J’essaye d’installer myelectricaldata.
Lors du lancement, il me dit qu’il crache.
Voici la fin du message d’erreur :
FileNotFoundError: [Errno 2] No such file or directory
[14:11:21] FATAL: The app has crashed. Are you sure you entered the correct config options?
Au cours du démarrage, me dit ça aussi :
… config file has an invalid yaml format. Please check the file in /config/myelectricaldata/config.yaml. Errors list above.
73:30 error no new line character at the end of file (new-line-at-end-of-file)
Merci pour votre aide.
Cordialement à tous
Alexandre
Voici mon code :
port: 5000
debug: true
log2file: false
wipe_influxdb: false
home_assistant:
enable: true
discovery: true
home_assistant_ws:
enable: false
ssl: false
token: null
url: null
ssl:
gateway: true
certfile: "/data/cert.pem"
keyfile: "/data/key.pem"
influxdb:
enable: 'true'
hostname: xxx-influxdb
port: 8086
token: xxx:xxxx
org: "-"
bucket: "HADB/autogen"
method: synchronous
batching_options:
batch_size: 1000
flush_interval: 1000
jitter_interval: 0
retry_interval: 5000
max_retry_time: 180_000
max_retries: 5
max_retry_delay: 125_000
exponential_base: 2
mqtt:
enable: true
hostname: mosquitto
port: 1883
username: xxx
password: xxx
prefix: myelectricaldata
client_id: myelectricaldata
retain: true
qos: 0
myelectricaldata:
15117221364720:
enable: "true"
token: xxx
addresses: "true"
cache: "true"
consumption: "true"
consumption_detail: "true"
consumption_price_base: "0"
consumption_price_hc: "0.1396"
consumption_price_hp: "0.2119"
consumption_max_date: "2021-06-01"
consumption_detail_max_date: "2021-06-01"
offpeak_hours_0: 22H00-6H00 # LUNDI
offpeak_hours_1: 22H00-6H00 # MARDI
offpeak_hours_2: 22H00-6H00 # MERCREDI
offpeak_hours_3: 22H00-6H00 # JEUDI
offpeak_hours_4: 22H00-6H00 # VENDREDI
offpeak_hours_5: 22H00-6H00;12H00-14H00 # SAMEDI
offpeak_hours_6: 22H00-6H00;12H00-14H00 # DIMANCHE
plan: HC/HP
production: "false"
production_detail: "false"
production_price: "0.0"
production_max_date: "2021-06-01"
production_detail_max_date: "2021-06-01"
refresh_addresse: "false"
refresh_contract: "false"
[center]## System Information
| version | core-2024.4.4 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.12.2 |
| os_name | Linux |
| os_version | 6.6.25-haos |
| arch | x86_64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| Installed Version | 1.34.0 |
| Stage | running |
| Available Repositories | 1399 |
| Downloaded Repositories | 5 |
| HACS Data | ok |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 12.2 |
| update_channel | stable |
| supervisor_version | supervisor-2024.04.0 |
| agent_version | 1.6.0 |
| docker_version | 25.0.5 |
| disk_total | 457.7 GB |
| disk_used | 22.2 GB |
| healthy | true |
| supported | true |
| board | generic-x86-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Terminal & SSH (9.13.0), Node-RED (17.0.12), Studio Code Server (5.15.0), InfluxDB (5.0.0), Grafana (9.2.2), Home Assistant Google Drive Backup (0.112.1), Linky (1.4.0), ESPHome (2024.4.1), Mosquitto broker (6.4.0), Zigbee2MQTT (1.36.1-1), go2rtc (1.8.5), MyElectricalData (0.12.0) |
| dashboards | 2 |
| resources | 2 |
| views | 7 |
| mode | storage |
| oldest_recorder_run | 24 avril 2024 à 07:18 |
| current_recorder_run | 27 avril 2024 à 13:51 |
| estimated_db_size | 72.70 MiB |
| database_engine | sqlite |
| database_version | 3.44.2 |
