yousaf465
Quick fix: Seems like the issue is with the fan platform, if you do not use the fan platform, you may exclude it from the config flow temporarily until a correct fix
in custom_components/localtuya/const.py line 49 change:
# Platforms in this list must support config flows
PLATFORMS = ["binary_sensor", "cover", "fan", "light", "sensor", "switch"]
to:
PLATFORMS = ["binary_sensor", "cover", "light", "sensor", "switch"]
donc dans \homeassistant\config\custom_components\localtuya\const.py
ligne 49, remplacer
PLATFORMS = [« binary_sensor », « cover », « fan », « light », « sensor », « switch »]
par
PLATFORMS = [« binary_sensor », « cover », « light », « sensor », « switch »]
testé et approuvé : mes devices refonctionnent à nouveau après modification du fichier et un reboot de HA.
Logger: tuya_iot
Source: /usr/local/lib/python3.9/site-packages/tuya_iot/openmq.py:161
First occurred: 17:56:03 (1 occurrences)
Last logged: 17:56:03
error while get mqtt config
Logger: homeassistant.helpers.integration_platform
Source: loader.py:620
First occurred: 17:56:08 (6 occurrences)
Last logged: 17:56:08
Unexpected error importing tuya/diagnostics.py
Unexpected error importing tuya/logbook.py
Unexpected error importing tuya/media_source.py
Unexpected error importing tuya/group.py
Unexpected error importing tuya/system_health.py
File "/usr/src/homeassistant/homeassistant/helpers/integration_platform.py", line 34, in _process
platform = integration.get_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 603, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 620, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 984, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'custom_components.tuya_v2.recorder'
Mais tous fonctionne…
J’ai eu hier une notification mais pour l’aspirateur Xiaomi
J’ai aussi ce message :
Logger: homeassistant.components.filesize.sensor
Source: components/filesize/sensor.py:79
Integration: File Size (documentation, issues)
First occurred: 17:55:58 (1 occurrences)
Last logged: 17:55:58
Configuration of the Filesize sensor platform in YAML is deprecated and will be removed in Home Assistant 2022.6; Your existing configuration has been imported into the UI automatically and can be safely removed from your configuration.yaml file
Mais je sais pas quoi en faire, pas bien compris le problème ?
Bonjour a tous,
Je partage le même problème que toi @bentou, j’ai passé la 2022.04 dimanche et depuis perdu mes spot ‹ wifi › et 2 lumières ‹ wifi ›.
@Pulpy-Luke , j’ai aussi fait la mise à jour de LocalTuya, sans amélioration… @bentou j’ai aussi suivi ton conseil en retirant ‹ fan › dans le fichier \const.py sans succès
J’ai tenté toutes les manip proposées, relaod mes version de LocalTuya, en v3.5, en master…rien !
Bouh, du coup retour en 2022.3.5, mais au moins tout fonctionne
Je n’est pas eu de soucis de migration vers le core 2022.4 et avec localtuya ( je suis même en version 2022.4.3).
Je me posais la question si vos problème ne viendrais pas d’une configuration de localtuya dans le configuration.yaml ? Car depuis que j’utilise localtuya, j’ai configurer tout les appareilles par le UI et non par YAML.
je suis désolé, j’ai attrappé une belle grippe, je suis completement HS. il vaut mieux que je ne touche pas à ma configuration avant d’avoir les yeux en face des trous.
j’avais ceci dans le configuration.yaml
mais j’ai tout retiré il y a un bon moment, le remède était pire que le mal.
pour les prises connectées, pas de problèmes, mais avec les spots c’est déjà moins facile à gérer de bout en bout.
pour info, ce sont ces ampoules Trust.com - Smart WiFi LED spot GU10 white ambience vu comme « Trust WiFi White Ambience (wcuan7llorpdbht7) » par Tuya
là tout de suite, j’ai les spots en tuya-cloud et les prises connectées en localTuya.
j’ai utiliser ce document pour configurer mes spots moes gu10 rgbcw Known working and non working devices · rospogrigio/localtuya Wiki · GitHub.
dans la doc il parle de id 1 ou 20 pour on/off, toi tu as le 4. après peu être ton model juste white est en 4.
Comme pour les températures tu as 2700-6500k et sur ta page trust c’est annoncé 1800-6500k, a vérifier les vrai valeurs de ton model.
Passe par le configuration UI, c’est mieux je trouve et on vois la liste des ids de ton model, juste a sélectionner le bon dans chaque case.
