Mise à jour impossible 2024.7.2 ou 2024.7.3
Bonjour depuis la mise à jour 2024.7.2 il m’est impossible de faire la mise à jour du core.
version core-2024.7.1
python_version 3.12.4
os_version 6.6.33-haos
arch x86_64
logged_in true
subscription_expiration 14 juin 2025 à 02:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled false
remote_server eu-central-1-20.ui.nabu.casa
certificate_status ready
instance_id 60f57470db854f42802f39211dca9f2d
supervisor_version supervisor-2024.06.2
agent_version 1.6.0
docker_version 26.1.4
disk_total 314.3 GB
disk_used 14.1 GB
virtualization kvm
board ova
installed_addons File editor (5.8.0), Terminal & SSH (9.14.0), Samba share (12.3.1), Duck DNS (1.18.0), Zigbee2MQTT (1.39.0-1), Mosquitto broker (6.4.1), Matter Server (6.3.1), MyElectricalData (0.13.2), InfluxDB (5.0.0), OpenThread Border Router (2.9.0), Home Assistant Google Drive Backup (0.112.1), Samba Backup (5.2.0), MQTT Explorer (browser-1.0.1)
dashboards 4
resources 25
views 55
oldest_recorder_run 11 juillet 2024 à 07:55
current_recorder_run 21 juillet 2024 à 19:23
estimated_db_size 336.13 MiB
database_version 3.45.3
Supervisor
2024-07-21 18:05:47.004 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-07-21 18:05:50.958 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-07-21 18:05:50.959 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-07-21 18:05:50.961 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-07-21 18:05:50.964 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-07-21 18:05:50.965 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-07-21 18:06:16.586 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-07-21 18:06:16.587 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-07-21 18:06:16.588 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-07-21 18:10:13.388 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:10:13.389 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:15:13.333 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:15:13.334 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:20:13.366 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:20:13.367 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:25:13.290 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:25:13.290 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:30:13.391 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:30:13.392 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:34:27.525 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-07-21 18:35:13.285 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:35:13.286 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:40:13.342 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:40:13.342 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:45:13.424 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:45:13.425 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:50:13.308 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:50:13.309 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:54:25.334 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-07-21 18:54:31.003 INFO (MainThread) [supervisor.host.services] Updating service information
2024-07-21 18:54:31.034 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-07-21 18:54:31.751 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-07-21 18:54:31.782 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-07-21 18:55:13.322 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:55:13.322 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 18:56:45.629 INFO (MainThread) [supervisor.backups.manager] Found 7 backup files
2024-07-21 18:56:49.007 INFO (MainThread) [supervisor.backups.manager] Found 7 backup files
2024-07-21 18:56:59.219 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
2024-07-21 18:56:59.227 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
2024-07-21 19:00:13.345 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 19:00:13.345 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 19:02:46.852 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping homeassistant application
2024-07-21 19:06:16.637 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-07-21 19:06:16.638 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-07-21 19:06:16.638 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-07-21 19:06:16.638 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-07-21 19:06:16.639 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-07-21 19:06:16.640 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-07-21 19:06:16.640 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-07-21 19:06:16.641 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-07-21 19:06:16.642 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-07-21 19:06:16.968 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-07-21 19:06:17.080 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-07-21 19:06:17.081 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-07-21 19:06:17.082 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-07-21 19:06:17.082 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-07-21 19:09:01.213 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning homeassistant application
2024-07-21 19:09:10.497 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-07-21 19:09:10.501 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-07-21 19:09:10.502 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-07-21 19:10:37.059 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-07-21 19:11:51.959 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version 2024.7.3
2024-07-21 19:11:51.960 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-07-21 19:14:52.668 ERROR (MainThread) [supervisor.homeassistant.core] No Home Assistant Core response, assuming a fatal startup error
2024-07-21 19:14:52.669 CRITICAL (MainThread) [supervisor.homeassistant.core] HomeAssistant update failed -> rollback!
2024-07-21 19:14:54.253 INFO (MainThread) [supervisor.homeassistant.core] A backup of the logfile is stored in /config/home-assistant-rollback.log
2024-07-21 19:14:54.253 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2024.7.1
2024-07-21 19:14:54.254 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.3 to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1
2024-07-21 19:14:54.255 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.7.1.
2024-07-21 19:15:17.483 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping homeassistant application
2024-07-21 19:15:54.039 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/music-assistant/home-assistant-addon repository
2024-07-21 19:15:54.057 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/adamoutler/mqtt-explorer repository
2024-07-21 19:15:54.078 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
2024-07-21 19:15:54.085 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/thomasmauerer/hassio-addons repository
2024-07-21 19:15:54.102 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
2024-07-21 19:15:54.110 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
2024-07-21 19:15:54.155 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
2024-07-21 19:15:54.160 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
2024-07-21 19:15:54.169 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/alexbelgium/hassio-addons repository
2024-07-21 19:16:11.114 ERROR (SyncWorker_3) [supervisor.utils.json] Can't read json from /data/addons/git/db21ed7f/linkwarden/config.json: trailing comma is not allowed: line 19 column 4 (char 759)
2024-07-21 19:16:11.115 WARNING (SyncWorker_3) [supervisor.store.data] Can't read /data/addons/git/db21ed7f/linkwarden/config.json from repository db21ed7f
2024-07-21 19:16:11.268 WARNING (SyncWorker_3) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Signalk Server
2024-07-21 19:16:13.525 ERROR (SyncWorker_0) [supervisor.utils.json] Can't read json from /data/addons/git/db21ed7f/linkwarden/config.json: trailing comma is not allowed: line 19 column 4 (char 759)
2024-07-21 19:16:13.526 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/db21ed7f/linkwarden/config.json from repository db21ed7f
2024-07-21 19:16:13.683 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Signalk Server
2024-07-21 19:16:14.224 INFO (MainThread) [supervisor.store] Loading add-ons from store: 176 all - 0 new - 1 remove
2024-07-21 19:16:14.225 INFO (MainThread) [supervisor.store] Loading add-ons from store: 176 all - 0 new - 0 remove
2024-07-21 19:16:33.912 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning homeassistant application
2024-07-21 19:16:38.999 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-07-21 19:17:41.208 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version 2024.7.1
2024-07-21 19:17:41.209 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-07-21 19:20:41.861 ERROR (MainThread) [supervisor.homeassistant.core] No Home Assistant Core response, assuming a fatal startup error
2024-07-21 19:23:27.655 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-07-21 19:23:28.139 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-07-21 19:23:28.279 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 19:23:28.280 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 19:23:29.257 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-07-21 19:26:01.794 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2024-07-21 19:26:29.807 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2024-07-21 19:28:28.403 WARNING (MainThread) [supervisor.addons.options] Unknown option 'serial' for Zigbee2MQTT (45df7312_zigbee2mqtt)
2024-07-21 19:28:28.406 WARNING (MainThread) [supervisor.addons.options] Unknown option 'advanced' for Zigbee2MQTT (45df7312_zigbee2mqtt)
Je pense que ton problème vient de ce fichier, et donc de l’addon correspondant.
Merci pour ta réponse, comment je peux savoir à quel addon il s’agit ?
Cest dans le nom du dossier, linkwarden.
Config.json
A priori il y a eu une modif hier, ca corrige peut etre le problème.
Répondre oui tout à fait la mise à jour est passé ce matin.
Merci pour ton aide.
Addon qui a du s’installer avec MyElectricalData.
a regarder sur le sujet specifique myelectricaldata
mais si j’ai bien compris ENEDIS a encore modifié son API, et pour le moment rien ne fonctionne
