Probleme accès File editor
Bonjour les geeks,
Hier j’ai joué un peu avec duckdns, les ouvertures de ports de ma freebox et file editor.
Et aujourd’hui je n’arrive plus a aller sur file editor, j’ai a chaque fois ce message:
« 401: Unauthorized »
j’ai desintallé et resinstallé mais rien ne change , j’ai meme essayé de mettre VSC mais j’ai la meme erreur !
chose bizarre je viens de me rendre compte que j’ai perdu l’accés à file editor que depuis mon pc , sur mon tel et ma tablette j’y ai accès alors que c’est le meme wifi !
dans le journal de file editor j’ai ça :
[12:01:15] INFO: Service exited with code 256 (by signal 15)
s6-rc: info: service configurator successfully stopped
s6-rc: info: service configurator: starting
s6-rc: info: service configurator successfully started
INFO:2024-05-07 12:07:12,581:hass_configurator.configurator:Starting server
INFO:2024-05-07 12:07:12,581:hass_configurator.configurator:Listening on: http://0.0.0.0:8099
INFO:2024-05-07 12:07:42,314:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:08:12,382:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:08:42,466:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:09:12,524:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:09:26,804:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:09:26,860:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2024-05-07 12:09:26,870:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2024-05-07 12:09:26,916:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2024-05-07 12:09:26,916:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2024-05-07 12:09:26,923:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2024-05-07 12:09:26,928:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2024-05-07 12:09:27,332:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2024-05-07 12:09:31,820:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/homeassistant/configuration.yaml HTTP/1.1" 200 -
INFO:2024-05-07 12:09:42,586:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:09:46,824:hass_configurator.configurator:172.30.32.2 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:09:46,882:hass_configurator.configurator:172.30.32.2 - "GET /material-icons.fallback.css HTTP/1.1" 200 -
INFO:2024-05-07 12:09:46,891:hass_configurator.configurator:172.30.32.2 - "GET /style.css HTTP/1.1" 200 -
INFO:2024-05-07 12:09:46,927:hass_configurator.configurator:172.30.32.2 - "GET /jquery-3.6.0.min.js HTTP/1.1" 200 -
INFO:2024-05-07 12:09:46,932:hass_configurator.configurator:172.30.32.2 - "GET /js-yaml.min.js HTTP/1.1" 200 -
INFO:2024-05-07 12:09:46,935:hass_configurator.configurator:172.30.32.2 - "GET /materialize.min.js HTTP/1.1" 200 -
INFO:2024-05-07 12:09:46,963:hass_configurator.configurator:172.30.32.2 - "GET /flUhRq6tzZclQEJ-Vdg-IuiaDsNc.woff2 HTTP/1.1" 200 -
INFO:2024-05-07 12:09:47,123:hass_configurator.configurator:172.30.32.2 - "GET /api/file?filename=/homeassistant/configuration.yaml HTTP/1.1" 200 -
INFO:2024-05-07 12:09:47,302:hass_configurator.configurator:172.30.32.2 - "GET /api/listdir?path=. HTTP/1.1" 200 -
INFO:2024-05-07 12:10:12,646:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:10:42,706:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:11:12,764:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:11:42,822:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:12:12,882:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:12:42,941:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:13:13,002:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:13:43,059:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:14:13,118:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:14:43,179:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:15:13,238:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:15:43,297:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:16:13,359:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:16:43,415:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:17:13,473:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2024-05-07 12:17:43,530:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
Merci pour votre aide
Informations système
Version core-2024.4.4
Type d’installation Home Assistant Supervised
Développement false
Supervisor true
Docker true
Utilisateur root
Environnement virtuel false
Version de Python 3.12.2
Version du système d’exploitation 5.10.0-28-amd64
Architecture du processeur x86_64
Fuseau horaire Europe/Paris
GÉRER
Installed Version 1.34.0
Available Repositories 1470
Downloaded Repositories 29
GÉRER
Connecté false
Accéder au serveur de certificats ok
Accéder au serveur d’authentification ok
Accéder à Home Assistant Cloud ok
Système d’exploitation hôte Debian GNU/Linux 11 (bullseye)
Canal de mise à jour stable
Version du Supervisor supervisor-2024.04.4
Version de l’agent 1.6.0
Version de Docker 26.0.0
Taille total du disque 30.4 GB
Taille du disque utilisé 13.0 GB
Sain true
Prise en charge true
API du Supervisor ok
Version de l’API ok
Modules complémentaires installés Terminal & SSH (9.13.0), Spotify Connect (0.13.0), Zigbee2MQTT Proxy (0.2.0), Mosquitto broker (6.4.0), ESPHome (2024.3.1), Node-RED (17.0.12), AdGuard Home (5.0.7), Let’s Encrypt (5.0.18), Duck DNS (1.17.0), Studio Code Server (5.15.0), File editor (5.8.0)
Tu utilises quoi comme adresse pour te connecter a ton HA ?
si tu utilises ton ip interne sur le port 8123 et que tu vas sur fileeditor
J utilise justement l’ip local et :8123
C’est original avec un autre utilisateur qui a fait à peu prêt comme toi il a le même soucis
me suis fait la même réflexion :slight_smile:
