depuis la dernière mise à jour de l’addon de gestion des onduleurs,
j’ai un plantage de cette addon :
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] nut: applying...
[fix-attrs.d] nut: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Network UPS Tools
Manage battery backup (UPS) devices
Add-on version: 0.4.0
You are running the latest version of this add-on.
System: Ubuntu 20.04.1 LTS (amd64 / qemux86-64)
Home Assistant Core: 2021.1.5
Home Assistant Supervisor: 2021.01.7
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nut.sh: executing...
[17:47:25] INFO: Setting mode to netserver...
[17:47:26] INFO: Generating /etc/nut/upsd.users...
[17:47:26] INFO: Configuring user: stephane
[17:47:27] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[17:47:30] INFO: Configuring Device named myups...
[17:47:30] INFO: Starting the UPS drivers...
Network UPS Tools - UPS driver controller 2.7.4
Network UPS Tools - Generic HID driver 0.41 (2.7.4)
No matching HID UPS found
Driver failed to start (exit status=1)
USB communication driver 0.33
[cont-init.d] nut.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
j’ai tenté de supprimer et réinstaller l’addon mais c’est identique !
je reviens sur mon sujet d’onduleur,
mon système a planté hier,
démarrage de hass en mode sans échec !
depuis, j’ai de nouveau le même message d’erreur sur mon addon UPS tools
sauf que en plus, même en supprimant et mettant une sauvegarde ancienne, cela ne corrige plus le problème
il y a depuis une nouvelle version 0.5.0 mais toujours pareil
@pepite
tu m’avait conseillé de supprimer le dossier de l’addon dans le répertoire .storage
mais sais tu ce qu’il faut supprimer ?
drwxr-xr-x 5 root root 4096 Feb 10 20:10 .
drwxr-xr-x 16 root root 4096 Feb 10 20:13 ..
-rw------- 1 root root 32727 Feb 10 20:10 auth
-rw------- 1 root root 168 Jan 3 08:16 auth_module.totp
-rw------- 1 root root 827 Nov 26 10:49 auth_provider.homeassistant
-rw-r--r-- 1 root root 1348 Mar 28 2020 core.area_registry
-rw------- 1 root root 393 Nov 29 07:14 core.config
-rw-r--r-- 1 root root 35720 Feb 10 18:02 core.config_entries
-rw-r--r-- 1 root root 120210 Feb 9 22:57 core.device_registry
-rw-r--r-- 1 root root 322875 Feb 9 22:32 core.entity_registry
-rw-r--r-- 1 root root 107909 Feb 10 20:02 core.restore_state
-rw------- 1 root root 116 Jun 10 2020 core.uuid
-rw-r--r-- 1 root root 1833 Feb 9 22:34 esphome.04bdc22723d37c1e8c8b30b6f1d0e718
-rw-r--r-- 1 root root 686 May 6 2020 esphome.095685601ec24e888c4b5484aae0e12d
-rw-r--r-- 1 root root 2030 Jun 8 2020 esphome.09693d5999fe49f0a8359411ad459c7a
-rw-r--r-- 1 root root 871 Feb 9 22:34 esphome.0df8a6430a6311ebbcbea754e1198d8e
-rw-r--r-- 1 root root 1552 Feb 5 20:26 esphome.0eb6db47bcd598e621387098485f69f5
-rw-r--r-- 1 root root 2030 Jun 9 2020 esphome.283a3213285647c1b6e103d39ac1f670
-rw-r--r-- 1 root root 1225 Dec 14 17:30 esphome.37005554c58f460a814639372f49484c
-rw-r--r-- 1 root root 1315 Apr 9 2020 esphome.412c3d6de52c4505864bef071f1e3d19
