Bien le bonjour,
Voici mon problème: j’ai découvert la config de romquenin (GitHub - romquenin/home-assistant-config-fr: 🏠Configuration de Home Assistant en français. 👨🏻💻 N'hésitez pas à ⭐ mon repo et à copier les bonnes idées ! 🇨🇵) et je souhaite copier sa partie météo avec l’integration GitHub - r-renato/ha-climacell-weather: Climacell weather provider integration is a custom component for Home Assistant. The climacell platform uses the Climacell API as a source for meteorological data for your location.. Normalement je doit avoir des sensors et sensor.cc_climacell_xxx mais il m’est impossible d’y arriver.
System Health
version |
core-2021.6.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
virtualenv |
false |
python_version |
3.8.9 |
os_name |
Linux |
os_version |
5.10.17-v7l |
arch |
armv7l |
timezone |
Europe/Paris |
GitHub API |
ok |
Github API Calls Remaining |
5000 |
Installed Version |
1.12.4 |
Stage |
running |
Available Repositories |
843 |
Installed Repositories |
8 |
logged_in |
true |
subscription_expiration |
13 juillet 2021 à 02:00 |
relayer_connected |
true |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
true |
google_enabled |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 6.0 |
update_channel |
stable |
supervisor_version |
supervisor-2021.06.3 |
docker_version |
20.10.6 |
disk_total |
28.6 GB |
disk_used |
11.4 GB |
healthy |
true |
supported |
true |
board |
rpi4 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
File editor (5.3.1), Samba share (9.5.1), Duck DNS (1.12.5), Glances (0.12.2), Node-RED (9.1.3), ESPHome (1.19.0), Portainer (1.5.0), Let’s Encrypt (4.11.0), Grafana (6.3.5), InfluxDB (4.1.1), RPC Shutdown (2.2), Check Home Assistant configuration (3.7.1), AdGuard Home (4.1.6), Terminal & SSH (9.1.3), CEC Scanner (2.4), Home Panel (2.2.1), Network UPS Tools (0.7.0), Freebox Add-On (1.1), Home Assistant Google Drive Backup (0.104.3), Mosquitto broker (6.0.1), TasmoAdmin (0.15.0) |
Lovelace
dashboards |
2 |
resources |
10 |
views |
7 |
mode |
storage |
Vu la version de HA que tu utilises, il semble que ce soit la clé version qui est manquante :
https://github.com/r-renato/ha-climacell-weather/issues/61
Je l’ai fait, j’ai essayé de regarder les issues du git mais rien n’a fait
j’ai trouvé ce qu’il y avait, il me manquait le champ name
- platform: climacell
api_key: !secret climacell_api_key
latitude: !secret latitude
longitude: !secret longitude
units: metric
timelines:
- name: "cherbourg" #Realtime
timestep: "1m"
forecast_obse
