Depuis quasi 2 semaines je n’arrive plus à démarrer l’intégration Netatmo
J’avais déjà eu le même soucis avec la version 2022.3 mais c’était revenu assez vite alors que là vraiment je n’arrive plus à rien malgré avoir essayé pas mal de choses (redémarrage box, renouvellement ip publique, màj api netatmo, etc …)
Voilà le log :
Logger: homeassistant.config_entries
Source: components/netatmo/data_handler.py:166
First occurred: 12:31:22 (1 occurrences)
Last logged: 12:31:22
Error setting up entry Configuration.yaml for netatmo
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 986, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore[return-value] # noqa
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1056, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1041, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 955, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 502, in sock_connect
return await fut
File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 537, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('169.254.182.25', 80)
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 335, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 144, in async_setup_entry
await data_handler.async_setup()
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 108, in async_setup
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 210, in register_data_class
await self.async_fetch_data(data_class_entry)
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 166, in async_fetch_data
await self.data[data_class_entry].async_update()
File "/usr/local/lib/python3.9/site-packages/pyatmo/camera.py", line 649, in async_update
await self._async_update_all_camera_urls()
File "/usr/local/lib/python3.9/site-packages/pyatmo/camera.py", line 659, in _async_update_all_camera_urls
await self.async_update_camera_urls(camera_id)
File "/usr/local/lib/python3.9/site-packages/pyatmo/camera.py", line 724, in async_update_camera_urls
] = await self._async_check_url(
File "/usr/local/lib/python3.9/site-packages/pyatmo/camera.py", line 731, in _async_check_url
resp = await self.auth.async_post_request(url=f"{url}/command/ping")
File "/usr/local/lib/python3.9/site-packages/pyatmo/auth.py", line 335, in async_post_request
async with self.websession.post(
File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 1138, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 535, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1206, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1175, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 992, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 169.254.182.25:80 ssl:default [Connect call failed ('169.254.182.25', 80)]
System Health
| version |
core-2022.5.5 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.9.9 |
| os_name |
Linux |
| os_version |
5.15.32-v8 |
| arch |
aarch64 |
| timezone |
Europe/Paris |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
5000 |
| Installed Version |
1.25.2 |
| Stage |
running |
| Available Repositories |
1053 |
| Downloaded Repositories |
26 |
| logged_in |
true |
| subscription_expiration |
27 juin 2022, 02:00 |
| relayer_connected |
true |
| remote_enabled |
true |
| remote_connected |
true |
| alexa_enabled |
false |
| google_enabled |
true |
| remote_server |
eu-west-2-1.ui.nabu.casa |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 8.1 |
| update_channel |
stable |
| supervisor_version |
supervisor-2022.05.3 |
| docker_version |
20.10.14 |
| disk_total |
109.3 GB |
| disk_used |
11.3 GB |
| healthy |
true |
| supported |
true |
| board |
rpi4-64 |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
File editor (5.3.3), Z-Wave JS to MQTT (0.41.0), Terminal & SSH (9.4.0), Samba share (9.6.1), Home Assistant Google Drive Backup (0.107.2), Enedisgateway2mqtt (0.7.7-3), Mosquitto broker (6.1.2), Zigbee2mqtt (1.25.1-1) |
| dashboards |
3 |
| resources |
21 |
| views |
17 |
| mode |
storage |
