Ce matin tous mes devices Zigbee2MQTT étaient hors ligne. Depuis le démarrage du module est en échec. Il n’y a pas eu de mise à jour récente de ce module et je n’ai pas changé la configuration.
La clé est une Sonoff_Zigbee_3.0_USB_Dongle_Plus. Elle fonctionnait sans problème depuis plusieurs mois! Est-elle en panne?
[16:19:30] INFO: Preparing to start...
[16:19:30] INFO: Socat not enabled
[16:19:31] INFO: Starting Zigbee2MQTT...
[2024-05-24 16:19:33] info: z2m: Logging to console, file (filename: log.log)
[2024-05-24 16:19:33] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-24 16:19:33] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-24 16:19:33] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-05-24 16:19:33] info: zh:zstack:znp: Serialport opened
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: - PAN ID: configured=11281, adapter=6754
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: - Extended PAN ID: configured=01ced0bf937b6e7b, adapter=00124b00257e14a8
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: - Network Key: configured=e9c5de3107df1a8829a420b655e87e6d, adapter=01030507090b0d0f00020406080a0c0d
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: - Channel List: configured=11, adapter=11
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /config/zigbee2mqtt/coordinator_backup.json.
[2024-05-24 16:19:33] error: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
[2024-05-24 16:19:33] error: z2m: Error while starting zigbee-herdsman
[2024-05-24 16:19:33] error: z2m: Failed to start zigbee
[2024-05-24 16:19:33] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-05-24 16:19:33] error: z2m: Exiting...
[2024-05-24 16:19:33] error: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at ZnpAdapterManager.determineStrategy (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:223:35)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:57:26)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:124:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
version
core-2024.5.4
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.12.2
os_name
Linux
os_version
6.6.25-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
5000
Installed Version
1.34.0
Stage
running
Available Repositories
1395
Downloaded Repositories
53
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 12.2
update_channel
stable
supervisor_version
supervisor-2024.05.1
agent_version
1.6.0
docker_version
25.0.5
disk_total
234.0 GB
disk_used
39.5 GB
healthy
true
supported
true
board
generic-x86-64
supervisor_api
ok
version_api
ok
installed_addons
Studio Code Server (5.15.0), Home Assistant Google Drive Backup (0.112.1), Node-RED (17.0.12), Samba share (12.3.1), Duck DNS (1.17.0), File editor (5.8.0), ESPHome (2024.5.2), Zigbee2MQTT (1.37.1-1), NGINX Home Assistant SSL proxy (3.9.0), SQLite Web (4.1.2), Mosquitto broker (6.4.0), Music Assistant BETA (2.1.0b1), Advanced SSH & Web Terminal (17.3.0), MQTT Explorer (browser-1.0.3), RTSPtoWeb - WebRTC (1.4.0), AppDaemon (0.16.6)
D’après ce que je lis, il y a 2 configurations diffférentes (par rapport à configuration.yaml dans le dossier zigbee2mqtt)
Et il t’indique la solution en supprimant le fichier coordinator_backup.json (dans le répertoire zigbee2mqtt).
En fait il vaut mieux le renommer en coordinator_backup.jsonbak, après avoir arrêté le module zigbee2mqtt.
Relancer le module et normalement, le fichier sera reconstruit avec les bon paramètres.
