il semblerais que je n’ai plus beaucoup d’erreur , mais rien ne remonte depuis hier …
Tout ce que les journaux me disent c’est :
2024-11-24 13:57:10.749 - ERROR : Echec de la récupération des données.
2024-11-24 13:57:10.749 - ERROR : => Technical error. Please try later.
2024-11-24 13:57:10.749 - ERROR : => 2024-11-22 -> 2024-11-26
heu … oui !! … MERCI DU RENSEIGNEMENT !!
Si quelqu’un peut me dire vers où chercher …
voici mon journal de démarrage , … , je vois pas ce qui cloche …
Add-on: MyElectricalData
Use Enedis Gateway API to send data in your MQTT Broker (latest channel)
Add-on version: 0.13.2
You are running the latest version of this add-on.
System: Home Assistant OS 13.2 (amd64 / generic-x86-64)
Home Assistant Core: 2024.11.3
Home Assistant Supervisor: 2024.11.4
Please, share the above information when looking for help
or support in, e.g., GitHub, forums
Provided by: https://github.com/alexbelgium/hassio-addons
/etc/cont-init.d/00-global_var.sh: executing
CONFIG_LOCATION='/config/myelectricaldata/config.yaml'
TZ='Europe/Paris'
mqtt_autodiscover='true'
verbose='true'
/etc/cont-init.d/01-config_yaml.sh: executing
Setting permissions for the config.yaml directory
Load environment variables from /config/myelectricaldata/config.yaml if existing
If accessing the file with filebrowser it should be mapped to /homeassistant/addons_config/enedisgateway2mqtt/config.yaml
Wiki here on how to use : github.com/alexbelgium/hassio-addons/wiki/Add‐ons-feature-:-add-env-variables
cycle='14400'
debug='true'
home_assistant_discovery='true'
home_assistant_discovery_prefix='homeassistant'
home_assistant_enable='true'
home_assistant_ws_enable='true'
home_assistant_ws_ssl='false'
home_assistant_ws_token='eyJhbGciOiJIUzI1NiIsInxxxxxxxxxxpGxghTS4okZ8vXfKQ'
home_assistant_ws_url='192.168.0.100:8123'
influxdb_batching_options_batch_size='1000'
influxdb_batching_options_exponential_base='2'
influxdb_batching_options_flush_interval='1000'
influxdb_batching_options_jitter_interval='0'
influxdb_batching_options_max_retries='5'
influxdb_batching_options_max_retry_delay='125000'
influxdb_batching_options_max_retry_time='180000'
influxdb_batching_options_retry_interval='5000'
influxdb_bucket='myelectricaldata'
influxdb_enable='false'
influxdb_hostname='influxdb'
influxdb_method='synchronous'
influxdb_org='myelectricaldata'
influxdb_port='8086'
influxdb_token='myelectricaldata'
log2file='false'
mqtt_client_id='myelectricaldata'
mqtt_enable='true'
mqtt_hostname='core-mosquitto'
mqtt_password='didxxxxx0'
mqtt_port='1883'
mqtt_prefix='myelectricaldata'
mqtt_qos='0'
mqtt_retain='true'
mqtt_username='mqttxxxxxx'
myelectricaldata_04174xxxxxxx262_cache='true'
myelectricaldata_04174xxxxxxx262_consumption='true'
myelectricaldata_04174xxxxxxx62_consumption_detail='true'
myelectricaldata_0417xxxxxxx62_consumption_detail_max_date='2024-11-20'
myelectricaldata_04xxxxxxx62_consumption_max_date='2024-11-22'
myelectricaldata_04xxxxxxx62_consumption_max_power='true'
myelectricaldata_041xxxxxxx262_consumption_price_base='0.175'
myelectricaldata_041xxxxxxx62_consumption_price_hc='0.175'
myelectricaldata_041xxxxxxx262_consumption_price_hp='0.175'
myelectricaldata_04xxxxxxx62_enable='true'
myelectricaldata_0417xxxxxxx62_name='brissy'
myelectricaldata_041xxxxxxx9262_offpeak_hours_0='22H00-6H00'
myelectricaldata_041xxxxxxx62_offpeak_hours_1='22H00-6H00'
myelectricaldata_041xxxxxxx262_offpeak_hours_2='22H00-6H00'
myelectricaldata_04xxxxxxx262_offpeak_hours_3='22H00-6H00'
myelectricaldata_04xxxxxxx62_offpeak_hours_4='22H00-6H00'
myelectricaldata_04xxxxxxx2_offpeak_hours_5='22H00-6H00'
myelectricaldata_041xxxxxxx62_offpeak_hours_6='22H00-6H00'
myelectricaldata_04xxxxxxx62_plan='HC/HP'
myelectricaldata_041xxxxxxx62_production='false'
myelectricaldata_041xxxxxxx262_production_detail='false'
myelectricaldata_04xxxxxxx2_production_price='0.0'
myelectricaldata_04xxxxxxx262_refresh_addresse='true'
myelectricaldata_04xxxxxxx2_refresh_contract='true'
myelectricaldata_041xxxxxxx62_token='n8FJtx2_9iljn_NZDQeump_zMJYRNxxxxxxxg='
wipe_influxdb='false'
/etc/cont-init.d/01-custom_script.sh: executing
Execute /homeassistant/addons_config/enedisgateway2mqtt/enedisgateway2mqtt.sh if existing
Wiki here : github.com/alexbelgium/hassio-addons/wiki/Add-ons-feature-:-customisation
/etc/cont-init.d/32-nginx_ingress.sh: executing
/etc/cont-init.d/91-mqtt_autodiscover.sh: executing
[14:08:28] INFO: mqtt_autodiscover is defined in options, attempting autodiscovery...
