### The problem
For something like a year I have seen this in the log every s…ingle time I start Home Assistant.
[homeassistant] Error doing job: Task was destroyed but it is pending!
I cannot trace what causes it. Last year people reported it as related to automations but I tried to remove all automations that run at start and it did not make a difference.
I have enabled debugging in the HA log and pasted the entire log below
### What is version of Home Assistant Core has the issue?
2021.5.2
### What was the last working version of Home Assistant Core?
At least a year ago
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Harmony
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/harmony/
### Example YAML snippet
```yaml
N/A
### Anything in the logs that might be useful for us?
```txt
021-05-11 23:05:17 DEBUG (Thread-16) [pychromecast.socket_client] [Workshop Speaker(None):8009] Resolved service ServiceInfo(type='mdns', data='Google-Home-Mini-ad732ef4ef84f7a56c4399774142397e._googlecast._tcp.local.') to 192.168.1.76:8009
2021-05-11 23:05:17 DEBUG (Thread-16) [pychromecast.socket_client] [Workshop Speaker(192.168.1.76):8009] Connecting to 192.168.1.76:8009
2021-05-11 23:05:17 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en-GB: sensor.deconz, sensor.amcrest, sensor.mobile_app, switch.deconz, binary_sensor.amcrest, light.deconz, binary_sensor.deconz, camera.amcrest, device_tracker.mobile_app
2021-05-11 23:05:17 DEBUG (MainThread) [aioesphomeapi.connection] 192.168.1.93: Got message of type <class 'api_pb2.ConnectResponse'>:
2021-05-11 23:05:17 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [281473529230624] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "media_player.ultracast_bedroom", "old_state": {"entity_id": "media_player.ultracast_bedroom", "state": "unavailable", "attributes": {"friendly_name": "Ultracast Bedroom", "supported_features": 152449}, "last_changed": "2021-05-11T21:05:17.454290+00:00", "last_updated": "2021-05-11T21:05:17.454290+00:00", "context": {"id": "b2e95a68c3274fff9e402b24439fec60", "parent_id": null, "user_id": null}}, "new_state": {"entity_id": "media_player.ultracast_bedroom", "state": "off", "attributes": {"friendly_name": "Ultracast Bedroom", "supported_features": 152461}, "last_changed": "2021-05-11T21:05:17.980836+00:00", "last_updated": "2021-05-11T21:05:17.980836+00:00", "context": {"id": "5d8f151df0712d26ca31308606307e83", "parent_id": null, "user_id": null}}}, "origin": "LOCAL", "time_fired": "2021-05-11T21:05:17.980836+00:00", "context": {"id": "5d8f151df0712d26ca31308606307e83", "parent_id": null, "user_id": null}}}
2021-05-11 23:05:17 DEBUG (Thread-17) [pychromecast.socket_client] [(None):8009] connection listener: ffff9a046ca0 (CastStatusListener) ConnectionStatus(status='CONNECTING', address=NetworkAddress(address=None, port=8009))
2021-05-11 23:05:17 DEBUG (Thread-17) [homeassistant.components.cast.media_player] [media_player.bedroom_display Bedroom Display] Received cast device connection status: CONNECTING
2021-05-11 23:05:17 DEBUG (Thread-17) [pychromecast.dial] get_info_from_service resolved service ServiceInfo(type='mdns', data='Google-Nest-Hub-1951c793118fe9b7c821907a48a42ed1._googlecast._tcp.local.') to service_info ServiceInfo(type='_googlecast._tcp.local.', name='Google-Nest-Hub-1951c793118fe9b7c821907a48a42ed1._googlecast._tcp.local.', addresses=[b'\xc0\xa8\x01G'], port=8009, weight=0, priority=0, server='1951c793-118f-e9b7-c821-907a48a42ed1.local.', properties={b'id': b'1951c793118fe9b7c821907a48a42ed1', b'cd': b'87BE3FA9506216A9626E2C5A8B66F886', b'rm': b'5D0AFBCA4344906C', b've': b'05', b'md': b'Google Nest Hub', b'ic': b'/setup/icon.png', b'fn': b'Bedroom Display', b'ca': b'233477', b'st': b'0', b'bs': b'FA8FCA609DBA', b'nf': b'1', b'rs': b''})
2021-05-11 23:05:17 DEBUG (Thread-17) [pychromecast.socket_client] [Bedroom Display(None):8009] Resolved service ServiceInfo(type='mdns', data='Google-Nest-Hub-1951c793118fe9b7c821907a48a42ed1._googlecast._tcp.local.') to 192.168.1.71:8009
2021-05-11 23:05:17 DEBUG (Thread-17) [pychromecast.socket_client] [Bedroom Display(192.168.1.71):8009] Connecting to 192.168.1.71:8009
