Hello, cela fait quelques temps que z2m plante fréquemment, ça tient désormais seulement quelques minutes avant de planter et je suis obligé de le reboot manuellement.
Voici les logs : (dernières remontées de capteur à 22:44:01, j’ai des pinces ampèremétriques sur la conso de la maison donc ça remonte très fréquemment des data)
Z2M
2024-03-25T21:42:57.119Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":104,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5669}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":150,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.121Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,133,52,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,242,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,233,73,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,212,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,248,100,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,223,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,38,122,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,40,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,166,149,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,112,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,31,171,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,197,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,100,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.121Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,133,52,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29] - 242
2024-03-25T21:42:57.122Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5780613,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,50,1,0,33,19,2,0,4,0,0,0,132]}}
2024-03-25T21:42:57.125Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":50,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8448,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,132]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.125Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.126Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,233,73,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,212,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,248,100,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,223,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,38,122,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,40,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,166,149,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,112,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,31,171,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,197,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,100,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.126Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,150,0,233,73,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29] - 212
2024-03-25T21:42:57.126Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":150,"securityuse":0,"timestamp":5786089,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,104,10,0,0,41,37,22]}}
2024-03-25T21:42:57.128Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":104,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5669}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":150,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.130Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,248,100,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,223,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,38,122,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,40,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,166,149,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,112,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,31,171,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,197,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,100,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.130Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,248,100,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29] - 223
2024-03-25T21:42:57.301Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5793016,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,50,1,0,33,19,2,0,4,0,0,0,132]}}
2024-03-25T21:42:57.306Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":50,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8448,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,132]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.306Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.306Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,38,122,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,40,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,166,149,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,112,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,31,171,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,197,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,100,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.307Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,150,0,38,122,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29] - 40
2024-03-25T21:42:57.307Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":150,"securityuse":0,"timestamp":5798438,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,104,10,0,0,41,37,22]}}
2024-03-25T21:42:57.309Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":104,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5669}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":150,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.311Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,166,149,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29,112,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,31,171,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,197,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,100,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.311Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,166,149,88,0,0,13,9,50,1,0,33,19,2,0,4,0,0,0,132,22,231,29] - 112
2024-03-25T21:42:57.312Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5805478,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,50,1,0,33,19,2,0,4,0,0,0,132]}}
2024-03-25T21:42:57.315Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":50,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8448,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,132]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.315Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.316Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,31,171,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,197,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,100,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.317Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,147,0,31,171,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29] - 197
2024-03-25T21:42:57.318Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":147,"securityuse":0,"timestamp":5810975,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,104,10,0,0,41,37,22]}}
2024-03-25T21:42:57.320Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":104,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5669}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":147,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.322Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29,100,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.322Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,147,0,206,219,88,0,0,8,8,104,10,0,0,41,37,22,209,108,29] - 100
2024-03-25T21:42:57.323Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":147,"securityuse":0,"timestamp":5823438,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,104,10,0,0,41,37,22]}}
