Voilà le json :
"__inputs": [
"name": "DS_PROXMOX",
"label": "proxmox",
"description": "",
"type": "datasource",
"pluginId": "influxdb",
"pluginName": "InfluxDB"
"__requires": [
"type": "panel",
"id": "bargauge",
"name": "Bar gauge",
"version": ""
"type": "grafana",
"id": "grafana",
"name": "Grafana",
"version": "8.1.1"
"type": "panel",
"id": "graph",
"name": "Graph (old)",
"version": ""
"id": "influxdb",
"name": "InfluxDB",
"version": "1.0.0"
"type": "panel",
"id": "stat",
"name": "Stat",
"version": ""
"type": "panel",
"id": "table-old",
"name": "Table (old)",
"version": ""
"annotations": {
"list": [
"builtIn": 1,
"datasource": "-- Grafana --",
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"target": {
"limit": 100,
"matchAny": false,
"tags": [],
"type": "dashboard"
"type": "dashboard"
"description": "Display data from the Proxmox host and hosted VM's and Containers.",
"editable": true,
"gnetId": 10048,
"graphTooltip": 0,
"id": null,
"links": [],
"panels": [
"collapsed": false,
"datasource": null,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 0
"id": 43,
"panels": [],
"title": "Summary",
"type": "row"
"cacheTimeout": null,
"datasource": "${DS_PROXMOX}",
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"decimals": 2,
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "dtdurations"
"overrides": []
"gridPos": {
"h": 3,
"w": 24,
"x": 0,
"y": 1
"id": 16,
"interval": null,
"links": [],
"maxDataPoints": 100,
"options": {
"colorMode": "value",
"graphMode": "none",
"justifyMode": "auto",
"orientation": "horizontal",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {},
"textMode": "auto"
"pluginVersion": "8.1.1",
"targets": [
"groupBy": [],
"measurement": "system",
"orderByTime": "ASC",
"policy": "default",
"refId": "A",
"resultFormat": "time_series",
"select": [
"params": [
"uptime"
"type": "field"
"params": [],
"type": "last"
"tags": [],
"tz": "Europe/Paris"
"timeFrom": null,
"timeShift": null,
"title": "Host Uptime",
"transparent": true,
"type": "stat"
"fieldConfig": {
"defaults": {
"color": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "none"
"overrides": []
"gridPos": {
"h": 3,
"w": 2,
"x": 0,
"y": 4
"id": 58,
"interval": null,
"links": [],
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {},
"textMode": "auto"
"targets": [
"groupBy": [],
"measurement": "cpustat",
"refId": "A",
"select": [
"params": [
"cpus"
"type": "field"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Cores",
"type": "stat"
"fieldConfig": {
"defaults": {
"color": {
"decimals": 1,
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "bytes"
"overrides": []
"gridPos": {
"h": 3,
"w": 2,
"x": 2,
"y": 4
"id": 60,
"interval": null,
"links": [],
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {},
"textMode": "auto"
"targets": [
"groupBy": [],
"measurement": "memory",
"refId": "A",
"select": [
"params": [
"memtotal"
"type": "field"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Total Memory",
"type": "stat"
"fieldConfig": {
"defaults": {
"color": {
"decimals": 1,
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "bytes"
"overrides": []
"gridPos": {
"h": 3,
"w": 2,
"x": 4,
"y": 4
"id": 62,
"interval": null,
"links": [],
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {},
"textMode": "auto"
"targets": [
"groupBy": [],
"refId": "A",
"select": [
"params": [
"swaptotal"
"type": "field"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Total Swap",
"type": "stat"
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"decimals": 2,
"displayName": "",
"mappings": [
"options": {
"match": "null",
"result": {
"text": "N/A"
"type": "special"
"max": 1,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "#73BF69",
"value": null
"color": "rgba(237, 129, 40, 0.89)",
"value": 0.7
"color": "#d44a3a",
"value": 0.85
"unit": "percentunit"
"overrides": []
"gridPos": {
"h": 6,
"w": 2,
"x": 7,
"y": 4
"id": 2,
"links": [],
"options": {
"displayMode": "lcd",
"orientation": "vertical",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"showUnfilled": true,
"text": {}
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"cpu"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Server CPU",
"type": "bargauge"
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"decimals": 2,
"mappings": [
"options": {
"match": "null",
"result": {
"text": "N/A"
"type": "special"
"max": 8,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "#73BF69",
"value": null
"value": 6
"color": "#d44a3a",
"value": 7
"unit": "gbytes"
"overrides": []
"gridPos": {
"h": 6,
"w": 2,
"x": 9,
"y": 4
"id": 11,
"links": [],
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {}
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"memused"
"type": "field"
"params": [],
"type": "mean"
"params": [
"/ 1073741824"
"type": "math"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Used Memory",
"type": "bargauge"
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"decimals": 2,
"mappings": [
"options": {
"match": "null",
"result": {
"text": "N/A"
"type": "special"
"max": 10,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "#73BF69",
"value": null
"value": 7
"color": "#d44a3a",
"value": 8.5
"unit": "short"
"overrides": []
"gridPos": {
"h": 6,
"w": 2,
"x": 11,
"y": 4
"id": 9,
"links": [],
