Un patch doit sortir pour le core 2023.6.3, prévu pour aujourd’hui. Plus cas patienter le temps du déploiement.
home-assistant:dev
← hacf-fr:meteo_france/fix_alert_catch
opened 11:05AM - 20 Jun 23 UTC
## Proposed change
Describe the big picture of your changes here to com… municate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Fixes #94839: allow Météo-France config entry to continue even if the alert API fails.
2 reasons to investigate:
- API server error: which is temporary
- API changes: which needs an integration rework
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [x] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #94839
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
Je n’ai pas non plus les alertes vigilance (le sensor.XX_weather_alert), à priori il y a eu une modification côté météo France, et je n’ai pas bien compris si ça allait être corrigé.
Herbs
Juin 23, 2023, 6:32
43
Salut messieurs,
SI on se base sur ce qui est entre parenthèses, il semblerait que la partie « alerte » doit être réécrite.
Alors le fix, est pour avoir les informations météo malgré que les alertes météo ne fonctionne pas.
La partie alerte météo doit être reécrite par rapport au nouveau api. Pour les alertes météo faudras patienter encore un peu.
Pareil
Revenu pour moi ce matin après avoir rechargé l’intégration
Pour les alertes, il y a une demande de correction ouverte ou on est juste nulle part ?
Je sais pas, le dev est au courant que les alertes sont cassées. Plus cas attente un fix pour le nouvelle api.
FillR2
Août 14, 2023, 10:20
48
Avant, j’avais les heures qui s’affichaient, c’est pareil chez vous ?
Tout pareil, pas d’info, je rattrape avec la carte
Bonjour a tous,
c’est réparer avec le core 2023.8.3
Hello, la vigilance est toujours HS chez vous ?
Ça serait bien si elle pouvait être de niveau opérationnel en cette période. Car qui dit canicule dit aussi orage
Bon dimanche à tous
Bonjour les experts de Météo France et du dashbaord Météo !
Les prévisions de pluie dans l’heure semblent ne plus se mettre à jour sur mes cartes météo. Il semblerait que l’intégration est bloquée sur « temps sec »… ce qui n’est pas vraiment le cas.
Les horaires sont aussi étranges (voir l’image, avec une copie faite à l’instant à 20h00) - la pluie dans l’heure est bloquée à 16h20. De façon intéressante, sur un autre écran (mon NSPanel Pro), ces horaitres sont différents, mais tout aussi faux, sur le même dashboard (même url).
Sur l’app Météo France, les prévisions sont correctes et à jour.
Etrange…
Merci de vos lumières
Bjr
Suite à ton poste je viens de vérifier et je ne m’en étais pas rendu compte, J ai le même problème
je pense que cela vient de la source car le capteur next Rain est passé en inconnu depuis je ne sais pas combien de temps…
Slt…
C’est bisar ou pas que Météo France n’est plus accessible dans page web ?
J’ai basculé sur Météo Consult en attendant !
Depuis Lovelace HA !
Je crois qu’ils ont pas basculer c’est parti, sur le nouvelle api. Il attendait que ca soit cassé
Ca n’a pas l’air de bouger beaucoup sur le Github sur le sujet des prévisions de pluie horaire…