2024-03-25T21:42:57.325Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":104,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5669}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":147,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.328Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,251,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.328Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,143,247,88,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29] - 251
2024-03-25T21:42:57.328Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5830543,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,51,1,0,34,20,2,0,4,0,0,9,72]}}
2024-03-25T21:42:57.332Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":51,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8704,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,9,72]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.332Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.333Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,45,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.333Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,150,0,84,12,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29] - 45
2024-03-25T21:42:57.334Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":150,"securityuse":0,"timestamp":5835860,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,104,10,0,0,41,37,22]}}
2024-03-25T21:42:57.336Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":104,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5669}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":150,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.338Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,148,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.339Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,62,40,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29] - 148
2024-03-25T21:42:57.339Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5843006,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,51,1,0,34,20,2,0,4,0,0,9,72]}}
2024-03-25T21:42:57.343Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":51,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8704,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,9,72]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.343Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.343Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29,92,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.344Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,150,0,20,61,89,0,0,8,8,104,10,0,0,41,37,22,209,108,29] - 92
2024-03-25T21:42:57.344Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":150,"securityuse":0,"timestamp":5848340,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,104,10,0,0,41,37,22]}}
2024-03-25T21:42:57.346Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":104,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5669}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":150,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.348Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,2,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.348Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,216,88,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29] - 2
2024-03-25T21:42:57.349Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5855448,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,51,1,0,34,20,2,0,4,0,0,9,72]}}
2024-03-25T21:42:57.353Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":51,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8704,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,9,72]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.353Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.354Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29,186,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.354Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,177,137,89,0,0,13,9,51,1,0,34,20,2,0,4,0,0,9,72,22,231,29] - 186
2024-03-25T21:42:57.354Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5867953,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,51,1,0,34,20,2,0,4,0,0,9,72]}}
2024-03-25T21:42:57.358Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":51,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8704,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,9,72]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.359Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.359Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,214,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.359Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,93,235,89,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29] - 214
2024-03-25T21:42:57.359Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5892957,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,52,1,0,35,17,2,0,4,0,11,106,193]}}
2024-03-25T21:42:57.363Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":52,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8960,"dpValues":[{"dp":17,"datatype":2,"data":{"type":"Buffer","data":[0,11,106,193]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.364Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.364Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,116,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.364Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,11,28,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29] - 116
2024-03-25T21:42:57.365Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5905419,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,52,1,0,35,17,2,0,4,0,11,106,193]}}
2024-03-25T21:42:57.369Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":52,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8960,"dpValues":[{"dp":17,"datatype":2,"data":{"type":"Buffer","data":[0,11,106,193]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.369Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.369Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,218,254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.369Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,245,76,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29] - 218
2024-03-25T21:42:57.370Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5917941,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,52,1,0,35,17,2,0,4,0,11,106,193]}}
2024-03-25T21:42:57.374Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":52,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8960,"dpValues":[{"dp":17,"datatype":2,"data":{"type":"Buffer","data":[0,11,106,193]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.374Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.374Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,33,68,129,0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29,167]
2024-03-25T21:42:57.374Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 33 - 2 - 4 - 129 - [0,0,0,239,22,231,1,1,0,138,0,185,125,90,0,0,13,9,52,1,0,35,17,2,0,4,0,11,106,193,22,231,29] - 167
2024-03-25T21:42:57.375Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":61184,"srcaddr":59158,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":138,"securityuse":0,"timestamp":5930425,"transseqnumber":0,"len":13,"data":{"type":"Buffer","data":[9,52,1,0,35,17,2,0,4,0,11,106,193]}}
