Bonjour a vous
Je suis entrain de m’occuper des piles de mes appareils
J’ai recupéré ce bout de code qui fonctionne bien,
Cependant je voudrais pouvoir exclure un appareil
Comment faire? un node specifique?
je souhaiterai pas mettre le 0% congélateur
ci joint mon flux
Merci a vous
Bonne journée
[{"id":"8ca4e8d2.84ae3","type":"inject","z":"2ab28c67eea4de3f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"86400","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":420,"wires":[["51bb149.aa40a6c"]]},{"id":"57dcc0ab.32cfd8","type":"api-call-service","z":"2ab28c67eea4de3f","name":"Notification: Low battery Warning","server":"4183c12c8383c4a2","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_tel_yaya","areaId":[],"deviceId":[],"entityId":[],"data":"{}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","output_location":"payload","output_location_type":"msg","x":1660,"y":360,"wires":[[]]},{"id":"e42f9b8e.45e3a","type":"function","z":"2ab28c67eea4de3f","name":"Prep Notification","func":"msg.payload = \n{\n \"data\": \n {\n \"title\": \"Batterie Faible\", \n \"message\": msg.payload\n }\n}\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1390,"y":360,"wires":[["57dcc0ab.32cfd8"]]},{"id":"5eb6b271.52402c","type":"debug","z":"2ab28c67eea4de3f","name":"Low battery Warning","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1400,"y":480,"wires":[]},{"id":"f667d0b2.2f4b18","type":"sort","z":"2ab28c67eea4de3f","name":"Sort by battery level","order":"ascending","as_num":false,"target":"","targetType":"seq","msgKey":"","msgKeyType":"elem","seqKey":"payload.state","seqKeyType":"msg","x":780,"y":420,"wires":[["ce46c9e.8e8ac38"]]},{"id":"a57739fe.7143a","type":"split","z":"2ab28c67eea4de3f","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":590,"y":420,"wires":[["f667d0b2.2f4b18"]]},{"id":"51bb149.aa40a6c","type":"ha-get-entities","z":"2ab28c67eea4de3f","name":"Sensors battery lower than 20%","server":"4183c12c8383c4a2","version":1,"rules":[{"property":"attributes.device_class","logic":"is","value":"battery","valueType":"str"},{"property":"attributes.battery","logic":"lte","value":"84","valueType":"num"},{"property":"entity_id","logic":"is_not","value":".+(_battery_level)$","valueType":"re"}],"outputType":"array","outputEmptyResults":false,"outputLocationType":"msg","outputLocation":"payload","outputResultsCount":1,"x":370,"y":420,"wires":[["a57739fe.7143a"]]},{"id":"f6ba2a6b.4dfa3","type":"join","z":"2ab28c67eea4de3f","name":"","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1170,"y":420,"wires":[["5eb6b271.52402c","e42f9b8e.45e3a"]]},{"id":"ce46c9e.8e8ac38","type":"function","z":"2ab28c67eea4de3f","name":"Prep message","func":"var sensor = msg.payload.attributes.friendly_name.replace(\" Battery\",\"\");\nmsg.payload = msg.payload.state + \"% pour \" + sensor;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1000,"y":420,"wires":[["f6ba2a6b.4dfa3"]]},{"id":"4183c12c8383c4a2","type":"server","name":"Home Assistant","version":5,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":": ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"default","statusTimeFormat":"h:m","enableGlobalContextStore":false}]
[center]
version | core-2023.11.0 |
installation_type | Home Assistant Container |
dev | false |
hassio | false |
docker | true |
user | root |
virtualenv | false |
python_version | 3.11.6 |
os_name | Linux |
os_version | 5.10.0-25-amd64 |
arch | x86_64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 5000 |
Installed Version | 1.33.0 |
Stage | running |
Available Repositories | 1336 |
Downloaded Repositories | 12 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
dashboards | 2 |
resources | 4 |
views | 3 |
mode | storage |
oldest_recorder_run | 7 novembre 2023 à 08:22 |
current_recorder_run | 7 novembre 2023 à 10:06 |
estimated_db_size | 525.65 MiB |
database_engine | sqlite |
database_version | 3.41.2 |
