Bonsoir,
Je confirme que les topics ont changés avec les dernières mise à jour de bsblan et que les posts montrent les anciennes valeurs.
Voici ma config pour t’aider
mqtt:
## CLIMATE ##
climate:
- name: "Thermostat radiateur "
unique_id: chauffage_radiateur
availability_topic: "BSB-LAN/status"
icon: mdi:radiator
payload_on: "1"
payload_off: "0"
modes:
- auto
- heat
- cool
- "off"
mode_state_topic: "BSB-LAN/0/8/700/status"
mode_state_template: >-
{% set values = { '0 - Mode protection':'off', '1 - Automatique':'auto', '2 - Réduit':'heat', '3 - Confort':'heat'} %}
{{ values[value] if value in values.keys() else 'off' }}
mode_command_topic: "BSB-LAN"
mode_command_template: >-
{% set values = { 'off':'S700=0', 'auto':'S700=1', 'cool':'S700=2', 'heat':'S700=3'} %}
{{ values[value] if value in values.keys() else '0' }}
preset_modes:
- eco
- comfort
- away
preset_mode_state_topic: "BSB-LAN/0/8/700/status"
preset_mode_value_template: >-
{% set values = { '0 - Mode protection':'away', '2 - Réduit':'eco', '3 - Confort':'comfort'} %}
{{ values[value] if value in values.keys() else 'eco' }}
preset_mode_command_topic: "BSB-LAN"
preset_mode_command_template: >-
{% set values = { 'away':'S700=0', 'eco':'S700=2', 'comfort':'S700=3'} %}
{{ values[value] if value in values.keys() else '2' }}
current_temperature_topic: "BSB-LAN/8740/status"
min_temp: 16
max_temp: 24
temp_step: 0.1
temperature_state_topic: "BSB-LAN/0/32/8741/status"
temperature_command_topic: "BSB-LAN"
temperature_command_template: "{{'S710='+ (value| string)}}"
device:
identifiers: "ESP32-BSB-LAN"
model: "ESP32-WROOM-32"
manufacturer: "Espressif"
# Thermostat plancher mode confort
- name: "Thermostat plancher"
unique_id: bsb_lan_climate_plancher
icon: mdi:heating-coil
payload_on: "1"
payload_off: "0"
modes:
- auto
- heat
- cool
- "off"
mode_state_topic: "BSB-LAN/0/9/1000/status"
{% set values = { '0 - Mode protection':'off', '1 - Automatique':'auto', '2 - Réduit':'cool', '3 - Confort':'heat'} %}
{% set values = { 'off':'S1000=0', 'auto':'S1000=1', 'cool':'S1000=2', 'heat':'S1000=3'} %}
preset_modes:
- eco
- comfort
- away
preset_mode_state_topic: "BSB-LAN/0/9/1000/status"
{% set values = { 'away':'S1000=0', 'eco':'S1000=2', 'comfort':'S1000=3'} %}
current_temperature_topic: "BSB-LAN/8770/status"
min_temp: 17
max_temp: 22
temp_step: 0.1
temperature_state_topic: "BSB-LAN/0/32/8771/status"
temperature_command_template: "{{'S1010='+ (value| string)}}"
device:
## SELECT ##
select:
- name: Mode radiateur
unique_id: bsb_lan_select_radiateur
value_template: >
{% set mapping = {0: 'Mode protection', 1: 'Automatique', 2: 'Réduit', 3: 'Confort'} %}
{% set idx = value.split() | first | int %}
{{ mapping[idx] }}
command_template: >
{% set mapping = {'Mode protection': 0, 'Automatique': 1, 'Réduit': 2, 'Confort': 3} %}
S700={{ mapping[value] }}
options:
- Mode protection
- Automatique
- Réduit
- Confort
icon: mdi:list-box
entity_category: "config"
device:
- name: Mode plancher
unique_id: bsb_lan_select_plancher
value_template: >
{{ mapping[idx] }}
command_template: >
S1000={{ mapping[value] }}
options:
- Mode protection
- Automatique
- Réduit
- Confort
icon: mdi:list-box
device:
## SWITCH ##
## SENSOR RADIATEUR ##
- name: "Temp thermostat radiateur"
unique_id: bsb_lan_temp_thermostat_radiateur
state_topic: "BSB-LAN/0/32/8740/status"
unit_of_measurement: °C
device_class: temperature
state_class: measurement
icon: mdi:radiator
device:
- name: "Regime PAC radiateur"
unique_id: bsb_lan_regime_pac_radiateur
state_topic: "BSB-LAN/0/28/8000/status"
icon: mdi:radiator
value_template: "{{value.split('- ')[1]}}"
device:
## SENSOR ECS ##
- name: "Etat ECS"
unique_id: bsb_lan_etat_ecs
state_topic: "BSB-LAN/0/28/8003/status"
icon: mdi:storage-tank
device:
- name: "Etat pompe ECS"
unique_id: bsb_lan_etat_pompe_ecs
state_topic: "BSB-LAN/0/32/8820/status"
icon: mdi:pump
device:
- name: "Etat résistance ECS"
unique_id: bsb_lan_etat_resistance_ecs
state_topic: "BSB-LAN/0/32/8821/status"
icon: mdi:resistor
device:
- name: "Temperature ECS"
unique_id: bsb_lan_temperature_ecs
state_topic: "BSB-LAN/0/32/8830/status"
icon: mdi:water-plus
device:
## SENSOR PLANCHER ##
- name: "Temp thermostat plancher"
unique_id: bsb_lan_temp_thermostat_plancher
state_topic: "BSB-LAN/0/32/8770/status"
device:
- name: "Regime PAC plancher"
unique_id: bsb_lan_regime_pac_plancher
state_topic: "BSB-LAN/0/28/8001/status"
device:
## SENSOR PAC ##
- name: "Compresseur"
unique_id: bsb_lan_compresseur
state_topic: "BSB-LAN/0/30/8400/status"
icon: mdi:heat-pump
device:
- name: "Etat PAC"
unique_id: bsb_lan_etat_pac
state_topic: "BSB-LAN/0/29/8006/status"
icon: mdi:heat-pump
device:
- name: "Exterieure PAC"
unique_id: bsb_lan_temp_ext
state_topic: "BSB-LAN/0/31/8700/status"
device:
## ENERGIE ##
## NUMBER ##
number:
- name: "Consigne confort radiateur"
unique_id: bsb_lan_consigne_confort_radiateur
state_topic: "BSB-LAN/0/8/710/status"
value_template: >
{{value | string }}
min: 16
max: 24
step: 0.1
icon: mdi:radiator
device:
- name: "Consigne eco radiateur"
unique_id: bsb_lan_consigne_eco_radiateur
state_topic: "BSB-LAN/0/8/712/status"
command_template: "{{'S712='+ (value| string)}}"
value_template: >
{{value | string }}
min: 14
max: 22
step: 0.1
icon: mdi:radiator
device:
- name: "Consigne confort plancher"
unique_id: bsb_lan_consigne_confort_plancher
state_topic: "BSB-LAN/0/10/1010/status"
value_template: >
{{value | string }}
min: 16
max: 24
step: 0.1
device:
- name: "Consigne eco plancher"
unique_id: bsb_lan_consigne_eco_plancher
state_topic: "BSB-LAN/0/10/1012/status"
command_template: "{{'S1012='+ (value| string)}}"
value_template: >
{{value | string }}
min: 14
max: 22
step: 0.1
device:
## TEMPLATE ##
#template:
