Voici le rapport SMART sur le premier disque :
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: WD-WCC7K3DV7NTE
LU WWN Device Id: 5 0014ee 2bae24b20
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Sep 5 19:12:33 2023 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (44700) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 474) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 168 165 021 Pre-fail Always - 6558
4 Start_Stop_Count 0x0032 094 094 000 Old_age Always - 6972
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 071 071 000 Old_age Always - 21273
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 095 095 000 Old_age Always - 5578
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 87
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 6916
194 Temperature_Celsius 0x0022 121 109 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 2
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
#01 Short offline Completed without error 00% 20309 -
#02 Short offline Completed without error 00% 20104 -
#03 Short offline Completed without error 00% 19836 -
#04 Short offline Completed without error 00% 19468 -
#05 Short offline Completed without error 00% 18796 -
#06 Short offline Completed without error 00% 18058 -
#07 Short offline Completed without error 00% 17398 -
#08 Short offline Completed without error 00% 16731 -
#09 Short offline Completed without error 00% 16041 -
#10 Short offline Completed without error 00% 14500 -
#11 Short offline Completed without error 00% 14283 -
#12 Short offline Completed without error 00% 14154 -
#13 Short offline Completed without error 00% 13501 -
#14 Short offline Completed without error 00% 12972 -
#15 Short offline Completed without error 00% 11774 -
#16 Short offline Completed without error 00% 11115 -
#17 Short offline Completed without error 00% 10373 -
#18 Short offline Completed without error 00% 9654 -
#19 Short offline Completed without error 00% 9020 -
#20 Short offline Completed without error 00% 7758 -
#21 Short offline Completed without error 00% 7171 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Et sur le second :
Model Family: Seagate IronWolf
Device Model: ST4000VN008-2DR166
Serial Number: ZGY8ZZYA
LU WWN Device Id: 5 000c50 0c8f6faae
Firmware Version: SC60
Rotation Rate: 5980 rpm
Local Time is: Tue Sep 5 19:16:09 2023 CEST
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
been run.
data collection: ( 581) seconds.
command.
power-saving mode.
recommended polling time: ( 1) minutes.
recommended polling time: ( 612) minutes.
SCT capabilities: (0x50bd) SCT Status supported.
SMART Attributes Data Structure revision number: 10
1 Raw_Read_Error_Rate 0x000f 100 064 044 Pre-fail Always - 19014
3 Spin_Up_Time 0x0003 093 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 098 098 020 Old_age Always - 2664
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 078 060 045 Pre-fail Always - 66449997
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5926 (166 171 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 098 098 020 Old_age Always - 2561
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 069 054 040 Old_age Always - 31 (Min/Max 25/31)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 099 099 000 Old_age Always - 2693
194 Temperature_Celsius 0x0022 031 046 000 Old_age Always - 31 (0 16 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 5911h+38m+03.393s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 27745769585
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 23497647696
No Errors Logged
#1 Short offline Completed without error 00% 4951 -
#2 Short offline Completed without error 00% 4744 -
#3 Short offline Completed without error 00% 4474 -
#4 Short offline Completed without error 00% 4106 -
#5 Short offline Completed without error 00% 3432 -
#6 Short offline Completed without error 00% 2694 -
#7 Short offline Completed without error 00% 2033 -
#8 Short offline Completed without error 00% 1364 -
#9 Short offline Completed without error 00% 672 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
