Merci à vous deux.
je suis partie sur ta solution, avec ajout d’informations température basse, haute et retour à la normal.
[{"id":"acaa9d94bc831aaa","type":"server-state-changed","z":"d9f0894f79496ce6","name":"Température buanderie ?","server":"2ac13f9d67a76d68","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.temperature_buanderie","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"num","halt_if_compare":"gt","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":130,"y":260,"wires":[["54bc0dbbd6e04be0"]]},{"id":"6fd6050e78bd70c1","type":"rbe","z":"d9f0894f79496ce6","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":650,"y":260,"wires":[["af6abbf7397c9fac"]]},{"id":"cd46a7343ed71ac9","type":"change","z":"d9f0894f79496ce6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Température haute","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":300,"wires":[["6fd6050e78bd70c1"]]},{"id":"d68509bc5b2bdf3a","type":"change","z":"d9f0894f79496ce6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Température basse","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":260,"wires":[["6fd6050e78bd70c1"]]},{"id":"54bc0dbbd6e04be0","type":"switch","z":"d9f0894f79496ce6","name":"","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"16","vt":"num","v2":"28","v2t":"num"},{"t":"lt","v":"16","vt":"num"},{"t":"gt","v":"28","vt":"num"}],"checkall":"true","repair":false,"outputs":3,"x":310,"y":260,"wires":[["b8f2ef74b1e1bc85"],["d68509bc5b2bdf3a"],["cd46a7343ed71ac9"]]},{"id":"af6abbf7397c9fac","type":"switch","z":"d9f0894f79496ce6","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Température normale","vt":"str"},{"t":"eq","v":"Température basse","vt":"str"},{"t":"eq","v":"Température haute","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":790,"y":260,"wires":[["9644d3bf78d0d7da"],["3c6c9ea6a68fa3aa"],["4dfb378b94522374"]]},{"id":"b8f2ef74b1e1bc85","type":"change","z":"d9f0894f79496ce6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Température normale","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":220,"wires":[["6fd6050e78bd70c1"]]},{"id":"2ac13f9d67a76d68","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
Un grand merci pour votre aide !
Bonne soirée.
