J’essai d’installer sur HA ma sonnette beward DS06M qui est une sonnette connecté
J’ai suivi ce lien GitHub - Limych/ha-beward: Home Assistant custom component for Beward security Cameras and Doorbells
voici ma config
beward:
- host: 192.168.1.25
username: xxxx
password: xxxxxxxxx
port: 8080
rtsp_port: 554
cameras:
- live
- last_motion
et voici les messages d’erreur:
Invalid config
The following integrations and platforms could not be set up:
beward
Please check your config and logs.
Error during setup of component beward
17:49:54 – custom_components/beward/__init__.py (ERROR)
Error! HTTPConnectionPool(host='192.168.1.25', port=80): Max retries exceeded with url: /cgi-bin/systeminfo_cgi?action=get (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x712f74d8>: Failed to establish a new connection: [Errno 111] Connection refused'))
17:49:51 – /usr/local/lib/python3.8/site-packages/beward/core.py (ERROR)
``## System Health
version |
core-2021.2.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
virtualenv |
false |
python_version |
3.8.7 |
os_name |
Linux |
os_version |
5.4.83-v7 |
arch |
armv7l |
timezone |
Europe/Paris |
GitHub API |
ok |
Github API Calls Remaining |
4974 |
Installed Version |
1.11.3 |
Stage |
running |
Available Repositories |
751 |
Installed Repositories |
4 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
Hass.io
host_os |
Home Assistant OS 5.11 |
update_channel |
stable |
supervisor_version |
supervisor-2021.02.11 |
docker_version |
19.03.13 |
disk_total |
58.0 GB |
disk_used |
4.0 GB |
healthy |
true |
supported |
true |
board |
rpi3 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Samba share (9.3.0), File editor (5.2.0), Duck DNS (1.12.5), ESPHome (1.16.0), Terminal & SSH (9.0.1) |
Lovelace
dashboards |
1 |
resources |
2 |
views |
5 |
mode |
storage |
voilà merci pour votre aide
Entre ça:
et:
Il y a un truc qui coince.
Tu donnes 8080 comme port et dans les logs on voit 80…
Si tu vas avec un navigateur sur ta caméra tu fais quoi http://192.168.1.25 ou http://192.168.1.25:8080 ?
Si c’est le deuxième et sauf si c’est un problème je mettrais le port par défaut (je suppose 80) sur la caméra et changer la config pour virer la ligne port: puisque tu auras la valeur par défaut.
merci @golvert c’était exactement ça la deuxième solution j’ai remis sur ma sonnette le port 80 car j’avais mis 8080 et ensuite supprimé le port dans configuration.yaml et la j’ai l’image. Au top merci