[14:08:29] INFO: ... MQTT service found, fetching server detail (you can enter those manually in your config file) ...
MQTT_HOST=core-mosquitto
MQTT_PORT=1883
MQTT_SSL=false
MQTT_USERNAME=addons
MQTT_PASSWORD=ohqueijea9Eij3Kooxxxxxxxo5hee
/etc/cont-init.d/99-run.sh: executing
creating symlink
[14:08:29] INFO: Using database file found in /config/myelectricaldata
[14:08:29] INFO: Using config file found in /config/myelectricaldata/config.yaml
Config file is a valid yaml
[14:08:29] INFO: Starting nginx
[14:08:29] INFO: Starting the app
2024-11-24 14:08:30.477 - INFO : Display configuration :
2024-11-24 14:08:30.477 - INFO : cycle: 14400
2024-11-24 14:08:30.477 - INFO : debug: True
2024-11-24 14:08:30.477 - INFO : home_assistant:
2024-11-24 14:08:30.477 - INFO : discovery: True
2024-11-24 14:08:30.477 - INFO : discovery_prefix: homeassistant
2024-11-24 14:08:30.477 - INFO : enable: True
2024-11-24 14:08:30.477 - INFO : home_assistant_ws:
2024-11-24 14:08:30.478 - INFO : enable: True
2024-11-24 14:08:30.478 - INFO : ssl: False
2024-11-24 14:08:30.478 - INFO : token: ** hidden **
2024-11-24 14:08:30.478 - INFO : url: 19xxxxxxx00:8123
2024-11-24 14:08:30.478 - INFO : influxdb:
2024-11-24 14:08:30.478 - INFO : batching_options:
2024-11-24 14:08:30.478 - INFO : batch_size: 1000
2024-11-24 14:08:30.478 - INFO : exponential_base: 2
2024-11-24 14:08:30.478 - INFO : flush_interval: 1000
2024-11-24 14:08:30.478 - INFO : jitter_interval: 0
2024-11-24 14:08:30.478 - INFO : max_retries: 5
2024-11-24 14:08:30.478 - INFO : max_retry_delay: 125000
2024-11-24 14:08:30.478 - INFO : max_retry_time: 180000
2024-11-24 14:08:30.478 - INFO : retry_interval: 5000
2024-11-24 14:08:30.478 - INFO : bucket: myelectricaldata
2024-11-24 14:08:30.478 - INFO : enable: False
2024-11-24 14:08:30.478 - INFO : hostname: influxdb
2024-11-24 14:08:30.478 - INFO : method: synchronous
2024-11-24 14:08:30.478 - INFO : org: myelectricaldata
2024-11-24 14:08:30.478 - INFO : port: 8086
2024-11-24 14:08:30.478 - INFO : log2file: False
2024-11-24 14:08:30.478 - INFO : mqtt:
2024-11-24 14:08:30.478 - INFO : client_id: myelectricaldata
2024-11-24 14:08:30.478 - INFO : hostname: core-mosquitto
2024-11-24 14:08:30.478 - INFO : password: ** hidden **
2024-11-24 14:08:30.478 - INFO : port: 1883
2024-11-24 14:08:30.478 - INFO : prefix: myelectricaldata
2024-11-24 14:08:30.478 - INFO : qos: 0
2024-11-24 14:08:30.478 - INFO : retain: True
2024-11-24 14:08:30.478 - INFO : username: mqtt
2024-11-24 14:08:30.478 - INFO : myelectricaldata:
2024-11-24 14:08:30.478 - INFO : 04xxxxxxx62:
2024-11-24 14:08:30.478 - INFO : cache: True
2024-11-24 14:08:30.478 - INFO : consumption: True
2024-11-24 14:08:30.479 - INFO : consumption_detail: True
2024-11-24 14:08:30.479 - INFO : consumption_detail_max_date: 2024-11-20
2024-11-24 14:08:30.479 - INFO : consumption_max_date: 2024-11-22
2024-11-24 14:08:30.479 - INFO : consumption_max_power: True
2024-11-24 14:08:30.479 - INFO : consumption_price_base: 0.175
2024-11-24 14:08:30.479 - INFO : consumption_price_hc: 0.175
2024-11-24 14:08:30.479 - INFO : consumption_price_hp: 0.175
2024-11-24 14:08:30.479 - INFO : enable: True
2024-11-24 14:08:30.479 - INFO : name: brissy
2024-11-24 14:08:30.479 - INFO : offpeak_hours_0: 22H00-6H00
2024-11-24 14:08:30.479 - INFO : offpeak_hours_1: 22H00-6H00
2024-11-24 14:08:30.479 - INFO : offpeak_hours_2: 22H00-6H00
2024-11-24 14:08:30.479 - INFO : offpeak_hours_3: 22H00-6H00
2024-11-24 14:08:30.479 - INFO : offpeak_hours_4: 22H00-6H00
