bonjour, suite a une coupure électrique, au redémarrage j’ais ce problème :
Invalid config
The following integrations and platforms could not be set up:
zeroconf
default_config
Please check your config and logs.
ne pause problème que supervisor et entités liées
Bien sûre redémarrage serveur et reboot du RPI ne résolvent pas le problème, docker fonctionne normalement
des idées ?
config :
## System Health
version | core-2021.11.3
installation_type | Home Assistant Supervised
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.9.7
os_name | Linux
os_version | 5.10.63-v7l+
arch | armv7l
timezone | UTC
GitHub API | ok
Github API Calls Remaining | 5000
Installed Version | 1.17.1
Stage | running
Available Repositories | 976
Installed Repositories | 12
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Raspbian GNU/Linux 10 (buster)
update_channel | beta
supervisor_version | supervisor-2021.10.8
docker_version | 20.10.11
disk_total | 117.1 GB
disk_used | 16.6 GB
healthy | true
supported | failed to load: Unsupported
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.3.3), ESPHome (2021.9.0), motionEye (0.16.0), VLC (0.1.3), Samba share (9.5.1), FTP (4.2.1), Node-RED (10.1.1), Let's Encrypt (4.11.0), CEC Scanner (3.0), Google Assistant SDK (2.5.0), PSA Car Controller (v2.5.4), Terminal & SSH (9.2.1), Rhasspy Assistant (2.5.11), OpenTTS fr (2.1.0), Mosquitto broker (6.0.1), Duck DNS (1.14.0)
</details>
<details><summary>Lovelace</summary>
dashboards | 3
resources | 5
views | 8
mode | storage
</details>
