Probleme ADB server
Effectivement, il n'y a pas l'air d'avoir de truc anormal (en lien avec le sujet).
Par contre, c'est pas la totalité des logs, jette un oeil ici (tout en bas des logs):
Evidement, core etc à jour ?
Bon j’ai des tonnes d’erreurs que je ne comprend pas … pourtant il y a des choses bien config …
Je te met tout si tu as des idées
2021-06-26 21:18:29 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miio_airconditioningcompanion which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-26 21:18:29 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration miio_yeelink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-26 21:18:29 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-26 21:18:29 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-26 21:18:29 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-26 21:18:29 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-26 21:18:32 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2021-06-26 21:18:32 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
2021-06-26 21:18:32 DEBUG (MainThread) [rflink.protocol] connected
2021-06-26 21:18:34 ERROR (MainThread) [homeassistant.components.sensor] Entity id already exists - ignoring: sensor.xiaomi_airpurifier_humidity
2021-06-26 21:18:34 ERROR (MainThread) [homeassistant.components.sensor] Entity id already exists - ignoring: sensor.xiaomi_airpurifier_air_quality_pm25
2021-06-26 21:18:34 ERROR (MainThread) [homeassistant.components.sensor] Entity id already exists - ignoring: sensor.xiaomi_airpurifier_speed
2021-06-26 21:18:34 ERROR (MainThread) [homeassistant.components.sensor] Entity id already exists - ignoring: sensor.xiaomi_airpurifier_filter_remaining
2021-06-26 21:18:37 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to get properties from 192.168.0.125: A socket error occurred when sending the command.
2021-06-26 21:18:37 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to import 192.168.0.125: cannot connect
2021-06-26 21:18:37 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to get properties from 192.168.0.123: A socket error occurred when sending the command.
2021-06-26 21:18:37 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to import 192.168.0.123: cannot connect
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.SecurityScan.Status:status already exists - ignoring binary_sensor.walter_security_status_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.Upgrade:update_available already exists - ignoring binary_sensor.walter_update_available_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_exceed_bad_sector_thr_sda already exists - ignoring binary_sensor.walter_drive_1_exceeded_max_bad_sectors_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_below_remain_life_thr_sda already exists - ignoring binary_sensor.walter_drive_1_below_min_remaining_life_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_exceed_bad_sector_thr_sdb already exists - ignoring binary_sensor.walter_drive_2_exceeded_max_bad_sectors_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_below_remain_life_thr_sdb already exists - ignoring binary_sensor.walter_drive_2_below_min_remaining_life_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_exceed_bad_sector_thr_sdc already exists - ignoring binary_sensor.walter_drive_3_exceeded_max_bad_sectors_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_below_remain_life_thr_sdc already exists - ignoring binary_sensor.walter_drive_3_below_min_remaining_life_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_exceed_bad_sector_thr_sdd already exists - ignoring binary_sensor.walter_drive_4_exceeded_max_bad_sectors_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_below_remain_life_thr_sdd already exists - ignoring binary_sensor.walter_drive_4_below_min_remaining_life_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_exceed_bad_sector_thr_sde already exists - ignoring binary_sensor.walter_drive_5_exceeded_max_bad_sectors_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_below_remain_life_thr_sde already exists - ignoring binary_sensor.walter_drive_5_below_min_remaining_life_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:cpu_user_load already exists - ignoring sensor.walter_cpu_utilization_user_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:cpu_total_load already exists - ignoring sensor.walter_cpu_utilization_total_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:cpu_5min_load already exists - ignoring sensor.walter_cpu_load_average_5_min
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:cpu_15min_load already exists - ignoring sensor.walter_cpu_load_average_15_min
