bonjour à tous,
je n’ai plus accès au schéma (ca tourne sans fin). existe il un moyen d’y remédier ?
Merci pour votre aide
Sans aucune description de la configuration, ça va être difficile…
Dans ces conditions, le seul conseil possible, c’est de relancer le container/add-on z2m.
Merci pour ton message
j’ai un rpi 4 avec une clef sonof E. la version de Zigbee2MQTT
Current version: 1.36.0-1.
Il faut autre chose?
regarder dans les logs de Z2M quand tu fait un scan du réseau. Soit tu ouvre une deuxième page pour regarder les logs pendant le scan. Sinon tu peu regarder les logs dans le dossier /config/zigbee2mqtt/log.
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/sonde noam', payload '{"battery":50,"humidity":47.12,"linkquality":76,"power_outage_count":16607,"pressure":996,"temperature":22.07,"voltage":2925}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/sonde julie', payload '{"battery":100,"humidity":61.66,"linkquality":44,"power_outage_count":369,"pressure":994.1,"temperature":14.66,"voltage":3005}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Aqara Entrée', payload '{"action":null,"battery":86,"linkquality":236,"operation_mode":null,"power_outage_count":80,"voltage":2979}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/inter double maxime', payload '{"action":null,"device_temperature":21,"flip_indicator_light":null,"linkquality":240,"mode_switch":"quick_mode","operation_mode_left":null,"operation_mode_right":null,"power_outage_count":15,"power_outage_memory":null,"state_left":"OFF","state_right":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.09,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":238,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/prise Lampe salon', payload '{"child_lock":"UNLOCK","current":0,"energy":7.96,"indicator_mode":"off/on","linkquality":240,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":239}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/boutoncirculaire', payload '{"action":null,"action_rate":null,"action_step_size":null,"action_transition_time":null,"battery":100,"linkquality":104,"operation_mode":"command","voltage":3000}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Prise_cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":168,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":241}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/prise_buffet', payload '{"child_lock":"UNLOCK","current":0,"energy":0.11,"indicator_mode":"off/on","linkquality":156,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":240}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/sonde_tom', payload '{"battery":100,"humidity":60.07,"linkquality":56,"power_outage_count":17707,"pressure":993.6,"temperature":18.65,"voltage":3105}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Ikea store G', payload '{"battery":80,"linkquality":76,"position":100,"state":"OPEN","update":{"installed_version":604241939,"latest_version":604241939,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/sonoff ext julie', payload '{"linkquality":32,"state":"OFF"}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/sonoff couloir', payload '{"linkquality":44,"state":"OFF"}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/sonde Amis', payload '{"battery":90,"humidity":61.14,"linkquality":156,"power_outage_count":10129,"pressure":994.5,"temperature":17.36,"voltage":2985}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Bouton_hue', payload '{"action":null,"battery":100,"linkquality":252,"update":{"installed_version":33566472,"latest_version":33566472,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Intertriple_sam', payload '{"backlight_mode":"medium","linkquality":172,"power_on_behavior":null,"power_on_behavior_left":"off","state_center":"OFF","state_left":"OFF","state_right":"OFF"}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Ikea répéteur cuisine', payload '{"linkquality":220,"update":{"installed_version":587753009,"latest_version":587753009,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Inter simple Maxime', payload '{"backlight_mode":null,"linkquality":104,"power_on_behavior":null,"state":"OFF"}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Ikea répéteur couloir', payload '{"linkquality":92,"update":{"installed_version":587753009,"latest_version":587753009,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/tradfri G', payload '{"action":null,"battery":1,"click":null,"linkquality":168,"update":{"installed_version":604241926,"latest_version":604241926,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/Ikea store D', payload '{"battery":96,"linkquality":164,"position":100,"state":"OPEN","update":{"installed_version":604241939,"latest_version":604241939,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2024-03-23 17:14:17: MQTT publish: topic 'zigbee2mqtt/tradfri D', payload '{"action":null,"battery":1,"click":null,"linkquality":176,"update":{"installed_version":604241926,"latest_version":604241926,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2024-03-23 17:14:18: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.09,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":219,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:19: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.17,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":219,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:23: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.17,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":230,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:24: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.95,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":230,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:28: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.95,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":154,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:29: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.2,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":154,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:30: MQTT publish: topic 'zigbee2mqtt/Prise_cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":172,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":241}'
