je voudrais caster mon interface Home Assistant sur mon Google Nest Hub en suivant ce tuto.
Mais quand je fais la commande python3 -m pip install catt ca ne fonctionne pas voici l’erreur:
Collecting catt
Downloading catt-0.12.5-py2.py3-none-any.whl (27 kB)
Collecting zeroconf==0.31.0
Downloading zeroconf-0.31.0-py3-none-any.whl (59 kB)
|████████████████████████████████| 59 kB 1.4 MB/s
Collecting yt-dlp>=2021.12.1
Downloading yt_dlp-2021.12.25-py2.py3-none-any.whl (2.4 MB)
|████████████████████████████████| 2.4 MB 152 kB/s
Collecting ifaddr>=0.1.7
Downloading ifaddr-0.1.7-py2.py3-none-any.whl (10 kB)
Collecting PyChromecast==9.2.0
Downloading PyChromecast-9.2.0-py2.py3-none-any.whl (63 kB)
|████████████████████████████████| 63 kB 1.6 kB/s
Requirement already satisfied: requests>=2.23.0 in /usr/lib/python3.9/site-packages (from catt) (2.26.0)
Collecting Click>=7.1.2
Downloading click-8.0.3-py3-none-any.whl (97 kB)
|████████████████████████████████| 97 kB 675 kB/s
Collecting protobuf>=3.0.0
Downloading protobuf-3.19.1-py2.py3-none-any.whl (162 kB)
|████████████████████████████████| 162 kB 5.2 MB/s
Collecting casttube>=0.2.0
Downloading casttube-0.2.1-py3-none-any.whl (6.5 kB)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/lib/python3.9/site-packages (from requests>=2.23.0->catt) (1.26.7)
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3.9/site-packages (from requests>=2.23.0->catt) (2020.12.5)
Requirement already satisfied: charset_normalizer~=2.0.0 in /usr/lib/python3.9/site-packages (from requests>=2.23.0->catt) (2.0.7)
Requirement already satisfied: idna<4,>=2.5 in /usr/lib/python3.9/site-packages (from requests>=2.23.0->catt) (3.3)
Collecting pycryptodomex
Downloading pycryptodomex-3.12.0.zip (3.7 MB)
|████████████████████████████████| 3.7 MB 59 kB/s
Collecting mutagen
Downloading mutagen-1.45.1-py3-none-any.whl (218 kB)
|████████████████████████████████| 218 kB 4.9 MB/s
Collecting websockets
Downloading websockets-10.1.tar.gz (83 kB)
|████████████████████████████████| 83 kB 132 kB/s
Using legacy 'setup.py install' for pycryptodomex, since package 'wheel' is not installed.
Using legacy 'setup.py install' for websockets, since package 'wheel' is not installed.
Installing collected packages: ifaddr, zeroconf, websockets, pycryptodomex, protobuf, mutagen, casttube, yt-dlp, PyChromecast, Click, catt
Running setup.py install for websockets ... done
Running setup.py install for pycryptodomex ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-i5i7h9eu/pycryptodomex_0b7fcc557bf9435cbf15d4c8486d3f56/setup.py'"'"'; __file__='"'"'/tmp/pip-install-i5i7h9eu/pycryptodomex_0b7fcc557bf9435cbf15d4c8486d3f56/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ss1_iqri/install-record.txt --single-version-externally-managed --compile --install-headers /usr/include/python3.9/pycryptodomex
cwd: /tmp/pip-install-i5i7h9eu/pycryptodomex_0b7fcc557bf9435cbf15d4c8486d3f56/
Complete output (328 lines):
Testing support for clang
Target does not support clang
Testing support for gcc
Target does not support gcc
Testing support for stdint.h header
Target does not support stdint.h header
Testing support for 128-bit integer
Target does not support 128-bit integer
Testing support for cpuid.h header
Target does not support cpuid.h header
Testing support for intrin.h header
Target does not support intrin.h header
Testing support for posix_memalign
Target does not support posix_memalign
Testing support for memalign
Target does not support memalign
Testing support for SSE2(intrin.h)
Target does not support SSE2(intrin.h)
Testing support for SSE2(x86intrin.h)
Target does not support SSE2(x86intrin.h)
Testing support for SSE2(emmintrin.h)
Target does not support SSE2(emmintrin.h)
Warning: compiler does not support AESNI instructions
Warning: compiler does not support CLMUL instructions
running install
running build
running build_py
creating build/lib.linux-aarch64-3.9
creating build/lib.linux-aarch64-3.9/Cryptodome
copying lib/Cryptodome/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome
creating build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/DES.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/PKCS1_v1_5.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ARC4.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/Salsa20.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_gcm.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ofb.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ocb.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_cbc.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/Blowfish.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/CAST.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_eax.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ChaCha20.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ecb.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ccm.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ARC2.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ctr.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ChaCha20_Poly1305.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/DES3.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_EKSBlowfish.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/PKCS1_OAEP.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_cfb.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_openpgp.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_siv.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/AES.py -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
creating build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/MD5.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA384.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHAKE256.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/KangarooTwelve.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/TupleHash128.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/KMAC128.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA1.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA3_256.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA3_384.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/KMAC256.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/BLAKE2b.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/MD4.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/BLAKE2s.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/keccak.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/cSHAKE128.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA256.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/HMAC.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/TupleHash256.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/RIPEMD.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/RIPEMD160.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA3_224.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHAKE128.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA3_512.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/CMAC.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/MD2.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/Poly1305.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA224.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA512.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/cSHAKE256.py -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
creating build/lib.linux-aarch64-3.9/Cryptodome/IO
copying lib/Cryptodome/IO/_PBES.py -> build/lib.linux-aarch64-3.9/Cryptodome/IO
copying lib/Cryptodome/IO/PEM.py -> build/lib.linux-aarch64-3.9/Cryptodome/IO
copying lib/Cryptodome/IO/PKCS8.py -> build/lib.linux-aarch64-3.9/Cryptodome/IO
copying lib/Cryptodome/IO/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/IO
creating build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/ElGamal.py -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/ECC.py -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/_openssh.py -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/DSA.py -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/RSA.py -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
