluxDB...
[19:33:33] INFO: InfluxDB stopped, restarting...
[19:33:34] INFO: Starting the InfluxDB...
[19:33:41] INFO: InfluxDB stopped, restarting...
[19:33:42] INFO: Starting the InfluxDB...
[19:33:49] INFO: InfluxDB stopped, restarting...
[19:33:51] INFO: Starting the InfluxDB...
[19:33:57] INFO: InfluxDB stopped, restarting...
[19:33:59] INFO: Starting the InfluxDB...
ts=2024-12-09T19:34:00.407+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:34:05] INFO: InfluxDB stopped, restarting...
[19:34:06] INFO: Starting the InfluxDB...
[19:34:13] INFO: InfluxDB stopped, restarting...
[19:34:15] INFO: Starting the InfluxDB...
[19:34:21] INFO: InfluxDB stopped, restarting...
[19:34:22] INFO: Starting the InfluxDB...
[19:34:30] INFO: InfluxDB stopped, restarting...
[19:34:31] INFO: Starting the InfluxDB...
ts=2024-12-09T19:34:33.833+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:34:38] INFO: InfluxDB stopped, restarting...
[19:34:39] INFO: Starting the InfluxDB...
[19:34:47] INFO: InfluxDB stopped, restarting...
[19:34:48] INFO: Starting the InfluxDB...
[19:34:55] INFO: InfluxDB stopped, restarting...
[19:34:56] INFO: Starting the InfluxDB...
[19:35:03] INFO: InfluxDB stopped, restarting...
[19:35:04] INFO: Starting the InfluxDB...
[19:35:12] INFO: InfluxDB stopped, restarting...
[19:35:13] INFO: Starting the InfluxDB...
[19:35:20] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:35:21.262+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:35:21] INFO: Starting the InfluxDB...
[19:35:28] INFO: InfluxDB stopped, restarting...
[19:35:29] INFO: Starting the InfluxDB...
[19:35:36] INFO: InfluxDB stopped, restarting...
[19:35:37] INFO: Starting the InfluxDB...
[19:35:43] INFO: InfluxDB stopped, restarting...
[19:35:44] INFO: Starting the InfluxDB...
[19:35:51] INFO: InfluxDB stopped, restarting...
[19:35:52] INFO: Starting the InfluxDB...
ts=2024-12-09T19:35:57.343+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:35:57.346+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:35:57.819+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:35:58.840+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:35:59] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:36:00.287+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:36:00] INFO: Starting the InfluxDB...
ts=2024-12-09T19:36:01.997+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:36:04.214+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:36:06.980+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:36:08] INFO: InfluxDB stopped, restarting...
[19:36:09] INFO: Starting the InfluxDB...
ts=2024-12-09T19:36:11.767+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:36:16] INFO: InfluxDB stopped, restarting...
[19:36:17] INFO: Starting the InfluxDB...
ts=2024-12-09T19:36:22.156+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:36:25] INFO: InfluxDB stopped, restarting...
[19:36:26] INFO: Starting the InfluxDB...
[19:36:32] INFO: InfluxDB stopped, restarting...
[19:36:34] INFO: Starting the InfluxDB...
ts=2024-12-09T19:36:38.110+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:36:41] INFO: InfluxDB stopped, restarting...
[19:36:42] INFO: Starting the InfluxDB...
[19:36:49] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:36:49.964+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:36:50] INFO: Starting the InfluxDB...
[19:36:57] INFO: InfluxDB stopped, restarting...
[19:36:58] INFO: Starting the InfluxDB...
[19:37:05] INFO: InfluxDB stopped, restarting...
[19:37:06] INFO: Starting the InfluxDB...
[19:37:13] INFO: InfluxDB stopped, restarting...
[19:37:14] INFO: Starting the InfluxDB...
[19:37:22] INFO: InfluxDB stopped, restarting...
[19:37:23] INFO: Starting the InfluxDB...
[19:37:29] INFO: InfluxDB stopped, restarting...
[19:37:30] INFO: Starting the InfluxDB...
ts=2024-12-09T19:37:31.221+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:37:38] INFO: InfluxDB stopped, restarting...
[19:37:39] INFO: Starting the InfluxDB...
[19:37:46] INFO: InfluxDB stopped, restarting...
[19:37:47] INFO: Starting the InfluxDB...
[19:37:54] INFO: InfluxDB stopped, restarting...
[19:37:55] INFO: Starting the InfluxDB...
[19:38:05] INFO: InfluxDB stopped, restarting...
[19:38:06] INFO: Starting the InfluxDB...
[19:38:13] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:38:13.877+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:38:14] INFO: Starting the InfluxDB...
[19:38:21] INFO: InfluxDB stopped, restarting...
[19:38:22] INFO: Starting the InfluxDB...
[19:38:29] INFO: InfluxDB stopped, restarting...
[19:38:30] INFO: Starting the InfluxDB...
[19:38:37] INFO: InfluxDB stopped, restarting...
[19:38:38] INFO: Starting the InfluxDB...
[19:38:45] INFO: InfluxDB stopped, restarting...
[19:38:46] INFO: Starting the InfluxDB...
[19:38:53] INFO: InfluxDB stopped, restarting...
[19:38:54] INFO: Starting the InfluxDB...
[19:39:01] INFO: InfluxDB stopped, restarting...
[19:39:02] INFO: Starting the InfluxDB...
[19:39:09] INFO: InfluxDB stopped, restarting...
[19:39:11] INFO: Starting the InfluxDB...
[19:39:17] INFO: InfluxDB stopped, restarting...
[19:39:18] INFO: Starting the InfluxDB...
[19:39:25] INFO: InfluxDB stopped, restarting...
[19:39:26] INFO: Starting the InfluxDB...
ts=2024-12-09T19:39:29.905+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:39:33] INFO: InfluxDB stopped, restarting...
[19:39:34] INFO: Starting the InfluxDB...
[19:39:42] INFO: InfluxDB stopped, restarting...
[19:39:43] INFO: Starting the InfluxDB...
[19:39:50] INFO: InfluxDB stopped, restarting...
[19:39:51] INFO: Starting the InfluxDB...
[19:39:57] INFO: InfluxDB stopped, restarting...
[19:39:58] INFO: Starting the InfluxDB...
[19:40:05] INFO: InfluxDB stopped, restarting...
[19:40:06] INFO: Starting the InfluxDB...
[19:40:15] INFO: InfluxDB stopped, restarting...
[19:40:16] INFO: Starting the InfluxDB...
[19:40:24] INFO: InfluxDB stopped, restarting...
[19:40:25] INFO: Starting the InfluxDB...
[19:40:33] INFO: InfluxDB stopped, restarting...
[19:40:34] INFO: Starting the InfluxDB...
ts=2024-12-09T19:40:40.934+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:40:41] INFO: InfluxDB stopped, restarting...
[19:40:42] INFO: Starting the InfluxDB...
[19:40:48] INFO: InfluxDB stopped, restarting...
[19:40:49] INFO: Starting the InfluxDB...
[19:40:56] INFO: InfluxDB stopped, restarting...
[19:40:57] INFO: Starting the InfluxDB...
[19:41:03] INFO: InfluxDB stopped, restarting...
[19:41:04] INFO: Starting the InfluxDB...
[19:41:14] INFO: InfluxDB stopped, restarting...
[19:41:15] INFO: Starting the InfluxDB...
[19:41:22] INFO: InfluxDB stopped, restarting...
[19:41:23] INFO: Starting the InfluxDB...
[19:41:29] INFO: InfluxDB stopped, restarting...
[19:41:30] INFO: Starting the InfluxDB...
[19:41:37] INFO: InfluxDB stopped, restarting...
[19:41:38] INFO: Starting the InfluxDB...
ts=2024-12-09T19:41:46.300+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:41:46.302+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:41:46.776+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:41:47] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:41:47.817+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:41:48] INFO: Starting the InfluxDB...
ts=2024-12-09T19:41:48.990+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:41:51.166+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:41:53.538+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:41:54] INFO: InfluxDB stopped, restarting...
[19:41:55] INFO: Starting the InfluxDB...
ts=2024-12-09T19:41:58.551+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:42:02] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:42:03.554+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:42:03] INFO: Starting the InfluxDB...
[19:42:10] INFO: InfluxDB stopped, restarting...
[19:42:11] INFO: Starting the InfluxDB...
ts=2024-12-09T19:42:14.446+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:42:19] INFO: InfluxDB stopped, restarting...
[19:42:20] INFO: Starting the InfluxDB...
ts=2024-12-09T19:42:20.894+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:42:27] INFO: InfluxDB stopped, restarting...
[19:42:28] INFO: Starting the InfluxDB...
[19:42:36] INFO: InfluxDB stopped, restarting...
[19:42:37] INFO: Starting the InfluxDB...
ts=2024-12-09T19:42:40.807+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:42:45] INFO: InfluxDB stopped, restarting...
[19:42:46] INFO: Starting the InfluxDB...
[19:42:52] INFO: InfluxDB stopped, restarting...
[19:42:53] INFO: Starting the InfluxDB...
[19:43:00] INFO: InfluxDB stopped, restarting...
[19:43:01] INFO: Starting the InfluxDB...
[19:43:08] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:43:08.948+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:43:09] INFO: Starting the InfluxDB...
[19:43:16] INFO: InfluxDB stopped, restarting...
[19:43:17] INFO: Starting the InfluxDB...
[19:43:24] INFO: InfluxDB stopped, restarting...
[19:43:25] INFO: Starting the InfluxDB...
[19:43:32] INFO: InfluxDB stopped, restarting...
[19:43:33] INFO: Starting the InfluxDB...
[19:43:40] INFO: InfluxDB stopped, restarting...
[19:43:41] INFO: Starting the InfluxDB...
[19:43:48] INFO: InfluxDB stopped, restarting...
[19:43:49] INFO: Starting the InfluxDB...
ts=2024-12-09T19:43:49.893+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:43:56] INFO: InfluxDB stopped, restarting...