Zigbee2MQTT:info 2024-03-23 17:14:31: MQTT publish: topic 'zigbee2mqtt/Prise_cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":172,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":241}'
Zigbee2MQTT:info 2024-03-23 17:14:33: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.2,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":184,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:34: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.86,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":184,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:36: MQTT publish: topic 'zigbee2mqtt/sonde Amis', payload '{"battery":83,"humidity":55.43,"linkquality":144,"power_outage_count":10129,"pressure":991.5,"temperature":18.05,"voltage":2975}'
Zigbee2MQTT:info 2024-03-23 17:14:38: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.86,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":151,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:39: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.74,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":151,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:42: MQTT publish: topic 'zigbee2mqtt/Prise_cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":172,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":241}'
Zigbee2MQTT:info 2024-03-23 17:14:43: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.74,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":197,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:44: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.08,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":197,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:48: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.08,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":212,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:56: MQTT publish: topic 'zigbee2mqtt/sonoff couloir', payload '{"linkquality":40,"state":"OFF"}'
Zigbee2MQTT:info 2024-03-23 17:14:56: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.64,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":212,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:14:56: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.64,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":128,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:00: Starting network scan (includeRoutes 'false')
Zigbee2MQTT:info 2024-03-23 17:15:06: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.64,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":142,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:07: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.64,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":142,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:09: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.64,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":163,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:12: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.76,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":163,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:14: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.76,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":213,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:21: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.02,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":213,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:30: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.02,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":225,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:40: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.02,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":246,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:42: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.13,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":246,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:51: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.13,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":259,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:15:59: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.13,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":270,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:16:04: MQTT publish: topic 'zigbee2mqtt/inter double maxime', payload '{"action":null,"device_temperature":22,"flip_indicator_light":null,"linkquality":240,"mode_switch":"quick_mode","operation_mode_left":null,"operation_mode_right":null,"power_outage_count":15,"power_outage_memory":null,"state_left":"OFF","state_right":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null}'
Zigbee2MQTT:info 2024-03-23 17:16:04: MQTT publish: topic 'zigbee2mqtt/prise Lampe salon', payload '{"child_lock":"UNLOCK","current":0,"energy":7.96,"indicator_mode":"off/on","linkquality":240,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":239}'
Zigbee2MQTT:info 2024-03-23 17:16:10: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.14,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":270,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:16:10: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.14,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":231,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:16:15: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.05,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":231,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:16:15: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.05,"energy":94.73,"indicator_mode":"off/on","linkquality":252,"power":302,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:16:15: MQTT publish: topic 'zigbee2mqtt/prise Lampe salon', payload '{"child_lock":"UNLOCK","current":0,"energy":7.96,"indicator_mode":"off/on","linkquality":240,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":239}'
Zigbee2MQTT:info 2024-03-23 17:16:20: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.19,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":302,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:16:20: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.19,"energy":94.73,"indicator_mode":"off/on","linkquality":255,"power":257,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:16:28: MQTT publish: topic 'zigbee2mqtt/prise Lampe salon', payload '{"child_lock":"UNLOCK","current":0,"energy":7.96,"indicator_mode":"off/on","linkquality":236,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":239}'
