custom.h
saisissez ou collez du code ici #include "esphome.h"
class CM1106 : public UARTDevice {
public:
CM1106(UARTComponent *parent) : UARTDevice(parent) {}
void setCo2CalibValue(uint16_t ppm = 400) {
uint8_t cmd[6];
memcpy(cmd, CM1106_CMD_SET_CO2_CALIB, sizeof(cmd));
cmd[3] = ppm >> 8;
cmd[4] = ppm & 0xFF;
uint8_t response[4] = {0};
bool success = sendUartCommand(cmd, sizeof(cmd), response, sizeof(response));
if(!success) {
ESP_LOGW(TAG, "Reading data from CM1106 failed!");
return;
if(memcmp(response, CM1106_CMD_SET_CO2_CALIB_RESPONSE, sizeof(response)) != 0) {
ESP_LOGW(TAG, "Got wrong UART response: %02X %02X %02X %02X", response[0], response[1], response[2], response[3]);
return;
ESP_LOGD(TAG, "CM1106 Successfully calibrated sensor to %uppm", ppm);
int16_t getCo2PPM() { // Get CO2 value in ppm
uint8_t response[8] = {0}; // response: 0x16, 0x05, 0x01, DF1, DF2, DF3, DF4, CRC. PPM: DF1*256+DF2
bool success = sendUartCommand(CM1106_CMD_GET_CO2, sizeof(CM1106_CMD_GET_CO2), response, sizeof(response));
if(!success) {
return -1;
if(!(response[0] == 0x16 && response[1] == 0x05 && response[2] == 0x01)) {
ESP_LOGW(TAG, "Got wrong UART response: %02X %02X %02X %02X...", response[0], response[1], response[2], response[3]);
return -1;
uint8_t checksum = calcCRC(response, sizeof(response));
// DF3 and DF4 are reserved
if(response[6] != checksum) {
ESP_LOGW(TAG, "Got wrong UART checksum: 0x%02X - Calculated: 0x%02X", response[6], checksum);
return -1;
if(response[7] != checksum) {
ESP_LOGW(TAG, "Got wrong UART checksum: 0x%02X - Calculated: 0x%02X", response[7], checksum);
return -1;
int16_t ppm = response[3] << 8 | response[4];
ESP_LOGD(TAG, "CM1106 Received CO₂=%uppm DF3=%02X DF4=%02X", ppm, response[5], response[6]);
return ppm;
private:
const char *TAG = "cm1106";
uint8_t CM1106_CMD_GET_CO2[4] = {0x11, 0x01, 0x01, 0xED}; // head, len, cmd, [data], crc
uint8_t CM1106_CMD_SET_CO2_CALIB[3] = {0x11, 0x03, 0x03 };
uint8_t CM1106_CMD_SET_CO2_CALIB_RESPONSE[2] = { 0x01, 0x03 };
// Checksum: 256-(HEAD+LEN+CMD+DATA)%256
uint8_t calcCRC(uint8_t* response, size_t len) {
uint8_t crc = 0;
for(int i = 0; i < len - 1; i++) {
crc -= response[i];
return crc;
bool sendUartCommand(uint8_t *command, size_t commandLen, uint8_t *response = nullptr, size_t responseLen = 0) {
// Empty RX Buffer
while (available()) {
read();
// Calculate CRC
command[commandLen - 1] = calcCRC(command, commandLen);
write_array(command, commandLen);
flush();
if(response == nullptr) {
return true;
return read_array(response, responseLen);
class CM1106Sensor : public PollingComponent, public Sensor {
private:
CM1106 *cm1106;
public:
CM1106Sensor(UARTComponent *parent, uint32_t update_interval) : PollingComponent(update_interval) {
cm1106 = new CM1106(parent);
float get_setup_priority() const { return setup_priority::DATA; }
void setup() override {
void update() override {
int16_t ppm = cm1106->getCo2PPM();
if(ppm > -1) {
publish_state(ppm);