2024-03-25T21:42:57.379Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":52,"manufacturerCode":null,"commandIdentifier":1},"Payload":{"seq":8960,"dpValues":[{"dp":17,"datatype":2,"data":{"type":"Buffer","data":[0,11,106,193]}}]},"Command":{"ID":1,"parameters":[{"name":"seq","type":33},{"name":"dpValues","type":1011}],"name":"dataResponse"}},"address":59158,"endpoint":1,"linkquality":138,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:42:57.379Z zigbee-herdsman:controller:log 'zcl' data is from unknown device with address '59158', skipping...
2024-03-25T21:42:57.380Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2024-03-25T21:42:59.920Z zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequest - {"dstaddr":13220,"destendpoint":1,"srcendpoint":1,"clusterid":2820,"transid":43,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[16,8,0,5,5,8,5,11,5]}}
2024-03-25T21:42:59.972Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,19,36,1,164,51,1,1,4,11,43,0,30,9,16,8,0,5,5,8,5,11,5,137]
2024-03-25T21:43:00.443Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,68,129,0,0,4,11,209,108,1,1,0,123,0,174,8,92,0,0,8,24,105,10,11,5,41,84,1,209,108,29,75,254,28,68,129,0,0,2,4,209,108,1,1,0,123,0,232,73,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,202,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,70,122,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,186,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,28,171,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,49,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,230,219,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,187,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,180,12,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,63,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,78,61,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,241,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,226,109,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,13,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,204,158,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,208,254,1,100,1,0,100,254,3,68,128,0,1,42,236,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,75,207,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,6,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,90,0,94,0,0,8,8,106,10,0,0,41,209,22,209,108,29,219]
2024-03-25T21:43:00.443Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,4,11,209,108,1,1,0,123,0,174,8,92,0,0,8,24,105,10,11,5,41,84,1,209,108,29,75,254,28,68,129,0,0,2,4,209,108,1,1,0,123,0,232,73,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,202,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,70,122,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,186,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,28,171,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,49,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,230,219,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,187,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,180,12,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,63,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,78,61,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,241,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,226,109,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,13,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,204,158,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,208,254,1,100,1,0,100,254,3,68,128,0,1,42,236,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,75,207,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,6,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,90,0,94,0,0,8,8,106,10,0,0,41,209,22,209,108,29,219]
2024-03-25T21:43:00.443Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,4,11,209,108,1,1,0,123,0,174,8,92,0,0,8,24,105,10,11,5,41,84,1,209,108,29] - 75
2024-03-25T21:43:00.590Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":2820,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":123,"securityuse":0,"timestamp":6031534,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[24,105,10,11,5,41,84,1]}}
2024-03-25T21:43:00.703Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":105,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":1291,"dataType":41,"attrData":340}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":123,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:43:00.898Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,123,0,232,73,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,202,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,70,122,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,186,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,28,171,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,49,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,230,219,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,187,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,180,12,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,63,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,78,61,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,241,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,226,109,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,13,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,204,158,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,208,254,1,100,1,0,100,254,3,68,128,0,1,42,236,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,75,207,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,6,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,90,0,94,0,0,8,8,106,10,0,0,41,209,22,209,108,29,219]
2024-03-25T21:43:00.899Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,123,0,232,73,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29] - 202
2024-03-25T21:43:00.900Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":123,"securityuse":0,"timestamp":6048232,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,106,10,0,0,41,209,22]}}
2024-03-25T21:43:00.902Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":106,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5841}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":123,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:43:00.904Z zigbee-herdsman:controller:endpoint DefaultResponse 0xdc8e95fffe4d3f35/1 1026(10, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false})
2024-03-25T21:43:01.066Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,70,122,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,186,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,28,171,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,49,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,230,219,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,187,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,180,12,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,63,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,78,61,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,241,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,226,109,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,13,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,204,158,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,208,254,1,100,1,0,100,254,3,68,128,0,1,42,236,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,75,207,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,6,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,90,0,94,0,0,8,8,106,10,0,0,41,209,22,209,108,29,219]
2024-03-25T21:43:01.067Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,150,0,70,122,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29] - 186
2024-03-25T21:43:01.067Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":150,"securityuse":0,"timestamp":6060614,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,106,10,0,0,41,209,22]}}
