Depuis que j’ai fait la mise à jour de Z-Wave JS, je n’ai plus accès à mes modules.
J’ai un message d’erreur au lancement du module :
cont-init: info: running /etc/cont-init.d/config.sh
[19:29:22] INFO: e[32mBoth 'network_key' and 's0_legacy_key' are set and match. All ok.e[0m
[19:29:23] INFO: e[32mSoft-reset set to automatice[0m
[19:29:23] INFO: e[32mVirtual Machine not detected, enabling soft-resete[0m
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
services-up: info: copying legacy longrun zwave_js (no readiness notification)
[19:29:24] INFO: e[32mSuccessfully send discovery information to Home Assistant.e[0m
2025-04-26T17:29:30.250Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2025-04-26T17:29:30.272Z DRIVER version 15.1.0
2025-04-26T17:29:30.273Z DRIVER
2025-04-26T17:29:31.547Z CONFIG version 15.1.0
2025-04-26T17:29:36.048Z CNTRLR querying Serial API capabilities...
2025-04-26T17:29:37.593Z CNTRLR received API capabilities:
firmware version: 5.4
manufacturer ID: 0x0147
product type: 0x0400
product ID: 0x02
supported functions:
· GetSerialApiInitData (0x02)
· SetApplicationNodeInformation (0x03)
· ApplicationCommand (0x04)
· GetControllerCapabilities (0x05)
· SetSerialApiTimeouts (0x06)
· GetSerialApiCapabilities (0x07)
· SoftReset (0x08)
· GetProtocolVersion (0x09)
· SerialAPIStarted (0x0a)
· SetRFReceiveMode (0x10)
· UNKNOWN_FUNC_SET_SLEEP_MODE (0x11)
· SendNodeInformation (0x12)
· SendData (0x13)
· SendDataMulticast (0x14)
· GetControllerVersion (0x15)
· SendDataAbort (0x16)
· FUNC_ID_ZW_R_F_POWER_LEVEL_SET (0x17)
· UNKNOWN_FUNC_SEND_DATA_META (0x18)
· FUNC_ID_ZW_GET_RANDOM (0x1c)
· GetControllerId (0x20)
· UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
· UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
· UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
· UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
· EnterBootloader (0x27)
· UNKNOWN_FUNC_UNKNOWN_0x28 (0x28)
· GetNVMId (0x29)
· ExtNVMReadLongBuffer (0x2a)
· ExtNVMWriteLongBuffer (0x2b)
· ExtNVMReadLongByte (0x2c)
· ExtExtWriteLongByte (0x2d)
· GetNodeProtocolInfo (0x41)
· HardReset (0x42)
· FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
· FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
· AssignReturnRoute (0x46)
· DeleteReturnRoute (0x47)
· RequestNodeNeighborUpdate (0x48)
· ApplicationUpdateRequest (0x49)
· AddNodeToNetwork (0x4a)
· RemoveNodeFromNetwork (0x4b)
· AddControllerAndAssignPrimary (0x4c)
· AddPrimaryController (0x4d)
· SetLearnMode (0x50)
· AssignSUCReturnRoute (0x51)
· RequestNetworkUpdate (0x53)
· SetSUCNodeId (0x54)
· DeleteSUCReturnRoute (0x55)
· GetSUCNodeId (0x56)
· SendSUCNodeId (0x57)
· ExploreRequestInclusion (0x5e)
· RequestNodeInfo (0x60)
· RemoveFailedNode (0x61)
· IsFailedNode (0x62)
· ReplaceFailedNode (0x63)
· UNKNOWN_FUNC_UNKNOWN_0x66 (0x66)
· UNKNOWN_FUNC_UNKNOWN_0x67 (0x67)
· FirmwareUpdateNVM (0x78)
· GetRoutingInfo (0x80)
· LockUnlockLastRoute (0x90)
· GetPriorityRoute (0x92)
· SetPriorityRoute (0x93)
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· undefined (0xb4)
· EnableWatchdog500 (0xb6)
· DisableWatchdog500 (0xb7)
· KickWatchdog500 (0xb8)
· UNKNOWN_FUNC_UNKNOWN_0xB9 (0xb9)
· UNKNOWN_FUNC_RF_POWERLEVEL_GET (0xba)
· GetLibrary (0xbd)
· SendTestFrame (0xbe)
· GetProtocolStatus (0xbf)
· StartWatchdog (0xd2)
· StopWatchdog (0xd3)
· SetMaximumRoutingAttempts (0xd4)
· undefined (0xef)
· Proprietary_F2 (0xf2)
· Proprietary_F4 (0xf4)
· Proprietary_F5 (0xf5)
2025-04-26T17:29:37.611Z CNTRLR querying additional controller information...
