Salutation,
je subit toujours des microcoupures sur mon reseau zigbee, je vous joins la copie du journl et des logs :
14:03:05:156 device state timeout ignored in state 3
14:03:06:206 device state timeout ignored in state 3
14:03:08:006 don't close database yet, keep open for 900 seconds
14:03:09:839 device state timeout ignored in state 3
14:03:11:840 device state timeout ignored in state 3
14:03:12:370 Current channel 25
14:03:12:380 Device TTL 3004 s flags: 0x7
14:03:12:396 no button map for: lumi.sensor_motion.aq2 ep: 0x01 cl: 0x0000 cmd: 0x0A pl[0]: 001
14:03:12:396 ZCL attribute report 0x00158D00036B99BC for cluster: 0x0000, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
14:03:12:396 0x00158D00036B99BC extract Xiaomi special attribute 0xFF01
14:03:12:396 01 battery 3005 (0x0BBD)
14:03:12:396 03 temperature 26 °C
14:03:12:396 04 unknown 5032 (0x13A8)
14:03:12:396 05 RSSI dB (?) 76 (0x004C)
14:03:12:396 06 LQI (?) 4294967296 (0x0100000000)
14:03:12:396 0a unknown 0 (0x0000)
14:03:12:396 64 on/off 0
14:03:12:396 0b lightlevel 1 (0x0001)
14:03:13:839 device state timeout ignored in state 3
14:03:13:888 dev /dev/ttyAMA0
14:03:13:889 GW firmware version: 0x264a0700
14:03:16:118 device state timeout ignored in state 3
14:03:35:938 don't close database yet, keep open for 900 seconds
14:03:35:940 no button map for: lumi.sensor_ht ep: 0x01 cl: 0x0000 cmd: 0x0A pl[0]: 001
14:03:35:940 ZCL attribute report 0x00158D0003CBBEEB for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000
14:03:35:940 0x00158D0003CBBEEB extract Xiaomi special attribute 0xFF01
14:03:35:940 01 battery 2985 (0x0BA9)
14:03:35:940 04 unknown 13224 (0x33A8)
14:03:35:940 05 RSSI dB (?) 17 (0x0011)
14:03:35:940 06 LQI (?) 8589934592 (0x0200000000)
14:03:35:940 64 temperature 2112
14:03:35:940 65 humidity 5599
14:03:35:940 0a unknown 0 (0x0000)
14:03:35:956 Remove websocket 172.30.32.1:45094 after error Unknown error
14:03:35:957 timeout on poll APS confirm
14:03:36:008 dev /dev/ttyAMA0
14:03:36:009 GW firmware version: 0x264a0700
14:03:36:034 0x00124B001EA81F46 error APSDE-DATA.confirm: 0xA7 on task
14:03:40:115 no button map for: lumi.plug ep: 0x02 cl: 0x000C cmd: 0x0A pl[0]: 055
14:03:40:115 ZCL attribute report 0x00158D00039FB1FA for cluster: 0x000C, ep: 0x02, frame control: 0x18, mfcode: 0x0000
14:03:40:123 no button map for: lumi.remote.b286acn01 ep: 0x01 cl: 0x0000 cmd: 0x0A pl[0]: 001
14:03:40:123 ZCL attribute report 0x00158D000355FC70 for cluster: 0x0000, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
14:03:40:123 0x00158D000355FC70 extract Xiaomi special attribute 0xFF01
14:03:40:123 01 battery 3005 (0x0BBD)
14:03:40:123 03 temperature 29 °C
14:03:40:123 04 unknown 17320 (0x43A8)
14:03:40:123 05 RSSI dB (?) 373 (0x0175)
14:03:40:123 06 LQI (?) 4294967296 (0x0100000000)
14:03:40:123 08 unknown 5129 (0x1409)
14:03:40:123 0a unknown 15795 (0x3DB3)
14:03:44:205 don't close database yet, keep open for 900 seconds
14:03:45:889 dev /dev/ttyAMA0
14:03:45:890 GW firmware version: 0x264a0700
14:03:49:115 device state timeout ignored in state 3
14:03:50:886 New websocket 172.30.32.1:49330 (state: 3)
14:03:55:116 device state timeout ignored in state 3
14:03:55:884 dev /dev/ttyAMA0
14:03:55:884 GW firmware version: 0x264a0700
14:03:57:339 device state timeout ignored in state 3
14:03:58:340 device state timeout ignored in state 3
14:03:59:340 device state timeout ignored in state 3
14:04:03:340 device state timeout ignored in state 3
14:04:05:884 dev /dev/ttyAMA0
14:04:05:885 GW firmware version: 0x264a0700
14:04:06:360 device state timeout ignored in state 3
14:04:10:859 Current channel 25
14:04:10:869 Device TTL 2945 s flags: 0x7
14:04:11:841 device state timeout ignored in state 3
14:04:13:839 device state timeout ignored in state 3
14:04:15:115 device state timeout ignored in state 3
14:04:15:888 dev /dev/ttyAMA0
14:04:15:888 GW firmware version: 0x264a0700
14:04:22:615 device state timeout ignored in state 3
14:04:25:884 dev /dev/ttyAMA0
14:04:25:884 GW firmware version: 0x264a0700
14:04:27:340 device state timeout ignored in state 3
14:04:28:340 device state timeout ignored in state 3
14:04:33:591 ZCL attribute report 0x00158D00039FB1FA for cluster: 0x0000, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
14:04:33:591 0x00158D00039FB1FA extract Xiaomi special attribute 0xFF01
14:04:33:591 64 on/off 0
14:04:33:591 03 temperature 32 °C
14:04:33:591 98 power 0.000000 (0)
14:04:33:591 95 consumption 6.369020 (6369)
14:04:33:591 05 RSSI dB (?) 18 (0x0012)
14:04:33:591 9a unknown 0 (0x00)
14:04:33:591 08 unknown 4898 (0x1322)
14:04:33:591 07 unknown 0 (0x0000000000000000)
14:04:33:591 09 unknown 768 (0x0300)
14:04:34:949 don't close database yet, keep open for 900 seconds
14:04:34:949 device state timeout ignored in state 3
14:04:35:275 0x00124B001EA81F46 error APSDE-DATA.confirm: 0xA7 on task
14:04:35:890 dev /dev/ttyAMA0
14:04:35:890 GW firmware version: 0x264a0700
14:04:36:155 0x00158D00039FB1FA error APSDE-DATA.confirm: 0xA7 on task
14:04:37:342 device state timeout ignored in state 3
14:04:38:339 device state timeout ignored in state 3
14:04:39:340 device state timeout ignored in state 3
14:04:40:340 device state timeout ignored in state 3
14:04:40:791 don't close database yet, keep open for 900 seconds
14:04:43:225 no button map for: lumi.sensor_motion ep: 0x01 cl: 0x0406 cmd: 0x0A pl[0]: 000
elles se produisent pendant de quelques secondes voir dizaines de secondes.
je suis avec une conbee II sans probleme depuis un an.
certains capteurs ont dû retard à émettre leur nouvel état.
vous avez une idée?
