Bonsoir,
Je possède deux caméras Mi Home Security 360, et un Mi air Purificateur 3H, le tout sans gateway, juste enregistrer sur l’application Xiamo Home.
Est-il possible de les récupérer sous Home Assistant ?
Faut-il absolument une gateway Xiaomi et si oui laquelle car je m’y perd un peu entre les différente « V3 »
D’avance merci pour votre aide
System Health
version | core-2021.4.6 |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.7 |
os_name | Linux |
os_version | 5.4.109 |
arch | x86_64 |
timezone | Europe/Paris |
GitHub API | ok |
Github API Calls Remaining | 4956 |
Installed Version | 1.12.1 |
Stage | running |
Available Repositories | 778 |
Installed Repositories | 7 |
logged_in | true |
subscription_expiration | 1 janvier 2018, 1:00 |
relayer_connected | false |
remote_enabled | false |
remote_connected | false |
alexa_enabled | false |
google_enabled | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 5.13 |
update_channel | stable |
supervisor_version | supervisor-2021.04.0 |
docker_version | 19.03.15 |
disk_total | 292.7 GB |
disk_used | 22.5 GB |
healthy | true |
supported | true |
board | intel-nuc |
supervisor_api | ok |
version_api | ok |
installed_addons | Samba share (9.3.1), File editor (5.3.0), Check Home Assistant configuration (3.7.1), Node-RED (9.0.1), Terminal & SSH (9.1.1), Samba Backup (4.5.0), MariaDB (2.3.0), Visual Studio Code (3.3.0), phpMyAdmin (0.4.0), Zigbee2mqtt (1.18.3-1), Mosquitto broker (5.1.1) |
Lovelace
dashboards | 1 |
resources | 3 |
views | 8 |
mode | storage |
