Je partage mon flow pour ceux qu’ils veulent une notif pour le courrier,un colis ou la relève du courrier. Cela envoi une notification classique et une notif tts sur ma google home.
Il faut trois capteurs d’ouverture de porte. 1 pour la fente et 1 pour la porte de la boite aux lettres. Le dernier est installé sur ma porte d’entrée. Si la porte d’entrée et celle de la boite aux lettres a été ouverte dans les 3 minutes alors c’est la relève du courrier sinon c’est un colis. Cela fonctionne très bien chez moi depuis quelque mois maintenant.
[{"id":"5acc8cf9.27a254","type":"tab","label":"Boîte aux lettres","disabled":false,"info":""},{"id":"2b7f2fdf.bbb38","type":"comment","z":"5acc8cf9.27a254","name":"[Boîte aux lettres] RAZ","info":"","x":120,"y":40,"wires":[]},{"id":"a0ee1db2.0920a","type":"inject","z":"5acc8cf9.27a254","name":"0h00","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"01 00 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":70,"y":140,"wires":[["f566d93b.3434e8","70dd6105.76e9b","14f464e.6cbd49b"]]},{"id":"f566d93b.3434e8","type":"api-call-service","z":"5acc8cf9.27a254","name":"RAZ Boîte aux Lettres","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.boite_aux_lettres","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":280,"y":80,"wires":[["dae1b157.0c7be"]]},{"id":"14f464e.6cbd49b","type":"api-call-service","z":"5acc8cf9.27a254","name":"RAZ Courrier","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.courier_bal","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":250,"y":200,"wires":[["dae1b157.0c7be"]]},{"id":"70dd6105.76e9b","type":"api-call-service","z":"5acc8cf9.27a254","name":"RAZ Colis","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.colis_bal","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":240,"y":140,"wires":[["dae1b157.0c7be"]]},{"id":"dae1b157.0c7be","type":"debug","z":"5acc8cf9.27a254","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":490,"y":140,"wires":[]},{"id":"7ed8eaa9.970974","type":"comment","z":"5acc8cf9.27a254","name":"[Boîte aux lettres] Courrier reçu","info":"","x":150,"y":260,"wires":[]},{"id":"a85e4be9.794e18","type":"server-state-changed","z":"5acc8cf9.27a254","name":"Fente Boîte aux Lettres","server":"a8c279c8.be8be8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.detecteur_fente_b_lettres","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":120,"y":320,"wires":[["b9a14059.22aac"],[]]},{"id":"b9a14059.22aac","type":"api-current-state","z":"5acc8cf9.27a254","name":"Pas de Courrier","server":"a8c279c8.be8be8","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.courier_bal","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":340,"y":320,"wires":[["d47afc6.7480c","adfdad74.4f94d"],[]]},{"id":"d47afc6.7480c","type":"api-call-service","z":"5acc8cf9.27a254","name":"Active Courrier","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.courier_bal","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":540,"y":280,"wires":[["569a0125.4ef9e"]]},{"id":"adfdad74.4f94d","type":"api-call-service","z":"5acc8cf9.27a254","name":"Active Boîte aux Lettres","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.boite_aux_lettres","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":570,"y":340,"wires":[["dd21ca3.9bd7c38"]]},{"id":"569a0125.4ef9e","type":"api-call-service","z":"5acc8cf9.27a254","name":"Notication Aurélien","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_aurelien","entityId":"","data":"{\"message\":\"Le facteur a déposé du courrier\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":true,"x":810,"y":280,"wires":[["3722907.258337"]]},{"id":"dd21ca3.9bd7c38","type":"api-call-service","z":"5acc8cf9.27a254","name":"Notication Siham","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_siham","entityId":"","data":"{\"message\":\"Le facteur a déposé du courrier\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":true,"x":810,"y":340,"wires":[["3722907.258337"]]},{"id":"2c2866ef.94852a","type":"debug","z":"5acc8cf9.27a254","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1270,"y":320,"wires":[]},{"id":"3722907.258337","type":"api-call-service","z":"5acc8cf9.27a254","name":"Annonce Google Home","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"tts","service":"google_translate_say","entityId":"media_player.salon","data":"{\"language\":\"fr\",\"message\":\"Le facteur a déposé du courrier\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1050,"y":320,"wires":[["2c2866ef.94852a"]]},{"id":"4f994d10.461664","type":"server-state-changed","z":"5acc8cf9.27a254","name":"Porte Boîte aux Lettres","server":"a8c279c8.be8be8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.detecteur_porte_b_lettres","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":120,"y":600,"wires":[["9cc7c0d.568b34"],[]]},{"id":"522c584c.98fef8","type":"api-call-service","z":"5acc8cf9.27a254","name":"Active