2024-03-25T21:43:01.069Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":106,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":41,"attrData":5841}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":27857,"endpoint":1,"linkquality":150,"groupID":0,"wasBroadcast":false,"destinationEndpoint":1}'
2024-03-25T21:43:01.072Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,28,171,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,49,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,230,219,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29,187,254,28,68,129,0,0,2,4,209,108,1,1,0,150,0,180,12,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,63,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,78,61,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,241,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,226,109,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,13,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,204,158,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,208,254,1,100,1,0,100,254,3,68,128,0,1,42,236,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,75,207,93,0,0,8,8,106,10,0,0,41,209,22,209,108,29,6,254,28,68,129,0,0,2,4,209,108,1,1,0,147,0,90,0,94,0,0,8,8,106,10,0,0,41,209,22,209,108,29,219]
2024-03-25T21:43:01.072Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,209,108,1,1,0,150,0,28,171,92,0,0,8,8,106,10,0,0,41,209,22,209,108,29] - 49
2024-03-25T21:43:01.544Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":27857,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":150,"securityuse":0,"timestamp":6073116,"transseqnumber":0,"len":8,"data":{
Les logs de l’interface web :
Info 2024-03-25 22:39:48Configuring '0x54ef441000991207'
Info 2024-03-25 22:40:35Successfully changed options
Info 2024-03-25 22:40:36MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":false},"status":"ok","transaction":"hhlqv-1"}'
Debug 2024-03-25 22:40:36Received MQTT message on 'zigbee2mqtt/bridge/request/options' with data '{"options":{"advanced":{"log_level":"error"}},"transaction":"hhlqv-2"}'
Info 2024-03-25 22:40:50Successfully changed options
Info 2024-03-25 22:40:50MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":false},"status":"ok","transaction":"hhlqv-4"}'
Info 2024-03-25 22:41:05MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":3.82,"energy":7621.15,"indicator_mode":"off/on","linkquality":150,"power":783,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-25 22:42:17MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":3.82,"energy":7621.15,"indicator_mode":"off/on","linkquality":150,"power":783,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Error 2024-03-25 22:42:23Failed to configure '0x54ef441000991207', attempt 1 (Error: Read 0x54ef441000991207/1 manuSpecificLumi([10], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":4447,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'Timeout' (9999)) at ZStackAdapter.sendZclFrameToEndpointInternal (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at runNextTicks (node:internal/process/task_queues:60:5) at processTimers (node:internal/timers:509:9) at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/app/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.read (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:466:28) at setupAttributes (/app/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:65:13) at configure (/app/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:86:17) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/index.ts:141:25) at Configure.configure (/app/lib/extension/configure.ts:122:13))
Info 2024-03-25 22:42:26MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":8.28,"energy":7621.15,"indicator_mode":"off/on","linkquality":147,"power":1634,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-25 22:42:26MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":2,"energy":7621.15,"indicator_mode":"off/on","linkquality":147,"power":351,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-25 22:42:30Successfully changed options
Info 2024-03-25 22:42:31MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":false},"status":"ok","transaction":"hhlqv-7"}'
Debug 2024-03-25 22:42:32Received MQTT message on 'zigbee2mqtt/bridge/request/options' with data '{"options":{"advanced":{"log_level":"info"}},"transaction":"hhlqv-8"}'
Info 2024-03-25 22:42:32Successfully changed options
Info 2024-03-25 22:42:33MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":false},"status":"ok","transaction":"hhlqv-8"}'
Info 2024-03-25 22:42:47MQTT publish: topic 'zigbee2mqtt/SmartPlug', payload '{"child_lock":"UNLOCK","current":0,"energy":10.9,"indicator_mode":"off/on","linkquality":123,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":230}'
Info 2024-03-25 22:42:52MQTT publish: topic 'zigbee2mqtt/Production', payload '{"child_lock":"UNLOCK","current":0,"energy":3893.45,"indicator_mode":"off/on","linkquality":75,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":237}'
Info 2024-03-25 22:42:52MQTT publish: topic 'zigbee2mqtt/SmartPlug', payload '{"child_lock":"UNLOCK","current":0,"energy":10.9,"indicator_mode":"off/on","linkquality":123,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
Info 2024-03-25 22:42:52MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":2,"energy":7621.15,"indicator_mode":"off/on","linkquality":150,"power":341,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-25 22:42:56MQTT publish: topic 'zigbee2mqtt/SmartPlug', payload '{"child_lock":"UNLOCK","current":0,"energy":10.9,"indicator_mode":"off/on","linkquality":123,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
Info 2024-03-25 22:42:59MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":2,"energy":7621.16,"indicator_mode":"off/on","linkquality":150,"power":341,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-25 22:42:59MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":2,"energy":7621.16,"indicator_mode":"off/on","linkquality":150,"power":352,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-25 22:43:07MQTT publish: topic 'zigbee2mqtt/Consommation', payload '{"child_lock":"UNLOCK","current":2,"energy":7621.16,"indicator_mode":"off/on","linkquality":147,"power":340,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
[center]## System Information
version | core-2024.3.0 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.12.2 |
os_name | Linux |
os_version | 6.1.73-haos-raspi |
arch | aarch64 |
timezone | Europe/Paris |
config_dir | /config |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 12.0 |
update_channel | stable |
supervisor_version | supervisor-2024.03.0 |
agent_version | 1.6.0 |
docker_version | 24.0.7 |
disk_total | 109.3 GB |
disk_used | 8.0 GB |
healthy | true |
supported | true |
board | rpi3-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | Samba share (12.3.0), File editor (5.8.0), Mosquitto broker (6.4.0), NGINX Home Assistant SSL proxy (3.8.0), Google Assistant SDK (2.5.0), Spotify Connect (0.13.0), Zigbee2MQTT (1.36.0-1), SQLite Web (4.1.2), Zigbee2mqtt Edge (edge), Duck DNS (1.15.0), Terminal & SSH (9.10.0) |
dashboards | 1 |
resources | 1 |
views | 2 |
mode | storage |
oldest_recorder_run | 2 mars 2024 à 18:42 |
current_recorder_run | 10 mars 2024 à 16:10 |
estimated_db_size | 1666.04 MiB |
database_engine | sqlite |
database_version | 3.44.2 |
Config z2m
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
user: mqtt
password: ***
serial:
port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ae38f4be2d45ec11a0c494fd6f14af06-if00-port0
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
host: 0.0.0.0
experimental: {}
availability: false
zigbee_herdsman_debug: true
