Depuis ce jour, Je rencontre ce problème:
MFailed to connect: Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed (‹ 172.30.33.4 ›, 3000)]on problème
Quand je vais dans le module complémentaire Z-Wave JS - Onglet , il me dit:
2024-04-04T20:20:05.610Z DRIVER version 12.4.4
2024-04-04T20:20:14.650Z DRIVER Failed to open the serial port: Error Resource temporarily unavailable Cannot
lock port
Unable to start driver ZWaveError: Failed to open the serial port: Error Resource temporarily unavailable Cannot lock port (ZW0100)
at Driver.openSerialport (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1286:9)
at Immediate. (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1121:5) {
code: 100,
context: undefined,
transactionSource: undefined
[20:20:14] WARNING: Halt add-on
Merci pour vos réponses.
Christian