[19:43:57] INFO: Starting the InfluxDB...
[19:44:04] INFO: InfluxDB stopped, restarting...
[19:44:05] INFO: Starting the InfluxDB...
[19:44:12] INFO: InfluxDB stopped, restarting...
[19:44:13] INFO: Starting the InfluxDB...
[19:44:19] INFO: InfluxDB stopped, restarting...
[19:44:20] INFO: Starting the InfluxDB...
[19:44:27] INFO: InfluxDB stopped, restarting...
[19:44:28] INFO: Starting the InfluxDB...
[19:44:35] INFO: InfluxDB stopped, restarting...
[19:44:36] INFO: Starting the InfluxDB...
[19:44:43] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:44:44.166+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:44:44] INFO: Starting the InfluxDB...
[19:44:50] INFO: InfluxDB stopped, restarting...
[19:44:51] INFO: Starting the InfluxDB...
[19:44:58] INFO: InfluxDB stopped, restarting...
[19:44:59] INFO: Starting the InfluxDB...
[19:45:07] INFO: InfluxDB stopped, restarting...
[19:45:09] INFO: Starting the InfluxDB...
[19:45:15] INFO: InfluxDB stopped, restarting...
[19:45:17] INFO: Starting the InfluxDB...
ts=2024-12-09T19:45:17.143+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:45:24] INFO: InfluxDB stopped, restarting...
[19:45:25] INFO: Starting the InfluxDB...
[19:45:33] INFO: InfluxDB stopped, restarting...
[19:45:34] INFO: Starting the InfluxDB...
[19:45:40] INFO: InfluxDB stopped, restarting...
[19:45:41] INFO: Starting the InfluxDB...
[19:45:48] INFO: InfluxDB stopped, restarting...
[19:45:49] INFO: Starting the InfluxDB...
[19:45:56] INFO: InfluxDB stopped, restarting...
[19:45:57] INFO: Starting the InfluxDB...
[19:46:04] INFO: InfluxDB stopped, restarting...
[19:46:05] INFO: Starting the InfluxDB...
[19:46:12] INFO: InfluxDB stopped, restarting...
[19:46:13] INFO: Starting the InfluxDB...
[19:46:20] INFO: InfluxDB stopped, restarting...
[19:46:21] INFO: Starting the InfluxDB...
[19:46:27] INFO: InfluxDB stopped, restarting...
[19:46:28] INFO: Starting the InfluxDB...
[19:46:35] INFO: InfluxDB stopped, restarting...
[19:46:36] INFO: Starting the InfluxDB...
ts=2024-12-09T19:46:41.789+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:46:43] INFO: InfluxDB stopped, restarting...
[19:46:44] INFO: Starting the InfluxDB...
[19:46:52] INFO: InfluxDB stopped, restarting...
[19:46:53] INFO: Starting the InfluxDB...
[19:46:59] INFO: InfluxDB stopped, restarting...
[19:47:00] INFO: Starting the InfluxDB...
[19:47:07] INFO: InfluxDB stopped, restarting...
[19:47:08] INFO: Starting the InfluxDB...
[19:47:15] INFO: InfluxDB stopped, restarting...
[19:47:16] INFO: Starting the InfluxDB...
[19:47:23] INFO: InfluxDB stopped, restarting...
[19:47:24] INFO: Starting the InfluxDB...
[19:47:32] INFO: InfluxDB stopped, restarting...
[19:47:33] INFO: Starting the InfluxDB...
ts=2024-12-09T19:47:36.999+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:47:37.003+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:47:37.578+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:47:38.567+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:47:39.226+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:47:40] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:47:40.638+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:47:41] INFO: Starting the InfluxDB...
ts=2024-12-09T19:47:43.965+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:47:47.688+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:47:48] INFO: InfluxDB stopped, restarting...
[19:47:49] INFO: Starting the InfluxDB...
ts=2024-12-09T19:47:53.106+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:47:57] INFO: InfluxDB stopped, restarting...
[19:47:58] INFO: Starting the InfluxDB...
ts=2024-12-09T19:47:58.778+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:48:04] INFO: InfluxDB stopped, restarting...
[19:48:05] INFO: Starting the InfluxDB...
[19:48:13] INFO: InfluxDB stopped, restarting...
[19:48:14] INFO: Starting the InfluxDB...
ts=2024-12-09T19:48:15.386+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:48:21] INFO: InfluxDB stopped, restarting...
[19:48:22] INFO: Starting the InfluxDB...
[19:48:28] INFO: InfluxDB stopped, restarting...
[19:48:29] INFO: Starting the InfluxDB...
ts=2024-12-09T19:48:34.646+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:48:36] INFO: InfluxDB stopped, restarting...
[19:48:37] INFO: Starting the InfluxDB...
[19:48:44] INFO: InfluxDB stopped, restarting...
[19:48:46] INFO: Starting the InfluxDB...
[19:48:53] INFO: InfluxDB stopped, restarting...
[19:48:54] INFO: Starting the InfluxDB...
[19:49:00] INFO: InfluxDB stopped, restarting...
[19:49:01] INFO: Starting the InfluxDB...
[19:49:08] INFO: InfluxDB stopped, restarting...
[19:49:09] INFO: Starting the InfluxDB...
ts=2024-12-09T19:49:15.343+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:49:17] INFO: InfluxDB stopped, restarting...
[19:49:18] INFO: Starting the InfluxDB...
[19:49:25] INFO: InfluxDB stopped, restarting...
[19:49:26] INFO: Starting the InfluxDB...
[19:49:34] INFO: InfluxDB stopped, restarting...
[19:49:36] INFO: Starting the InfluxDB...
[19:49:42] INFO: InfluxDB stopped, restarting...
[19:49:43] INFO: Starting the InfluxDB...
ts=2024-12-09T19:49:44.359+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:49:50] INFO: InfluxDB stopped, restarting...
[19:49:51] INFO: Starting the InfluxDB...
[19:49:59] INFO: InfluxDB stopped, restarting...
[19:50:00] INFO: Starting the InfluxDB...
[19:50:06] INFO: InfluxDB stopped, restarting...
[19:50:07] INFO: Starting the InfluxDB...
ts=2024-12-09T19:50:14.662+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:50:15] INFO: InfluxDB stopped, restarting...
[19:50:16] INFO: Starting the InfluxDB...
[19:50:23] INFO: InfluxDB stopped, restarting...
[19:50:24] INFO: Starting the InfluxDB...
[19:50:31] INFO: InfluxDB stopped, restarting...
[19:50:32] INFO: Starting the InfluxDB...
[19:50:38] INFO: InfluxDB stopped, restarting...
[19:50:39] INFO: Starting the InfluxDB...
[19:50:47] INFO: InfluxDB stopped, restarting...
[19:50:48] INFO: Starting the InfluxDB...
[19:50:55] INFO: InfluxDB stopped, restarting...
[19:50:56] INFO: Starting the InfluxDB...
[19:51:03] INFO: InfluxDB stopped, restarting...
[19:51:04] INFO: Starting the InfluxDB...
[19:51:11] INFO: InfluxDB stopped, restarting...
[19:51:12] INFO: Starting the InfluxDB...
[19:51:19] INFO: InfluxDB stopped, restarting...
[19:51:20] INFO: Starting the InfluxDB...
[19:51:27] INFO: InfluxDB stopped, restarting...
[19:51:28] INFO: Starting the InfluxDB...
[19:51:35] INFO: InfluxDB stopped, restarting...
[19:51:36] INFO: Starting the InfluxDB...
ts=2024-12-09T19:51:42.905+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:51:42] INFO: InfluxDB stopped, restarting...
[19:51:43] INFO: Starting the InfluxDB...
[19:51:50] INFO: InfluxDB stopped, restarting...
[19:51:51] INFO: Starting the InfluxDB...
[19:51:58] INFO: InfluxDB stopped, restarting...
[19:51:59] INFO: Starting the InfluxDB...
[19:52:05] INFO: InfluxDB stopped, restarting...
[19:52:06] INFO: Starting the InfluxDB...
[19:52:13] INFO: InfluxDB stopped, restarting...
[19:52:14] INFO: Starting the InfluxDB...
[19:52:21] INFO: InfluxDB stopped, restarting...
[19:52:22] INFO: Starting the InfluxDB...
[19:52:29] INFO: InfluxDB stopped, restarting...
[19:52:30] INFO: Starting the InfluxDB...
[19:52:38] INFO: InfluxDB stopped, restarting...
[19:52:39] INFO: Starting the InfluxDB...
ts=2024-12-09T19:52:46.458+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:52:46.463+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:52:46] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:52:47.168+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:52:47.546+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:52:47] INFO: Starting the InfluxDB...
ts=2024-12-09T19:52:48.606+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:52:49.869+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:52:52.825+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:52:54] INFO: InfluxDB stopped, restarting...
[19:52:55] INFO: Starting the InfluxDB...
ts=2024-12-09T19:52:58.164+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:53:02] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:53:02.708+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:53:03] INFO: Starting the InfluxDB...
ts=2024-12-09T19:53:09.626+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:53:11] INFO: InfluxDB stopped, restarting...
[19:53:12] INFO: Starting the InfluxDB...
[19:53:18] INFO: InfluxDB stopped, restarting...
[19:53:20] INFO: Starting the InfluxDB...
ts=2024-12-09T19:53:24.304+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:53:26] INFO: InfluxDB stopped, restarting...
[19:53:27] INFO: Starting the InfluxDB...
[19:53:34] INFO: InfluxDB stopped, restarting...
[19:53:35] INFO: Starting the InfluxDB...
[19:53:42] INFO: InfluxDB stopped, restarting...
[19:53:43] INFO: Starting the InfluxDB...
ts=2024-12-09T19:53:45.241+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:53:50] INFO: InfluxDB stopped, restarting...
[19:53:51] INFO: Starting the InfluxDB...
[19:53:58] INFO: InfluxDB stopped, restarting...
[19:53:59] INFO: Starting the InfluxDB...