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {}
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"avg1"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Load Average (1 Minute)",
"type": "bargauge"
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"decimals": 2,
"mappings": [
"options": {
"match": "null",
"result": {
"text": "N/A"
"type": "special"
"max": 1,
"min": 0,
"thresholds": {
"mode": "absolute",
"steps": [
"color": "#73BF69",
"value": null
"value": 0.7
"color": "#d44a3a",
"value": 0.85
"overrides": []
"gridPos": {
"h": 6,
"w": 2,
"x": 13,
"y": 4
"id": 10,
"links": [],
"options": {
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"text": {}
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"wait"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "I/O Wait",
"type": "bargauge"
"columns": [],
"fontSize": "100%",
"gridPos": {
"h": 6,
"w": 9,
"x": 15,
"y": 4
"id": 7,
"interval": "",
"links": [],
"pageSize": null,
"scroll": true,
"showHeader": true,
"sort": {
"col": 1,
"desc": false
"styles": [
"alias": "Time",
"align": "auto",
"colorMode": null,
"colors": [
"rgba(245, 54, 54, 0.9)",
"rgba(50, 172, 45, 0.97)"
"dateFormat": "YYYY-MM-DD HH:mm:ss",
"decimals": 2,
"mappingType": 1,
"pattern": "Time",
"thresholds": [],
"type": "hidden",
"unit": "short"
"alias": "Uptime",
"align": "auto",
"colorMode": null,
"colors": [
"decimals": 1,
"mappingType": 1,
"pattern": "uptime",
"rangeMaps": [
"from": "",
"text": "",
"to": ""
"thresholds": [],
"type": "number",
"unit": "dtdurations",
"valueMaps": [
"text": "Offline",
"value": "0"
"alias": "VM",
"align": "auto",
"colorMode": null,
"colors": [
"decimals": 2,
"mappingType": 1,
"pattern": "host",
"sanitize": true,
"thresholds": [],
"type": "string",
"unit": "short",
"valueMaps": []
"targets": [
"groupBy": [
"params": [
"host"
"type": "tag"
"limit": "1",
"query": "SELECT last(uptime) AS \"uptime\" FROM \"system\" WHERE (\"object\" = 'qemu' OR \"object\" = 'lxc') AND time > (now() - 10m) AND uptime > 0 GROUP BY \"host\" limit 1",
"rawQuery": true,
"refId": "A",
"resultFormat": "table",
"select": [
"params": [
"uptime"
"type": "field"
"params": [
"uptime"
"type": "alias"
"tags": [
"key": "object",
"operator": "=",
"value": "qemu"
"condition": "OR",
"key": "object",
"operator": "=",
"value": "lxc"
"timeFrom": null,
"timeShift": null,
"title": "Running VMs",
"transform": "table",
"type": "table-old"
"collapsed": false,
"datasource": null,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 10
"id": 26,
"panels": [],
"title": "Memory And CPU Usage",
"type": "row"
"alert": {
"alertRuleTags": {},
"conditions": [
"evaluator": {
"params": [
80
"type": "gt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "avg"
"type": "query"
"executionErrorState": "alerting",
"for": "5m",
"frequency": "1m",
"handler": 1,
"name": "Host CPU Usage alert",
"noDataState": "no_data",
"notifications": []
"aliasColors": {
"I/O Wait": "dark-blue",
"Load Average (1 Min)": "dark-red"
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 12,
"x": 0,
"y": 11
"hiddenSeries": false,
"id": 22,
"interval": "",
"legend": {
"alignAsTable": false,
"avg": true,
"current": true,
"max": false,
"min": false,
"rightSide": false,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"nullPointMode": "null",
"options": {
"alertThreshold": true
"percentage": false,
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [
"$$hashKey": "object:692",
"alias": "Load Average (1 Min)",
"yaxis": 2
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"alias": "CPU Usage",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"cpu"
"type": "field"
"params": [],
"type": "mean"
"params": [
"* 100"
"type": "math"
"tags": [],
"alias": "I/O Wait",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"wait"
"type": "field"
"params": [],
"type": "mean"
"params": [
" * 100"
"type": "math"
"tags": [],
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "C",
"select": [
"params": [
"avg1"
"type": "field"
"params": [],
"type": "mean"
"thresholds": [
"colorMode": "critical",
"fill": true,
"line": true,
"op": "gt",
"value": 80,
"visible": true
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Host CPU Usage",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:699",
"decimals": null,
"format": "percent",
"label": "Percent",
"logBase": 1,
"max": null,
"min": "0",
"show": true
"$$hashKey": "object:700",
"decimals": null,
"format": "short",
"label": "Load",
"logBase": 1,
"max": "10",
"min": "0",
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"alert": {
"conditions": [
"evaluator": {
"params": [
90
"type": "gt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "avg"
"type": "query"
"for": "5m",
"frequency": "1m",
"handler": 1,
"name": "Host Memory Usage alert",
"notifications": []
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 12,
"x": 12,
"y": 11
"id": 4,
"interval": "",
"legend": {
"alignAsTable": true,
"avg": true,
"current": true,
"max": true,
"min": true,
"rightSide": false,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": false,
"targets": [
"alias": "Memory Use",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "SELECT mean(\"memused\")/mean(\"memtotal\") * 100 FROM \"memory\" WHERE $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"memused"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"value": "/^$server$/"