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:memory_real_usage already exists - ignoring sensor.walter_memory_usage_real_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:memory_available_swap already exists - ignoring sensor.walter_memory_available_swap_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:memory_available_real already exists - ignoring sensor.walter_memory_available_real_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:memory_total_swap already exists - ignoring sensor.walter_memory_total_swap_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:memory_total_real already exists - ignoring sensor.walter_memory_total_real_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:network_up already exists - ignoring sensor.walter_network_up_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Core.System.Utilization:network_down already exists - ignoring sensor.walter_network_down_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_status_volume_2 already exists - ignoring sensor.walter_volume_2_status_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_size_used_volume_2 already exists - ignoring sensor.walter_volume_2_used_space_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_percentage_used_volume_2 already exists - ignoring sensor.walter_volume_2_volume_used_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_disk_temp_avg_volume_2 already exists - ignoring sensor.walter_volume_2_average_disk_temp_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_status_volume_1 already exists - ignoring sensor.walter_volume_1_status_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_size_used_volume_1 already exists - ignoring sensor.walter_volume_1_used_space_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_percentage_used_volume_1 already exists - ignoring sensor.walter_volume_1_volume_used_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:volume_disk_temp_avg_volume_1 already exists - ignoring sensor.walter_volume_1_average_disk_temp_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_status_sda already exists - ignoring sensor.walter_drive_1_status_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_temp_sda already exists - ignoring sensor.walter_drive_1_temperature_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_status_sdb already exists - ignoring sensor.walter_drive_2_status_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_temp_sdb already exists - ignoring sensor.walter_drive_2_temperature_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_status_sdc already exists - ignoring sensor.walter_drive_3_status_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_temp_sdc already exists - ignoring sensor.walter_drive_3_temperature_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_status_sdd already exists - ignoring sensor.walter_drive_4_status_2
2021-06-26 21:18:38 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_temp_sdd already exists - ignoring sensor.walter_drive_4_temperature_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_status_sde already exists - ignoring sensor.walter_drive_5_status_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.Storage.CGI.Storage:disk_temp_sde already exists - ignoring sensor.walter_drive_5_temperature_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.sensor] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.DSM.Info:temperature already exists - ignoring sensor.walter_temperature_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.switch] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.HomeMode:home_mode already exists - ignoring switch.walter_home_mode_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.camera] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.Camera:1 already exists - ignoring camera.walter_rue_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.camera] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.Camera:2 already exists - ignoring camera.walter_garage_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.camera] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.Camera:3 already exists - ignoring camera.walter_entree_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.camera] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.Camera:4 already exists - ignoring camera.walter_salon_2
2021-06-26 21:18:39 ERROR (MainThread) [homeassistant.components.camera] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.Camera:5 already exists - ignoring camera.walter_cuisine_2
2021-06-26 21:18:40 ERROR (MainThread) [homeassistant.components.camera] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.Camera:6 already exists - ignoring camera.walter_sous_sol_2
2021-06-26 21:18:40 ERROR (MainThread) [homeassistant.components.camera] Platform synology_dsm does not generate unique IDs. ID C7LWN09761_SYNO.SurveillanceStation.Camera:9 already exists - ignoring camera.walter_garage_int_2
2021-06-26 21:18:46 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2021-06-26 21:18:46 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2021-06-26 21:18:56 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2021-06-26 21:18:56 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2021-06-26 21:18:57 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:requestSync failed: 403
2021-06-26 21:19:33 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 21:23:57 DEBUG (MainThread) [homeassistant.components.rflink] Sending command: DOWN to Rflink device: RTS_E98195:_3
2021-06-26 21:23:57 DEBUG (MainThread) [rflink.protocol] sending command: {'protocol': 'RTS', 'id': 'E98195:', 'switch': '3', 'command': 'DOWN'}
2021-06-26 21:23:57 DEBUG (MainThread) [rflink.protocol] writing data: '10;RTS;E98195:;3;DOWN;\r\n'
2021-06-26 21:23:57 DEBUG (MainThread) [rflink.protocol] waiting for acknowledgement
2021-06-26 21:24:01 DEBUG (MainThread) [rflink.protocol] received data: 20;76;OK;
