Integration Renault HS
Est ce que l’intégration Renault fonctionne de votre coté ? ca fonctionne plus depuis hier de mon coté
Logger: homeassistant.config_entries
Source: components/renault/coordinator.py:55
First occurred: 08:03:42 (3 occurrences)
Last logged: 11:14:43
Error setting up entry Renault for renault
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 388, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/renault/__init__.py", line 30, in async_setup_entry
    await renault_hub.async_initialise(config_entry)
  File "/usr/src/homeassistant/homeassistant/components/renault/renault_hub.py", line 62, in async_initialise
    await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/components/renault/renault_hub.py", line 93, in async_initialise_vehicle
    await vehicle.async_initialise()
  File "/usr/src/homeassistant/homeassistant/components/renault/renault_vehicle.py", line 116, in async_initialise
  File "/usr/src/homeassistant/homeassistant/components/renault/coordinator.py", line 78, in async_config_entry_first_refresh
    await self._async_refresh(log_failures=False, raise_on_auth_failed=True)
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/components/renault/coordinator.py", line 55, in _async_update_data
    return await self.update_method()
  File "/usr/local/lib/python3.11/site-packages/renault_api/renault_vehicle.py", line 131, in get_battery_status
    response = await self.session.get_vehicle_data(
  File "/usr/local/lib/python3.11/site-packages/renault_api/renault_session.py", line 221, in get_vehicle_data
    return await kamereon.get_vehicle_data(
  File "/usr/local/lib/python3.11/site-packages/renault_api/kamereon/__init__.py", line 305, in get_vehicle_data
    await request(
  File "/usr/local/lib/python3.11/site-packages/renault_api/kamereon/__init__.py", line 123, in request
    async with websession.request(
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1141, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 560, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 899, in start
    message, payload = await protocol.read()  # type: ignore[union-attr]
  File "/usr/local/lib/python3.11/site-packages/aiohttp/streams.py", line 616, in read
    await self._waiter
asyncio.exceptions.CancelledError: aiohttp connection lost
Loïc
Effectivement ça déconne un peu en ce moment, même l’appli android.
Fred
merci, ca refonctionne depuis hier soir