"thresholds": [
"fill": true,
"line": true,
"op": "gt",
"value": 90,
"visible": true
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Host Memory Usage",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:754",
"decimals": null,
"label": null,
"logBase": 1,
"max": "100",
"min": "0",
"show": true
"$$hashKey": "object:755",
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"alert": {
"conditions": [
"evaluator": {
"params": [
80
"type": "gt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "avg"
"type": "query"
"for": "5m",
"frequency": "1m",
"handler": 1,
"name": "VM CPU Usage alert",
"notifications": []
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"decimals": 2,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 0,
"y": 18
"id": 28,
"interval": "",
"legend": {
"avg": true,
"current": true,
"hideEmpty": false,
"hideZero": true,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"alias": "$tag_host",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"host"
"type": "tag"
"params": [
"null"
"type": "fill"
"query": "SELECT last(\"cpu\") FROM \"system\" WHERE (\"object\" = 'qemu' OR \"object\" = 'lxc') AND $timeFilter GROUP BY time(1m), \"host\" fill(null) tz('Europe/Paris')",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"cpu"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "object",
"operator": "=",
"value": "qemu"
"condition": "OR",
"key": "object",
"operator": "=",
"value": "lxc"
"thresholds": [
"fill": true,
"line": true,
"op": "gt",
"value": 80,
"visible": true
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "VM CPU Usage",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:809",
"decimals": 2,
"format": "percentunit",
"label": "",
"logBase": 1,
"max": null,
"min": null,
"show": true
"$$hashKey": "object:810",
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 12,
"y": 18
"id": 31,
"interval": "",
"legend": {
"avg": true,
"current": true,
"hideZero": true,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"host"
"type": "tag"
"params": [
"null"
"type": "fill"
"query": "SELECT (mean(\"mem\")/last(maxmem))*100 FROM \"system\" WHERE (\"object\" = 'qemu' OR \"object\" = 'lxc') AND $timeFilter GROUP BY time($__interval), \"host\" fill(previous)",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"mem"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "object",
"operator": "=",
"value": "qemu"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "VMs Memory Usage",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:373",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"$$hashKey": "object:374",
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"collapsed": false,
"datasource": null,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 24
"id": 34,
"panels": [],
"title": "Disk I/O",
"type": "row"
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 0,
"y": 25
"id": 36,
"interval": "",
"legend": {
"avg": false,
"current": true,
"hideZero": true,
"max": true,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"host"
"type": "tag"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"diskread"
"type": "field"
"params": [],
"type": "mean"
"params": [
"1s"
"type": "derivative"
"tags": [
"key": "object",
"operator": "=",
"value": "qemu"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "VMs I/O Read",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "Bps",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 12,
"y": 25
"id": 37,
"interval": "",
"legend": {
"avg": false,
"current": true,
"hideZero": true,
"max": true,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"host"
"type": "tag"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"diskwrite"
"type": "field"
"params": [],
"type": "mean"
"params": [
"1s"
"tags": [
"key": "object",
"operator": "=",
"value": "qemu"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "VMs I/O Write",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "Bps",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"collapsed": false,
"datasource": null,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 31
"id": 41,
"panels": [],
"title": "Network Traffic",
"type": "row"
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 0,
"y": 32
"id": 45,
"interval": "",
"legend": {
"avg": true,
"current": true,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"alias": "Rx",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"measurement": "nics",
"query": "SELECT non_negative_derivative(mean(\"receive\"), 10s) AS \"Rx\", non_negative_derivative(mean(\"receive\"), 10s) AS \"Tx\" FROM \"nics\" WHERE (\"host\" =~ /^$server$/ AND \"instance\" = 'enp2s0') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": false,
"refId": "A",
"select": [
"params": [
"receive"
"type": "field"
"params": [],
"type": "mean"
"params": [
"10s"
"type": "non_negative_derivative"
"params": [
"Rx"
"type": "alias"
"tags": [
"key": "instance",
"operator": "=",
"value": "enp3s0"
"alias": "Tx",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"transmit"
"type": "field"
"params": [],
"type": "mean"
"params": [
"10s"
"tags": [
"key": "instance",
"operator": "=",
