Aujourd’hui
up to date, audited 26 packages in 5s
4 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
[22:41:24] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
28 Mar 22:41:39 - [info]
Welcome to Node-RED
28 Mar 22:41:39 - [info] Node-RED version: v3.1.7
28 Mar 22:41:39 - [info] Node.js version: v18.19.1
28 Mar 22:41:39 - [info] Linux 6.1.63-haos-raspi arm64 LE
28 Mar 22:41:59 - [info] Loading palette nodes
28 Mar 22:42:05 - [info] Node-RED Contrib Theme Collection version: v3.1.11
28 Mar 22:42:16 - [info] Dashboard version 3.6.5 started at /endpoint/ui
28 Mar 22:42:25 - [info] Settings file : /etc/node-red/config.js
28 Mar 22:42:25 - [info] Context store : 'default' [module=memory]
28 Mar 22:42:25 - [info] User directory : /config/
28 Mar 22:42:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Mar 22:42:25 - [info] Flows file : /config/flows.json
28 Mar 22:42:25 - [info] Server now running at http://127.0.0.1:46836/
[22:42:26] INFO: Starting NGinx...
28 Mar 22:42:31 - [info] Starting flows
28 Mar 22:42:55 - [info] [cronplus:Allumer Lundi, Mardi et jeudi 7h] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0 7 * * MON,TUE,THU *","location":"","offset":"0","solarType":"selected","solarEvents":"nauticalDusk"}
[22:43:00] INFO: Service Node-RED exited with code 256 (by signal 9)
[22:43:02] INFO: Starting Node-RED...
> start
28 Mar 22:43:13 - [info]
Welcome to Node-RED
28 Mar 22:43:13 - [info] Node-RED version: v3.1.7
28 Mar 22:43:13 - [info] Node.js version: v18.19.1
28 Mar 22:43:13 - [info] Linux 6.1.63-haos-raspi arm64 LE
28 Mar 22:43:17 - [info] Loading palette nodes
28 Mar 22:43:20 - [info] Node-RED Contrib Theme Collection version: v3.1.11
28 Mar 22:43:31 - [info] Dashboard version 3.6.5 started at /endpoint/ui
28 Mar 22:43:57 - [info] Settings file : /etc/node-red/config.js
28 Mar 22:43:57 - [info] Context store : 'default' [module=memory]
28 Mar 22:43:57 - [info] User directory : /config/
28 Mar 22:43:57 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Mar 22:43:57 - [info] Flows file : /config/flows.json
28 Mar 22:43:57 - [info] Server now running at http://127.0.0.1:46836/
28 Mar 22:43:58 - [info] Starting flows
28 Mar 22:43:58 - [info] [cronplus:Allumer Lundi, Mardi et jeudi 7h] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0 7 * * MON,TUE,THU *","location":","offset":"0","solarType":"selected","solarEvents":"nauticalDusk"}
28 Mar 22:43:58 - [info] [cronplus:Eteindre Lundi, Mardi merc et jeudi 8h et semaine 23h30 et week end 0h45] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0 8 * * MON,TUE,WED,THU *","location":"9","offset":"0","solarType":"selected","solarEvents":"nauticalDusk"}
28 Mar 22:43:58 - [info] [cronplus:Eteindre Lundi, Mardi merc et jeudi 8h et semaine 23h30 et week end 0h45] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"cron","expression":"0 25 23 * * SUN-THU *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:58 - [info] [cronplus:Eteindre Lundi, Mardi merc et jeudi 8h et semaine 23h30 et week end 0h45] createTask - index: 2, static: true, opt: {"name":"schedule3","topic":"topic3","payloadType":"default","payload":"","expressionType":"cron","expression":"0 45 0 * * FRI-SAT *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:58 - [info] [cronplus:Ouverture RDC cuisine + bow window + sejour] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0 7 * * MON-FRI *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:58 - [info] [cronplus:Ouverture RDC cuisine + bow window + sejour] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0 9 * * SAT *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:58 - [info] [cronplus:Fermeture RDC] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 0 7 * * MON-FRI *","location":"","offset":"15","solarType":"selected","solarEvents":"sunset"}