Colis","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.colis_bal","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":850,"y":660,"wires":[["8ad14ee9.ed423"]]},{"id":"ac41607c.b9b47","type":"api-call-service","z":"5acc8cf9.27a254","name":"Active Boîte aux Lettres","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.boite_aux_lettres","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":890,"y":720,"wires":[["557118e8.6cd918"]]},{"id":"8ad14ee9.ed423","type":"api-call-service","z":"5acc8cf9.27a254","name":"Notication Aurélien","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_aurelien","entityId":"","data":"{\"message\":\"Le facteur a déposé un colis\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":true,"x":1130,"y":660,"wires":[["a6e604f2.e59468"]]},{"id":"557118e8.6cd918","type":"api-call-service","z":"5acc8cf9.27a254","name":"Notication Siham","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_siham","entityId":"","data":"{\"message\":\"Le facteur a déposé un colis\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":true,"x":1130,"y":720,"wires":[["a6e604f2.e59468"]]},{"id":"a6e604f2.e59468","type":"api-call-service","z":"5acc8cf9.27a254","name":"Annonce Google Home","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"tts","service":"google_translate_say","entityId":"media_player.salon","data":"{\"language\":\"fr\",\"message\":\"Le facteur a déposé un colis\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1370,"y":700,"wires":[["bf358099.86955"]]},{"id":"bf358099.86955","type":"debug","z":"5acc8cf9.27a254","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1590,"y":700,"wires":[]},{"id":"14754c3c.620004","type":"comment","z":"5acc8cf9.27a254","name":"[Boîte aux lettres] Colis reçu / Releve Courrier","info":"","x":190,"y":420,"wires":[]},{"id":"1eedf94.ef97e07","type":"api-call-service","z":"5acc8cf9.27a254","name":"RAZ Boîte aux Lettres","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.boite_aux_lettres","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":880,"y":420,"wires":[["a4e792ac.10b9b"]]},{"id":"60533a69.8f0924","type":"api-call-service","z":"5acc8cf9.27a254","name":"RAZ Colis","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.colis_bal","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":840,"y":480,"wires":[[]]},{"id":"4d9f5058.f76b7","type":"api-call-service","z":"5acc8cf9.27a254","name":"RAZ Courrier","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.courier_bal","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":850,"y":540,"wires":[["df4b8a06.ffc438"]]},{"id":"a4e792ac.10b9b","type":"api-call-service","z":"5acc8cf9.27a254","name":"Notication Aurélien","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_aurelien","entityId":"","data":"{\"message\":\"Courrier relevé\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":true,"x":1110,"y":460,"wires":[["49085065.ffe2"]]},{"id":"df4b8a06.ffc438","type":"api-call-service","z":"5acc8cf9.27a254","name":"Notication Siham","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_smartphone_siham","entityId":"","data":"{\"message\":\"Courrier relevé\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":true,"x":1110,"y":520,"wires":[["49085065.ffe2"]]},{"id":"49085065.ffe2","type":"api-call-service","z":"5acc8cf9.27a254","name":"Annonce Google Home","server":"a8c279c8.be8be8","version":1,"debugenabled":false,"service_domain":"tts","service":"google_translate_say","entityId":"media_player.salon","data":"{\"language\":\"fr\",\"message\":\"Courrier relevé\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1350,"y":500,"wires":[["5ea23d92.64b744"]]},{"id":"5ea23d92.64b744","type":"debug","z":"5acc8cf9.27a254","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1570,"y":500,"wires":[]},{"id":"5a032c4d.a22854","type":"api-render-template","z":"5acc8cf9.27a254","name":"Colis ou Reléve","server":"a8c279c8.be8be8","template":" {% set mailbox_last_changed = as_timestamp(states.binary_sensor.detecteur_porte_b_lettres.last_changed) %}\n {% set front_door_last_changed = as_timestamp(states.binary_sensor.detecteur_porte_entree.last_changed) %}\n {% if (mailbox_last_changed - front_door_last_changed)|abs < 180 %}\nreleve_courrier\n {% else %}\ncolis_recu\n {% endif %}","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":520,"y":600,"wires":[["973eae8d.03711"]]},{"id":"973eae8d.03711","type":"switch","z":"5acc8cf9.27a254","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"releve_courrier","vt":"str"},{"t":"eq","v":"colis_recu","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":690,"y":600,"wires":[["1eedf94.ef97e07","60533a69.8f0924","4d9f5058.f76b7"],["522c584c.98fef8","ac41607c.b9b47"]]},{"id":"9cc7c0d.568b34","type":"delay","z":"5acc8cf9.27a254","name":"","pauseType":"delay","timeout":"120","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":330,"y":600,"wires":[["5a032c4d.a22854"]]},{"id":"a8c279c8.be8be8","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