2024-11-24 14:08:30.479 - INFO : offpeak_hours_5: 22H00-6H00
2024-11-24 14:08:30.479 - INFO : offpeak_hours_6: 22H00-6H00
2024-11-24 14:08:30.479 - INFO : plan: HC/HP
2024-11-24 14:08:30.479 - INFO : production: False
2024-11-24 14:08:30.479 - INFO : production_detail: False
2024-11-24 14:08:30.479 - INFO : production_detail_max_date:
2024-11-24 14:08:30.479 - INFO : production_max_date:
2024-11-24 14:08:30.479 - INFO : production_price: 0.0
2024-11-24 14:08:30.479 - INFO : refresh_addresse: True
2024-11-24 14:08:30.479 - INFO : refresh_contract: True
2024-11-24 14:08:30.479 - INFO : token: ** hidden **
2024-11-24 14:08:30.479 - INFO : wipe_influxdb: False
2024-11-24 14:08:30.479 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:30.479 - INFO : Check config.yaml :
2024-11-24 14:08:30.479 - INFO : CONFIG VALID
INFO [alembic.runtime.migration] Context impl SQLiteImpl.
INFO [alembic.runtime.migration] Will assume non-transactional DDL.
2024-11-24 14:08:31.052 - INFO : Configure Databases
2024-11-24 14:08:31.077 - INFO : => day
2024-11-24 14:08:31.079 - INFO : => call_number
2024-11-24 14:08:31.081 - INFO : => max_call
2024-11-24 14:08:31.082 - INFO : => version
2024-11-24 14:08:31.084 - INFO : => lock
2024-11-24 14:08:31.085 - INFO : => lastUpdate
2024-11-24 14:08:31.085 - INFO : Success
2024-11-24 14:08:31.085 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.085 - INFO : Connect to MQTT broker core-mosquitto:1883
2024-11-24 14:08:31.089 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.089 - INFO : CONNECTION SUCCESS
/app/models/query_contract.py:40: SyntaxWarning: invalid escape sequence '\('
offpeak_hours = re.search("HC \((.*)\)", contracts["offpeak_hours"]).group(1)
2024-11-24 14:08:31.341 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.342 - INFO : RUN IN PRODUCTION MODE
2024-11-24 14:08:31.342 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.342 - INFO : CHARGEMENT DU CONFIG.YAML...
2024-11-24 14:08:31.342 - INFO : 04xxxxxxx62
2024-11-24 14:08:31.355 - INFO : => Success
2024-11-24 14:08:31.355 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.355 - INFO : NETTOYAGE DE LA BASE DE DONNÉES...
/app/main.py:93: DeprecationWarning:
on_event is deprecated, use lifespan event handlers instead.
Read more about it in the
[FastAPI docs for Lifespan Events](https://fastapi.tiangolo.com/advanced/events/).
@APP.on_event("startup")
/app/main.py:99: DeprecationWarning:
/app/main.py:105: DeprecationWarning:
2024-11-24 14:08:31.387 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.387 - INFO : ▌│█║▌║▌║ __ __ _____ _ _ _ _ ____ _ ║▌║▌║█│▌
2024-11-24 14:08:31.387 - INFO : ▌│█║▌║▌║ | \/ | _ _ | ____|| | ___ ___ | |_ _ __ (_) ___ __ _ | || _ \ __ _ | |_ __ _ ║▌║▌║█│▌
2024-11-24 14:08:31.387 - INFO : ▌│█║▌║▌║ | |\/| || | | || _| | | / _ \ / __|| __|| '__|| | / __| / _` || || | | | / _` || __| / _` | ║▌║▌║█│▌
2024-11-24 14:08:31.387 - INFO : ▌│█║▌║▌║ | | | || |_| || |___ | || __/| (__ | |_ | | | || (__ | (_| || || |_| || (_| || |_ | (_| | ║▌║▌║█│▌
2024-11-24 14:08:31.387 - INFO : ▌│█║▌║▌║ |_| |_| \__, ||_____||_| \___| \___| \__||_| |_| \___| \__,_||_||____/ \__,_| \__| \__,_| ║▌║▌║█│▌
2024-11-24 14:08:31.387 - INFO : ▌│█║▌║▌║ |___/ ║▌║▌║█│▌
2024-11-24 14:08:31.387 - INFO : ▌│█║▌║▌║ VERSION : 0.13.2 ║▌║▌║█│▌
2024-11-24 14:08:31.405 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.405 - INFO : RUN IN PRODUCTION MODE
2024-11-24 14:08:31.405 - INFO : CHARGEMENT DU CONFIG.YAML...
