J’ai Music assistant d’installer sur HA. Je peux écouter de la musique directement sur mon PC mais si je change d’onglet, je vais sur mon dashboard par exemple la musique se coupe. Il faut que je reste sur l’onglet de Music assistant.
Y’aurait-il une solution pour garder la musique active quand je change d’onglet ?
[center]## System Information
version
core-2025.4.4
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.13.2
os_name
Linux
os_version
6.6.74-haos-raspi
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
5000
Installed Version
2.0.5
Stage
running
Available Repositories
1684
Downloaded Repositories
31
logged_in
true
subscription_expiration
4 mai 2025 à 02:00
relayer_connected
true
relayer_region
eu-central-1
remote_enabled
true
remote_connected
true
alexa_enabled
false
google_enabled
true
cloud_ice_servers_enabled
true
remote_server
eu-central-1-20.ui.nabu.casa
certificate_status
ready
instance_id
7ed66cda8e14435b9413f50d081e0d97
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 15.2
update_channel
stable
supervisor_version
supervisor-2025.04.0
agent_version
1.7.2
docker_version
28.0.4
disk_total
228.5 GB
disk_used
9.0 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Linky (1.5.0), Mosquitto broker (6.5.0), Get HACS (1.3.1), Zigbee2MQTT (2.2.1-1), Samba share (12.5.0), ArgonOne Active Linear Cooling - Classic (30a), ArgonOne Active Linear Cooling (30a), File editor (5.8.0), Network UPS Tools (0.14.1), Music Assistant Server (2.5.2), Terminal & SSH (9.17.0), VLC (0.3.0)
