Je rencontre un soucis dans node red. J’utilise un « call service » qui retourne une valeur dans une entrée « input_number » pour retourner la valeur, j’utilise le champ « Data » avec un jsonata:
{"value": $.payload}
Hors, cela perturbe un autre input_number que je renseigne depuis un autre flow
Je vous joint le flow:
"id": "69539e27a828b993",
"type": "group",
"z": "8e6e60e0a5ebb824",
"style": {
"stroke": "#999999",
"stroke-opacity": "1",
"fill": "none",
"fill-opacity": "1",
"label": true,
"label-position": "nw",
"color": "#a4a4a4"
"nodes": [
"ba0cd25d0d761c73",
"56b9563c430c8c5f",
"ac89b82cdebba6fe",
"0a35b48019d8067c",
"db274a5f2daa9467",
"fb926825df79e687",
"c8eaa17de9dd9d2b",
"fff44738210b4d02",
"b683d8ee82ea4e91",
"24bf5d9017e63899",
"1c42093d49048d7b",
"3f8c1a2b2ab3a67d",
"6303061f43eabd47",
"758317247d26797b",
"eef6e36426b280dd"
"x": 134,
"y": 799,
"w": 1372,
"h": 522
"id": "ba0cd25d0d761c73",
"type": "inject",
"g": "69539e27a828b993",
"name": "TT les min",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "60",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 250,
"y": 900,
"wires": [
"56b9563c430c8c5f",
"ac89b82cdebba6fe",
"758317247d26797b"
"id": "56b9563c430c8c5f",
"type": "api-current-state",
"name": "PV_Conso inst",
"server": "9bf5a907952a79de",
"version": 3,
"outputs": 1,
"halt_if": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "sensor.0x00158d000952036a_papp",
"state_type": "num",
"blockInputOverrides": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "entity"
"for": "0",
"forType": "num",
"forUnits": "minutes",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 440,
"y": 900,
"wires": [
"0a35b48019d8067c"
"id": "ac89b82cdebba6fe",
"name": "PV_Prod inst",
"version": 3,
"outputs": 1,
"halt_if": "",
"entity_id": "sensor.envoy_122132004662_current_power_production",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 440,
"y": 960,
"wires": [
"id": "0a35b48019d8067c",
"type": "join",
"name": "Array[1]",
"mode": "custom",
"build": "array",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "2",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 620,
"y": 900,
"wires": [
"db274a5f2daa9467"
"id": "db274a5f2daa9467",
"type": "change",
"name": "$soubstr(payload)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "(payload[1] - payload[0])",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 830,
"y": 900,
"wires": [
"c8eaa17de9dd9d2b"
"id": "fb926825df79e687",
"type": "comment",
"name": "index surprod du jour",
"info": "",
"x": 260,
"y": 840,
"wires": []
"id": "c8eaa17de9dd9d2b",
"type": "switch",
"name": "Sur ou Sous Prod inst ?",
"rules": [
"t": "gte",
"v": "0",
"vt": "num"
"t": "lt",
"v": "0",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 310,
"y": 1220,
"wires": [
"3f8c1a2b2ab3a67d",
"24bf5d9017e63899"
"fff44738210b4d02"
"id": "fff44738210b4d02",
"type": "change",
"name": "Sous Prod alors Valeur = 0",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "0",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 320,
"y": 1280,
"wires": [
"24bf5d9017e63899",
"3f8c1a2b2ab3a67d"
"id": "b683d8ee82ea4e91",
"type": "change",
"name": "index_SProd",
"rules": [
"t": "set",
"p": "index_SProd",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1200,
"y": 1200,
"wires": [
"6303061f43eabd47",
"eef6e36426b280dd"
"id": "24bf5d9017e63899",
"type": "join",
"name": "Array[1]",
"mode": "custom",
"build": "array",
"key": "topic",
"joiner": "\\n",
"timeout": "",
"count": "2",
"reduceExp": "",
"reduceInit": "",
"reduceFixup": "",
"x": 820,
"y": 1200,
"wires": [
"1c42093d49048d7b"
"id": "1c42093d49048d7b",
"type": "change",
"name": "$sum(payload)",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "(payload[1] + payload[0])",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1000,
"y": 1200,
"wires": [
"b683d8ee82ea4e91"
"id": "3f8c1a2b2ab3a67d",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "index_SProd",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 620,
"y": 1280,
"wires": [
"24bf5d9017e63899"
"id": "6303061f43eabd47",
"type": "debug",
"name": "SProd Jour",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1390,
"y": 1100,
"wires": []
"id": "758317247d26797b",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "2800",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 450,
"y": 1020,
"wires": [
"0a35b48019d8067c"
"id": "eef6e36426b280dd",
"type": "api-call-service",
"version": 5,
"debugenabled": true,
"domain": "input_number",
"service": "set_value",
"areaId": [
"cellier"
"deviceId": [],
"entityId": [
"input_number.index_sprodjour"
"data": "{\"value\": $$.payload}",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 1390,
"y": 1200,
"wires": [
"id": "9bf5a907952a79de",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": ": ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "default",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": false
Si vous avez une idée, je suis preneur. Merci