2024-11-24 14:08:31.406 - INFO : 041xxxxxxx62
2024-11-24 14:08:31.409 - INFO : => Success
2024-11-24 14:08:31.409 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.409 - INFO : NETTOYAGE DE LA BASE DE DONNÉES...
2024-11-24 14:08:31.434 - INFO : Started server process [888]
2024-11-24 14:08:31.434 - INFO : Waiting for application startup.
2024-11-24 14:08:31.442 - INFO : Application startup complete.
2024-11-24 14:08:31.444 - INFO : Uvicorn running on http://0.0.0.0:5000 (Press CTRL+C to quit)
2024-11-24 14:08:31.446 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.446 - INFO : DÉMARRAGE DU JOB D'IMPORTATION DANS 10S
2024-11-24 14:08:31.446 - INFO : 10s
2024-11-24 14:08:31.449 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:31.449 - INFO : RÉCUPÉRATION DU STATUT DE LA PASSERELLE :
2024-11-24 14:08:31.523 - INFO : status: True
2024-11-24 14:08:31.523 - INFO : information: None
2024-11-24 14:08:31.523 - INFO : nb_client: 3173
2024-11-24 14:08:31.523 - INFO : waiting_estimation: 0.0s
2024-11-24 14:08:32.446 - INFO : 9s
2024-11-24 14:08:33.260 - INFO : 127.0.0.1:42986 - "GET / HTTP/1.1" 200
2024-11-24 14:08:33.447 - INFO : 8s
2024-11-24 14:08:34.447 - INFO : 7s
2024-11-24 14:08:35.448 - INFO : 6s
2024-11-24 14:08:36.448 - INFO : 5s
2024-11-24 14:08:37.449 - INFO : 4s
2024-11-24 14:08:38.302 - INFO : 127.0.0.1:42994 - "GET / HTTP/1.1" 200
2024-11-24 14:08:38.449 - INFO : 3s
2024-11-24 14:08:39.449 - INFO : 2s
2024-11-24 14:08:40.450 - INFO : 1s
2024-11-24 14:08:41.450 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:41.450 - INFO : RÉCUPÉRATION DU STATUT DE LA PASSERELLE :
2024-11-24 14:08:41.451 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:41.670 - INFO : status: True
2024-11-24 14:08:41.670 - INFO : information: None
2024-11-24 14:08:41.670 - INFO : nb_client: 3173
2024-11-24 14:08:41.670 - INFO : waiting_estimation: 0.0s
2024-11-24 14:08:41.671 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:41.672 - INFO : RÉCUPÉRATION DES DONNÉES TEMPO :
2024-11-24 14:08:41.672 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:41.761 - INFO : => Toutes les données sont déjà en cache.
2024-11-24 14:08:41.763 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:41.763 - INFO : CALCUL DES JOURS TEMPO :
2024-11-24 14:08:41.769 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:41.769 - INFO : RÉCUPÉRATION DES TARIFS TEMPO :
2024-11-24 14:08:42.060 - INFO : => Toutes les valeurs sont misent à jours.
2024-11-24 14:08:42.064 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:42.064 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:42.064 - INFO : RÉCUPÉRATION DES DONNÉES ECOWATT :
2024-11-24 14:08:43.351 - INFO : 127.0.0.1:53882 - "GET / HTTP/1.1" 200
2024-11-24 14:08:47.681 - INFO : 2022-12-09: Pas d’alerte.
2024-11-24 14:08:47.681 - INFO : 2022-12-10: Pas d’alerte.
2024-11-24 14:08:47.681 - INFO : 2022-12-11: Pas d’alerte.
2024-11-24 14:08:47.681 - INFO : 2022-12-12: Pas d’alerte.
2024-11-24 14:08:47.681 - INFO : 2022-12-19: Pas d’alerte.
2024-11-24 14:08:47.681 - INFO : 2022-12-20: Pas d’alerte.
