Perso j’ai parsé les infos qui m’intéressaient.
configuration.yaml :
- platform: rest
resource: http://192.168.1.80/WEBPROG/CGX/homeval.CGX
method: GET
authentication: basic
username: admin
password: wes
json_attributes_path: "$.form"
json_attributes:
- "array"
- "bssw"
- "java"
- "html"
value_template: 'OK'
sensors:
wesheurecreuseraw :
value_template: >-
{{ states.sensor.weshomeval.attributes["html"][5]["value"] }}
wesheurecreuse :
friendly_name: wes_tarif_HC
value_template: >-
{% if states('sensor.wesheurecreuseraw') == 'H. Creuses' %}
1
wespcewatt :
friendly_name: wespcewatt
value_template: >-
{{ states.sensor.weshomeval.attributes["array"][2]["value"] }}
wesvewatt :
friendly_name: wes_VE_Watt
device_class : power
unit_of_measurement: 'W'
value_template: >-
{{ (states('sensor.wespcewatt').split(",")[1]) }}
wesgeneralwatt :
friendly_name: wes_general_Watt
value_template: >-
{{ (states('sensor.wespcewatt').split(",")[2]) }}
wesgaragewatt :
friendly_name: wes_garage_Watt
value_template: >-
{{ (states('sensor.wespcewatt').split(",")[3]) }}
weslocalpiscinewatt :
friendly_name: wes_localpiscine_Watt
value_template: >-
{{ (states('sensor.wespcewatt').split(",")[4]) }}
wesrl1 :
friendly_name: wesrl1
value_template: >-
{{ states.sensor.weshomeval.attributes["bssw"][0]["value"] }}
wessw :
friendly_name: wes_switch_virtuel
value_template: >-
{{ states.sensor.weshomeval.attributes["java"][74]["value"] }}
wessw1 :
friendly_name: wes_switch_virtuel_1_VE_Now
value_template: "{{ ((states('sensor.wessw') | float ) - (states('sensor.wessw') | float // 2 * 2)) | int }}"
wessw2 :
friendly_name: wes_switch_virtuel_2_VE_HC
value_template: "{{ (((states('sensor.wessw') | float ) - (states('sensor.wessw') | float // 4 * 4)) // 2 ) | int }}"
wessw3 :
friendly_name: wes_switch_virtuel_3_VE_Surplus
value_template: "{{ (((states('sensor.wessw') | float ) - (states('sensor.wessw') | float // 8 * 8)) // 4 ) | int }}"
- platform: rest
resource: http://192.168.1.80/tic1.cgx
method: GET
username: admin
password: wes
json_attributes_path: "$.data"
json_attributes:
- "tic1"
sensors:
westichp :
friendly_name: wes_tic_hp
unit_of_measurement: 'Wh'
value_template: >-
{{ states.sensor.westic.attributes["tic1"]["HCHP"] | float }}
westichc :
friendly_name: wes_tic_hc
value_template: >-
{{ states.sensor.westic.attributes["tic1"]["HCHC"]| float }}
westicinj :
friendly_name: wes_tic_injection
value_template: >-
{{ states.sensor.westic.attributes["tic1"]["INJECTION"]| float }}
westiciinst :
friendly_name: wes_tic_i_instantanne
unit_of_measurement: 'A'
value_template: >-
{{ states.sensor.westic.attributes["tic1"]["IINST"]| float }}
westension :
friendly_name: wes_tic_tension
unit_of_measurement: 'V'
value_template: >-
{{ states.sensor.westic.attributes["tic1"]["TENSION1"]| float }}
