Comment accède tu as ton instance HA ?
Ci joint Mon Fichier config de MyElectricalData qui fonctionne pour que tu puisses comparer
backend:
uri: sqlite:////data/myelectricaldata.db
gateway:
ssl: true
url: myelectricaldata.fr
home_assistant:
card_myenedis: true
discovery: true
enable: true
home_assistant_ws:
batch_size: 1000
enable: true
purge: false
ssl: false
token: # Token Long Donné dans HA
url: 192.168.1.49:8123 # URL pour accéder à HA
influxdb:
batching_options:
batch_size: 1000
exponential_base: 2
flush_interval: 1000
jitter_interval: 0
max_retries: 5
max_retry_delay: '125_000'
max_retry_time: '180_000'
retry_interval: 5000
bucket: "MyElectricalData/autogen"
enable: true
hostname: a0d7b954-influxdb
method: synchronous
org: "-"
port: 8086
scheme: http
timezone: UTC
token: MyElectricalData:myelectricaldata
wipe: false
logging:
debug: false
log2file: false
log_format: '%(asctime)s.%(msecs)03d - %(levelname)8s : %(message)s'
log_format_date: '%Y-%m-%d %H:%M:%S'
log_http: false
log_level: 20
mqtt:
cert: false
client_id: myelectricaldata
enable: true
hostname: core-mosquitto
password: # Mot de passe créer dans utilisateur HA Paramètres/Personnes/Utilisateur pour Mqtt
port: 1883
prefix: myelectricaldata
qos: 0
retain: true
username: # Mon Nom d'utilisateur créer dans HA pour Paramètres/Personnes/Utilisateur Mqtt
myelectricaldata:
'# Numéro DPL':
cache: true
consumption: true
consumption_detail: true
consumption_detail_max_date: ''
consumption_max_date: ''
consumption_max_power: true
consumption_price_base: 0.2516
consumption_price_hc: 0.2068
consumption_price_hp: 0.27
enable: true
offpeak_hours_0: 23h26-07h26
offpeak_hours_1: 23h26-07h26
offpeak_hours_2: 23h26-07h26
offpeak_hours_3: 23h26-07h26
offpeak_hours_4: 23h26-07h26
offpeak_hours_5: 23h26-07h26
offpeak_hours_6: 23h26-07h26
plan: HC/HP
production: false
production_detail: false
production_detail_max_date: ''
production_max_date: ''
production_price: 0.0
refresh_addresse: true
refresh_contract: true
token: # Token passerelle MyElectricalData
wipe_influxdb: false
opentelemetry:
enable: false
endpoint: http://localhost:4317
environment: production
extension:
- sqlalchemy
- fastapi
service_name: myelectricaldata
server:
certfile: ''
cidr: 0.0.0.0
cycle: 14400
debug: true
keyfile: ''
log2file: true
port: 5000
Gil94
Février 19, 2025, 7:57
2022
Merci, voici ma config. Si tu vois quelque chose …
cycle: 14400 # 4H
debug: true
log2file: false
wipe_influxdb: false # Work only with influxdb > 2.X
# Par défaut le backend en local dans le /data/cache.db du conteneur.
# Mais il est possible de basculer sur une base de données externe de type SQLite ou PostgreSQL
# Exemple pour Postgres :
# storage_uri: postgresql://myelectricaldata:myelectricaldata@postgres:5432/myelectricaldata
mqtt:
enable: true
hostname: mosquitto
port: 1883
username: null
password: null
client_id: myelectricaldata # DOIT ETRE UNIQUE SUR LA TOTALITE DES CLIENTS CONNECTE AU SERVEUR MQTT
retain: true
qos: 0
home_assistant: # MQTT est obligaoire pour Home Assistant
enable: true
discovery: true
home_assistant_ws:
enable: true
ssl: true
token: TOKEN_LONGUE_DUREE
url: 192.168.0.48:8123
influxdb:
enable: false
hostname: influxdb
port: 8086
token: myelectricaldata
org: myelectricaldata
bucket: myelectricaldata
# ATTENTION, L'activation de l'importation asynchrone va réduire fortement le temps d'importation dans InfluxDB
# mais va augmenter la consommation mémoire & CPU et donc à activer uniquement sur un hardware robuste.
method: synchronous # Mode disponible : synchronous / asynchronous / batching
# batching_options permet uniquement de configurer la methode `batching`.
# Pour plus d'information : https://github.com/influxdata/influxdb-client-python#batching
batching_options:
batch_size: 1000
jitter_interval: 0
max_retry_time: 180_000
max_retries: 5
max_retry_delay: 125_000
exponential_base: 2
myelectricaldata:
"MON_PDL_1":
enable: "true"
token:
addresses: "true"
cache: "true"
consumption: "true"
consumption_detail: "true"
consumption_price_base: "0.145907"
consumption_price_hc: "0.124364"
consumption_price_hp: "0.164915"
consumption_max_date: "2021-06-01"
consumption_detail_max_date: "2021-06-01"
offpeak_hours_0: 22H00-6H00 # LUNDI
offpeak_hours_1: 22H00-6H00 # MARDI
offpeak_hours_2: 22H00-6H00 # MERCREDI
offpeak_hours_3: 22H00-6H00 # JEUDI
offpeak_hours_4: 22H00-6H00 # VENDREDI
offpeak_hours_5: 22H00-6H00;12H00-14H00 # SAMEDI
offpeak_hours_6: 22H00-6H00;12H00-14H00 # DIMANCHE
plan: HC/HP
production: "false"
production_detail: "false"
production_price: "0.0"
production_max_date: "2021-06-01"
production_detail_max_date: "2021-06-01"
refresh_addresse: "false"
refresh_contract: "false"
"MON_PDL_2_AVEC_PRODUCTION":
enable: "false"
token: TOKEN_DE_MON_PDL_2
name: "Maison de vacances"
cache: "true"
consumption: "true"
consumption_price_base: "0.175"
consumption_price_hc: "0.175"
consumption_price_hp: "0.175"
offpeak_hours_0: ""
offpeak_hours_1: ""
offpeak_hours_2: ""
offpeak_hours_3: ""
offpeak_hours_4: ""
offpeak_hours_5: ""
offpeak_hours_6: ""
plan: BASE
production: "true"
production_detail: "true"
production_price: "0.10"
t’a essayé avec ssl: false
Gil94:
ssl: true
Black_Dragon34:
ssl: false
Gil94
Février 19, 2025, 9:18
2024
Merci beaucoup pour ton aide … Hélas toujours la même erreur
benhass
Février 19, 2025, 3:09
2025
Toujours instable, j’ai nettoyé mon yaml, mais j’ai toujours ceci ; d’ailleurs est-ce normal toutes ces « INFO : 127.0.0.1 »
2025-02-19 14:14:42.193 - INFO : 127.0.0.1:59714 - "GET / HTTP/1.1" 200
2025-02-19 14:14:47.521 - INFO : 127.0.0.1:59720 - "GET / HTTP/1.1" 200
/./etc/cont-init.d/99-run.sh: line 153: 759 Killed python -u /app/main.py
[14:14:50] FATAL: The app has crashed. Are you sure you entered the correct config options?
Starting the upstream container
config : RPi 3, dernière version de HA, MQTT ok
benhass
Février 20, 2025, 9:19
2026
J’ai installé la version dev, ça semble résoudre mon problème
edit : ah non, ça finit par planter, mais moins vite :
/./etc/cont-init.d/99-run.sh: line 159: 815 Killed python -u /app/main.py
[19:49:15] FATAL: The app has crashed. Are you sure you entered the correct config options?