2024-11-24 14:08:47.681 - INFO : 2022-12-21: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-22: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-23: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-24: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-25: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-26: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-27: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-28: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-29: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-30: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2022-12-31: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-01: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-02: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-03: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-04: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-05: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-06: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-07: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-08: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-09: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-10: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-11: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-12: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-13: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-14: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-15: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-16: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-17: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-18: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-19: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-20: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-21: Pas d’alerte.
2024-11-24 14:08:47.682 - INFO : 2023-01-22: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-23: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-24: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-25: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-26: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-27: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-28: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-29: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-30: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-01-31: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-01: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-02: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-03: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-04: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-05: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-06: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-07: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-08: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-09: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-10: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-11: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-12: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-13: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-14: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-15: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-16: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-17: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-18: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-19: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-20: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-21: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-22: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-23: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-24: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-25: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-26: Pas d’alerte.
2024-11-24 14:08:47.683 - INFO : 2023-02-27: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-02-28: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-01: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-02: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-03: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-04: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-05: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-06: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-07: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-08: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-09: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-10: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-11: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-12: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-13: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-14: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-15: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-16: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-17: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-18: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-19: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-20: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-21: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-22: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-23: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-24: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-25: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-26: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-27: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-28: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-29: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-30: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-03-31: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-04-01: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-04-02: Pas d’alerte.
2024-11-24 14:08:47.684 - INFO : 2023-04-03: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-04: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-05: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-06: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-07: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-08: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-09: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-10: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-11: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-12: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-13: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-14: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-15: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-16: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-17: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-18: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-19: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-20: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-21: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-22: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-23: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-24: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-25: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-26: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-27: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-28: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-29: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-04-30: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-01: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-02: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-03: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-04: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-05: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-06: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-07: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-08: Pas d’alerte.
2024-11-24 14:08:47.685 - INFO : 2023-05-09: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-10: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-11: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-12: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-13: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-14: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-15: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-16: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-17: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-18: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-19: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-20: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-21: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-22: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-23: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-24: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-25: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-26: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-27: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-28: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-29: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-30: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-05-31: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-01: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-02: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-03: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-04: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-05: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-06: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-07: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-08: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-09: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-10: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-11: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-12: Pas d’alerte.
2024-11-24 14:08:47.686 - INFO : 2023-06-13: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-14: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-15: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-16: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-17: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-18: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-19: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-20: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-21: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-22: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-23: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-24: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-25: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-26: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-27: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-28: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-29: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-06-30: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-01: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-02: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-03: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-04: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-05: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-06: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-07: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-08: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-09: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-10: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-11: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-12: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-13: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-14: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-15: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-16: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-17: Pas d’alerte.
2024-11-24 14:08:47.687 - INFO : 2023-07-18: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-19: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-20: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-21: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-22: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-23: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-24: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-25: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-26: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-27: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-28: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-29: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-30: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-07-31: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-01: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-02: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-03: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-04: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-05: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-06: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-07: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-08: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-09: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-10: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-11: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-12: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-13: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-14: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-15: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-16: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-17: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-18: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-19: Pas d’alerte.
2024-11-24 14:08:47.688 - INFO : 2023-08-20: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-21: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-22: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-23: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-24: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-25: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-26: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-27: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-28: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-29: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-30: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-08-31: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-01: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-02: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-03: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-04: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-05: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-06: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-07: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-08: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-09: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-10: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-11: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-12: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-13: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-14: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-15: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-16: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-17: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-18: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-19: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-20: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-21: Pas d’alerte.
2024-11-24 14:08:47.689 - INFO : 2023-09-22: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-23: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-24: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-25: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-26: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-27: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-28: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-29: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-09-30: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-01: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-02: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-03: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-04: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-05: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-06: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-07: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-08: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-09: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-10: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-11: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-12: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-13: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-14: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-15: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-16: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-17: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-18: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-19: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-20: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-21: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-22: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-23: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-24: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-25: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-26: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-27: Pas d’alerte.
2024-11-24 14:08:47.690 - INFO : 2023-10-28: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-10-29: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-10-30: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-10-31: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-01: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-02: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-03: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-04: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-05: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-06: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-07: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-08: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-09: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-10: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-11: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-12: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-13: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-14: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-15: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-16: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-17: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-18: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-19: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-20: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-21: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-22: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-23: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-24: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-25: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-26: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-27: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-28: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-29: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-11-30: Pas d’alerte.
2024-11-24 14:08:47.691 - INFO : 2023-12-01: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-02: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-03: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-04: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-05: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-06: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-07: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-08: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-09: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-10: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-11: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-12: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-13: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-14: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-15: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-16: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-17: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-18: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-19: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-20: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-21: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-22: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-23: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-24: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-25: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-26: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-27: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-28: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-29: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-30: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2023-12-31: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2024-01-01: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2024-01-02: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2024-01-03: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2024-01-04: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2024-01-05: Pas d’alerte.