2021-05-11 23:05:17 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [281473384830864] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "media_player.ultracast_bedroom", "old_state": {"entity_id": "media_player.ultracast_bedroom", "state": "unavailable", "attributes": {"friendly_name": "Ultracast Bedroom", "supported_features": 152449}, "last_changed": "2021-05-11T21:05:17.454290+00:00", "last_updated": "2021-05-11T21:05:17.454290+00:00", "context": {"id": "b2e95a68c3274fff9e402b24439fec60", "parent_id": null, "user_id": null}}, "new_state": {"entity_id": "media_player.ultracast_bedroom", "state": "off", "attributes": {"friendly_name": "Ultracast Bedroom", "supported_features": 152461}, "last_changed": "2021-05-11T21:05:17.980836+00:00", "last_updated": "2021-05-11T21:05:17.980836+00:00", "context": {"id": "5d8f151df0712d26ca31308606307e83", "parent_id": null, "user_id": null}}}, "origin": "LOCAL", "time_fired": "2021-05-11T21:05:17.980836+00:00", "context": {"id": "5d8f151df0712d26ca31308606307e83", "parent_id": null, "user_id": null}}}
2021-05-11 23:05:18 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [281473529230624] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "sensor.living_room_camera_ptz_preset", "old_state": null, "new_state": {"entity_id": "sensor.living_room_camera_ptz_preset", "state": "4", "attributes": {"friendly_name": "Living room camera PTZ Preset", "icon": "mdi:camera-iris"}, "last_changed": "2021-05-11T21:05:17.986699+00:00", "last_updated": "2021-05-11T21:05:17.986699+00:00", "context": {"id": "b92419c1db45017dfa7003670cebf94d", "parent_id": null, "user_id": null}}}, "origin": "LOCAL", "time_fired": "2021-05-11T21:05:17.986699+00:00", "context": {"id": "b92419c1db45017dfa7003670cebf94d", "parent_id": null, "user_id": null}}}
2021-05-11 23:05:18 DEBUG (SyncWorker_1) [homeassistant.components.amcrest.sensor] Updating Kitchen camera PTZ Preset sensor
2021-05-11 23:05:18 DEBUG (SyncWorker_1) [amcrest.http] <Amcrest2:AMC00104161DE28N5K> HTTP query 5: http://192.168.1.78:80/cgi-bin/ptz.cgi?action=getPresets&channel=0
2021-05-11 23:05:18 DEBUG (SyncWorker_1) [amcrest.http] <Amcrest2:AMC00104161DE28N5K> Running query 5 attempt 1
2021-05-11 23:05:18 DEBUG (SyncWorker_13) [homeassistant.components.amcrest.binary_sensor] Updating Kitchen camera Motion Detected binary sensor
2021-05-11 23:05:18 DEBUG (SyncWorker_13) [amcrest.http] <Amcrest2:AMC00104161DE28N5K> HTTP query 6: http://192.168.1.78:80/cgi-bin/eventManager.cgi?action=getEventIndexes&code=VideoMotion
2021-05-11 23:05:18 DEBUG (SyncWorker_13) [amcrest.http] <Amcrest2:AMC00104161DE28N5K> Running query 6 attempt 1
2021-05-11 23:05:18 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [281473529230624] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "binary_sensor.living_room_camera_online", "old_state": null, "new_state": {"entity_id": "binary_sensor.living_room_camera_online", "state": "on", "attributes": {"friendly_name": "Living room camera Online", "device_class": "connectivity"}, "last_changed": "2021-05-11T21:05:17.987521+00:00", "last_updated": "2021-05-11T21:05:17.987521+00:00", "context": {"id": "07c21e71b81a025b48198c95a9b0710e", "parent_id": null, "user_id": null}}}, "origin": "LOCAL", "time_fired": "2021-05-11T21:05:17.987521+00:00", "context": {"id": "07c21e71b81a025b48198c95a9b0710e", "parent_id": null, "user_id": null}}}
2021-05-11 23:05:18 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [281473384830864] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "sensor.living_room_camera_ptz_preset", "old_state": null, "new_state": {"entity_id": "sensor.living_room_camera_ptz_preset", "state": "4", "attributes": {"friendly_name": "Living room camera PTZ Preset", "icon": "mdi:camera-iris"}, "last_changed": "2021-05-11T21:05:17.986699+00:00", "last_updated": "2021-05-11T21:05:17.986699+00:00", "context": {"id": "b92419c1db45017dfa7003670cebf94d", "parent_id": null, "user_id": null}}}, "origin": "LOCAL", "time_fired": "2021-05-11T21:05:17.986699+00:00", "context": {"id": "b92419c1db45017dfa7003670cebf94d", "parent_id": null, "user_id": null}}}
2021-05-11 23:05:18 DEBUG (Thread-17) [pychromecast.socket_client] [Bedroom Display(192.168.1.71):8009] connection listener: ffff9a046ca0 (CastStatusListener) ConnectionStatus(status='CONNECTED', address=NetworkAddress(address='192.168.1.71', port=8009))