2021-06-26 21:24:01 DEBUG (MainThread) [rflink.protocol] got packet: 20;76;OK;
2021-06-26 21:24:01 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'unknown', 'ok': True}
2021-06-26 21:24:01 DEBUG (MainThread) [rflink.protocol] command response: {'node': 'gateway', 'protocol': 'unknown', 'ok': True}
2021-06-26 21:24:01 DEBUG (MainThread) [rflink.protocol] packet acknowledged
2021-06-26 21:24:16 DEBUG (MainThread) [rflink.protocol] received data: 20;77;NewKa
2021-06-26 21:24:16 DEBUG (MainThread) [rflink.protocol] received data: ku;ID=0097ab66;SWITCH=a;
2021-06-26 21:24:16 DEBUG (MainThread) [rflink.protocol] received data: CMD=OFF;
2021-06-26 21:24:16 DEBUG (MainThread) [rflink.protocol] got packet: 20;77;NewKaku;ID=0097ab66;SWITCH=a;CMD=OFF;
2021-06-26 21:24:16 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '0097ab66', 'switch': 'a', 'command': 'off'}
2021-06-26 21:24:16 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_0097ab66_a', 'command': 'off'}
2021-06-26 21:24:16 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'newkaku_0097ab66_a', 'command': 'off'}
2021-06-26 21:24:16 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['switch.etat_volet_bureau']
2021-06-26 21:24:16 DEBUG (MainThread) [homeassistant.components.rflink] passing event to switch.etat_volet_bureau
2021-06-26 21:25:26 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 21:29:11 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 21:29:26 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 21:32:51 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 21:33:09 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 21:35:10 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 21:39:11 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 21:45:29 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 21:49:41 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 21:54:41 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 21:57:30 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 21:58:43 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 21:59:11 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 22:05:46 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 22:07:16 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:09:46 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.xiaomi_gateway_light fails
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 193, in send
data, addr = s.recvfrom(1024)
socket.timeout: timed out
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 350, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 566, in async_device_update
await task
File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/light.py", line 1037, in async_update
state_dict = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/gateway/light.py", line 43, in rgb_status
state_int = self._gateway.send("get_rgb").pop()
File "/usr/local/lib/python3.8/site-packages/miio/device.py", line 178, in send
return self._protocol.send(
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 233, in send
return self.send(
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 161, in send
self.send_handshake()
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 74, in send_handshake
raise DeviceException("Unable to discover the device %s" % self.ip)
miio.exceptions.DeviceException: Unable to discover the device 192.168.0.101
2021-06-26 22:12:52 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:15:41 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 22:17:02 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:19:11 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 22:22:00 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:22:11 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 22:28:16 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.xiaomi_gateway_light fails
await task
return self.send(
2021-06-26 22:28:41 ERROR (MainThread) [homeassistant.components.xiaomi_miio.sensor] Got exception while fetching the gateway illuminance state: Got an exception while getting gateway illumination
2021-06-26 22:28:41 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.xiaomi_gateway_light fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 558, in async_device_update
raise exc
2021-06-26 22:28:41 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 22:29:11 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 22:29:12 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:30:39 ERROR (MainThread) [homeassistant.components.broadlink.updater] Error fetching Ri4 (RM4 mini at 192.168.0.100) data: [Errno -4000] Network timeout
2021-06-26 22:30:41 ERROR (Thread-15) [pychromecast.socket_client] [Television(192.168.0.63):8009] Error reading from socket.
2021-06-26 22:30:42 ERROR (Poll status) [pyShelly] Timeout connecting to http://192.168.0.136/status [192.168.0.136]
2021-06-26 22:30:42 ERROR (SyncWorker_8) [homeassistant.components.yeelight] Unable to update device 192.168.0.124, Halogene2: Bulb closed the connection.
2021-06-26 22:30:42 ERROR (SyncWorker_1) [homeassistant.components.yeelight] Unable to update device 192.168.0.121, yeelight_color_0x0000000007d02967: Bulb closed the connection.
2021-06-26 22:30:42 ERROR (SyncWorker_20) [homeassistant.components.yeelight] Unable to update device 192.168.0.122, Halogene1: Bulb closed the connection.