"value": "enp3s0"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "enp2s0",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "bps",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 12,
"y": 32
"id": 46,
"interval": "",
"legend": {
"avg": true,
"current": true,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"alias": "Rx",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"receive"
"type": "field"
"params": [],
"type": "mean"
"params": [
"10s"
"tags": [
"key": "instance",
"operator": "=",
"value": "vmbr0"
"alias": "Tx",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"transmit"
"type": "field"
"params": [],
"type": "mean"
"params": [
"10s"
"tags": [
"key": "instance",
"operator": "=",
"value": "vmbr0"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "vmbr0",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "bps",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 0,
"y": 38
"id": 47,
"interval": "",
"legend": {
"avg": true,
"current": true,
"hideEmpty": false,
"hideZero": true,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"host"
"type": "tag"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"netin"
"type": "field"
"params": [],
"type": "mean"
"params": [
"10s"
"tags": [
"key": "object",
"operator": "=",
"value": "qemu"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "VMs Traffic In",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "bps",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 12,
"y": 38
"id": 49,
"interval": "",
"legend": {
"avg": true,
"current": true,
"hideEmpty": false,
"hideZero": true,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"host"
"type": "tag"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"netout"
"type": "field"
"params": [],
"type": "mean"
"params": [
"10s"
"tags": [
"key": "object",
"operator": "=",
"value": "qemu"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "VMs Traffic Out",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "bps",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"collapsed": false,
"datasource": null,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 44
"id": 52,
"panels": [],
"title": "Storage Pools",
"type": "row"
"alert": {
"conditions": [
"evaluator": {
"params": [
0.8
"type": "gt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "avg"
"type": "query"
"for": "5m",
"frequency": "1m",
"handler": 1,
"name": "local-lvm Usage alert",
"notifications": []
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 8,
"x": 0,
"y": 45
"id": 54,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "SELECT last(\"used\") / last(\"total\") FROM \"system\" WHERE (\"host\" = 'local-lvm') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"thresholds": [
"fill": true,
"line": true,
"op": "gt",
"value": 0.8,
"visible": true
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "local-lvm Usage",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"label": null,
"logBase": 1,
"max": "1",
"min": "0",
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"alert": {
"conditions": [
"evaluator": {
"params": [
0.8
"type": "gt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "avg"
"type": "query"
"for": "5m",
"frequency": "1m",
"handler": 1,
"name": "local Usage alert",
"notifications": []
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 8,
"x": 8,
"y": 45
"id": 55,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "SELECT last(\"used\") / last(\"total\") FROM \"system\" WHERE (\"host\" = 'local') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"thresholds": [
"fill": true,
"line": true,
"op": "gt",
"value": 0.8,
"visible": true
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "local Usage",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"label": null,
"logBase": 1,
"max": "1",
"min": "0",
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"alert": {
"conditions": [
"evaluator": {
"params": [
0.8
"type": "gt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "avg"
"type": "query"
"for": "20m",
"frequency": "1m",
"handler": 1,
"name": "backup Usage alert",
"notifications": []
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 8,
"x": 16,
"y": 45
"id": 56,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 2,
"links": [],
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "SELECT last(\"used\") / last(\"total\") FROM \"system\" WHERE (\"host\" = 'nas') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"thresholds": [
"fill": true,
"line": true,
"op": "gt",
"value": 0.8,
"visible": true
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "backup Usage",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:58",
"label": null,
"logBase": 1,
"max": "1",
"min": "0",
"show": true
"$$hashKey": "object:59",
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"refresh": "10s",
"schemaVersion": 30,
"style": "dark",
"tags": [
"proxmox",
"infrastructure"
"templating": {
"list": []
"time": {
"from": "now-3h",
"to": "now"
"timepicker": {
"hidden": false,
"refresh_intervals": [
"5s",
"10s",
"30s",
"1m",
"5m",
"15m",
"30m",
"1h",
"2h",
"1d"
"time_options": [
"5m",
"15m",
"1h",
"6h",
"12h",
"24h",
"2d",
"7d",
"30d"
"timezone": "",
"title": "Proxmox",
"uid": "kxQQuHRZk",
"version": 49
Il est prévu pour une datasource influxdb 1.8 (pas v2 !) avec les metriques envoyées par proxmox. C’est configurable dans l’UI de proxmox.