2024-11-24 14:08:47.692 - INFO : 2024-01-06: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-07: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-08: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-09: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-10: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-11: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-12: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-13: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-14: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-15: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-16: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-17: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-18: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-19: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-20: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-21: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-22: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-23: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-24: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-25: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-26: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-27: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-28: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-29: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-30: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-01-31: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-01: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-02: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-03: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-04: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-05: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-06: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-07: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-08: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-09: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-10: Pas d’alerte.
2024-11-24 14:08:47.693 - INFO : 2024-02-11: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-12: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-13: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-14: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-15: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-16: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-17: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-18: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-19: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-20: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-21: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-22: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-23: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-24: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-25: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-26: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-27: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-28: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-02-29: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-01: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-02: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-03: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-04: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-05: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-06: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-07: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-08: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-09: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-10: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-11: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-12: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-13: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-14: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-15: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-16: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-17: Pas d’alerte.
2024-11-24 14:08:47.694 - INFO : 2024-03-18: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-19: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-20: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-21: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-22: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-23: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-24: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-25: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-26: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-27: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-28: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-29: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-30: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-03-31: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-01: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-02: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-03: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-04: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-05: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-06: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-07: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-08: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-09: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-10: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-11: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-12: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-13: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-14: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-15: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-16: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-17: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-18: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-19: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-20: Pas d’alerte.
2024-11-24 14:08:47.695 - INFO : 2024-04-21: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-22: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-23: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-24: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-25: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-26: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-27: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-28: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-29: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-04-30: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-01: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-02: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-03: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-04: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-05: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-06: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-07: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-08: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-09: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-10: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-11: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-12: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-13: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-14: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-15: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-16: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-17: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-18: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-19: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-20: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-21: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-22: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-23: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-24: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-25: Pas d’alerte.
2024-11-24 14:08:47.696 - INFO : 2024-05-26: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-05-27: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-05-28: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-05-29: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-05-30: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-05-31: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-01: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-02: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-03: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-04: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-05: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-06: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-07: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-08: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-09: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-10: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-11: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-12: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-13: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-14: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-15: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-16: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-17: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-18: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-19: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-20: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-21: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-22: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-23: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-24: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-25: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-26: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-27: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-28: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-29: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-06-30: Pas d’alerte.
2024-11-24 14:08:47.697 - INFO : 2024-07-01: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-07-02: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-07-03: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-04: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-05: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-06: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-07: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-08: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-09: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-10: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-11: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-12: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-13: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-14: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-15: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-16: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-17: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-18: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-19: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-20: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-21: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-22: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-23: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-24: Pas d’alerte.
2024-11-24 14:08:47.698 - INFO : 2024-11-25: Pas d’alerte.
2024-11-24 14:08:47.700 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:47.700 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:47.700 - INFO : ▌│█║▌║▌║ Point de livraison : 04174674369262 ║▌║▌║█│▌
2024-11-24 14:08:47.710 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:47.710 - INFO : [0xxxxxxx62] RÉCUPÉRATION DES INFORMATIONS DU COMPTE :
2024-11-24 14:08:47.786 - INFO : valid: True
2024-11-24 14:08:47.786 - INFO : information:
2024-11-24 14:08:47.786 - INFO : consent_expiration_date: 2027-11-23T10:05:12
2024-11-24 14:08:47.786 - INFO : call_number: 13
2024-11-24 14:08:47.786 - INFO : quota_reached: False
2024-11-24 14:08:47.786 - INFO : quota_limit: 500
2024-11-24 14:08:47.786 - INFO : quota_reset_at: 2024-11-24T23:59:59.999999
2024-11-24 14:08:47.786 - INFO : last_call: 2024-11-23T09:45:23.562891
2024-11-24 14:08:47.786 - INFO : ban: False
2024-11-24 14:08:47.792 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:47.792 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:47.793 - INFO : [04xxxxxxx62] RÉCUPÉRATION DES INFORMATIONS CONTRACTUELLES :
2024-11-24 14:08:47.793 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:47.795 - INFO : => Pas de cache
2024-11-24 14:08:48.379 - ERROR : {'error': True, 'description': 'No consent can be found for this customer and this usage point.'}
2024-11-24 14:08:48.379 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:48.379 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:48.379 - INFO : [04xxxxxxx62] RÉCUPÉRATION DES COORDONNÉES POSTALES :
2024-11-24 14:08:48.381 - INFO : => Pas de cache
2024-11-24 14:08:48.398 - INFO : 127.0.0.1:53902 - "GET / HTTP/1.1" 200
2024-11-24 14:08:48.855 - ERROR : {'error': True, 'description': 'No consent can be found for this customer and this usage point.'}
2024-11-24 14:08:48.855 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:48.855 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:48.855 - INFO : [041xxxxxxx62] RÉCUPÉRATION DE LA CONSOMMATION JOURNALIÈRE :
2024-11-24 14:08:48.859 - INFO : Récupération des données : 2024-11-22 => 2024-11-26
2024-11-24 14:08:48.871 - INFO : Chargement des données depuis MyElectricalData 2024-11-22 => 2024-11-26
2024-11-24 14:08:49.738 - ERROR : Echec de la récupération des données
2024-11-24 14:08:49.738 - ERROR : => Technical error. Please try later.
