Bonjour j’ai acheté une passerelle wifi zigbee gateway ZXGWZ-04
sur le cloud de tuya je récupère la cle local RAS
Ensuite sur HA lors de l’intégration le boitier est bien reconnu mais j’ai ce message :
"Connection to device succeeded but no datapoints found, please try again. Create a new issue and include debug logs if problem persists. "
avez vous une idée…
je pensais avec ce boitier étendre ma couverture zigbee
Merci bcp Gilles
Renseigner votre problème
System Health
version: core-2021.11.3
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.17-v7
arch: armv7l
timezone: Europe/Paris
GitHub API: ok
Github API Calls Remaining: 4944
Installed Version: 1.17.2
Stage: running
Available Repositories: 920
Installed Repositories: 8
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 6.6
update_channel: stable
supervisor_version: supervisor-2021.10.8
docker_version: 20.10.8
disk_total: 27.9 GB
disk_used: 4.8 GB
healthy: true
supported: true
board: rpi3
supervisor_api: ok
version_api: ok
installed_addons: File editor (5.3.3), ESPHome (2021.11.1), Terminal & SSH (9.2.1), Samba share (9.5.1), Mosquitto broker (6.0.1), Node-RED (10.1.0)
dashboards: 1
resources: 0
mode: storage___