[19:54:09] INFO: InfluxDB stopped, restarting...
[19:54:10] INFO: Starting the InfluxDB...
[19:54:17] INFO: InfluxDB stopped, restarting...
[19:54:18] INFO: Starting the InfluxDB...
ts=2024-12-09T19:54:21.169+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:54:25] INFO: InfluxDB stopped, restarting...
[19:54:26] INFO: Starting the InfluxDB...
[19:54:32] INFO: InfluxDB stopped, restarting...
[19:54:33] INFO: Starting the InfluxDB...
[19:54:40] INFO: InfluxDB stopped, restarting...
[19:54:41] INFO: Starting the InfluxDB...
[19:54:48] INFO: InfluxDB stopped, restarting...
[19:54:49] INFO: Starting the InfluxDB...
[19:54:56] INFO: InfluxDB stopped, restarting...
[19:54:57] INFO: Starting the InfluxDB...
[19:55:04] INFO: InfluxDB stopped, restarting...
[19:55:05] INFO: Starting the InfluxDB...
[19:55:14] INFO: InfluxDB stopped, restarting...
[19:55:15] INFO: Starting the InfluxDB...
ts=2024-12-09T19:55:18.422+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:55:23] INFO: InfluxDB stopped, restarting...
[19:55:24] INFO: Starting the InfluxDB...
[19:55:30] INFO: InfluxDB stopped, restarting...
[19:55:31] INFO: Starting the InfluxDB...
[19:55:39] INFO: InfluxDB stopped, restarting...
[19:55:40] INFO: Starting the InfluxDB...
[19:55:48] INFO: InfluxDB stopped, restarting...
[19:55:49] INFO: Starting the InfluxDB...
[19:55:56] INFO: InfluxDB stopped, restarting...
[19:55:57] INFO: Starting the InfluxDB...
[19:56:04] INFO: InfluxDB stopped, restarting...
[19:56:05] INFO: Starting the InfluxDB...
ts=2024-12-09T19:56:08.205+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:56:13] INFO: InfluxDB stopped, restarting...
[19:56:14] INFO: Starting the InfluxDB...
[19:56:21] INFO: InfluxDB stopped, restarting...
[19:56:22] INFO: Starting the InfluxDB...
[19:56:28] INFO: InfluxDB stopped, restarting...
[19:56:29] INFO: Starting the InfluxDB...
[19:56:36] INFO: InfluxDB stopped, restarting...
[19:56:38] INFO: Starting the InfluxDB...
[19:56:45] INFO: InfluxDB stopped, restarting...
[19:56:46] INFO: Starting the InfluxDB...
ts=2024-12-09T19:56:49.999+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:56:53] INFO: InfluxDB stopped, restarting...
[19:56:54] INFO: Starting the InfluxDB...
[19:57:01] INFO: InfluxDB stopped, restarting...
[19:57:02] INFO: Starting the InfluxDB...
[19:57:08] INFO: InfluxDB stopped, restarting...
[19:57:09] INFO: Starting the InfluxDB...
[19:57:16] INFO: InfluxDB stopped, restarting...
[19:57:17] INFO: Starting the InfluxDB...
[19:57:25] INFO: InfluxDB stopped, restarting...
[19:57:26] INFO: Starting the InfluxDB...
[19:57:32] INFO: InfluxDB stopped, restarting...
[19:57:33] INFO: Starting the InfluxDB...
ts=2024-12-09T19:57:36.057+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:57:41] INFO: InfluxDB stopped, restarting...
[19:57:42] INFO: Starting the InfluxDB...
[19:57:49] INFO: InfluxDB stopped, restarting...
[19:57:50] INFO: Starting the InfluxDB...
[19:57:57] INFO: InfluxDB stopped, restarting...
[19:57:58] INFO: Starting the InfluxDB...
[19:58:05] INFO: InfluxDB stopped, restarting...
[19:58:06] INFO: Starting the InfluxDB...
[19:58:13] INFO: InfluxDB stopped, restarting...
[19:58:14] INFO: Starting the InfluxDB...
[19:58:20] INFO: InfluxDB stopped, restarting...
[19:58:21] INFO: Starting the InfluxDB...
[19:58:28] INFO: InfluxDB stopped, restarting...
[19:58:29] INFO: Starting the InfluxDB...
[19:58:36] INFO: InfluxDB stopped, restarting...
[19:58:37] INFO: Starting the InfluxDB...
[19:58:44] INFO: InfluxDB stopped, restarting...
[19:58:45] INFO: Starting the InfluxDB...
[19:58:53] INFO: InfluxDB stopped, restarting...
[19:58:54] INFO: Starting the InfluxDB...
[19:59:00] INFO: InfluxDB stopped, restarting...
[19:59:01] INFO: Starting the InfluxDB...
ts=2024-12-09T19:59:04.809+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:59:04.814+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:59:05.089+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:59:05.885+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:59:06.925+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:59:08] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T19:59:08.963+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:59:09] INFO: Starting the InfluxDB...
ts=2024-12-09T19:59:12.706+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:59:16] INFO: InfluxDB stopped, restarting...
[19:59:17] INFO: Starting the InfluxDB...
ts=2024-12-09T19:59:17.976+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T19:59:22.186+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:59:24] INFO: InfluxDB stopped, restarting...
[19:59:25] INFO: Starting the InfluxDB...
ts=2024-12-09T19:59:31.562+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:59:33] INFO: InfluxDB stopped, restarting...
[19:59:34] INFO: Starting the InfluxDB...
ts=2024-12-09T19:59:39.249+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:59:40] INFO: InfluxDB stopped, restarting...
[19:59:41] INFO: Starting the InfluxDB...
[19:59:48] INFO: InfluxDB stopped, restarting...
[19:59:49] INFO: Starting the InfluxDB...
ts=2024-12-09T19:59:53.237+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[19:59:55] INFO: InfluxDB stopped, restarting...
[19:59:56] INFO: Starting the InfluxDB...
[20:00:03] INFO: InfluxDB stopped, restarting...
[20:00:04] INFO: Starting the InfluxDB...
ts=2024-12-09T20:00:11.386+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:00:13] INFO: InfluxDB stopped, restarting...
[20:00:14] INFO: Starting the InfluxDB...
[20:00:21] INFO: InfluxDB stopped, restarting...
[20:00:22] INFO: Starting the InfluxDB...
[20:00:29] INFO: InfluxDB stopped, restarting...
[20:00:31] INFO: Starting the InfluxDB...
[20:00:37] INFO: InfluxDB stopped, restarting...
[20:00:38] INFO: Starting the InfluxDB...
[20:00:45] INFO: InfluxDB stopped, restarting...
[20:00:46] INFO: Starting the InfluxDB...
[20:00:53] INFO: InfluxDB stopped, restarting...
[20:00:54] INFO: Starting the InfluxDB...
ts=2024-12-09T20:00:58.500+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:01:00] INFO: InfluxDB stopped, restarting...
[20:01:01] INFO: Starting the InfluxDB...
[20:01:09] INFO: InfluxDB stopped, restarting...
[20:01:10] INFO: Starting the InfluxDB...
[20:01:17] INFO: InfluxDB stopped, restarting...
[20:01:18] INFO: Starting the InfluxDB...
[20:01:25] INFO: InfluxDB stopped, restarting...
[20:01:26] INFO: Starting the InfluxDB...
ts=2024-12-09T20:01:32.495+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:01:33] INFO: InfluxDB stopped, restarting...
[20:01:34] INFO: Starting the InfluxDB...
[20:01:40] INFO: InfluxDB stopped, restarting...
[20:01:41] INFO: Starting the InfluxDB...
[20:01:48] INFO: InfluxDB stopped, restarting...
[20:01:49] INFO: Starting the InfluxDB...
[20:01:57] INFO: InfluxDB stopped, restarting...
[20:01:58] INFO: Starting the InfluxDB...
[20:02:04] INFO: InfluxDB stopped, restarting...
[20:02:05] INFO: Starting the InfluxDB...
[20:02:12] INFO: InfluxDB stopped, restarting...
[20:02:13] INFO: Starting the InfluxDB...
[20:02:21] INFO: InfluxDB stopped, restarting...
[20:02:22] INFO: Starting the InfluxDB...
[20:02:28] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:02:28.931+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:02:29] INFO: Starting the InfluxDB...
[20:02:36] INFO: InfluxDB stopped, restarting...
[20:02:37] INFO: Starting the InfluxDB...
[20:02:45] INFO: InfluxDB stopped, restarting...
[20:02:46] INFO: Starting the InfluxDB...
[20:02:52] INFO: InfluxDB stopped, restarting...
[20:02:53] INFO: Starting the InfluxDB...
[20:03:00] INFO: InfluxDB stopped, restarting...
[20:03:01] INFO: Starting the InfluxDB...
[20:03:08] INFO: InfluxDB stopped, restarting...
[20:03:09] INFO: Starting the InfluxDB...
[20:03:15] INFO: InfluxDB stopped, restarting...
[20:03:16] INFO: Starting the InfluxDB...
ts=2024-12-09T20:03:22.899+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:03:23] INFO: InfluxDB stopped, restarting...
[20:03:24] INFO: Starting the InfluxDB...
[20:03:31] INFO: InfluxDB stopped, restarting...
[20:03:32] INFO: Starting the InfluxDB...
[20:03:39] INFO: InfluxDB stopped, restarting...
[20:03:40] INFO: Starting the InfluxDB...
[20:03:47] INFO: InfluxDB stopped, restarting...
[20:03:48] INFO: Starting the InfluxDB...
[20:03:54] INFO: InfluxDB stopped, restarting...
[20:03:55] INFO: Starting the InfluxDB...
[20:04:03] INFO: InfluxDB stopped, restarting...
[20:04:04] INFO: Starting the InfluxDB...
[20:04:10] INFO: InfluxDB stopped, restarting...
[20:04:11] INFO: Starting the InfluxDB...
[20:04:18] INFO: InfluxDB stopped, restarting...