2021-06-26 22:30:52 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:31:16 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.xiaomi_gateway_light fails
await task
return self.send(
2021-06-26 22:32:16 ERROR (MainThread) [homeassistant.components.xiaomi_miio.sensor] Got exception while fetching the gateway illuminance state: Got an exception while getting gateway illumination
2021-06-26 22:32:41 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.xiaomi_gateway_light fails
raise exc
2021-06-26 22:32:41 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 22:33:09 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:33:16 ERROR (MainThread) [homeassistant.components.xiaomi_miio.sensor] Got exception while fetching the gateway illuminance state: Got an exception while getting gateway illumination
2021-06-26 22:35:10 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:36:14 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:38:52 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:39:46 ERROR (MainThread) [homeassistant.components.xiaomi_miio.sensor] Got exception while fetching the gateway illuminance state: Got an exception while getting gateway illumination
2021-06-26 22:39:46 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 22:40:14 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:42:10 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:44:46 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 22:46:22 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 22:46:41 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.xiaomi_gateway_light fails
raise exc
2021-06-26 22:47:45 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
2021-06-26 22:48:27 ERROR (MainThread) [homeassistant.components.xiaomi_miio.sensor] Got exception while fetching the gateway illuminance state: Got an exception while getting gateway illumination
2021-06-26 22:48:41 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
2021-06-26 22:51:16 ERROR (MainThread) [homeassistant.components.xiaomi_miio.alarm_control_panel] Got exception while fetching the state: Unable to discover the device 192.168.0.101
2021-06-26 22:51:41 ERROR (MainThread) [homeassistant.components.xiaomi_miio.sensor] Got exception while fetching the gateway illuminance state: Got an exception while getting gateway illumination
2021-06-26 22:51:41 ERROR (MainThread) [homeassistant.helpers.entity] Update for light.xiaomi_gateway_light fails
raise exc
2021-06-26 22:54:32 ERROR (Thread-17) [pychromecast.socket_client] [Shield salon(192.168.0.2):8009] Error reading from socket.
Bon, tu as plein d’anomalies sur Google Assistant, ton NAS, ta gateway Xiaomi … mais pas sur la firetv …
Là, je vois pas …
Dernière idée, commenter l’inclusion de media-player et mettre directement la déclaration dans le fichier configuration.yaml
google assistant je ne m’en sert plus, le nas je ne sais pas pourquoi et xiaomi ca a tjrs été sans que je comprenne pourquoi…
J’y ai pensais mais je crois qu’il y a un style particulier dans le configuration.yaml par rapport au media-player non ?
Ca me fait des erreurs quand je fait un copié collé
Pour les trucs qui ne servent plus ça vaut le coup de commenter les restes de configuration. Quand on cherche une information et que c’est noyé dans la masse, c’est moins facile.
Pour la télé, reprend intégralement l’exemple que j’ai donné (en respectant les espaces et le tiret) et change juste l’adresse ip. Il faut par contre bien commenter la ligne include correspondante pour pas que ça rale
quand je fais un copié collé de la doc dans le configuration .yaml j'ai une erreur j'ai une erreur je ne comprend pas pourquoi.
Tu as pas le contenu du message d’erreur ?
Tu as essayé de mettre le bloc plus haut, voir si le comportement est différent ?
Tu passes pas l’éditeur classique ou visual studio ?
Principe de base :
Fournir le log :+1:
:wink:
oui :grin: enfin une erreur juste le rond rouge avec le point d’exclamation et ca :
media_player
L'éditeur de base est vraiment pas terrible... Perso je passe par cet addon
Donc erreur mais on est bien d'accord que tu as commenté la ligne
media_player: !include media_players.yaml
devenue
#media_player: !include media_players.yaml
parce que sinon, l'erreur c'est le doublon
par exemple
Bon alors, c’est bien ce que tu pensais.
En mettant tout dans le configuraton.yaml c’est bon j’ai bien androidtv.adb_command. Et le problème de media_player était bien celui la !
Donc je ne peux pas tout mettre dans un fichier média_player ?
