* Error adding entities for domain sensor with platform hassio
- Error while setting up hassio platform for sensor
Bonjour à toutes et à tous,
Ci-dessus le titre de mes 2 premières erreurs apparues dans la journal de HA. Voici le détail communiqué par HA :
<Logger: homeassistant.components.sensor
Source: helpers/entity_registry.py:1025
Integration: Capteur (documentation, issues)
First occurred: 16:15:06 (2 occurrences)
Last logged: 16:15:06
File « /usr/src/homeassistant/homeassistant/helpers/entity_platform.py », line 507, in async_add_entities
await asyncio.gather(*tasks)
File « /usr/src/homeassistant/homeassistant/helpers/entity_platform.py », line 563, in _async_add_entity
entity.add_to_platform_start(
File « /usr/src/homeassistant/homeassistant/components/sensor/init.py », line 211, in add_to_platform_start
self._async_read_entity_options()
File « /usr/src/homeassistant/homeassistant/components/sensor/init.py », line 785, in _async_read_entity_options
registry.async_update_entity_options(
File « /usr/src/homeassistant/homeassistant/helpers/entity_registry.py », line 1025, in async_update_entity_options
old = self.entities[entity_id]
File « /usr/local/lib/python3.11/collections/init.py », line 1126, in getitem
raise KeyError(key)
KeyError: None>
Comment puis-je corriger cela ?
Anthony
| version |
core-2023.9.2 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.11.5 |
| os_name |
Linux |
| os_version |
6.1.45 |
| arch |
x86_64 |
| timezone |
Europe/Brussels |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
4958 |
| Installed Version |
1.32.1 |
| Stage |
running |
| Available Repositories |
1295 |
| Downloaded Repositories |
4 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 10.5 |
| update_channel |
stable |
| supervisor_version |
supervisor-2023.09.2 |
| agent_version |
1.5.1 |
| docker_version |
23.0.6 |
| disk_total |
234.0 GB |
| disk_used |
5.8 GB |
| healthy |
true |
| supported |
true |
| board |
generic-x86-64 |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Z-Wave JS (0.1.90), File editor (5.6.0), Terminal & SSH (9.7.1), Samba share (10.0.2) |
| dashboards |
2 |
| resources |
1 |
| views |
2 |
| mode |
storage |
| oldest_recorder_run |
17 septembre 2023 à 08:32 |
| current_recorder_run |
24 septembre 2023 à 16:14 |
| estimated_db_size |
10.89 MiB |
| database_engine |
sqlite |
| database_version |
3.41.2 |
Bj
pour commencé met le journal d’erreur dans les </> pour formaté le texte et avoir une meilleur lecture
A part donné les info d’une erreur tu explique pas comment celle ci est arrivé
Apres installe d’un addon, a cause d’un sensor que tu as crée autres ?
As tu essayé de faire quelque chose de particulier ??
tu dois pouvoir cliqué sur documentation/issues dans
cela va t’amene sur les même souci que tu as et peut etre trouvé une solution
Merci pour ta réponse. Le problème est parti tout seul …
Bon dimanche