[20:04:19] INFO: Starting the InfluxDB...
ts=2024-12-09T20:04:21.616+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:04:21.620+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:04:22.284+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:04:23.179+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:04:24.685+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:04:26.106+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:04:26] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:04:27.524+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:04:27] INFO: Starting the InfluxDB...
ts=2024-12-09T20:04:31.055+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:04:34] INFO: InfluxDB stopped, restarting...
[20:04:35] INFO: Starting the InfluxDB...
ts=2024-12-09T20:04:37.096+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:04:43] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:04:43.981+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:04:44] INFO: Starting the InfluxDB...
[20:04:50] INFO: InfluxDB stopped, restarting...
[20:04:52] INFO: Starting the InfluxDB...
ts=2024-12-09T20:04:56.520+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:04:58] INFO: InfluxDB stopped, restarting...
[20:04:59] INFO: Starting the InfluxDB...
[20:05:06] INFO: InfluxDB stopped, restarting...
[20:05:07] INFO: Starting the InfluxDB...
ts=2024-12-09T20:05:11.698+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:05:15] INFO: InfluxDB stopped, restarting...
[20:05:16] INFO: Starting the InfluxDB...
[20:05:23] INFO: InfluxDB stopped, restarting...
[20:05:24] INFO: Starting the InfluxDB...
[20:05:31] INFO: InfluxDB stopped, restarting...
[20:05:32] INFO: Starting the InfluxDB...
ts=2024-12-09T20:05:32.881+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:05:39] INFO: InfluxDB stopped, restarting...
[20:05:40] INFO: Starting the InfluxDB...
[20:05:47] INFO: InfluxDB stopped, restarting...
[20:05:48] INFO: Starting the InfluxDB...
[20:05:56] INFO: InfluxDB stopped, restarting...
[20:05:57] INFO: Starting the InfluxDB...
ts=2024-12-09T20:06:03.015+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:06:03] INFO: InfluxDB stopped, restarting...
[20:06:04] INFO: Starting the InfluxDB...
[20:06:13] INFO: InfluxDB stopped, restarting...
[20:06:14] INFO: Starting the InfluxDB...
[20:06:20] INFO: InfluxDB stopped, restarting...
[20:06:22] INFO: Starting the InfluxDB...
[20:06:28] INFO: InfluxDB stopped, restarting...
[20:06:29] INFO: Starting the InfluxDB...
[20:06:36] INFO: InfluxDB stopped, restarting...
[20:06:37] INFO: Starting the InfluxDB...
[20:06:44] INFO: InfluxDB stopped, restarting...
[20:06:45] INFO: Starting the InfluxDB...
[20:06:51] INFO: InfluxDB stopped, restarting...
[20:06:53] INFO: Starting the InfluxDB...
[20:06:59] INFO: InfluxDB stopped, restarting...
[20:07:01] INFO: Starting the InfluxDB...
[20:07:07] INFO: InfluxDB stopped, restarting...
[20:07:08] INFO: Starting the InfluxDB...
ts=2024-12-09T20:07:14.360+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:07:15] INFO: InfluxDB stopped, restarting...
[20:07:16] INFO: Starting the InfluxDB...
[20:07:23] INFO: InfluxDB stopped, restarting...
[20:07:24] INFO: Starting the InfluxDB...
[20:07:31] INFO: InfluxDB stopped, restarting...
[20:07:32] INFO: Starting the InfluxDB...
[20:07:38] INFO: InfluxDB stopped, restarting...
[20:07:40] INFO: Starting the InfluxDB...
[20:07:46] INFO: InfluxDB stopped, restarting...
[20:07:47] INFO: Starting the InfluxDB...
ts=2024-12-09T20:07:52.305+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:07:54] INFO: InfluxDB stopped, restarting...
[20:07:55] INFO: Starting the InfluxDB...
[20:08:02] INFO: InfluxDB stopped, restarting...
[20:08:03] INFO: Starting the InfluxDB...
[20:08:10] INFO: InfluxDB stopped, restarting...
[20:08:11] INFO: Starting the InfluxDB...
[20:08:18] INFO: InfluxDB stopped, restarting...
[20:08:19] INFO: Starting the InfluxDB...
[20:08:26] INFO: InfluxDB stopped, restarting...
[20:08:27] INFO: Starting the InfluxDB...
[20:08:34] INFO: InfluxDB stopped, restarting...
[20:08:35] INFO: Starting the InfluxDB...
[20:08:41] INFO: InfluxDB stopped, restarting...
[20:08:42] INFO: Starting the InfluxDB...
[20:08:50] INFO: InfluxDB stopped, restarting...
[20:08:51] INFO: Starting the InfluxDB...
[20:08:58] INFO: InfluxDB stopped, restarting...
[20:08:59] INFO: Starting the InfluxDB...
[20:09:06] INFO: InfluxDB stopped, restarting...
[20:09:07] INFO: Starting the InfluxDB...
ts=2024-12-09T20:09:07.705+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:09:14] INFO: InfluxDB stopped, restarting...
[20:09:15] INFO: Starting the InfluxDB...
[20:09:21] INFO: InfluxDB stopped, restarting...
[20:09:22] INFO: Starting the InfluxDB...
[20:09:29] INFO: InfluxDB stopped, restarting...
[20:09:30] INFO: Starting the InfluxDB...
[20:09:37] INFO: InfluxDB stopped, restarting...
[20:09:38] INFO: Starting the InfluxDB...
[20:09:44] INFO: InfluxDB stopped, restarting...
[20:09:45] INFO: Starting the InfluxDB...
[20:09:52] INFO: InfluxDB stopped, restarting...
[20:09:53] INFO: Starting the InfluxDB...
[20:10:00] INFO: InfluxDB stopped, restarting...
[20:10:01] INFO: Starting the InfluxDB...
[20:10:07] INFO: InfluxDB stopped, restarting...
[20:10:08] INFO: Starting the InfluxDB...
ts=2024-12-09T20:10:14.082+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:10:14.087+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:10:14.368+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:10:14.809+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:10:15.511+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:10:15] INFO: InfluxDB stopped, restarting...
[20:10:16] INFO: Starting the InfluxDB...
ts=2024-12-09T20:10:16.792+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:10:19.837+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:10:23] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:10:24.549+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:10:24] INFO: Starting the InfluxDB...
[20:10:31] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:10:31.899+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:10:32] INFO: Starting the InfluxDB...
[20:10:38] INFO: InfluxDB stopped, restarting...
[20:10:39] INFO: Starting the InfluxDB...
ts=2024-12-09T20:10:41.528+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:10:47] INFO: InfluxDB stopped, restarting...
[20:10:48] INFO: Starting the InfluxDB...
ts=2024-12-09T20:10:49.244+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:10:55] INFO: InfluxDB stopped, restarting...
[20:10:56] INFO: Starting the InfluxDB...
[20:11:03] INFO: InfluxDB stopped, restarting...
[20:11:04] INFO: Starting the InfluxDB...
ts=2024-12-09T20:11:05.151+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:11:10] INFO: InfluxDB stopped, restarting...
[20:11:11] INFO: Starting the InfluxDB...
[20:11:18] INFO: InfluxDB stopped, restarting...
[20:11:19] INFO: Starting the InfluxDB...
[20:11:26] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:11:26.728+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:11:27] INFO: Starting the InfluxDB...
[20:11:33] INFO: InfluxDB stopped, restarting...
[20:11:34] INFO: Starting the InfluxDB...
[20:11:41] INFO: InfluxDB stopped, restarting...
[20:11:42] INFO: Starting the InfluxDB...
[20:11:49] INFO: InfluxDB stopped, restarting...
[20:11:51] INFO: Starting the InfluxDB...
[20:11:58] INFO: InfluxDB stopped, restarting...
[20:11:59] INFO: Starting the InfluxDB...
[20:12:06] INFO: InfluxDB stopped, restarting...
[20:12:07] INFO: Starting the InfluxDB...
[20:12:13] INFO: InfluxDB stopped, restarting...
[20:12:14] INFO: Starting the InfluxDB...
ts=2024-12-09T20:12:16.146+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:12:21] INFO: InfluxDB stopped, restarting...
[20:12:22] INFO: Starting the InfluxDB...
[20:12:28] INFO: InfluxDB stopped, restarting...
[20:12:29] INFO: Starting the InfluxDB...
[20:12:36] INFO: InfluxDB stopped, restarting...
[20:12:37] INFO: Starting the InfluxDB...
[20:12:44] INFO: InfluxDB stopped, restarting...
[20:12:45] INFO: Starting the InfluxDB...
[20:12:53] INFO: InfluxDB stopped, restarting...
[20:12:54] INFO: Starting the InfluxDB...
[20:13:01] INFO: InfluxDB stopped, restarting...
[20:13:02] INFO: Starting the InfluxDB...
[20:13:10] INFO: InfluxDB stopped, restarting...
[20:13:11] INFO: Starting the InfluxDB...
[20:13:18] INFO: InfluxDB stopped, restarting...
[20:13:19] INFO: Starting the InfluxDB...
[20:13:26] INFO: InfluxDB stopped, restarting...
[20:13:27] INFO: Starting the InfluxDB...
[20:13:33] INFO: InfluxDB stopped, restarting...
[20:13:34] INFO: Starting the InfluxDB...
[20:13:41] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:13:42.649+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:13:43] INFO: Starting the InfluxDB...
[20:13:49] INFO: InfluxDB stopped, restarting...
[20:13:50] INFO: Starting the InfluxDB...
[20:13:57] INFO: InfluxDB stopped, restarting...
[20:13:58] INFO: Starting the InfluxDB...
[20:14:04] INFO: InfluxDB stopped, restarting...
[20:14:05] INFO: Starting the InfluxDB...
[20:14:12] INFO: InfluxDB stopped, restarting...
[20:14:13] INFO: Starting the InfluxDB...
[20:14:20] INFO: InfluxDB stopped, restarting...
[20:14:21] INFO: Starting the InfluxDB...
[20:14:29] INFO: InfluxDB stopped, restarting...
