Merci pour le coup de main, mais je suis vraiment perdu
Au niveau des logs en effectuant la manip appui long puis appuis répété j’ai ceci :
Warning 2022-06-25 11:44:44Device '0xa4c1383c4cf4cb78' left the network
Info 2022-06-25 11:44:44MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1383c4cf4cb78","ieee_address":"0xa4c1383c4cf4cb78"},"type":"device_leave"}'
Info 2022-06-25 11:44:44MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"left_network","meta":{"friendly_name":"0xa4c1383c4cf4cb78"},"type":"device_removed"}'
=>puis plus rien…
j’ai activé les logs du module Zigbee-herdman pour en savoir plus, mais la c’est pas hyper clair pour moi.
2022-06-25T09:55:31.524Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,53,68,129,0,0,6,0,113,38,1,1,0,84,0,222,20,245,0,0,33,8,80,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0,175,114,28,152]
2022-06-25T09:55:31.524Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,53,68,129,0,0,6,0,113,38,1,1,0,84,0,222,20,245,0,0,33,8,80,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0,175,114,28,152]
2022-06-25T09:55:31.524Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 53 - 2 - 4 - 129 - [0,0,6,0,113,38,1,1,0,84,0,222,20,245,0,0,33,8,80,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0,175,114,28] - 152
2022-06-25T09:55:31.525Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":6,"srcaddr":9841,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":84,"securityuse":0,"timestamp":16061662,"transseqnumber":0,"len":33,"data":{"type":"Buffer","data":[8,80,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0]}}
2022-06-25T09:55:31.526Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":80,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":16,"attrData":1},{"attrId":16385,"dataType":33,"attrData":0},{"attrId":16386,"dataType":33,"attrData":0},{"attrId":32769,"dataType":48,"attrData":1},{"attrId":32770,"dataType":48,"attrData":1},{"attrId":20480,"dataType":48,"attrData":1},{"attrId":32768,"dataType":16,"attrData":0}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":9841,"endpoint":1,"linkquality":84,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2022-06-25T09:55:31.526Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '9841', skipping...
2022-06-25T09:55:31.526Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2022-06-25T09:55:31.764Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,70,68,129,0,0,1,224,113,38,1,1,0,81,0,180,23,245,0,0,50,8,81,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0,175,114,28,6]
2022-06-25T09:55:31.765Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,70,68,129,0,0,1,224,113,38,1,1,0,81,0,180,23,245,0,0,50,8,81,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0,175,114,28,6]
2022-06-25T09:55:31.765Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 70 - 2 - 4 - 129 - [0,0,1,224,113,38,1,1,0,81,0,180,23,245,0,0,50,8,81,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0,175,114,28] - 6
2022-06-25T09:55:31.765Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":57345,"srcaddr":9841,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":81,"securityuse":0,"timestamp":16062388,"transseqnumber":0,"len":50,"data":{"type":"Buffer","data":[8,81,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0]}}
2022-06-25T09:55:31.766Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":81,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":53264,"dataType":48,"attrData":1},{"attrId":53296,"dataType":48,"attrData":0},{"attrId":53248,"dataType":32,"attrData":1},{"attrId":53249,"dataType":27,"attrData":0},{"attrId":53250,"dataType":35,"attrData":2352626},{"attrId":53251,"dataType":35,"attrData":140},{"attrId":53252,"dataType":35,"attrData":12537},{"attrId":53253,"dataType":35,"attrData":1530}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":9841,"endpoint":1,"linkquality":81,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2022-06-25T09:55:31.766Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '9841', skipping...
