As-tu fais ceci ?
- Créer un sous-répertoire dans le répertoire configuration portant le nom de « zha_quirks »
- Créer un fichier du nom de « lidl_tfs011f_plug.py » et y mettre le code suivant :
"""LIDL TS011F plug."""
import asyncio
from zigpy.profiles import zha
from zigpy.zcl.clusters.general import (
Basic,
GreenPowerProxy,
Groups,
Identify,
OnOff,
Ota,
Scenes,
Time,
from zhaquirks.const import (
DEVICE_TYPE,
ENDPOINTS,
INPUT_CLUSTERS,
MODEL,
OUTPUT_CLUSTERS,
PROFILE_ID,
from zhaquirks.tuya.ts011f_plug import Plug_3AC_4USB
class Lidl_Plug_3AC_4USB(Plug_3AC_4USB):
"""LIDL 3 outlet + 4 USB with restore power state support."""
def __init__(self, *args, **kwargs):
"""Initialize with task."""
super().__init__(*args, **kwargs)
self._init_plug_task = asyncio.create_task(self.spell())
async def spell(self) -> None:
"""Initialize device so that all endpoints become available."""
basic_cluster = self.endpoints[1].in_clusters[0]
# The magic spell is needed only once.
# TODO: Improve by doing this only once (successfully).
# Magic spell - part 1
attr_to_read = [4, 0, 1, 5, 7, 0xFFFE]
await basic_cluster.read_attributes(attr_to_read)
# Magic spell - part 2 (skipped - does not seem to be needed)
# attr_to_write={0xffde:13}
# basic_cluster.write_attributes(attr_to_write)
signature = {
MODEL: "TS011F",
ENDPOINTS: {
# <SimpleDescriptor endpoint=1 profile=260 device_type=266
# device_version=1
# input_clusters=[0, 3, 4, 5, 6]
# output_clusters=[10, 25]>
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.ON_OFF_PLUG_IN_UNIT,
INPUT_CLUSTERS: [
Basic.cluster_id,
Identify.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
OnOff.cluster_id,
OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
# <SimpleDescriptor endpoint=242 profile=41440 device_type=97
# device_version=1
# input_clusters=[]
# output_clusters=[33]>
242: {
PROFILE_ID: 41440,
DEVICE_TYPE: 97,
INPUT_CLUSTERS: [],
OUTPUT_CLUSTERS: [GreenPowerProxy.cluster_id],
- Redémarrer.
- Copier ceci dans le fichier « configuration.yaml » :
zha:
enable_quirks: true
custom_quirks_path: /config/zha_quirks
zha_toolkit:
- Redémarrer.
- Appairer la prise avec ZHA