[20:14:30] INFO: Starting the InfluxDB...
ts=2024-12-09T20:14:31.997+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:14:36] INFO: InfluxDB stopped, restarting...
[20:14:37] INFO: Starting the InfluxDB...
[20:14:44] INFO: InfluxDB stopped, restarting...
[20:14:45] INFO: Starting the InfluxDB...
[20:14:52] INFO: InfluxDB stopped, restarting...
[20:14:53] INFO: Starting the InfluxDB...
[20:15:00] INFO: InfluxDB stopped, restarting...
[20:15:01] INFO: Starting the InfluxDB...
[20:15:08] INFO: InfluxDB stopped, restarting...
[20:15:09] INFO: Starting the InfluxDB...
[20:15:16] INFO: InfluxDB stopped, restarting...
[20:15:17] INFO: Starting the InfluxDB...
[20:15:23] INFO: InfluxDB stopped, restarting...
[20:15:25] INFO: Starting the InfluxDB...
[20:15:31] INFO: InfluxDB stopped, restarting...
[20:15:32] INFO: Starting the InfluxDB...
ts=2024-12-09T20:15:36.345+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:15:36.349+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:15:36.682+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:15:37.237+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:15:38.705+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:15:39] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:15:40.048+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:15:40] INFO: Starting the InfluxDB...
ts=2024-12-09T20:15:43.316+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:15:46] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:15:47.265+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:15:47] INFO: Starting the InfluxDB...
[20:15:54] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:15:54.557+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:15:55] INFO: Starting the InfluxDB...
ts=2024-12-09T20:16:01.553+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:16:01] INFO: InfluxDB stopped, restarting...
[20:16:02] INFO: Starting the InfluxDB...
[20:16:09] INFO: InfluxDB stopped, restarting...
[20:16:10] INFO: Starting the InfluxDB...
ts=2024-12-09T20:16:13.003+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:16:16] INFO: InfluxDB stopped, restarting...
[20:16:17] INFO: Starting the InfluxDB...
[20:16:25] INFO: InfluxDB stopped, restarting...
[20:16:26] INFO: Starting the InfluxDB...
[20:16:32] INFO: InfluxDB stopped, restarting...
[20:16:33] INFO: Starting the InfluxDB...
ts=2024-12-09T20:16:37.531+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:16:40] INFO: InfluxDB stopped, restarting...
[20:16:41] INFO: Starting the InfluxDB...
[20:16:47] INFO: InfluxDB stopped, restarting...
[20:16:48] INFO: Starting the InfluxDB...
[20:16:56] INFO: InfluxDB stopped, restarting...
[20:16:57] INFO: Starting the InfluxDB...
[20:17:03] INFO: InfluxDB stopped, restarting...
[20:17:04] INFO: Starting the InfluxDB...
[20:17:11] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:17:11.551+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:17:12] INFO: Starting the InfluxDB...
[20:17:18] INFO: InfluxDB stopped, restarting...
[20:17:19] INFO: Starting the InfluxDB...
[20:17:28] INFO: InfluxDB stopped, restarting...
[20:17:29] INFO: Starting the InfluxDB...
[20:17:36] INFO: InfluxDB stopped, restarting...
[20:17:37] INFO: Starting the InfluxDB...
[20:17:44] INFO: InfluxDB stopped, restarting...
[20:17:45] INFO: Starting the InfluxDB...
[20:17:52] INFO: InfluxDB stopped, restarting...
[20:17:53] INFO: Starting the InfluxDB...
ts=2024-12-09T20:17:58.511+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:18:00] INFO: InfluxDB stopped, restarting...
[20:18:01] INFO: Starting the InfluxDB...
[20:18:08] INFO: InfluxDB stopped, restarting...
[20:18:09] INFO: Starting the InfluxDB...
[20:18:15] INFO: InfluxDB stopped, restarting...
[20:18:16] INFO: Starting the InfluxDB...
[20:18:24] INFO: InfluxDB stopped, restarting...
[20:18:25] INFO: Starting the InfluxDB...
[20:18:32] INFO: InfluxDB stopped, restarting...
[20:18:33] INFO: Starting the InfluxDB...
[20:18:40] INFO: InfluxDB stopped, restarting...
[20:18:41] INFO: Starting the InfluxDB...
[20:18:47] INFO: InfluxDB stopped, restarting...
[20:18:48] INFO: Starting the InfluxDB...
[20:18:54] INFO: InfluxDB stopped, restarting...
[20:18:55] INFO: Starting the InfluxDB...
[20:19:03] INFO: InfluxDB stopped, restarting...
[20:19:04] INFO: Starting the InfluxDB...
[20:19:10] INFO: InfluxDB stopped, restarting...
[20:19:11] INFO: Starting the InfluxDB...
ts=2024-12-09T20:19:16.473+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:19:18] INFO: InfluxDB stopped, restarting...
[20:19:19] INFO: Starting the InfluxDB...
[20:19:26] INFO: InfluxDB stopped, restarting...
[20:19:27] INFO: Starting the InfluxDB...
[20:19:33] INFO: InfluxDB stopped, restarting...
[20:19:34] INFO: Starting the InfluxDB...
[20:19:41] INFO: InfluxDB stopped, restarting...
[20:19:42] INFO: Starting the InfluxDB...
[20:19:48] INFO: InfluxDB stopped, restarting...
[20:19:49] INFO: Starting the InfluxDB...
[20:19:56] INFO: InfluxDB stopped, restarting...
[20:19:57] INFO: Starting the InfluxDB...
[20:20:04] INFO: InfluxDB stopped, restarting...
[20:20:05] INFO: Starting the InfluxDB...
ts=2024-12-09T20:20:09.735+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:20:12] INFO: InfluxDB stopped, restarting...
[20:20:13] INFO: Starting the InfluxDB...
[20:20:19] INFO: InfluxDB stopped, restarting...
[20:20:20] INFO: Starting the InfluxDB...
[20:20:27] INFO: InfluxDB stopped, restarting...
[20:20:28] INFO: Starting the InfluxDB...
[20:20:34] INFO: InfluxDB stopped, restarting...
[20:20:36] INFO: Starting the InfluxDB...
[20:20:42] INFO: InfluxDB stopped, restarting...
[20:20:43] INFO: Starting the InfluxDB...
[20:20:50] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:20:51.557+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:20:51.559+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:20:51] INFO: Starting the InfluxDB...
ts=2024-12-09T20:20:52.167+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:20:52.558+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:20:53.175+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:20:55.552+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:20:57.611+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:20:58] INFO: InfluxDB stopped, restarting...
[20:20:59] INFO: Starting the InfluxDB...
ts=2024-12-09T20:21:01.599+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:21:04.689+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:21:05] INFO: InfluxDB stopped, restarting...
[20:21:06] INFO: Starting the InfluxDB...
ts=2024-12-09T20:21:10.274+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:21:13] INFO: InfluxDB stopped, restarting...
[20:21:14] INFO: Starting the InfluxDB...
[20:21:21] INFO: InfluxDB stopped, restarting...
[20:21:22] INFO: Starting the InfluxDB...
ts=2024-12-09T20:21:27.611+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:21:28] INFO: InfluxDB stopped, restarting...
[20:21:29] INFO: Starting the InfluxDB...
[20:21:36] INFO: InfluxDB stopped, restarting...
[20:21:37] INFO: Starting the InfluxDB...
ts=2024-12-09T20:21:38.133+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:21:43] INFO: InfluxDB stopped, restarting...
[20:21:45] INFO: Starting the InfluxDB...
[20:21:51] INFO: InfluxDB stopped, restarting...
[20:21:52] INFO: Starting the InfluxDB...
[20:21:58] INFO: InfluxDB stopped, restarting...
[20:21:59] INFO: Starting the InfluxDB...
[20:22:06] INFO: InfluxDB stopped, restarting...
[20:22:07] INFO: Starting the InfluxDB...
ts=2024-12-09T20:22:10.524+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:22:14] INFO: InfluxDB stopped, restarting...
[20:22:15] INFO: Starting the InfluxDB...
[20:22:21] INFO: InfluxDB stopped, restarting...
[20:22:22] INFO: Starting the InfluxDB...
[20:22:28] INFO: InfluxDB stopped, restarting...
[20:22:29] INFO: Starting the InfluxDB...
[20:22:37] INFO: InfluxDB stopped, restarting...
[20:22:38] INFO: Starting the InfluxDB...
[20:22:45] INFO: InfluxDB stopped, restarting...
[20:22:46] INFO: Starting the InfluxDB...
ts=2024-12-09T20:22:48.799+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:22:53] INFO: InfluxDB stopped, restarting...
[20:22:54] INFO: Starting the InfluxDB...
[20:23:01] INFO: InfluxDB stopped, restarting...
[20:23:02] INFO: Starting the InfluxDB...
[20:23:09] INFO: InfluxDB stopped, restarting...
[20:23:10] INFO: Starting the InfluxDB...
[20:23:17] INFO: InfluxDB stopped, restarting...
[20:23:18] INFO: Starting the InfluxDB...
[20:23:24] INFO: InfluxDB stopped, restarting...
[20:23:26] INFO: Starting the InfluxDB...
[20:23:33] INFO: InfluxDB stopped, restarting...
[20:23:34] INFO: Starting the InfluxDB...
[20:23:40] INFO: InfluxDB stopped, restarting...
[20:23:41] INFO: Starting the InfluxDB...
[20:23:47] INFO: InfluxDB stopped, restarting...
[20:23:48] INFO: Starting the InfluxDB...
[20:23:55] INFO: InfluxDB stopped, restarting...
[20:23:56] INFO: Starting the InfluxDB...
ts=2024-12-09T20:23:57.915+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:24:03] INFO: InfluxDB stopped, restarting...
[20:24:04] INFO: Starting the InfluxDB...
[20:24:10] INFO: InfluxDB stopped, restarting...
[20:24:11] INFO: Starting the InfluxDB...
[20:24:18] INFO: InfluxDB stopped, restarting...