2021-05-11 23:05:18 DEBUG (Thread-17) [homeassistant.components.cast.media_player] [media_player.bedroom_display Bedroom Display] Received cast device connection status: CONNECTED
2021-05-11 23:05:18 DEBUG (Thread-17) [homeassistant.components.cast.media_player] [media_player.bedroom_display Bedroom Display] Cast device availability changed: CONNECTED
2021-05-11 23:05:18 DEBUG (Thread-17) [pychromecast.controllers] Receiver:Updating status
2021-05-11 23:05:18 DEBUG (Thread-17) [pychromecast.socket_client] [Bedroom Display(192.168.1.71):8009] Sending: Message urn:x-cast:com.google.cast.tp.connection from sender-0 to receiver-0: {'type': 'CONNECT', 'origin': {}, 'userAgent': 'PyChromecast', 'senderInfo': {'sdkType': 2, 'version': '15.605.1.3', 'browserVersion': '44.0.2403.30', 'platform': 4, 'systemVersion': 'Macintosh; Intel Mac OS X10_10_3', 'connectionType': 1}}
2021-05-11 23:05:18 DEBUG (Thread-17) [pychromecast.socket_client] [Bedroom Display(192.168.1.71):8009] Sending: Message urn:x-cast:com.google.cast.receiver from sender-0 to receiver-0: {'type': 'GET_STATUS', 'requestId': 1}
2021-05-11 23:05:18 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [281473384830864] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "binary_sensor.living_room_camera_online", "old_state": null, "new_state": {"entity_id": "binary_sensor.living_room_camera_online", "state": "on", "attributes": {"friendly_name": "Living room camera Online", "device_class": "connectivity"}, "last_changed": "2021-05-11T21:05:17.987521+00:00", "last_updated": "2021-05-11T21:05:17.987521+00:00", "context": {"id": "07c21e71b81a025b48198c95a9b0710e", "parent_id": null, "user_id": null}}}, "origin": "LOCAL", "time_fired": "2021-05-11T21:05:17.987521+00:00", "context": {"id": "07c21e71b81a025b48198c95a9b0710e", "parent_id": null, "user_id": null}}}
2021-05-11 23:05:18 INFO (MainThread) [homeassistant.components.esphome] Successfully connected to 192.168.1.93
2021-05-11 23:05:18 DEBUG (Thread-17) [pychromecast.socket_client] [Bedroom Display(192.168.1.71):8009] Connected!
2021-05-11 23:05:18 DEBUG (Thread-17) [pychromecast.socket_client] Thread started...
2021-05-11 23:05:18 DEBUG (MainThread) [aioesphomeapi.connection] 192.168.1.93: Sending <class 'api_pb2.DeviceInfoRequest'>:
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.socket_client] [Office Speaker(192.168.1.70):8009] connection listener: ffff977425e0 (CastStatusListener) ConnectionStatus(status='CONNECTED', address=NetworkAddress(address='192.168.1.70', port=8009))
2021-05-11 23:05:18 DEBUG (Thread-15) [homeassistant.components.cast.media_player] [media_player.office_speaker Office Speaker] Received cast device connection status: CONNECTED
2021-05-11 23:05:18 DEBUG (Thread-15) [homeassistant.components.cast.media_player] [media_player.office_speaker Office Speaker] Cast device availability changed: CONNECTED
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.controllers] Receiver:Updating status
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.socket_client] [Office Speaker(192.168.1.70):8009] Sending: Message urn:x-cast:com.google.cast.tp.connection from sender-0 to receiver-0: {'type': 'CONNECT', 'origin': {}, 'userAgent': 'PyChromecast', 'senderInfo': {'sdkType': 2, 'version': '15.605.1.3', 'browserVersion': '44.0.2403.30', 'platform': 4, 'systemVersion': 'Macintosh; Intel Mac OS X10_10_3', 'connectionType': 1}}
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.socket_client] [Office Speaker(192.168.1.70):8009] Sending: Message urn:x-cast:com.google.cast.receiver from sender-0 to receiver-0: {'type': 'GET_STATUS', 'requestId': 1}
2021-05-11 23:05:18 DEBUG (SyncWorker_9) [amcrest.http] <AMC000EW_KT531F:AMC000EWK7SWKT531F> Query 12 worked. Exit code: <200>
2021-05-11 23:05:18 DEBUG (SyncWorker_9) [amcrest.http] <AMC000EW_KT531F:AMC000EWK7SWKT531F> HTTP query 13: http://192.168.1.61:80/cgi-bin/configManager.cgi?action=getConfig&name=MotionDetect
2021-05-11 23:05:18 DEBUG (SyncWorker_9) [amcrest.http] <AMC000EW_KT531F:AMC000EWK7SWKT531F> Running query 13 attempt 1
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.socket_client] [Office Speaker(192.168.1.70):8009] Connected!
