Affaire résolu j’ai mis mon mot de passe dans credential_secret et ça fonctionne. Merci
Bonjour a tous , j’ai moi aussi une Bad Gateway et j’ai essayer les réponse précédentes, pourtant tout à l’air ok niveau log … une idée?
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.0.2
You are running the latest version of this add-on.
System: Home Assistant OS 9.5 (amd64 / qemux86-64)
Home Assistant Core: 2023.2.5
Home Assistant Supervisor: 2023.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
patching file nodes/ui_base.html
Hunk #1 succeeded at 1164 (offset 633 lines).
s6-rc: info: service init-nginx successfully started
