2023-01-02 19:28:16.416 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration braviatv_psk which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.425 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration programmable_thermostat which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.431 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration climate_group which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.436 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.441 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.455 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration tapo_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.465 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration xiaomi_miot_raw which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.470 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.476 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.482 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:16.487 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-02 19:28:35.674 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2023-01-02 19:28:48.043 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [platform] is an invalid option for [automation]. Check: automation->platform. (See /config/configuration.yaml, line 25).
2023-01-02 19:28:48.194 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [platform] is an invalid option for [automation]. Check: automation->platform. (See /config/configuration.yaml, line 25).
2023-01-02 19:28:57.425 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2023-01-02 19:28:57.430 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2023-01-02 19:28:57.433 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2023-01-02 19:28:57.437 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2023-01-02 19:29:07.069 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2023-01-02 19:29:07.072 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2023-01-02 19:29:07.075 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2023-01-02 19:29:07.077 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2023-01-02 19:29:16.855 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7b3dd510>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:29:16.878 WARNING (MainThread) [homeassistant.config_entries] Config entry '192.168.1.49' for tapo_control integration not ready yet: None; Retrying in background
2023-01-02 19:29:17.704 ERROR (Thread-4) [tuya_iot] error while get mqtt config
2023-01-02 19:29:17.754 ERROR (Thread-4) [root] Uncaught thread exception
File "/usr/local/lib/python3.10/threading.py", line 1016, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.10/site-packages/tuya_iot/openmq.py", line 161, in run
time.sleep(self.mq_config.expire_time - 60)
AttributeError: 'NoneType' object has no attribute 'expire_time'
2023-01-02 19:29:21.672 WARNING (zeroconf-ServiceBrowser-_googlecast._tcp-115) [pychromecast.dial] Failed to determine cast type for host <unknown> (<urlopen error [Errno 113] Host is unreachable>) (services:{ServiceInfo(type='mdns', data='BRAVIA-4K-UR2-6d52d1f826e04dc4efbe7d04b88e8f76._googlecast._tcp.local.')})
2023-01-02 19:29:23.713 ERROR (Thread-7) [pychromecast.socket_client] [Télé du salon(192.168.1.40):8009] Failed to connect to service ServiceInfo(type='mdns', data='BRAVIA-4K-UR2-6d52d1f826e04dc4efbe7d04b88e8f76._googlecast._tcp.local.'), retrying in 5.0s
2023-01-02 19:29:29.250 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f836bb850>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:29:29.321 WARNING (MainThread) [homeassistant.components.kodi.media_player] Unable to connect to Kodi via websocket
2023-01-02 19:29:35.684 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities switch.two_way_temperature_and_humidity_switch_switch_1 or it is/they are currently not available
2023-01-02 19:29:40.152 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f737b0a90>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:29:59.550 WARNING (MainThread) [homeassistant.helpers.entity] Update of camera.tapo_camera_2_hd_stream is taking over 10 seconds
2023-01-02 19:30:01.815 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6ef037c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:30:07.490 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 19:30:12.520 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 19:30:41.843 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8d2816c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:32:01.872 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6eb3da80>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:32:07.462 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 19:32:07.637 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 19:33:21.894 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6ebf4fd0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:34:41.916 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8e6b0610>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:36:01.939 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f72fbc340>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:36:39.489 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 19:37:21.962 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e640e80>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:38:37.475 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 19:38:41.991 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e8321d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:38:42.512 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 19:40:02.014 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d7f4160>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:40:37.481 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 19:40:37.656 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 19:41:22.036 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d82c0a0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:42:42.064 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d82fd90>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:43:39.585 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 19:44:02.114 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d861030>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:45:22.146 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d82fee0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:45:37.552 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 19:45:42.575 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 19:46:42.175 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a347340>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:47:37.557 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 19:47:37.731 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 19:48:02.229 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a348250>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:49:22.269 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a370310>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:50:42.290 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3ad2d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:52:02.314 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a38c4f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:53:09.634 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 19:53:22.348 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3b2ad0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:54:42.370 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a38cbb0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:55:07.586 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 19:55:12.605 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 19:56:02.396 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a349540>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:57:07.591 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 19:57:09.790 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 19:57:22.419 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3359f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:58:42.483 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a334e50>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 19:59:09.635 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:00:03.447 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e647550>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:01:07.603 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:01:12.629 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:01:23.468 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d7d4a00>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:02:43.492 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a346470>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:03:07.606 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:03:09.789 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:04:03.516 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d7d78e0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:05:23.546 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e796f20>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:05:39.652 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:06:43.586 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e76fee0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:07:37.619 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:07:42.638 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:08:03.615 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6f949030>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:09:23.663 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e87be50>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:09:37.624 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:09:37.800 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:10:43.704 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f83afdc60>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:12:03.734 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d863070>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:12:37.634 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:13:24.213 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3aefe0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:14:37.637 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:14:44.246 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e5f7220>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:16:04.272 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6828afb0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:16:39.682 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:17:24.302 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d82ee90>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:18:37.647 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:18:42.668 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:18:44.324 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6828b250>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:20:04.369 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f682e2620>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:20:37.652 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:20:37.839 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:21:24.392 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f682f4b50>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:22:39.682 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:22:44.417 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6701edd0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:24:04.441 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f682e15a0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:24:37.659 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:24:42.678 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:25:24.464 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f682e0520>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:26:37.663 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:26:42.680 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:26:44.490 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f670338e0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:26:47.709 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:26:47.721 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Failed to restart Bluetooth scanner: hci0 (B8:27:EB:8F:E0:0C): Failed to start Bluetooth: [org.bluez.Error.NotReady] Resource Not Ready