creating build/lib.linux-aarch64-3.9/Cryptodome/Protocol
copying lib/Cryptodome/Protocol/KDF.py -> build/lib.linux-aarch64-3.9/Cryptodome/Protocol
copying lib/Cryptodome/Protocol/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/Protocol
copying lib/Cryptodome/Protocol/SecretSharing.py -> build/lib.linux-aarch64-3.9/Cryptodome/Protocol
creating build/lib.linux-aarch64-3.9/Cryptodome/Random
copying lib/Cryptodome/Random/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/Random
copying lib/Cryptodome/Random/random.py -> build/lib.linux-aarch64-3.9/Cryptodome/Random
creating build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/PKCS1_v1_5.py -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/PKCS1_PSS.py -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/pkcs1_15.py -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/DSS.py -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/pss.py -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
creating build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/strxor.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/Padding.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/_cpu_features.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/_raw_api.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/asn1.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/py3compat.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/RFC1751.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/_file_system.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/Counter.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/number.py -> build/lib.linux-aarch64-3.9/Cryptodome/Util
creating build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/_IntegerCustom.py -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/_IntegerNative.py -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/Primality.py -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/_IntegerBase.py -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/Numbers.py -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/_IntegerGMP.py -> build/lib.linux-aarch64-3.9/Cryptodome/Math
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest
copying lib/Cryptodome/SelfTest/loader.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest
copying lib/Cryptodome/SelfTest/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest
copying lib/Cryptodome/SelfTest/st_common.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest
copying lib/Cryptodome/SelfTest/__main__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_DES.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_GCM.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_ARC2.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/common.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_CTR.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_OpenPGP.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_pkcs1_oaep.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_Salsa20.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_OCB.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_pkcs1_15.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_EAX.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_ChaCha20_Poly1305.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_CFB.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_Blowfish.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_CAST.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_DES3.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_OFB.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_AES.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_ChaCha20.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_SIV.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_CCM.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_ARC4.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
copying lib/Cryptodome/SelfTest/Cipher/test_CBC.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Cipher
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_cSHAKE.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_HMAC.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHAKE.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA1.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_MD4.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA3_384.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA224.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_MD5.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/common.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_RIPEMD160.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_Poly1305.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA512.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA256.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA3_256.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_BLAKE2.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_MD2.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA3_512.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA3_224.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_TupleHash.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_CMAC.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_SHA384.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_KMAC.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_KangarooTwelve.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
copying lib/Cryptodome/SelfTest/Hash/test_keccak.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Hash
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/IO
copying lib/Cryptodome/SelfTest/IO/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/IO
copying lib/Cryptodome/SelfTest/IO/test_PKCS8.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/IO
copying lib/Cryptodome/SelfTest/IO/test_PBES.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/IO
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Protocol
copying lib/Cryptodome/SelfTest/Protocol/test_SecretSharing.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Protocol
copying lib/Cryptodome/SelfTest/Protocol/test_KDF.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Protocol
copying lib/Cryptodome/SelfTest/Protocol/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Protocol
copying lib/Cryptodome/SelfTest/Protocol/test_rfc1751.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Protocol
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/test_import_ECC.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/test_ECC.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/test_RSA.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/test_import_DSA.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/test_ElGamal.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/test_import_RSA.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
copying lib/Cryptodome/SelfTest/PublicKey/test_DSA.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/PublicKey
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Random
copying lib/Cryptodome/SelfTest/Random/test_random.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Random
copying lib/Cryptodome/SelfTest/Random/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Random
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Signature
copying lib/Cryptodome/SelfTest/Signature/test_pkcs1_15.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Signature
copying lib/Cryptodome/SelfTest/Signature/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Signature
copying lib/Cryptodome/SelfTest/Signature/test_pss.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Signature
copying lib/Cryptodome/SelfTest/Signature/test_dss.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Signature
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
copying lib/Cryptodome/SelfTest/Util/test_strxor.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
copying lib/Cryptodome/SelfTest/Util/test_number.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
copying lib/Cryptodome/SelfTest/Util/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