2025-04-26T17:29:37.729Z CNTRLR received additional controller information:
Z-Wave API version: 5 (legacy)
Z-Wave chip type: ZW050x
node type Controller
controller role: primary
controller is the SIS: true
controller supports timers: false
Z-Wave Classic nodes: 1, 2, 3
2025-04-26T17:29:37.735Z CNTRLR querying version info...
2025-04-26T17:29:37.773Z CNTRLR received version info:
controller type: Static Controller
library version: Z-Wave 4.05
2025-04-26T17:29:37.777Z CNTRLR querying protocol version info...
2025-04-26T17:29:37.802Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 4.5.0
2025-04-26T17:29:37.806Z CNTRLR querying controller capabilities...
2025-04-26T17:29:37.846Z CNTRLR received controller capabilities:
controller role: Primary
is the SUC: true
started this network: true
SIS is present: true
was real primary: true
2025-04-26T17:29:37.868Z CNTRLR supported Z-Wave features:
2025-04-26T17:29:37.888Z CNTRLR Performing soft reset...
2025-04-26T17:29:37.924Z CNTRLR Waiting for the controller to reconnect...
2025-04-26T17:29:39.430Z CNTRLR Waiting for the Serial API to start...
2025-04-26T17:29:44.434Z CNTRLR Did not receive notification that Serial API has started, checking if it respo
nds...
2025-04-26T17:29:44.450Z CNTRLR Serial API responded
2025-04-26T17:29:44.454Z CNTRLR querying controller IDs...
2025-04-26T17:29:44.466Z CNTRLR Serial API restarted unexpectedly.
2025-04-26T17:29:44.467Z CNTRLR Currently active command will be retried...
ZWaveError: The Serial API restarted unexpectedly (ZW0206)
at Driver.handleSerialAPIStartedUnexpectedly (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5013:7)
at Driver.handleRequest (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5575:19)
at Driver.handleUnsolicitedMessage (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4963:16)
at Driver.serialport_onData (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:3995:14)
at runNextTicks (node:internal/process/task_queues:65:5)
at processImmediate (node:internal/timers:459:9)
[17:29:44] WARNING: e[33mHalt add-one[0m
[center]## System Information
| version |
core-2025.4.4 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.13.2 |
| os_name |
Linux |
| os_version |
6.6.74-haos-raspi |
| arch |
aarch64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
| HACS Data |
ok |
5000 |
| Installed Version |
2.0.5 |
| Stage |
running |
| Available Repositories |
1682 |
| Downloaded Repositories |
3 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 15.2 |
| update_channel |
stable |
| supervisor_version |
supervisor-2025.04.0 |
| agent_version |
1.7.2 |
| docker_version |
28.0.4 |
| disk_total |
219.4 GB |
| disk_used |
118.6 GB |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
| board |
rpi4-64 |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Mosquitto broker (6.5.0), Terminal & SSH (9.17.0), File editor (5.8.0), teleinfo2mqtt (9.0.4), Frigate (Full Access) (0.15.1), Matter Server (7.0.0), go2rtc (1.9.9), Z-Wave JS (0.12.0) |
| dashboards |
4 |
| resources |
2 |
| views |
5 |
| mode |
storage |
Network Configuration
| adapters |
lo (disabled), wlan0 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth8c4fc66 (disabled), vethb462c3e (disabled), vethfa92272 (disabled), veth1be304b (disabled), veth478143f (disabled), vethf879b04 (disabled), veth9a1a078 (disabled), vetha32fc47 (disabled), veth60046c6 (disabled), veth7ebb963 (disabled) |
| ipv4_addresses |
lo (127.0.0.1/8), wlan0 (192.168.0.231/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth8c4fc66 (), vethb462c3e (), vethfa92272 (), veth1be304b (), veth478143f (), vethf879b04 (), veth9a1a078 (), vetha32fc47 (), veth60046c6 (), veth7ebb963 () |
| ipv6_addresses |
lo (::1/128), wlan0 (fe80::d600:f23b:b9aa:b481/64), hassio (fe80::94ff:76ff:fed3:f59b/64), docker0 (fe80::5c1e:b4ff:fec0:e11f/64), veth8c4fc66 (fe80::7c34:dcff:fee4:c6e2/64), vethb462c3e (fe80::d8fe:76ff:fed9:873f/64), vethfa92272 (fe80::683b:3fff:fe3c:884/64), veth1be304b (fe80::64dc:1eff:fed4:21c7/64), veth478143f (fe80::94e2:9eff:fe1d:911/64), vethf879b04 (fe80::640e:8ff:fe7b:1ef2/64), veth9a1a078 (fe80::24d2:18ff:fefb:fe64/64), vetha32fc47 (fe80::6880:e9ff:feab:ac34/64), veth60046c6 (fe80::486e:b3ff:fe4d:a125/64), veth7ebb963 (fe80::ccee:7bff:fe9f:b1bb/64) |
| announce_addresses |
192.168.0.231, fe80::d600:f23b:b9aa:b481 |
| oldest_recorder_run |
15 avril 2025 à 16:57 |
| current_recorder_run |
26 avril 2025 à 19:14 |
| estimated_db_size |
691.96 MiB |
| database_engine |
sqlite |
| database_version |
3.48.0 |
[/center]
Ça ressemble a une carte qui commence a flanché. Tu l’as depuis longtemps.
