Bonsoir,
Le capteur Ikea HS à l’été dernier (surchauffe) et ayant un PMS5003 avec un ESP-12F D1 mini.
Pour quoi ne pas se servir du boitier et d’ajouter 4 leds au projet.
La photo:
Le code sous ESPHome sur une idée de https://forum.airgradient.com/t/sharing-my-experiences/152
esphome:
friendly_name: qualite-air-led
esp8266:
board: esp01_1m
# Enable logging
logger:
baud_rate: 0
level: DEBUG
esp8266_store_log_strings_in_flash: False
# Enable Home Assistant API
api:
encryption:
key: "votrecleavous"
ota:
password: "votrepasswordavous"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.240
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Qualite-Air-Led Fallback Hotspot"
password: "idemavous"
captive_portal:
uart:
rx_pin: GPIO2 #D4
baud_rate: 9600
- platform: pmsx003
type: PMSX003
pm_1_0:
filters:
- sliding_window_moving_average:
window_size: 30
send_every: 30
pm_2_5:
filters:
window_size: 30
send_every: 30
pm_10_0:
filters:
window_size: 30
send_every: 30
icon: mdi:chemical-weapon
unit_of_measurement: µg/m³
lambda: |-
return id(pm_2_5).state;
update_interval: 60s
filters:
window_size: 1440 # = 24 hours x 60 minutes
send_every: 1
on_value:
then:
- script.execute: update_aqi
lambda: |-
return id(pm_10).state;
filters:
send_every: 1
on_value:
then:
text_sensor:
name: "Airgradient Air Quality Index"
icon: mdi:air-filter
script:
- id: update_aqi
mode: restart
then:
- if:
condition:
or:
- sensor.in_range:
above: 25
- sensor.in_range:
above: 50
then:
- text_sensor.template.publish:
state: Tres Mauvais
- script.execute: show_tr_bad
else:
- if:
condition:
or:
- sensor.in_range:
above: 20
- sensor.in_range:
above: 40
then:
state: Mauvais
- script.execute: show_bad
else:
- if:
condition:
or:
- sensor.in_range:
above: 10
- sensor.in_range:
above: 20
then:
state: Mediocre
- script.execute: show_acceptable
else:
state: Bon
- script.execute: show_good
# Configuration for showing AQI status with the RGB LED
- id: show_tr_bad
then:
- light.turn_on:
brightness: 25%
red: 80%
green: 0%
blue: 20%
- id: show_bad
then:
- light.turn_on:
brightness: 25%
red: 100%
green: 60%
blue: 20%
- id: show_acceptable
then:
- light.turn_on:
brightness: 25%
red: 100%
green: 87%
blue: 20%
- id: show_good
then:
- light.turn_on:
brightness: 25%
red: 0%
green: 60%
blue: 40%
interval:
- interval: 120s
then:
- switch.turn_on: pms_set
- delay: 20s
- switch.turn_off: pms_set
switch:
- platform: gpio
pin:
number: GPIO0 #D3
- platform: restart
light:
- platform: neopixelbus
type: GRB
variant: WS2812x
pin: GPIO4
num_leds: 4
en test et après il suffira de remonter dans le boitier