28 Mar 22:43:58 - [info] [cronplus:Fermeture Etage] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 0 7 * * MON-FRI *","location":","offset":"15","solarType":"selected","solarEvents":"sunset"}
28 Mar 22:43:58 - [info] [cronplus:ouvrir etage 7h20] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"dates","expression":"0 20 7 * * MON-SUN *","location":"","offset":"15","solarType":"selected","solarEvents":"sunset"}
28 Mar 22:43:58 - [info] [cronplus:Fermer etage et Bow wind2,3 et Porte F sejour LUN- VEN 9h] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"dates","expression":"0 0 9 * * MON-FRI *","","offset":"15","solarType":"selected","solarEvents":"sunset"}
28 Mar 22:43:58 - [info] [cronplus:Fermer bandeau LUN-VEN 12h] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"dates","expression":"0 0 12 * * MON-FRI *","location":"offset":"15","solarType":"selected","solarEvents":"sunset"}
28 Mar 22:43:58 - [info] [cronplus:Ouverture porte fenetre cuisine + bow 1 9H] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 13 8 * * MON-FRI *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:58 - [info] [cronplus:Ouverture porte fenetre cuisine + bow 1 9H] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"cron","expression":"0 0 9 * * SAT *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:59 - [info] [cronplus:Ouverture bandeau 2 a moitier] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 04 7 * * MON-FRI *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:59 - [info] [cronplus:Ouverture bandeau 2 a moitier] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"cron","expression":"0 03 9 * * SAT-SUN *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:59 - [info] [cronplus:Ouverture bandeau 1 a moitier] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 02 7 * * MON-FRI *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:59 - [info] [cronplus:Ouverture bandeau 1 a moitier] createTask - index: 1, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"cron","expression":"0 02 9 * * SAT-SUN *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:59 - [info] [cronplus:Allumer coucher soleil] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 0 8 * * MON,TUE,THU *","location":"","offset":"10","solarType":"selected","solarEvents":"sunset"}
28 Mar 22:43:59 - [info] [cronplus:Eteindre semaine 23h35 et week end 0h15] createTask - index: 0, static: true, opt: {"name":"schedule2","topic":"topic2","payloadType":"default","payload":"","expressionType":"cron","expression":"0 35 23 * * SUN-THU *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:59 - [info] [cronplus:Eteindre semaine 23h35 et week end 0h15] createTask - index: 1, static: true, opt: {"name":"schedule3","topic":"topic3","payloadType":"default","payload":"","expressionType":"cron","expression":"0 15 0 * * SAT-SUN *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}
28 Mar 22:43:59 - [info] [cronplus:Sunset test] createTask - index: 0, static: true, opt: {"name":"schedule1","topic":"topic1","payloadType":"default","payload":"","expressionType":"solar","expression":"0 0 7 * * MON-FRI *","","offset":"15","solarType":"selected","solarEvents":"sunset"}
28 Mar 22:43:59 - [error] [mqtt out:f5b9249b54468ace] missing broker configuration
28 Mar 22:44:00 - [info] Started flows
28 Mar 22:44:01 - [info] [server:Home Assistant ok] Connecting to http://supervisor/core
[22:44:12] INFO: Service Node-RED exited with code 256 (by signal 9)
[22:44:13] INFO: Starting Node-RED...
> start
28 Mar 22:44:28 - [info]
Welcome to Node-RED
28 Mar 22:44:28 - [info] Node-RED version: v3.1.7
28 Mar 22:44:28 - [info] Node.js version: v18.19.1
28 Mar 22:44:28 - [info] Linux 6.1.63-haos-raspi arm64 LE