-rw-r--r-- 1 root root 686 May 6 2020 esphome.463d0c7ca6ab4dad8fbd5bba213d3111
-rw-r--r-- 1 root root 2028 May 2 2020 esphome.48c42033366c4ba6a46c9749903892d7
-rw-r--r-- 1 root root 2109 Feb 9 22:34 esphome.62633704ff2911eabbafe30b7c00df10
-rw-r--r-- 1 root root 1629 Dec 24 13:41 esphome.62aac0c90ce13c76f75b20264ca23f54
-rw-r--r-- 1 root root 995 Jan 9 23:39 esphome.6437d666301f07af90ac158144f04490
-rw-r--r-- 1 root root 1278 Jun 1 2020 esphome.691bb31612d149498b2d9e663586c419
-rw-r--r-- 1 root root 3865 Oct 13 19:36 esphome.6d515277fbd211ea8f60dd8604ff72f6
-rw-r--r-- 1 root root 1635 Feb 10 06:59 esphome.74a98a98ccfdb543065b7c517353d2d2
-rw-r--r-- 1 root root 6464 Feb 9 22:34 esphome.888296920d8211ebb37a0d51e5a061f0
-rw-r--r-- 1 root root 1308 Feb 9 22:34 esphome.a5df52c29d0b48a2a54d5f33e1da623c
-rw-r--r-- 1 root root 1114 Aug 1 2020 esphome.c4b48f31faa047859cf9f595d3884b0d
-rw-r--r-- 1 root root 1641 May 31 2020 esphome.c96a2a0ff277460195156cc402344559
-rw-r--r-- 1 root root 1629 Jan 9 23:39 esphome.e1d1001066c98076a8262c6cbd0038b2
-rw-r--r-- 1 root root 1811 Feb 9 22:34 esphome.f84c34ae10a311eb8df19d29fd01ee5d
-rw-r--r-- 1 root root 686 May 6 2020 esphome.faacb2ff07bc4637b5f1d992b4c4fa4d
drwxr-xr-x 2 root root 4096 Apr 24 2020 freebox
-rw-r--r-- 1 root root 230 Apr 8 2020 frontend.user_data_73ee4ea3732b4de7a2571132bfe04edd
-rw-r--r-- 1 root root 159 Feb 10 08:21 frontend_theme
drwxr-xr-x 2 root root 4096 Feb 10 20:02 hacs
-rw-r--r-- 1 root root 295 Feb 9 20:53 hacs.critical
-rw-r--r-- 1 root root 150 Feb 9 20:53 hacs.hacs
-rw-r--r-- 1 root root 980793 Feb 10 19:32 hacs.repositories
-rw-r--r-- 1 root root 120 Mar 22 2020 hassio
-rw-r--r-- 1 root root 538 Feb 9 22:18 homekit.64b09babfc79517d87ed6fe158508c9b.aids
-rw-r--r-- 1 root root 236 Feb 9 22:18 homekit.64b09babfc79517d87ed6fe158508c9b.state
-rw-r--r-- 1 root root 4265 Feb 8 17:43 homekit.6e5aac123ca707d8b2aed566770706f7.aids
-rw-r--r-- 1 root root 236 Feb 8 17:43 homekit.6e5aac123ca707d8b2aed566770706f7.state
-rw-r--r-- 1 root root 283 Feb 9 22:31 http
drwxr-xr-x 2 root root 4096 Apr 1 2020 icloud
-rw-r--r-- 1 root root 362 Sep 18 06:46 image
-rw-r--r-- 1 root root 1488 Dec 20 07:06 input_boolean
-rw-r--r-- 1 root root 90 Dec 4 16:23 input_datetime
-rw-r--r-- 1 root root 1929 Jan 9 07:01 input_number
-rw-r--r-- 1 root root 75016 Feb 8 16:55 lovelace
-rw-r--r-- 1 root root 696 Dec 27 20:11 lovelace_resources
-rw-r--r-- 1 root root 214930 Feb 10 19:48 mobile_app
-rw------- 1 root root 167 Mar 22 2020 onboarding
-rw-r--r-- 1 root root 1345 Nov 30 08:50 person
-rw-r--r-- 1 root root 5998 Dec 23 07:38 scheduler.storage
-rw-r--r-- 1 root root 311 Dec 23 20:45 tag
-rw------- 1 root root 0 Dec 30 19:24 tmpg8mx1jzb
-rw-r--r-- 1 root root 1359 Dec 26 14:51 zone
.storage $
Il ne faut pas que tu supprimes un des fichiers.
Il faut que tu ailles LIRE un fichier et trouver dans lequel est ton addon. Je n’ai pas sous les yeux.
Je dirais dans un des "core."xxxxxxxxx