2024-11-24 14:08:49.739 - ERROR : => 2024-11-22 -> 2024-11-26
2024-11-24 14:08:49.739 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:49.739 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:49.740 - INFO : [04xxxxxxx62] RÉCUPÉRATION DE LA CONSOMMATION DÉTAILLÉE :
2024-11-24 14:08:49.740 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:49.747 - INFO : Récupération des données : 2024-11-20 => 2024-11-26
2024-11-24 14:08:49.750 - INFO : - 10079m absente du relevé.
2024-11-24 14:08:49.751 - INFO : Chargement des données depuis MyElectricalData 2024-11-20 => 2024-11-26
2024-11-24 14:08:51.788 - ERROR : Echec de la récupération des données.
2024-11-24 14:08:51.788 - ERROR : => Technical error. Please try later.
2024-11-24 14:08:51.788 - ERROR : => 2024-11-20 -> 2024-11-26
2024-11-24 14:08:51.788 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:51.789 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:51.789 - INFO : [041xxxxxxx62] RÉCUPÉRATION DE LA PRODUCTION JOURNALIÈRE :
2024-11-24 14:08:51.790 - INFO : Récupération de la production journalière désactivée sur le point de livraison
2024-11-24 14:08:51.792 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:51.792 - INFO : [04xxxxxxx2] RÉCUPÉRATION DE LA PRODUCTION DÉTAILLÉE :
2024-11-24 14:08:51.793 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:51.793 - INFO : Récupération de la production détaillée désactivée sur le point de livraison
2024-11-24 14:08:51.793 - INFO : [041xxxxxxx62] RÉCUPÉRATION DE LA PUISSANCE MAXIMUM JOURNALIÈRE :
2024-11-24 14:08:51.794 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:51.806 - INFO : Récupération des données : 2024-11-22 => 2024-11-26
2024-11-24 14:08:51.826 - INFO : Chargement des données depuis MyElectricalData 2024-11-22 => 2024-11-26
2024-11-24 14:08:52.785 - ERROR : Echec de la récupération des données.
2024-11-24 14:08:52.785 - ERROR : => Technical error. Please try later.
2024-11-24 14:08:52.785 - ERROR : => 2024-11-22 -> 2024-11-26
2024-11-24 14:08:52.785 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:52.786 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:52.786 - INFO : [04xxxxxxx62] GÉNÉRATION DES STATISTIQUES TARIFAIRE DE CONSOMMATION/PRODUCTION :
2024-11-24 14:08:52.786 - INFO : Consommation :
2024-11-24 14:08:52.810 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:52.810 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:52.810 - INFO : [04xxxxxxx2] EXPORT MQTT
2024-11-24 14:08:52.811 - INFO : Statut du compte.
2024-11-24 14:08:52.817 - INFO : => OK
2024-11-24 14:08:52.817 - INFO : Génération des messages du contrat
2024-11-24 14:08:52.820 - INFO : => ERREUR
2024-11-24 14:08:52.820 - INFO : Génération des messages d'addresse
2024-11-24 14:08:52.822 - INFO : => ERREUR
2024-11-24 14:08:52.822 - INFO : Génération des données Ecowatt
2024-11-24 14:08:52.828 - INFO : => OK
2024-11-24 14:08:52.829 - INFO : Envoie des données Tempo
2024-11-24 14:08:52.838 - INFO : => Pas de donnée
2024-11-24 14:08:52.838 - INFO : Génération des données annuelles
2024-11-24 14:08:52.851 - INFO : => Pas de donnée
2024-11-24 14:08:52.851 - INFO : Génération des données linéaires journalières.
2024-11-24 14:08:52.861 - INFO : => Pas de donnée
2024-11-24 14:08:52.861 - INFO : Génération des données annuelles détaillé.
2024-11-24 14:08:52.869 - INFO : => Pas de donnée
2024-11-24 14:08:52.869 - INFO : Génération des données linéaires détaillées
2024-11-24 14:08:52.877 - INFO : => Pas de donnée
2024-11-24 14:08:52.877 - INFO : Génération des données de puissance max journalières.
