Mon HASS m’informe d’une mise a jour firmware de mon smart Meter Qubino ZMNHTD de 6.5 vers 80.1
Après moultes essais, la mise à jour ne se fait pas.
Avez vous déjà eu ce problème?
[center]## System Information
| version |
core-2025.11.3 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| container_arch |
amd64 |
| user |
root |
| virtualenv |
false |
| python_version |
3.13.9 |
| os_name |
Linux |
| os_version |
6.12.51-haos |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
| HACS Data |
ok |
5000 |
| Installed Version |
2.0.5 |
| Stage |
running |
| Available Repositories |
2468 |
| Downloaded Repositories |
19 |
| logged_in |
true |
| subscription_expiration |
1 janvier 2018 à 01:00 |
| relayer_connected |
false |
| relayer_region |
null |
| remote_enabled |
false |
| remote_connected |
false |
| alexa_enabled |
true |
| google_enabled |
true |
| cloud_ice_servers_enabled |
true |
| remote_server |
null |
| certificate_status |
null |
| instance_id |
922112ff862e406c9e9d77e9a3abefa8 |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 16.3 |
| update_channel |
stable |
| supervisor_version |
supervisor-2025.11.5 |
| agent_version |
1.7.2 |
| docker_version |
28.3.3 |
| disk_total |
46.5 GB |
| disk_used |
10.5 GB |
| nameservers |
192.168.1.254, fd0f:ee:b0::1, 192.168.1.111 |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
kvm |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Matter Server (8.1.1), Z-Wave JS (0.27.0), Studio Code Server (6.0.1), Let’s Encrypt (5.4.9), Advanced SSH & Web Terminal (22.0.3), Node-RED (20.2.3), Samba share (12.5.4), Zigbee2MQTT (2.7.0-1), NGINX Home Assistant SSL proxy (3.14.0) |
| dashboards |
7 |
| resources |
8 |
| views |
29 |
| mode |
storage |
Network Configuration
| adapters |
lo (disabled), enp6s18 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethdd07575 (disabled), vethd43eacd (disabled), veth8808371 (disabled), vethfdf55a2 (disabled), veth3460771 (disabled), vethcab31aa (disabled), veth6b6dd37 (disabled), veth42f7d26 (disabled), veth894f6d5 (disabled) |
| ipv4_addresses |
lo (127.0.0.1/8), enp6s18 (192.168.1.123/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethdd07575 (), vethd43eacd (), veth8808371 (), vethfdf55a2 (), veth3460771 (), vethcab31aa (), veth6b6dd37 (), veth42f7d26 (), veth894f6d5 () |
| ipv6_addresses |
lo (::1/128), enp6s18 (2a01:e0a:2da:49c0:cd7f:4e48:946b:bd17/64, fe80::2698:2019:4ed4:bc13/64), hassio (fd0c:ac1e:2100::1/48, fe80::d0c6:49ff:fe1f:400e/64), docker0 (fe80::741a:45ff:fe19:5632/64), vethdd07575 (fe80::2869:30ff:fe14:2bf0/64), vethd43eacd (fe80::a49a:19ff:fe35:f582/64), veth8808371 (fe80::70f1:85ff:fed8:7c62/64), vethfdf55a2 (fe80::f052:11ff:fe1c:760d/64), veth3460771 (fe80::2a:1eff:fee2:e840/64), vethcab31aa (fe80::38c7:8ff:fe33:17f9/64), veth6b6dd37 (fe80::285e:a9ff:fe49:d7e7/64), veth42f7d26 (fe80::104c:2bff:fef2:b529/64), veth894f6d5 (fe80::1ca0:7cff:fe35:4945/64) |
| announce_addresses |
192.168.1.123, 2a01:e0a:2da:49c0:cd7f:4e48:946b:bd17, fe80::2698:2019:4ed4:bc13 |
| oldest_recorder_run |
20 novembre 2025 à 18:20 |
| current_recorder_run |
1 décembre 2025 à 17:47 |
| estimated_db_size |
736.76 MiB |
| database_engine |
sqlite |
| database_version |
3.49.2 |
[/center]
