Impossible de faire fonctionner l’intégration Netatmo après de multiples essais et redémarrage. Je comprends pas. Une idée ?
Logger: homeassistant.config_entries
Source: components/netatmo/data_handler.py:164
First occurred: 10:03:52 (1 occurrences)
Last logged: 10:03:52
Error setting up entry Home Assistant Cloud for netatmo
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 986, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)  # type: ignore[return-value]  # noqa
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1064, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1049, in create_connection
    sock = await self._connect_sock(
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 960, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 500, in sock_connect
    return await fut
  File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 535, in _sock_connect_cb
    raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('169.254.160.233', 80)
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 357, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 153, in async_setup_entry
    await data_handler.async_setup()
  File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 108, in async_setup
    await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 204, in subscribe
    await self.async_fetch_data(signal_name)
  File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 164, in async_fetch_data
    await self.data[signal_name].async_update()
  File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 649, in async_update
    await self._async_update_all_camera_urls()
  File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 659, in _async_update_all_camera_urls
    await self.async_update_camera_urls(camera_id)
  File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 724, in async_update_camera_urls
    ] = await self._async_check_url(
  File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 731, in _async_check_url
    resp = await self.auth.async_post_request(url=f"{url}/command/ping")
  File "/usr/local/lib/python3.10/site-packages/pyatmo/auth.py", line 335, in async_post_request
    async with self.websession.post(
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 1138, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 535, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 542, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 907, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1206, in _create_direct_connection
    raise last_exc
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1175, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 992, in _wrap_create_connection
    raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 169.254.160.233:80 ssl:default [Connect call failed ('169.254.160.233', 80)]
version | core-2022.8.3
installation_type | Home Assistant Container
dev | false
hassio | false
docker | true
user | root
virtualenv | false
python_version | 3.10.5
os_name | Linux
os_version | 5.15.32-v8+
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4774
Installed Version | 1.26.2
Stage | running
Available Repositories | 1094
Downloaded Repositories | 11
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
dashboards | 2
resources | 6
views | 6
mode | storage
</details>
oldest_recorder_run | 15 juillet 2022 à 06:47
current_recorder_run | 15 août 2022 à 09:57
estimated_db_size | 316.23 MiB
database_engine | mysql
database_version | 10.5.16
</details>