2024-11-24 14:08:52.880 - INFO : => Pas de donnée
2024-11-24 14:08:52.880 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:52.880 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:52.880 - INFO : [0xxxxxxx62] EXPORTATION DES DONNÉES VERS HOME ASSISTANT (VIA MQTT)
2024-11-24 14:08:52.885 - INFO : Consommation :
2024-11-24 14:08:53.130 - INFO : - sensor.linky_04xxxxxxx62_consumption
2024-11-24 14:08:53.138 - INFO : - sensor.linky_041xxxxxxx262_consumption.last5day
2024-11-24 14:08:53.157 - INFO : - sensor.linky_041xxxxxxx262_consumption.history
2024-11-24 14:08:53.162 - INFO : - sensor.rte_tempo_today
2024-11-24 14:08:53.166 - INFO : - sensor.rte_tempo_tomorrow
2024-11-24 14:08:53.170 - INFO : - sensor.edf_tempo_info
2024-11-24 14:08:53.173 - INFO : - sensor.edf_tempo_days_red
2024-11-24 14:08:53.175 - INFO : - sensor.edf_tempo_days_white
2024-11-24 14:08:53.177 - INFO : - sensor.edf_tempo_days_blue
2024-11-24 14:08:53.182 - INFO : - sensor.edf_tempo_price_red_hc
2024-11-24 14:08:53.184 - INFO : - sensor.edf_tempo_price_red_hp
2024-11-24 14:08:53.187 - INFO : - sensor.edf_tempo_price_blue_hc
2024-11-24 14:08:53.191 - INFO : - sensor.edf_tempo_price_blue_hp
2024-11-24 14:08:53.193 - INFO : - sensor.edf_tempo_price_white_hc
2024-11-24 14:08:53.197 - INFO : - sensor.edf_tempo_price_white_hp
2024-11-24 14:08:53.202 - INFO : - sensor.rte_ecowatt_j0
2024-11-24 14:08:53.207 - INFO : - sensor.rte_ecowatt_j1
2024-11-24 14:08:53.213 - INFO : - sensor.rte_ecowatt_j2
2024-11-24 14:08:53.214 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ TERMINE ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:53.214 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:53.214 - INFO : [04xxxxxxx262] IMPORT DES DONNÉES VERS L'ONGLET ENERGY DE HOME ASSISTANT (WEBSOCKET)
2024-11-24 14:08:53.217 - INFO : Connexion au WebSocket Home Assistant ws://192.168.0.100:8123/api/websocket
2024-11-24 14:08:53.219 - INFO : Authentification requise
2024-11-24 14:08:53.220 - INFO : => OK
2024-11-24 14:08:53.220 - INFO : Importation des données du point de livraison : 04174674369262
2024-11-24 14:08:53.222 - INFO : Consommation
2024-11-24 14:08:53.246 - INFO : Clean old data import In Home Assistant Recorder 04174674369262
2024-11-24 14:08:53.246 - INFO : Effacement des données importées dans Energy.
2024-11-24 14:08:53.254 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:53.254 - INFO : SWITCH PURGE TO FALSE
2024-11-24 14:08:53.263 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:53.263 - INFO : REFRESH ORM OBJECTS
2024-11-24 14:08:53.263 - INFO : DÉSACTIVÉ DANS LA CONFIGURATION (EXEMPLE: HTTPS://TINYURL.COM/2KBD62S9)
2024-11-24 14:08:53.264 - INFO : ▌│█║▌║▌║ ___ _ _____ _ _ _ _ _ _ ║▌║▌║█│▌
2024-11-24 14:08:53.264 - INFO : ▌│█║▌║▌║ |_ _| _ __ ___ _ __ ___ _ __ | |_ | ___|(_) _ __ (_) ___ | |__ | || || | ║▌║▌║█│▌
2024-11-24 14:08:53.264 - INFO : ▌│█║▌║▌║ | | | '_ ` _ \ | '_ \ / _ \ | '__|| __| | |_ | || '_ \ | |/ __|| '_ \ | || || | ║▌║▌║█│▌
2024-11-24 14:08:53.264 - INFO : ▌│█║▌║▌║ | | | | | | | || |_) || (_) || | | |_ | _| | || | | || |\__ \| | | ||_||_||_| ║▌║▌║█│▌
2024-11-24 14:08:53.264 - INFO : ▌│█║▌║▌║ |___||_| |_| |_|| .__/ \___/ |_| \__| |_| |_||_| |_||_||___/|_| |_|(_)(_)(_) ║▌║▌║█│▌
2024-11-24 14:08:53.264 - INFO : ▌│█║▌║▌║ |_| ║▌║▌║█│▌
2024-11-24 14:08:53.264 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2024-11-24 14:08:53.458 - INFO : 127.0.0.1:35570 - "GET / HTTP/1.1" 200
2024-11-24 14:08:58.510 - INFO : 127.0.0.1:35572 - "GET / HTTP/1.1" 200