[20:24:19] INFO: Starting the InfluxDB...
[20:24:26] INFO: InfluxDB stopped, restarting...
[20:24:27] INFO: Starting the InfluxDB...
ts=2024-12-09T20:24:33.090+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:24:34] INFO: InfluxDB stopped, restarting...
[20:24:35] INFO: Starting the InfluxDB...
[20:24:41] INFO: InfluxDB stopped, restarting...
[20:24:42] INFO: Starting the InfluxDB...
[20:24:49] INFO: InfluxDB stopped, restarting...
[20:24:50] INFO: Starting the InfluxDB...
[20:24:57] INFO: InfluxDB stopped, restarting...
[20:24:58] INFO: Starting the InfluxDB...
[20:25:05] INFO: InfluxDB stopped, restarting...
[20:25:06] INFO: Starting the InfluxDB...
[20:25:12] INFO: InfluxDB stopped, restarting...
[20:25:13] INFO: Starting the InfluxDB...
ts=2024-12-09T20:25:16.051+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:25:20] INFO: InfluxDB stopped, restarting...
[20:25:21] INFO: Starting the InfluxDB...
[20:25:27] INFO: InfluxDB stopped, restarting...
[20:25:28] INFO: Starting the InfluxDB...
[20:25:36] INFO: InfluxDB stopped, restarting...
[20:25:37] INFO: Starting the InfluxDB...
[20:25:43] INFO: InfluxDB stopped, restarting...
[20:25:45] INFO: Starting the InfluxDB...
[20:25:51] INFO: InfluxDB stopped, restarting...
[20:25:52] INFO: Starting the InfluxDB...
[20:26:00] INFO: InfluxDB stopped, restarting...
[20:26:01] INFO: Starting the InfluxDB...
[20:26:08] INFO: InfluxDB stopped, restarting...
[20:26:09] INFO: Starting the InfluxDB...
[20:26:16] INFO: InfluxDB stopped, restarting...
[20:26:17] INFO: Starting the InfluxDB...
[20:26:23] INFO: InfluxDB stopped, restarting...
[20:26:24] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:30.570+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:30.577+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:30.990+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:31.594+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:32.346+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:32] INFO: InfluxDB stopped, restarting...
[20:26:33] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:34.311+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:37.255+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:40] INFO: InfluxDB stopped, restarting...
[20:26:41] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:42.886+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-09T20:26:46.495+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:48] INFO: InfluxDB stopped, restarting...
[20:26:49] INFO: Starting the InfluxDB...
ts=2024-12-09T20:26:52.982+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:26:55] INFO: InfluxDB stopped, restarting...
[20:26:56] INFO: Starting the InfluxDB...
[20:27:03] INFO: InfluxDB stopped, restarting...
ts=2024-12-09T20:27:04.463+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:27:04] INFO: Starting the InfluxDB...
[20:27:11] INFO: InfluxDB stopped, restarting...
[20:27:12] INFO: Starting the InfluxDB...
ts=2024-12-09T20:27:14.447+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:27:19] INFO: InfluxDB stopped, restarting...
[20:27:20] INFO: Starting the InfluxDB...
[20:27:26] INFO: InfluxDB stopped, restarting...
[20:27:27] INFO: Starting the InfluxDB...
[20:27:33] INFO: InfluxDB stopped, restarting...
[20:27:35] INFO: Starting the InfluxDB...
[20:27:41] INFO: InfluxDB stopped, restarting...
[20:27:42] INFO: Starting the InfluxDB...
[20:27:49] INFO: InfluxDB stopped, restarting...
[20:27:50] INFO: Starting the InfluxDB...
ts=2024-12-09T20:27:50.418+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[20:27:57] INFO: InfluxDB stopped, restarting...
[20:27:58] INFO: Starting the InfluxDB...
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46846" url=/
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46846" response_time=6.981771ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46860" url=/index.c708214f.css
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46866" url=/index.4493d50d.js
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46866" response_time=12.342904ms status=200
[20:28:05] INFO: InfluxDB stopped, restarting...
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46860" response_time=51.062062ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46874" url=/worker.f6754a45.js
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46874" response_time=1.285679ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46884" response_time=1.714678ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46896" response_time="554.03µs" status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46898" response_time=1.547412ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Failed to retrieve database version" error="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused" url="http://localhost:8086"
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46900" response_time=2.591739ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46906" response_time="884.029µs" status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46908" url=/icomoon.779fca40.woff2
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46908" response_time=1.183094ms status=200
time="2024-12-09T20:28:05+01:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:46916" response_time="485.997µs" status=400
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46932" url=/laser-spinner.c83a0b4c.png
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46932" response_time=3.098727ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46934" response_time="455.926µs" status=200
time="2024-12-09T20:28:05+01:00" level=error msg="Error message Post \"http://localhost:8086/query?db=&epoch=ms&q=SELECT+count%28%22value%22%29+AS+%22count_value%22+FROM+%22chronograf%22.%22autogen%22.%22alerts%22+WHERE+time+%3E+now%28%29+-+30d+AND+time+%3C+now%28%29+GROUP+BY+time%281d%29+FILL%28null%29&rp=\": dial tcp [::1]:8086: connect: connection refused" component=server http_status =400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:46948" response_time="556.21µs" status=400
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46950" url=/Roboto-Regular.b5b51c7e.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46958" url=/Roboto-Bold.daa8e441.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46964" url=/Roboto-Black.dbac53af.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46964" response_time=24.032248ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:46974" url=/Roboto-Medium.9eff68ae.ttf
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46958" response_time=57.079108ms status=200
time="2024-12-09T20:28:05+01:00" level=error msg="Error message Post \"http://localhost:8086/query?db=chronograf&epoch=ms&q=SELECT+host%2C+value%2C+level%2C+alertName+FROM+alerts+WHERE+time+%3E%3D+%272024-11-09T20%3A28%3A05%2B01%3A00%27+AND+time+%3C%3D+%272024-12-09T20%3A28%3A05%2B01%3A00%27+ORDER+BY+time+desc+LIMIT+30&rp=\": dial tcp [::1]:8086: connect: connection refused" component=server http_status =400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:46980" response_time=25.100219ms status=400
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46974" response_time=25.197352ms status=200
time="2024-12-09T20:28:05+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46950" response_time=59.488723ms status=200
[20:28:06] INFO: Starting the InfluxDB...
[20:28:13] INFO: InfluxDB stopped, restarting...
[20:28:14] INFO: Starting the InfluxDB...
time="2024-12-09T20:28:15+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:37484" response_time=1.894173ms status=200
[20:28:21] INFO: InfluxDB stopped, restarting...
[20:28:22] INFO: Starting the InfluxDB...
time="2024-12-09T20:28:23+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:37512" response_time=2.729987ms status=200
time="2024-12-09T20:28:23+01:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2024-12-09T20:28:23+01:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:37500" response_time=6.220237ms status=400
time="2024-12-09T20:28:23+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:37528" response_time=25.035654ms status=200
time="2024-12-09T20:28:23+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:37542" response_time=1.364787ms status=204
time="2024-12-09T20:28:25+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52330" response_time="40.373µs" status=200
[20:28:28] INFO: InfluxDB stopped, restarting...
[20:28:29] INFO: Starting the InfluxDB...
ts=2024-12-09T20:28:30.155+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
time="2024-12-09T20:28:31+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52350" response_time=6.483171ms status=200
time="2024-12-09T20:28:31+01:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2024-12-09T20:28:31+01:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:52346" response_time=6.975259ms status=400
time="2024-12-09T20:28:31+01:00" level=error msg="Error message Post \"http://localhost:8086/query?db=chronograf&epoch=ms&q=SELECT+host%2C+value%2C+level%2C+alertName+FROM+alerts+WHERE+time+%3E%3D+%272024-12-08T20%3A28%3A31%2B01%3A00%27+AND+time+%3C%3D+%272024-12-09T20%3A28%3A31%2B01%3A00%27+ORDER+BY+time+desc+&rp=\": dial tcp [::1]:8086: connect: connection refused" component=server http_status =400
time="2024-12-09T20:28:31+01:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:52362" response_time=3.162623ms status=400
time="2024-12-09T20:28:35+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:41752" response_time="346.19µs" status=200
[20:28:36] INFO: InfluxDB stopped, restarting...
[20:28:38] INFO: Starting the InfluxDB...
[20:28:44] INFO: InfluxDB stopped, restarting...
[20:28:45] INFO: Starting the InfluxDB...
[20:28:51] INFO: InfluxDB stopped, restarting...
[20:28:52] INFO: Chronograf stopped, restarting...
[20:28:52] INFO: NGINX stopped, restarting...
s6-svwait: fatal: timed out
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
[20:28:55] INFO: Kapacitor stopped, restarting...
s6-rc: info: service base-addon-banner: starting
 Add-on: InfluxDB
 Scalable datastore for metrics, events, and real-time analytics
 Add-on version: 5.0.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 14.0  (amd64 / qemux86-64)
 Home Assistant Core: 2024.12.1
 Home Assistant Supervisor: 2024.11.4
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
[20:29:00] INFO: Configuring timezone (Europe/Paris)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
cont-init: info: running /etc/cont-init.d/create-users.sh
cont-init: info: /etc/cont-init.d/create-users.sh exited 0
cont-init: info: running /etc/cont-init.d/influxdb.sh
cont-init: info: /etc/cont-init.d/influxdb.sh exited 0
cont-init: info: running /etc/cont-init.d/kapacitor.sh
cont-init: info: /etc/cont-init.d/kapacitor.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun chronograf (no readiness notification)
services-up: info: copying legacy longrun influxdb (no readiness notification)
services-up: info: copying legacy longrun kapacitor (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[20:29:00] INFO: Kapacitor is waiting until InfluxDB is available...
[20:29:00] INFO: Chronograf is waiting until InfluxDB is available...
[20:29:00] INFO: Starting the InfluxDB...
[20:29:08] INFO: InfluxDB stopped, restarting...
[20:29:09] INFO: Starting the InfluxDB...