Gil94
Février 21, 2025, 10:49
2027
Voici le log que j’obtiens lorsque je demande le consentement :
Login attempt or request with invalid authentication from db21ed7f-enedisgateway2mqtt.local.hass.io (172.30.33.6). Requested URL: '/api/websocket'. (None)
Stef_42
Février 24, 2025, 10:58
2028
Hello, avez vous des latences de récupération des données de la veille ? Comme dit plus haut, j’ai supprimé les caches mais j’ai toujours un souci, je vois les données dans MyElectricalData mais cela ne remonte pas dans HA…
Même problème de mise en cache des données de la veille. La consultation web de myelectricaldata mentionne une erreur. Les données se rafraîchissent à j+2. Vider le cache résoud le problème mais cette anomalie réapparaît dès le lendemain.
Idem, mais plutôt J-2 chez moi
Pbranly
Février 26, 2025, 8:21
2031
Problème connu du concepteur
Stef_42
Février 26, 2025, 8:48
2032
Il y a une MAJ prévue pour pallier au problème ?
Il est au courant depuis novembre et pas de news depuis :
ouvert 10:48AM - 18 Nov 24 UTC
bug
**Description du bug**
La conso de la veille ne semble pas calculée, elle le se… ra demain cf screen-shot joint
idem pour la puissance max d'hier
<details>
<summary>Configuration (config.yaml)</summary>
```yaml
cycle: 10800
debug: true
home_assistant:
discovery: true
enable: true
home_assistant_ws:
enable: false
ssl: false
influxdb:
bucket: myelectricaldata/RETENTION
enable: true
hostname: xxxxxxxx
method: asynchronous
org: "-"
port: 8086
token: xxxxxxxxxxxxxxxx:yyyyyyyyyyyy
mqtt:
enable: true
hostname: xxxxxxxxxxxxxx
password: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
port: 1883
qos: 0
retain: true
username: homeassistant
myelectricaldata:
"14xxxxxx9":
activation_date_daily: ""
activation_date_detail: ""
addresses: true
cache: "true"
consumption: "true"
consumption_detail_max_date: "2021-03-05"
consumption_max_date: "2021-03-05"
consumption_max_power: "true"
consumption_price_base: "0.2460"
consumption_price_hc: "0.1828"
consumption_price_hp: "0.2460"
enable: "true"
name:
offpeak_hours_0: 01h30-07h30;12h30-14h30
offpeak_hours_1: 01h30-07h30;12h30-14h30
offpeak_hours_2: 01h30-07h30;12h30-14h30
offpeak_hours_3: 01h30-07h30;12h30-14h30
offpeak_hours_4: 01h30-07h30;12h30-14h30
offpeak_hours_5: 01h30-07h30;12h30-14h30
offpeak_hours_6: 01h30-07h30;12h30-14h30
plan: HC/HP
production: "false"
production_detail_max_date: ""
production_max_date: ""
token: xxxxxxxxxxxxxxxxx
</details>
**Type d'installation**
-Core 2024.11.2
Supervisor 2024.11.2
Operating System 13.2
Interface utilisateur 20241106.2
**Version : 0.13.2 **
Appart vider le cache local et passerelle, pas de solution encore…
Stef_42
Février 26, 2025, 9:35
2034
Ok merci. J’espère que ça va être solutionné car si faut vider les caches tous les jours ça perd de son intérêt.
De mon côté, c’est de temps en temps, mais pas tous les jours.
J’aimerais personaliser un peu cette carte, savez vous comment on peut modifier l’image du compteur linky présent sur la carte , j’ai fouiller dans les répertoire de home assistant mais sans succès
/local/community/content-card-linky/icons/linky.svg
avec file editor, on voit le dossier et l’image :
vu le nombre important de messages et de suivi du sujet. Afin d’éviter de saturer les notifications par mail, nous passons le sujet en archive. Nous ouvrons un nouveau sujet pour continuer celui-là.
Vous pouvez demander de l’aide sur le nouveau sujet:
nouveau sujet pour MyElectricalData:
L’ancien sujet est en archive, si besoin:
