Bonjour à tous
Je vous contacte car j’ai un souci sur mon HA test qui est installé en HA supervised sur PI4 via https://yyyy.duckdns.org:8234 (probablement non lié, j’ai également un HA prod disponible en VM HA OS via https://xxx.duckdns.org:8123.
Les containers se lancent, mais il subsiste les éléments d’HACS qui ne se chargent pas :
Du coup probablement, le Vérifier la configuration tourne en rond.
Voyez-vous ce qui peut clocher ?
Merci beaucoup pour votre aide !
##Le log de Home Assistant Core (normal)
2023-09-17 18:16:56.793 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration climate_group which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.808 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration signal_ecogaz which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.815 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.841 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration plant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.868 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration eufy_security which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.879 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.886 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration waste_collection_schedule which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.889 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration google_fit which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.897 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.900 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration deebot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.902 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.905 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration variable which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.907 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.911 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration blitzortung which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.913 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hpprinter which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.915 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration googlewifi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.958 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration home_connect_alt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.961 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration prixCarburant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.971 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration ble_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.983 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration tplink_easy_smart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:56.985 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration daikin_residential which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:57.020 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration rte_ecowatt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:57.023 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration pollens which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:57.027 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration ssh which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:57.047 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration keyatome which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:57.050 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration ezviz_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-17 18:16:57.054 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration freebox_player which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
[center]## System Information
| version |
core-2023.9.2 |
| installation_type |
Home Assistant Supervised |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.11.5 |
| os_name |
Linux |
| os_version |
6.1.21-v8+ |
| arch |
aarch64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
5000 |
| Installed Version |
1.32.1 |
| Stage |
null |
| Available Repositories |
1372 |
| Downloaded Repositories |
60 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Debian GNU/Linux 11 (bullseye) |
| update_channel |
stable |
| supervisor_version |
supervisor-2023.09.2 |
| agent_version |
1.5.1 |
| docker_version |
24.0.5 |
| disk_total |
915.6 GB |
| disk_used |
42.8 GB |
| healthy |
true |
| supported |
failed to load: Unsupported |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Duck DNS (1.15.0), ESPHome (1.16.2), Eufy Security Add-on (1.3.0), File editor (5.6.0), Home Assistant Google Drive Backup (0.111.1), Mosquitto broker (6.3.1), RTSP Simple Server Add-on (v0.17.6), Samba Backup (5.2.0), Samba share with features (10.0.2.3), Terminal & SSH (9.7.1), Zigbee2MQTT (1.33.0-1) |
| dashboards |
1 |
| resources |
39 |
| views |
15 |
| mode |
storage |
| oldest_recorder_run |
17 septembre 2023 à 03:00 |
| current_recorder_run |
17 septembre 2023 à 18:17 |
| estimated_db_size |
29.16 MiB |
| database_engine |
sqlite |
| database_version |
3.41.2 |
Spotify
| api_endpoint_reachable |
ok |
[/center]
Dans votre HA, Menu latéral `Paramètres` > `Système` > `Corrections` puis les trois petits points en haut a droite > `Informations Système` puis une fois en bas `Copier`