[20:29:16] INFO: InfluxDB stopped, restarting...
[20:29:17] INFO: Starting the InfluxDB...
[20:29:24] INFO: InfluxDB stopped, restarting...
[20:29:25] INFO: Starting the InfluxDB...
[20:29:32] INFO: InfluxDB stopped, restarting...
[20:29:33] INFO: Starting the InfluxDB...
[20:29:40] INFO: InfluxDB stopped, restarting...
[20:29:41] INFO: Starting the InfluxDB...
[20:29:50] INFO: InfluxDB stopped, restarting...
[20:29:51] INFO: Starting the InfluxDB...
[20:29:58] INFO: InfluxDB stopped, restarting...
[20:29:59] INFO: Starting the InfluxDB...
[20:30:06] INFO: InfluxDB stopped, restarting...
[20:30:07] INFO: Starting the InfluxDB...
[20:30:14] INFO: InfluxDB stopped, restarting...
[20:30:15] INFO: Starting the InfluxDB...
[20:30:22] INFO: InfluxDB stopped, restarting...
[20:30:23] INFO: Starting the InfluxDB...
[20:30:29] INFO: InfluxDB stopped, restarting...
[20:30:30] INFO: Starting the InfluxDB...
[20:30:38] INFO: InfluxDB stopped, restarting...
[20:30:39] INFO: Starting the InfluxDB...
[20:30:45] INFO: InfluxDB stopped, restarting...
[20:30:46] INFO: Starting the InfluxDB...
[20:30:53] INFO: InfluxDB stopped, restarting...
[20:30:54] INFO: Starting the InfluxDB...
[20:31:00] INFO: InfluxDB stopped, restarting...
[20:31:01] INFO: Starting the InfluxDB...
[20:31:08] INFO: InfluxDB stopped, restarting...
[20:31:09] INFO: Starting the InfluxDB...
[20:31:15] INFO: InfluxDB stopped, restarting...
[20:31:16] INFO: Starting the InfluxDB...
[20:31:23] INFO: InfluxDB stopped, restarting...
[20:31:24] INFO: Starting the InfluxDB...
[20:31:30] INFO: InfluxDB stopped, restarting...
[20:31:31] INFO: Starting the InfluxDB...
[20:31:38] INFO: InfluxDB stopped, restarting...
[20:31:39] INFO: Starting the InfluxDB...
[20:31:46] INFO: InfluxDB stopped, restarting...
[20:31:47] INFO: Starting the InfluxDB...
[20:31:53] INFO: InfluxDB stopped, restarting...
[20:31:54] INFO: Starting the InfluxDB...
[20:32:01] INFO: InfluxDB stopped, restarting...
[20:32:02] INFO: Starting the InfluxDB...
[20:32:09] INFO: InfluxDB stopped, restarting...
[20:32:10] INFO: Starting the InfluxDB...
[20:32:17] INFO: InfluxDB stopped, restarting...
[20:32:18] INFO: Starting the InfluxDB...
[20:32:24] INFO: InfluxDB stopped, restarting...
[20:32:25] INFO: Starting the InfluxDB...
[20:32:32] INFO: InfluxDB stopped, restarting...
[20:32:33] INFO: Starting the InfluxDB...
[20:32:39] INFO: InfluxDB stopped, restarting...
[20:32:40] INFO: Starting the InfluxDB...
[20:32:47] INFO: InfluxDB stopped, restarting...
[20:32:48] INFO: Starting the InfluxDB...
[20:32:54] INFO: InfluxDB stopped, restarting...
[20:32:56] INFO: Starting the InfluxDB...
[20:33:02] INFO: InfluxDB stopped, restarting...
[20:33:03] INFO: Starting the InfluxDB...
[20:33:10] INFO: InfluxDB stopped, restarting...
[20:33:11] INFO: Starting the InfluxDB...
[20:33:18] INFO: InfluxDB stopped, restarting...
[20:33:19] INFO: Starting the InfluxDB...
[20:33:25] INFO: InfluxDB stopped, restarting...
[20:33:26] INFO: Starting the InfluxDB...
[20:33:34] INFO: InfluxDB stopped, restarting...
[20:33:35] INFO: Starting the InfluxDB...
[20:33:41] INFO: InfluxDB stopped, restarting...
[20:33:42] INFO: Starting the InfluxDB...
[20:33:49] INFO: InfluxDB stopped, restarting...
[20:33:50] INFO: Starting the InfluxDB...
[20:33:57] INFO: InfluxDB stopped, restarting...
[20:33:58] INFO: Starting the InfluxDB...
[20:34:06] INFO: NGINX stopped, restarting...
[20:34:06] INFO: InfluxDB stopped, restarting...
[20:34:06] INFO: Kapacitor stopped, restarting...
[20:34:06] INFO: Chronograf stopped, restarting...
 Add-on: InfluxDB
[20:34:17] INFO: Configuring timezone (Europe/Paris)...
[20:34:18] INFO: Kapacitor is waiting until InfluxDB is available...
[20:34:18] INFO: Chronograf is waiting until InfluxDB is available...
[20:34:18] INFO: Starting the InfluxDB...
[20:34:26] INFO: InfluxDB stopped, restarting...
[20:34:27] INFO: Starting the InfluxDB...
[20:34:34] INFO: InfluxDB stopped, restarting...
[20:34:36] INFO: Starting the InfluxDB...
[20:34:39] INFO: Chronograf stopped, restarting...
[20:34:39] INFO: NGINX stopped, restarting...
[20:34:39] INFO: InfluxDB stopped, restarting...
[20:34:39] INFO: Kapacitor stopped, restarting...
 Add-on: InfluxDB
[21:42:14] INFO: Configuring timezone (Europe/Paris)...
[21:42:15] INFO: Kapacitor is waiting until InfluxDB is available...
[21:42:15] INFO: Chronograf is waiting until InfluxDB is available...
[21:42:15] INFO: Starting the InfluxDB...
[21:42:23] INFO: InfluxDB stopped, restarting...
[21:42:24] INFO: Starting the InfluxDB...
[21:42:31] INFO: InfluxDB stopped, restarting...
[21:42:32] INFO: Starting the InfluxDB...
[21:42:39] INFO: InfluxDB stopped, restarting...
[21:42:40] INFO: Starting the InfluxDB...
[21:42:47] INFO: InfluxDB stopped, restarting...
[21:42:48] INFO: Starting the InfluxDB...
[21:42:57] INFO: InfluxDB stopped, restarting...
[21:42:58] INFO: Starting the InfluxDB...
[21:43:02] INFO: NGINX stopped, restarting...
[21:43:02] INFO: InfluxDB stopped, restarting...
[21:43:02] INFO: Chronograf stopped, restarting...
[21:43:02] INFO: Kapacitor stopped, restarting...
 Add-on: InfluxDB
[23:47:15] INFO: Configuring timezone (Europe/Paris)...
[23:47:16] INFO: Chronograf is waiting until InfluxDB is available...
[23:47:16] INFO: Kapacitor is waiting until InfluxDB is available...
[23:47:16] INFO: Starting the InfluxDB...
[23:47:23] INFO: InfluxDB stopped, restarting...
[23:47:24] INFO: Starting the InfluxDB...
[23:47:27] INFO: NGINX stopped, restarting...
[23:47:27] INFO: Kapacitor stopped, restarting...
[23:47:27] INFO: Chronograf stopped, restarting...
[23:47:27] INFO: InfluxDB stopped, restarting...
 Add-on: InfluxDB
[23:47:48] INFO: Configuring timezone (Europe/Paris)...
[23:47:48] INFO: Kapacitor is waiting until InfluxDB is available...
[23:47:48] INFO: Chronograf is waiting until InfluxDB is available...
[23:47:49] INFO: Starting the InfluxDB...
[23:47:56] INFO: InfluxDB stopped, restarting...
[23:47:57] INFO: Starting the InfluxDB...
[23:47:59] INFO: InfluxDB stopped, restarting...
[23:47:59] INFO: Chronograf stopped, restarting...
[23:47:59] INFO: Kapacitor stopped, restarting...
[23:47:59] INFO: NGINX stopped, restarting...
 Add-on: InfluxDB
[23:49:25] INFO: Configuring timezone (Europe/Paris)...
[23:49:26] INFO: Kapacitor is waiting until InfluxDB is available...
[23:49:26] INFO: Chronograf is waiting until InfluxDB is available...
[23:49:26] INFO: Starting the InfluxDB...
[23:49:36] INFO: Starting the Kapacitor
[23:49:36] INFO: Starting Chronograf...
2024/12/09 23:49:37 Using configuration at: /etc/kapacitor/kapacitor.conf
time="2024-12-09T23:49:40+01:00" level=info msg="Serving chronograf at http://127.0.0.1:8889" component=server
time="2024-12-09T23:49:40+01:00" level=info msg="Reporting usage stats" component=usage freq=24h reporting_addr="https://usage.influxdata.com" stats="os,arch,version,cluster_id,uptime"
[23:49:40] INFO: Starting NGINX...
time="2024-12-09T23:51:09+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33318" url=/
time="2024-12-09T23:51:09+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33318" response_time=6.75371ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33334" url=/index.c708214f.css
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33338" url=/index.4493d50d.js
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33338" response_time=26.686072ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33334" response_time=69.301098ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33346" url=/worker.f6754a45.js
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33346" response_time=2.347834ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33348" response_time=1.367672ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33350" response_time="785.069µs" status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33366" response_time=2.653603ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33378" response_time=3.688535ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33390" response_time=1.844045ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33404" url=/icomoon.779fca40.woff2
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33404" response_time=2.269524ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:33408" response_time="396.879µs" status=204
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33418" url=/laser-spinner.c83a0b4c.png
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33432" response_time=1.391997ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33418" response_time=6.764976ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33468" url=/Roboto-Bold.daa8e441.ttf
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33456" url=/Roboto-Regular.b5b51c7e.ttf
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:33444" response_time=23.751539ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:33472" url=/Roboto-Black.dbac53af.ttf
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:33480" response_time=31.638208ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33468" response_time=62.500858ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33456" response_time=64.990522ms status=200
time="2024-12-09T23:51:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33472" response_time=68.316772ms status=200
time="2024-12-09T23:51:16+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:45584" url=/Roboto-Medium.9eff68ae.ttf
time="2024-12-09T23:51:16+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:45584" response_time=16.932473ms status=200
time="2024-12-09T23:51:18+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:45596" response_time="319.192µs" status=204
time="2024-12-09T23:51:18+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:45598" response_time="87.661µs" status=200
time="2024-12-09T23:51:18+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:45606" response_time=2.691556ms status=204
time="2024-12-09T23:51:18+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:45618" response_time=5.379649ms status=200
time="2024-12-09T23:51:20+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:45622" response_time="88.455µs" status=200
[12:45:29] INFO: InfluxDB stopped, restarting...