2022-06-25T09:55:31.766Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
Zigbee2MQTT:debug 2022-06-25 09:55:33: Received MQTT message on 'homeassistant/sensor/81' with data '{"time":"2022-06-25 09:55:31","model":"Oregon-THGR810","id":81,"channel":1,"battery_ok":1,"temperature_C":23.8,"humidity":57}'
2022-06-25T09:55:38.302Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,32,68,129,0,0,2,7,113,38,1,1,0,2,0,158,103,245,0,0,12,8,82,10,0,0,37,126,3,0,0,0,0,173,207,28,195]
2022-06-25T09:55:38.302Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,32,68,129,0,0,2,7,113,38,1,1,0,2,0,158,103,245,0,0,12,8,82,10,0,0,37,126,3,0,0,0,0,173,207,28,195]
2022-06-25T09:55:38.302Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 32 - 2 - 4 - 129 - [0,0,2,7,113,38,1,1,0,2,0,158,103,245,0,0,12,8,82,10,0,0,37,126,3,0,0,0,0,173,207,28] - 195
2022-06-25T09:55:38.303Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1794,"srcaddr":9841,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":2,"securityuse":0,"timestamp":16082846,"transseqnumber":0,"len":12,"data":{"type":"Buffer","data":[8,82,10,0,0,37,126,3,0,0,0,0]}}
2022-06-25T09:55:38.309Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":82,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":37,"attrData":[0,894]}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":9841,"endpoint":1,"linkquality":2,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2022-06-25T09:55:38.309Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '9841', skipping...
2022-06-25T09:55:38.309Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2022-06-25T09:55:38.445Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,29,68,129,0,0,0,224,113,38,1,1,0,2,0,78,105,245,0,0,9,8,84,10,2,208,72,2,0,10,173,207,28,12]
2022-06-25T09:55:38.445Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,29,68,129,0,0,0,224,113,38,1,1,0,2,0,78,105,245,0,0,9,8,84,10,2,208,72,2,0,10,173,207,28,12]
2022-06-25T09:55:38.445Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 29 - 2 - 4 - 129 - [0,0,0,224,113,38,1,1,0,2,0,78,105,245,0,0,9,8,84,10,2,208,72,2,0,10,173,207,28] - 12
2022-06-25T09:55:38.446Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":57344,"srcaddr":9841,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":2,"securityuse":0,"timestamp":16083278,"transseqnumber":0,"len":9,"data":{"type":"Buffer","data":[8,84,10,2,208,72,2,0,10]}}
2022-06-25T09:55:38.448Z zigbee-herdsman:controller:log Received 'raw' data '{"clusterID":57344,"data":{"type":"Buffer","data":[8,84,10,2,208,72,2,0,10]},"address":9841,"endpoint":1,"linkquality":2,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2022-06-25T09:55:38.448Z zigbee-herdsman:controller:log 'raw' data is from unknown device with address '9841', skipping...
2022-06-25T09:55:38.448Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2022-06-25T09:55:38.852Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,53,68,129,0,0,6,0,113,38,1,1,0,34,0,80,110,245,0,0,33,8,85,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0,71,248,27,122]
2022-06-25T09:55:38.852Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,53,68,129,0,0,6,0,113,38,1,1,0,34,0,80,110,245,0,0,33,8,85,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0,71,248,27,122]
2022-06-25T09:55:38.852Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 53 - 2 - 4 - 129 - [0,0,6,0,113,38,1,1,0,34,0,80,110,245,0,0,33,8,85,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0,71,248,27] - 122
2022-06-25T09:55:38.852Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":6,"srcaddr":9841,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":34,"securityuse":0,"timestamp":16084560,"transseqnumber":0,"len":33,"data":{"type":"Buffer","data":[8,85,10,0,0,16,1,1,64,33,0,0,2,64,33,0,0,1,128,48,1,2,128,48,1,0,80,48,1,0,128,16,0]}}
2022-06-25T09:55:38.853Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":85,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":16,"attrData":1},{"attrId":16385,"dataType":33,"attrData":0},{"attrId":16386,"dataType":33,"attrData":0},{"attrId":32769,"dataType":48,"attrData":1},{"attrId":32770,"dataType":48,"attrData":1},{"attrId":20480,"dataType":48,"attrData":1},{"attrId":32768,"dataType":16,"attrData":0}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":9841,"endpoint":1,"linkquality":34,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2022-06-25T09:55:38.854Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '9841', skipping...