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 229, in _async_start
await self.scanner.start() # type: ignore[no-untyped-call]
File "/usr/local/lib/python3.10/site-packages/bleak/__init__.py", line 156, in start
await self._backend.start()
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/scanner.py", line 191, in start
self._stop = await manager.active_scan(
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/manager.py", line 357, in active_scan
assert_reply(reply)
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/utils.py", line 20, in assert_reply
raise BleakDBusError(reply.error_name, reply.body)
bleak.exc.BleakDBusError: [org.bluez.Error.NotReady] Resource Not Ready
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 364, in _async_scanner_watchdog
await self._async_start()
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 310, in _async_start
raise ScannerStartError(
homeassistant.components.bluetooth.scanner.ScannerStartError: hci0 (B8:27:EB:8F:E0:0C): Failed to start Bluetooth: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:27:09.852 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:28:04.519 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3d4790>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:29:24.548 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6701eb00>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:29:39.714 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:30:44.570 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f67033340>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:31:37.675 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:31:42.691 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:32:04.677 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6704b7c0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:33:24.711 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f670b0ee0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:33:37.752 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:33:37.936 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:34:44.760 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6704a9b0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:35:39.714 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:36:04.786 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f670e4e20>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:37:24.809 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f820cbb80>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:37:37.692 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:37:42.711 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:38:44.849 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f66e46cb0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:39:37.698 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:39:39.928 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:40:04.886 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f66e770a0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:41:24.929 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f820ca6e0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:42:09.729 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:42:44.961 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f820ae470>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:44:04.996 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f670c2260>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:44:07.710 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:44:12.734 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:45:25.025 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6709ae90>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:46:07.712 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:46:09.957 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:46:45.048 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f67041660>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:48:05.071 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f67042680>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:49:09.761 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:49:25.096 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6701df00>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:50:45.125 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f682b16f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:51:07.727 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:51:12.747 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:52:05.148 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f682b2710>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:52:41.076 WARNING (Thread-9) [pychromecast.socket_client] [Google nest(192.168.1.116):8009] Heartbeat timeout, resetting connection
2023-01-02 20:53:07.732 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:53:09.975 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 20:53:11.090 ERROR (Thread-9) [pychromecast.socket_client] [Google nest(192.168.1.116):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.116', 8009)), retrying in 5.0s
2023-01-02 20:53:26.991 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f73c96ef0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:54:47.549 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f670405b0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:55:39.778 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:56:00.720 WARNING (Thread-9) [pychromecast.socket_client] [Google nest(192.168.1.116):8009] Heartbeat timeout, resetting connection
2023-01-02 20:56:07.575 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f682c60e0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:57:27.596 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f66e47820>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:57:37.742 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 20:57:42.761 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 20:58:47.622 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f83172560>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 20:59:37.747 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 20:59:39.930 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 21:00:07.649 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3350f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:01:27.680 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a40c3d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:02:09.794 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:02:47.705 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3b3580>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:04:07.732 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f68296c20>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:04:07.758 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:05:27.764 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3ac070>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:06:09.795 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:06:47.798 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a362320>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:08:07.773 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:08:07.864 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d8329b0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:08:12.805 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 21:09:27.894 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a363ee0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:10:07.776 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 21:10:07.950 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 21:10:47.932 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d7bb280>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:12:07.981 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d7bb010>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:13:09.826 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:13:28.016 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d7d4760>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:14:48.042 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a334040>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:15:07.784 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:15:12.805 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] could not be reset due to timeout
2023-01-02 21:16:08.090 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6d7d5840>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:17:07.788 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.NotReady] Resource Not Ready
2023-01-02 21:17:09.977 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [B8:27:EB:8F:E0:0C] successfully turned back ON
2023-01-02 21:17:28.115 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e862800>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:18:48.141 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e888400>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:19:09.857 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:20:08.185 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e5eaf50>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:21:07.798 ERROR (MainThread) [homeassistant.components.bluetooth.scanner] hci0 (B8:27:EB:8F:E0:0C): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
2023-01-02 21:21:28.216 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6edc0eb0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:22:48.246 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f83427880>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:24:08.271 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6e76e8f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:25:28.297 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7b3d5ab0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:26:48.324 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6a3acdf0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-02 21:28:08.547 ERROR (MainThread) [custom_components.tapo_control] Unable to connect to Tapo: Cameras Control controller: HTTPSConnectionPool(host='192.168.1.49', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f66e746d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