Depuis 2016, mais elle fonctionnait parfaitement avant update.
Je vais la tester sur mon 2ᵉ raspberry.
Mais tu parles de maj de quoi ? Tu as pas un pb avec les gpio ?
De la mise à jour de Z-Wave JS, oui je parle bien de ma carte z-wave en GPIO
J’ai disable option : « 500 series controller soft-reset »
Ça semble mieux :
[22:27:45] INFO: e[32mBoth 'network_key' and 's0_legacy_key' are set and match. All ok.e[0m
[22:27:47] INFO: e[32mSoft-reset disabled by usere[0m
[22:27:49] INFO: e[32mSuccessfully send discovery information to Home Assistant.e[0m
2025-04-26T20:28:01.945Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2025-04-26T20:28:01.952Z DRIVER version 15.1.0
2025-04-26T20:28:01.953Z DRIVER
2025-04-26T20:28:03.214Z CONFIG version 15.1.0
2025-04-26T20:28:08.050Z CNTRLR querying Serial API capabilities...
2025-04-26T20:28:09.606Z CNTRLR received API capabilities:
product ID: 0x02
· SoftReset (0x08)
· SendData (0x13)
· GetNVMId (0x29)
· HardReset (0x42)
· undefined (0xb4)
· GetLibrary (0xbd)
· undefined (0xef)
2025-04-26T20:28:09.626Z CNTRLR querying additional controller information...
2025-04-26T20:28:09.760Z CNTRLR received additional controller information:
2025-04-26T20:28:09.764Z CNTRLR querying version info...
2025-04-26T20:28:09.815Z CNTRLR received version info:
2025-04-26T20:28:09.817Z CNTRLR querying protocol version info...
2025-04-26T20:28:09.845Z CNTRLR received protocol version info:
2025-04-26T20:28:09.848Z CNTRLR querying controller capabilities...
2025-04-26T20:28:09.881Z CNTRLR received controller capabilities:
is the SUC: true
2025-04-26T20:28:09.893Z CNTRLR supported Z-Wave features:
2025-04-26T20:28:09.904Z CNTRLR querying controller IDs...
2025-04-26T20:28:09.940Z CNTRLR received controller IDs:
home ID: 0xda471873
own node ID: 1
2025-04-26T20:28:09.942Z CNTRLR finding SUC...
2025-04-26T20:28:09.986Z CNTRLR This is the SUC
2025-04-26T20:28:09.987Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2025-04-26T20:28:10.026Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1000 ms, byte = 15
0 ms
2025-04-26T20:28:10.304Z CNTRLR [Node 001] Embedded device config loaded
2025-04-26T20:28:10.377Z CNTRLR Interview completed
Starting server on <all interfaces>:3000
2025-04-26T20:28:10.470Z CNTRLR [Node 001] The node is alive.
2025-04-26T20:28:10.472Z CNTRLR [Node 001] The node is ready to be used
2025-04-26T20:28:10.477Z CNTRLR Interviewing nodes and/or determining their status: 3, 2
2025-04-26T20:28:10.485Z CNTRLR [Node 003] Beginning interview - last completed stage: ProtocolInfo
2025-04-26T20:28:10.491Z CNTRLR » [Node 003] pinging the node...
2025-04-26T20:28:10.848Z CNTRLR [Node 002] The node is asleep.
2025-04-26T20:28:10.856Z CNTRLR [Node 002] Beginning interview - last completed stage: ProtocolInfo
2025-04-26T20:28:10.869Z CNTRLR » [Node 002] querying node info...
ZwaveJS server listening on <all interfaces>:3000
2025-04-26T20:28:15.063Z CNTRLR [Node 003] The node did not respond after 1 attempts, it is presumed dead
2025-04-26T20:28:15.066Z CNTRLR [Node 003] The node is dead.
2025-04-26T20:28:15.082Z CNTRLR [Node 003] ping failed: The node did not acknowledge the command (ZW0204)
2025-04-26T20:28:15.083Z CNTRLR [Node 003] Interview attempt (1/5) failed, node is dead.
C’est bon, l’option désactivée a bien tout réparé.
system
A fermé ce sujet ()
8