2022-06-25T09:55:38.854Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2022-06-25T09:55:39.243Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,70,68,129,0,0,1,224,113,38,1,1,0,42,0,20,115,245,0,0,50,8,86,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0,113,38,29,53]
2022-06-25T09:55:39.244Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,70,68,129,0,0,1,224,113,38,1,1,0,42,0,20,115,245,0,0,50,8,86,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0,113,38,29,53]
2022-06-25T09:55:39.244Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 70 - 2 - 4 - 129 - [0,0,1,224,113,38,1,1,0,42,0,20,115,245,0,0,50,8,86,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0,113,38,29] - 53
2022-06-25T09:55:39.244Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":57345,"srcaddr":9841,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":42,"securityuse":0,"timestamp":16085780,"transseqnumber":0,"len":50,"data":{"type":"Buffer","data":[8,86,10,16,208,48,1,48,208,48,0,0,208,32,1,1,208,27,0,0,0,0,2,208,35,242,229,35,0,3,208,35,140,0,0,0,4,208,35,249,48,0,0,5,208,35,250,5,0,0]}}
2022-06-25T09:55:39.247Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":86,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":53264,"dataType":48,"attrData":1},{"attrId":53296,"dataType":48,"attrData":0},{"attrId":53248,"dataType":32,"attrData":1},{"attrId":53249,"dataType":27,"attrData":0},{"attrId":53250,"dataType":35,"attrData":2352626},{"attrId":53251,"dataType":35,"attrData":140},{"attrId":53252,"dataType":35,"attrData":12537},{"attrId":53253,"dataType":35,"attrData":1530}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":9841,"endpoint":1,"linkquality":42,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2022-06-25T09:55:39.247Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '9841', skipping...
2022-06-25T09:55:39.247Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2022-06-25T09:55:39.634Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,35,68,129,0,0,0,0,113,38,1,1,0,42,0,227,119,245,0,0,15,8,87,10,1,0,32,74,226,255,32,53,228,255,32,1,113,38,29,179]
2022-06-25T09:55:39.635Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,35,68,129,0,0,0,0,113,38,1,1,0,42,0,227,119,245,0,0,15,8,87,10,1,0,32,74,226,255,32,53,228,255,32,1,113,38,29,179]
2022-06-25T09:55:39.635Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 35 - 2 - 4 - 129 - [0,0,0,0,113,38,1,1,0,42,0,227,119,245,0,0,15,8,87,10,1,0,32,74,226,255,32,53,228,255,32,1,113,38,29] - 179
2022-06-25T09:55:39.635Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":0,"srcaddr":9841,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":42,"securityuse":0,"timestamp":16087011,"transseqnumber":0,"len":15,"data":{"type":"Buffer","data":[8,87,10,1,0,32,74,226,255,32,53,228,255,32,1]}}
2022-06-25T09:55:39.636Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":87,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":1,"dataType":32,"attrData":74},{"attrId":65506,"dataType":32,"attrData":53},{"attrId":65508,"dataType":32,"attrData":1}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":9841,"endpoint":1,"linkquality":42,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2022-06-25T09:55:39.636Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '9841', skipping...
2022-06-25T09:55:39.636Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
Zigbee2MQTT:debug 2022-06-25 09:55:43: Received MQTT message on 'homeassistant/sensor/174' with data '{"time":"2022-06-25 09:55:42","model":"LaCrosse-TX141THBv2","id":174,"channel":0,"battery_ok":0,"temperature_C":26.7,"humidity":44,"test":"No","mic":"CRC"}'
2022-06-25T09:55:44.290Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,13,69,201,113,38,120,203,244,76,60,56,193,164,0,0,0,188]
2022-06-25T09:55:44.290Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,13,69,201,113,38,120,203,244,76,60,56,193,164,0,0,0,188]
2022-06-25T09:55:44.290Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 13 - 2 - 5 - 201 - [113,38,120,203,244,76,60,56,193,164,0,0,0] - 188
2022-06-25T09:55:44.291Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - leaveInd - {"srcaddr":9841,"extaddr":"0xa4c1383c4cf4cb78","request":0,"removechildren":0,"rejoin":0}
2022-06-25T09:55:44.291Z zigbee-herdsman:controller:log Device leave '0xa4c1383c4cf4cb78'
Zigbee2MQTT:warn 2022-06-25 09:55:44: Device '0xa4c1383c4cf4cb78' left the network
Fait nouveau, j’ai tenté l’inclusion d’une lampe ikea (non utilisé jusque la)=> rien du tout de chez rien du tout ! => soit c’est c’est du coté du routeur (CC2531) soit coté Z2M.
En bref mon install est ok pour les module appairés mais impossible d’appairer de nouveaux devices. Je vais suivre voire compléter l’issue 12813 car la description est en tout point identique.
Le seul point qui puisse m’aider et je pense une confirmation d’autres membres en config similaire.