copying lib/Cryptodome/SelfTest/Util/test_Counter.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
copying lib/Cryptodome/SelfTest/Util/test_rfc1751.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
copying lib/Cryptodome/SelfTest/Util/test_Padding.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
copying lib/Cryptodome/SelfTest/Util/test_asn1.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Util
creating build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Math
copying lib/Cryptodome/SelfTest/Math/test_modexp.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Math
copying lib/Cryptodome/SelfTest/Math/__init__.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Math
copying lib/Cryptodome/SelfTest/Math/test_Numbers.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Math
copying lib/Cryptodome/SelfTest/Math/test_Primality.py -> build/lib.linux-aarch64-3.9/Cryptodome/SelfTest/Math
copying lib/Cryptodome/py.typed -> build/lib.linux-aarch64-3.9/Cryptodome
copying lib/Cryptodome/__init__.pyi -> build/lib.linux-aarch64-3.9/Cryptodome
copying lib/Cryptodome/Cipher/CAST.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ctr.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/Blowfish.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ccm.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ARC4.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/PKCS1_OAEP.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ChaCha20.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_eax.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_openpgp.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_cfb.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_gcm.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ARC2.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/DES.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/DES3.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_siv.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/AES.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ofb.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/PKCS1_v1_5.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_EKSBlowfish.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/Salsa20.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/ChaCha20_Poly1305.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_cbc.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ecb.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/__init__.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Cipher/_mode_ocb.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Cipher
copying lib/Cryptodome/Hash/SHA3_224.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/TupleHash128.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA3_384.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/RIPEMD160.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA1.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/KMAC256.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/MD2.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA224.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/BLAKE2b.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/KMAC128.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/cSHAKE256.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA3_512.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA384.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/cSHAKE128.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/Poly1305.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/HMAC.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/MD4.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/KangarooTwelve.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA512.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA3_256.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHAKE256.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHA256.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/CMAC.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/BLAKE2s.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/keccak.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/SHAKE128.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/MD5.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/TupleHash256.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/RIPEMD.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/Hash/__init__.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Hash
copying lib/Cryptodome/IO/PKCS8.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/IO
copying lib/Cryptodome/IO/PEM.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/IO
copying lib/Cryptodome/IO/_PBES.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/IO
copying lib/Cryptodome/PublicKey/ECC.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/_openssh.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/ElGamal.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/RSA.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/DSA.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/PublicKey/__init__.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/PublicKey
copying lib/Cryptodome/Protocol/KDF.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Protocol
copying lib/Cryptodome/Protocol/SecretSharing.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Protocol
copying lib/Cryptodome/Protocol/__init__.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Protocol
copying lib/Cryptodome/Random/random.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Random
copying lib/Cryptodome/Random/__init__.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Random
copying lib/Cryptodome/Signature/PKCS1_PSS.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/pss.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/DSS.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/PKCS1_v1_5.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Signature/pkcs1_15.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Signature
copying lib/Cryptodome/Util/_file_system.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/asn1.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/number.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/Counter.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/RFC1751.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/strxor.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/_cpu_features.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/Padding.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/py3compat.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Util/_raw_api.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Util
copying lib/Cryptodome/Math/_IntegerBase.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/Primality.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/_IntegerNative.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/_IntegerGMP.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/_IntegerCustom.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Math
copying lib/Cryptodome/Math/Numbers.pyi -> build/lib.linux-aarch64-3.9/Cryptodome/Math
running build_ext
building 'Cryptodome.Hash._MD2' extension
creating build/temp.linux-aarch64-3.9
creating build/temp.linux-aarch64-3.9/src
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -g -fno-semantic-interposition -g -fno-semantic-interposition -g -fno-semantic-interposition -DTHREAD_STACK_SIZE=0x100000 -fPIC -DPYCRYPTO_LITTLE_ENDIAN -DSYS_BITS=64 -DLTC_NO_ASM -Isrc/ -I/usr/include/python3.9 -c src/MD2.c -o build/temp.linux-aarch64-3.9/src/MD2.o
error: command 'gcc' failed: No such file or directory
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-i5i7h9eu/pycryptodomex_0b7fcc557bf9435cbf15d4c8486d3f56/setup.py'"'"'; __file__='"'"'/tmp/pip-install-i5i7h9eu/pycryptodomex_0b7fcc557bf9435cbf15d4c8486d3f56/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ss1_iqri/install-record.txt --single-version-externally-managed --compile --install-headers /usr/include/python3.9/pycryptodomex Check the logs for full command output.
Pouvez-vous m’aider svp
OS Version: Home Assistant OS 7.0
Home Assistant Core: 2021.12.5
Sur un raspberry pi 4