Bon ben c’est déjà un bon point :sweat_smile:
En principe, si ! Il faut juste comprendre pourquoi le fichier ne s’inclue pas … Un problème de chemin ou de format…
Donc à mettre au même niveau que le fichier configuration.yaml, à nommer exactement pareil (avec un S)… Le contenu est identique SAUF la première ligne media_player: que l’on ne met pas.
Et tu vires tous les autres contenus pour ne mettre que la firetv (au moins temporairement)
Alor j’ai fait tout comme tu m’a dit et quand je met sans un fichier media_playerS.yaml j’ai bien les appareils mais pas le service androidtv.adb_command…
Etrange
Salut.
Les appareils sans le service ? Je suis pas sur de comprendre.
Il y a forcément une erreur de syntaxe… Tu es le seul à pouvoir chercher, sans les fichiers en complément, moi je suis aveugle
Les appareils apparaissent bien dans HA mais quand je cherche le service il n’est plus la ( quans je met tous dans un fichier media_players.yaml)
Voila le fichier media_players.yaml
#                   ShieldTV                #
  # Use the Python ADB implementation
  - platform: androidtv
    host: 192.168.0.177
    host: 192.168.0.2
    name: "NVIDIA Shield Salon"
    device_class : androidtv
    adb_server_ip: 127.0.0.1
    adb_server_port: 5037
    apps:
      com.canal.android.canal: MyCanal
      com.google.android.tvlauncher: “Home”
      com.google.android.youtube.tv: “Youtube”
      com.amazon.amazonvideo.livingroom: “Amazon Prime Video”
      com.plexapp.android: “Plex”
      com.netflix.ninja: “Netflix”
      com.google.android.tv: “Live Channels”
    host: 192.168.0.4
    name: "NVIDIA Shield Ben"
    apps:
    host: 192.168.0.5
    apps:
Et le configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
switch: !include switchs.yaml
sensor: !include sensors.yaml
cover: !include covers.yaml
light: !include lights.yaml
fan: !include fans.yaml
notify: !include notificsations.yaml
# Example configuration.yaml entry
mobile_app:
discovery:
frontend:
lovelace:
  resources:
    - url: /hacsfiles/lovelace-battery-entity-row/battery-entity-row.js
      type: module
    - url: https://cdn.jsdelivr.net/gh/Imbuzi/meteo-france-weather-card@1.1/dist/meteo-france-weather-card.js
      type: module
homeassistant:
  packages: !include_dir_named packages
#                   Enceintes             #
api:
alexa:
  smart_home:
#                   Boolean               #
input_boolean:
  shieldtv_chambre_ben:
    name: Eteindre Fire Tv
  mode1:
  mode2:
  soir:
  volets_soir:
  boombox:
  systeme_son:
  systeme_son_plus_fort:
    name: Systeme son plus fort
  systeme_son_moins_fort:
    name: Systeme son moins fort
  television:
#               Shelly                    #
shelly:
  username:
  password:
#                   RFLink                #
rflink:
  port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_557323237303517061E1-if00
logger:
  default: error
  logs:
    rflink: debug
    homeassistant.components.rflink: debug
#                   MQTT                #
mqtt:
  broker: 192.168.0.130
  port:
  username:
  password:
  discovery: true
#                   LAMPES                #
yeelight:
  devices:
    192.168.0.121:
      name: salle de bain
    192.168.0.122:
    192.168.0.124:
#                   ShieldTV                #
media_player:
    host: 192.168.0.177
    device_class: firetv
    apps:
    host: 192.168.0.2
    device_class: androidtv
    apps:
    host: 192.168.0.4
    apps:
    host: 192.168.0.5
    apps:
Je rejoins @Pulpy-Luke as tu bien activé le mode devellopeur ?
oui oui j’ai meme reçu encore ce matin le message me demandant lde faire confiance à un appareil du réseau
Il te manque la déclaration de media_player dans le premier fichier non ?
bien comme c’est le fichier media_players il le faut quand même?
Oui sinon il est pas inclus automatiquement… Comme les autres d’ailleurs.
Et il faut garder une seule déclaration ! Pas les 2
