Je débute sur HA venant de Domoticz. et ces débuts se passent plutôt bien .
J’accroche pour le moment sur la mise en place de MetersToHA.
J’utilise l’addon MetersToHA sur Ha OS (dernier patchs appliqués) que j’ai installé via module complémentaire en ajoutant le repo.
Jusqu’à la tout va bien, je fais la configuration de la partie Veolia qui m’intéresse, le module démarre.
Dans les logs, aucunes erreurs (CF ci-dessus), les configs semblent bien prise en compte.
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service base-addon-banner: starting
Add-on: MetersToHA
MetersToHA add-on for Home Assistant
Add-on version: dev
You are running the latest version of this add-on.
System: Home Assistant OS 13.0 (amd64 / generic-x86-64)
Home Assistant Core: 2024.8.1
Home Assistant Supervisor: 2024.08.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
Log level is set to DEBUG
s6-rc: info: service base-addon-log-level successfully started
Cloning into 'MetersToHA'...
git checkout
Your branch is up to date with 'origin/meters-to-ha'.
MetersToHA Container version: dev.017 #2815b130869d0d7b049de3b0fc03f3e3 /run.sh
MetersToHA Python GIT version: 30665a2 on Fri Mar 1 17:59:13 2024 +0100
Generate configuration file
Generated configuration file '/m2h_config.json':
"log_level":"debug",
"logs_folder":"/config",
"veolia_login":"xxxxx",
"veolia_password":"xxxxxx",
"veolia_contract":"xxxxxxx",
"timeout":"30",
"download_folder":"/config",
"ha_server": "http://supervisor/core",
"ha_token": "xxxxx",
"type": "ha"
DISPLAY:'xxxxxx:3.0'
EVENT CONF: veolia:call_veolia grdf:call_grdf
=== Generated script '/execEvent.sh': ==========
#!/bin/bash
TARGET_OPT=""
[[ "$1" == "call_veolia" ]] && TARGET_OPT=--veolia
[[ "$1" == "call_grdf" ]] && TARGET_OPT=--grdf
[[ "$1" == "homeassistant_started" ]] && TARGET_OPT="-k --skip-download --veolia --grdf"
[[ "$TARGET_OPT" == "" ]] && ( echo "Unrecognized event '$1'" ; exit 1 )
date
echo "python3 MetersToHA/apps/meters_to_ha/meters_to_ha.py -l /config --display --screenshot --keep-output -c \"/m2h_config.json\" $TARGET_OPT -r"
python3 MetersToHA/apps/meters_to_ha/meters_to_ha.py -l /config --display --screenshot --keep-output -c "/m2h_config.json" $TARGET_OPT -r
# Copy chrome logs
for i in ~/.config/*/chrome_debug.log ; do
[[ -r "$i" ]] || continue
SUBDIR="/config/$(basename "$(dirname "$i")")"
mkdir -p "${SUBDIR}"
cp -p "$i" "${SUBDIR}"
done
echo "Done $(date)"
} >> "/config/m2h_exec.log" 2>&1
=== End of Generated script '/execEvent.sh': ===
Test access to Home Assistant API (should show '{"message":"API running."}')
curl -H 'Authorization: Bearer xxxxxxx ' -H 'Content-Type: application/json' http://supervisor/core/api/
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 26 100 26 0 0 1900 0 --:--:-- --:--:-- --:--:-- 2000
"./haevent2exec.py" --config-json "/m2h_config.json" --external-program "/execEvent.sh" --log-level="debug" call_veolia call_grdf homeassistant_started
[2024/08/14 11:02:02] (haevent2exec.py) INFO Received {'type': 'auth_required', 'ha_version': '2024.8.1'}
[2024/08/14 11:02:02] (haevent2exec.py) INFO Connected
[2024/08/14 11:02:02] (haevent2exec.py) INFO Result of subscription for 'call_veolia': None
[2024/08/14 11:02:02] (haevent2exec.py) INFO Result of subscription for 'call_grdf': None
[2024/08/14 11:02:02] (haevent2exec.py) INFO Result of subscription for 'homeassistant_started': None
[2024/08/14 11:02:02] (haevent2exec.py) INFO send_event_msg: Got id (4,)
[2024/08/14 11:02:02] (haevent2exec.py) INFO Subscribed, waiting for messages
[2024/08/14 11:02:02] (haevent2exec.py) INFO Received WSMessage(type=<WSMsgType.TEXT: 1>, data='{"id":1,"type":"result","success":true,"result":null}', extra='')
[2024/08/14 11:02:02] (haevent2exec.py) INFO Received WSMessage(type=<WSMsgType.TEXT: 1>, data='{"id":2,"type":"result","success":true,"result":null}', extra='')
[2024/08/14 11:02:02] (haevent2exec.py) INFO Received WSMessage(type=<WSMsgType.TEXT: 1>, data='{"id":3,"type":"result","success":true,"result":null}', extra='')
Il semble que je sois pas le seul dans ce cas , est ce que l’addon est toujours fonctionnel ?
Je prends toutes les idées/pistes, merci d’avance.