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.socket_client] Thread started...
2021-05-11 23:05:18 DEBUG (Thread-16) [pychromecast.socket_client] [Workshop Speaker(192.168.1.76):8009] connection listener: ffff97685280 (CastStatusListener) ConnectionStatus(status='CONNECTED', address=NetworkAddress(address='192.168.1.76', port=8009))
2021-05-11 23:05:18 DEBUG (Thread-16) [homeassistant.components.cast.media_player] [media_player.workshop_speaker Workshop Speaker] Received cast device connection status: CONNECTED
2021-05-11 23:05:18 DEBUG (Thread-16) [homeassistant.components.cast.media_player] [media_player.workshop_speaker Workshop Speaker] Cast device availability changed: CONNECTED
2021-05-11 23:05:18 DEBUG (Thread-16) [pychromecast.controllers] Receiver:Updating status
2021-05-11 23:05:18 ERROR (Thread-16) [homeassistant] Error doing job: Task was destroyed but it is pending!
2021-05-11 23:05:18 DEBUG (Thread-16) [pychromecast.socket_client] [Workshop Speaker(192.168.1.76):8009] Sending: Message urn:x-cast:com.google.cast.tp.connection from sender-0 to receiver-0: {'type': 'CONNECT', 'origin': {}, 'userAgent': 'PyChromecast', 'senderInfo': {'sdkType': 2, 'version': '15.605.1.3', 'browserVersion': '44.0.2403.30', 'platform': 4, 'systemVersion': 'Macintosh; Intel Mac OS X10_10_3', 'connectionType': 1}}
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.socket_client] [Office Speaker(192.168.1.70):8009] Received: Message urn:x-cast:com.google.cast.receiver from receiver-0 to sender-0: {'requestId': 1, 'status': {'userEq': {'high_shelf': {'frequency': 4500.0, 'gain_db': 0.0, 'quality': 0.707}, 'low_shelf': {'frequency': 150.0, 'gain_db': 0.0, 'quality': 0.707}, 'max_peaking_eqs': 0, 'peaking_eqs': []}, 'volume': {'controlType': 'master', 'level': 0.44999998807907104, 'muted': False, 'stepInterval': 0.019999999552965164}}, 'type': 'RECEIVER_STATUS'}
2021-05-11 23:05:18 DEBUG (Thread-15) [pychromecast.controllers] Received status: CastStatus(is_active_input=None, is_stand_by=None, volume_level=0.44999998807907104, volume_muted=False, app_id=None, display_name=None, namespaces=[], session_id=None, transport_id=None, status_text='', icon_url=None, volume_control_type='master')
2021-05-11 23:05:18 DEBUG (Thread-16) [pychromecast.socket_client] [Workshop Speaker(192.168.1.76):8009] Sending: Message urn:x-cast:com.google.cast.receiver from sender-0 to receiver-0: {'type': 'GET_STATUS', 'requestId': 1}
2021-05-11 23:05:18 DEBUG (Thread-16) [pychromecast.socket_client] [Workshop Speaker(192.168.1.76):8009] Connected!
2021-05-11 23:05:18 DEBUG (Thread-16) [pychromecast.socket_client] Thread started...
### Additional information
I cannot see what it is that causes the issue. I have several Google Assistant devices. 7 to be exact
The ERROR is in an area of the log where HA inits connection to a Google Assistant box.
But is it related? I cannot see anything failing. It just spits out the single error in the middle of the log with nothing I can see that fails afterwards
EDIT. See discussion below. Issue seems related to the Harmony integration and not at all Google.