Zigbee2MQTT:info 2024-03-23 17:16:28: MQTT publish: topic 'zigbee2mqtt/prise Lampe salon', payload '{"child_lock":"UNLOCK","current":0,"energy":7.96,"indicator_mode":"off/on","linkquality":240,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":240}'
Zigbee2MQTT:info 2024-03-23 17:16:39: MQTT publish: topic 'zigbee2mqtt/prise Lampe salon', payload '{"child_lock":"UNLOCK","current":0,"energy":7.96,"indicator_mode":"off/on","linkquality":240,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":240}'
Zigbee2MQTT:info 2024-03-23 17:16:39: Starting network scan (includeRoutes 'false')
Zigbee2MQTT:info 2024-03-23 17:16:43: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.19,"energy":94.74,"indicator_mode":"off/on","linkquality":252,"power":257,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:17:11: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":1.19,"energy":94.74,"indicator_mode":"off/on","linkquality":252,"power":88,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:17:13: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.53,"energy":94.74,"indicator_mode":"off/on","linkquality":255,"power":88,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:17:18: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.53,"energy":94.74,"indicator_mode":"off/on","linkquality":252,"power":88,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:17:31: MQTT publish: topic 'zigbee2mqtt/prise Lampe salon', payload '{"child_lock":"UNLOCK","current":0,"energy":7.96,"indicator_mode":"off/on","linkquality":240,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":237}'
Zigbee2MQTT:info 2024-03-23 17:17:31: MQTT publish: topic 'zigbee2mqtt/Prise_cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":156,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":239}'
Zigbee2MQTT:info 2024-03-23 17:18:10: MQTT publish: topic 'zigbee2mqtt/sonoff ext julie', payload '{"linkquality":40,"state":"OFF"}'
Zigbee2MQTT:info 2024-03-23 17:18:12: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.53,"energy":94.74,"indicator_mode":"off/on","linkquality":252,"power":77,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:18:36: MQTT publish: topic 'zigbee2mqtt/prise_buffet', payload '{"child_lock":"UNLOCK","current":0,"energy":0.11,"indicator_mode":"off/on","linkquality":148,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":240}'
Zigbee2MQTT:info 2024-03-23 17:18:36: MQTT publish: topic 'zigbee2mqtt/prise_buffet', payload '{"child_lock":"UNLOCK","current":0,"energy":0.11,"indicator_mode":"off/on","linkquality":152,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":238}'
Zigbee2MQTT:info 2024-03-23 17:18:47: MQTT publish: topic 'zigbee2mqtt/prise_buffet', payload '{"child_lock":"UNLOCK","current":0,"energy":0.11,"indicator_mode":"off/on","linkquality":152,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":238}'
Zigbee2MQTT:info 2024-03-23 17:18:50: MQTT publish: topic 'zigbee2mqtt/sonoff couloir', payload '{"linkquality":40,"state":"OFF"}'
Zigbee2MQTT:info 2024-03-23 17:19:35: MQTT publish: topic 'zigbee2mqtt/Prise_cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":168,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":239}'
Zigbee2MQTT:info 2024-03-23 17:19:46: MQTT publish: topic 'zigbee2mqtt/Prise_cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":168,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":239}'
Zigbee2MQTT:info 2024-03-23 17:20:39: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.5,"energy":94.74,"indicator_mode":"off/on","linkquality":255,"power":77,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Zigbee2MQTT:info 2024-03-23 17:20:39: MQTT publish: topic 'zigbee2mqtt/prise zigbee', payload '{"child_lock":"LOCK","current":0.5,"energy":94.74,"indicator_mode":"off/on","linkquality":255,"power":80,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":243}'
Ta pas d’erreur dans les logs.
Un soucis du navigateur peu être, essayer de vider le cache et retenter.
J’utilise chrome, est pas de soucis avec la dernière versiuon de Z2M.
merci
ca ne marche pas non plus sur chrome ou sur un autre ordi
Ta essayer de redémarrer HA ?
Ça peut mettre un certain temps à apparaître. Quand je le consulte, je laisse la fenêtre sans y toucher et je reviens dessus 20 à 30 minutes plus tard.
chez moi avec 69 appareils et un RPI4, ca me l’affiche en moins de 2min.
Je ne sais pas combien de temps ça met.J’ai jamais eu la patience d’attendre devant ![]()
le message dit entre 10sec a 2min. le temps d’aller pisser ![]()
merci oui j’ai redémarré plusieurs fois.
avant ca mettait moins de 2 minutes
Alors le temps est vraiment magnifique indicatif cela dépend bcp de la qualité du réseau de sa taille et d’autres paramètres que je ne maîtrise pas.
Mais chez moi 200 devices je tourne aux alentours de 6/7 minutes en gros
j’ai un répéteur sono (zb mini) avec cette erreur depuis peu . c’est peut être cela qui bloquel e schéma ?
Pourtant il est à 5m d’un autre répéteur
Failed to configure 'sonoff couloir', attempt 4 (Error: {"address":11219,"clusterId":32801,"sequence":70} after 10000ms at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at Driver.zdoRequest (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:659:43) at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:574:13 at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:551:13) at setupAttributes (/app/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:56:13) at result.configure (/app/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:125:13) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/index.ts:141:25) at Configure.configure (/app/lib/extension/configure.ts:122:13) at Configure.onMQTTMessage (/app/lib/extension/configure.ts:55:21))
Alors des erreur de ce type là j’en ai plein sur mon z2m plus des erreur de rapport plus des erreur de Bind alors que je ne Bind pas du tout !!
Donc je dirais non
Pour moi z2m commence enfin ça fait un moment qu’il est gros gros et qu’il a du mal à suivre toute la chaîne.
A mon avis il a besoin d’un gros refresh et de passer en V2