[12:45:30] INFO: Starting the InfluxDB...
ts=2024-12-10T12:45:37.076+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[12:45:38] INFO: InfluxDB stopped, restarting...
[12:45:39] INFO: Starting the InfluxDB...
time="2024-12-10T12:45:49+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53810" url=/
time="2024-12-10T12:45:49+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53810" response_time=4.785557ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53824" url=/index.c708214f.css
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53840" url=/index.4493d50d.js
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53840" response_time=10.435377ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53824" response_time=67.508211ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53852" url=/worker.f6754a45.js
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53852" response_time=4.375334ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53864" response_time=2.137767ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53870" response_time="517.336µs" status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53880" response_time=1.56688ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53890" response_time=10.663199ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53902" response_time=1.169537ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:53904" response_time="281.963µs" status=204
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53920" url=/laser-spinner.c83a0b4c.png
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53920" response_time=2.818871ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53932" response_time="661.174µs" status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53948" url=/icomoon.779fca40.woff2
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53948" response_time=1.554165ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53958" url=/Roboto-Regular.b5b51c7e.ttf
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53972" url=/Roboto-Bold.daa8e441.ttf
time="2024-12-10T12:45:50+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:53970" url=/Roboto-Black.dbac53af.ttf
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53972" response_time=49.155598ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53970" response_time=57.121354ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:53958" response_time=70.302789ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:53950" response_time=145.030411ms status=200
time="2024-12-10T12:45:50+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:53980" response_time=137.6182ms status=200
time="2024-12-10T12:45:57+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:54286" response_time=1.599379ms status=204
time="2024-12-10T12:45:57+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54302" response_time=6.654612ms status=200
time="2024-12-10T12:45:57+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54312" response_time="71.536µs" status=200
time="2024-12-10T12:45:57+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54318" response_time=2.412923ms status=200
time="2024-12-10T12:45:57+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54320" response_time=1.891761ms status=200
time="2024-12-10T12:45:59+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:54334" response_time="785.591µs" status=204
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54346" response_time=11.222426ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54362" response_time=11.701627ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:54376" url=/RobotoMono-Medium.6ab04320.ttf
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54372" response_time=6.182743ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54370" response_time=21.499198ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54390" response_time=2.3514ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54396" response_time=2.490391ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54376" response_time=36.408462ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54402" response_time=1.122345ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:54408" response_time=1.764539ms status=200
time="2024-12-10T12:46:00+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54424" response_time="337.897µs" status=200
[13:15:51] INFO: InfluxDB stopped, restarting...
[13:15:52] INFO: Starting the InfluxDB...
[13:15:58] INFO: InfluxDB stopped, restarting...
[13:15:59] INFO: Starting the InfluxDB...
[13:16:05] INFO: InfluxDB stopped, restarting...
[13:16:06] INFO: Starting the InfluxDB...
[13:16:12] INFO: InfluxDB stopped, restarting...
[13:16:13] INFO: Starting the InfluxDB...
[13:16:20] INFO: InfluxDB stopped, restarting...
[13:16:21] INFO: Starting the InfluxDB...
[13:16:27] INFO: InfluxDB stopped, restarting...
[13:16:28] INFO: Starting the InfluxDB...
[13:16:34] INFO: InfluxDB stopped, restarting...
[13:16:35] INFO: Starting the InfluxDB...
ts=2024-12-10T13:16:37.075+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:16:37.653+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:16:38.452+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:16:39.349+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:16:40.871+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:17:06] INFO: InfluxDB stopped, restarting...
[13:17:07] INFO: Starting the InfluxDB...
[13:17:13] INFO: InfluxDB stopped, restarting...
[13:17:14] INFO: Starting the InfluxDB...
[13:17:21] INFO: InfluxDB stopped, restarting...
[13:17:22] INFO: Starting the InfluxDB...
[13:17:28] INFO: InfluxDB stopped, restarting...
[13:17:29] INFO: Starting the InfluxDB...
[13:17:35] INFO: InfluxDB stopped, restarting...
[13:17:36] INFO: Starting the InfluxDB...
ts=2024-12-10T13:17:37.071+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:17:37.455+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:17:38.510+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:17:39.620+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:17:41.947+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:17:42] INFO: InfluxDB stopped, restarting...
[13:17:43] INFO: Starting the InfluxDB...
ts=2024-12-10T13:17:44.646+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:17:48.751+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:17:49] INFO: InfluxDB stopped, restarting...
[13:17:50] INFO: Starting the InfluxDB...
ts=2024-12-10T13:17:55.424+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:17:57] INFO: InfluxDB stopped, restarting...
[13:17:58] INFO: Starting the InfluxDB...
ts=2024-12-10T13:18:00.415+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:18:04] INFO: InfluxDB stopped, restarting...
[13:18:05] INFO: Starting the InfluxDB...
ts=2024-12-10T13:18:11.036+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:18:11] INFO: InfluxDB stopped, restarting...
[13:18:12] INFO: Starting the InfluxDB...
[13:18:18] INFO: InfluxDB stopped, restarting...
[13:18:19] INFO: Starting the InfluxDB...
[13:18:25] INFO: InfluxDB stopped, restarting...
[13:18:26] INFO: Starting the InfluxDB...
ts=2024-12-10T13:18:31.904+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:18:32] INFO: InfluxDB stopped, restarting...
[13:18:33] INFO: Starting the InfluxDB...
[13:18:47] INFO: InfluxDB stopped, restarting...
[13:18:48] INFO: Starting the InfluxDB...
[13:18:54] INFO: InfluxDB stopped, restarting...
[13:18:55] INFO: Starting the InfluxDB...
ts=2024-12-10T13:18:58.998+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:19:01] INFO: InfluxDB stopped, restarting...
[13:19:02] INFO: Starting the InfluxDB...
[13:19:10] INFO: InfluxDB stopped, restarting...
[13:19:11] INFO: Starting the InfluxDB...
dans les journaux système
Enregistreur: homeassistant.components.influxdb
Source: components/influxdb/__init__.py:591
intégration: InfluxDB (documentation, problèmes)
S'est produit pour la première fois: 13:18:10 (1 occurrences)
Dernier enregistrement: 13:18:10
Cannot connect to InfluxDB due to 'HTTPConnectionPool(host='a0d7b954-influxdb', port=8086): Max retries exceeded with url: /write?db=HADB (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7efe926e8e60>: Failed to establish a new connection: [Errno 111] Connection refused'))'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible.
informations système
## System Information
version | core-2024.12.1
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.13.0
os_name | Linux
os_version | 6.6.63-haos
arch | x86_64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
Installed Version | 2.0.1
Stage | running
Available Repositories | 1481
Downloaded Repositories | 14
</details>
logged_in | true
subscription_expiration | 1 décembre 2025 à 01:00
relayer_connected | true
relayer_region | eu-central-1
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | true
cloud_ice_servers_enabled | true
remote_server | eu-central-1-23.ui.nabu.casa
certificate_status | ready
instance_id | a7b9998462ca450b96a8d915b549eaa6
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 14.0
update_channel | stable
supervisor_version | supervisor-2024.11.4
agent_version | 1.6.0
docker_version | 27.2.0
disk_total | 129.2 GB
disk_used | 22.7 GB
healthy | true
supported | true
host_connectivity | true
ntp_synchronized | true
virtualization | kvm
board | ova
supervisor_api | ok
version_api | ok
installed_addons | Studio Code Server (5.17.3), Terminal & SSH (9.15.0), Grafana (10.2.2), File editor (5.8.0), SQLite Web (4.3.0), InfluxDB (5.0.1), Mosquitto broker (6.4.1), Zigbee2MQTT (1.42.0-2)
</details>
dashboards | 7
resources | 5
views | 6
mode | storage
</details>
oldest_recorder_run | 29 novembre 2024 à 20:11
current_recorder_run | 9 décembre 2024 à 23:50
estimated_db_size | 672.58 MiB
database_engine | sqlite
database_version | 3.45.3
</details>
petit complément car influxdb vient de redémarrer, jusqu’à quand…
la fin de ses logs ici :
[13:20:21] INFO: InfluxDB stopped, restarting...
[13:20:22] INFO: Starting the InfluxDB...
[13:20:28] INFO: InfluxDB stopped, restarting...
[13:20:29] INFO: Starting the InfluxDB...
[13:20:35] INFO: InfluxDB stopped, restarting...
[13:20:36] INFO: Starting the InfluxDB...
ts=2024-12-10T13:20:37.068+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:20:37.432+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:20:38.209+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:20:39.765+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
ts=2024-12-10T13:20:41.082+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:20:42] INFO: InfluxDB stopped, restarting...
ts=2024-12-10T13:20:43.258+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:20:43] INFO: Starting the InfluxDB...
ts=2024-12-10T13:20:47.228+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:20:49] INFO: InfluxDB stopped, restarting...
ts=2024-12-10T13:20:50.218+01:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp [::1]:8086: connect: connection refused"
[13:20:50] INFO: Starting the InfluxDB...
Bon je continue à me répondre.,…
J’ai vérifié la consommation mémoire sur la participation Proxmox et j’étais à 95% et plus, avec 4 go déclarés, je suis passé à 8 go et ça semble nettement mieux.
A suivre
